path: root/drivers/edac/mpc85xx_edac.c
2011-07-26drivers/edac/mpc85xx_edac.c: correct offset_in_page mask bits in ↵Kai.Jiang
edac_mc_handle_ce() Parameter offset_in_page in edac_mc_handle_ce() should mask the higher bits above the page size, not the lower bits. The original input sometimes causes a crash. Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: "David S. Miller" <davem@davemloft.net> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-04edac/mpc85xx: Limit setting/clearing of HID1[RFXE] to e500v1/v2 coresKumar Gala
Only the e500v1/v2 cores have HID1[RXFE] so we should attempt to set or clear this register bit on them. Otherwise we get crashes like: NIP: c0579f84 LR: c006d550 CTR: c0579f84 REGS: ef857ec0 TRAP: 0700 Not tainted (2.6.38.2-00072-gf15ba3c) MSR: 00021002 <ME,CE> CR: 22044022 XER: 00000000 TASK = ef8559c0[1] 'swapper' THREAD: ef856000 CPU: 0 GPR00: c006d538 ef857f70 ef8559c0 00000000 00000004 00000000 00000000 00000000 GPR08: c0590000 c30170a8 00000000 c30170a8 00000001 0fffe000 00000000 00000000 GPR16: 00000000 7ffa0e60 00000000 00000000 7ffb0bd8 7ff3b844 c05be000 00000000 GPR24: 00000000 00000000 c05c28b0 c0579fac 00000000 00029002 00000000 c0579f84 NIP [c0579f84] mpc85xx_mc_clear_rfxe+0x0/0x28 LR [c006d550] on_each_cpu+0x34/0x50 Call Trace: [ef857f70] [c006d538] on_each_cpu+0x1c/0x50 (unreliable) [ef857f90] [c057a070] mpc85xx_mc_init+0xc4/0xdc [ef857fa0] [c0001cd4] do_one_initcall+0x34/0x1a8 [ef857fd0] [c055d9d8] kernel_init+0x17c/0x218 [ef857ff0] [c000cda4] kernel_thread+0x4c/0x68 Instruction dump: 40be0018 3c60c052 3863c70c 4be9baad 3be0ffed 4bd7c99d 80010014 7fe3fb78 83e1000c 38210010 7c0803a6 4e800020 <7c11faa6> 54290024 81290008 3d60c06e Oops: Exception in kernel mode, sig: 4 [#2] ---[ end trace 49ff3b8f93efde1a ]--- Also use the HID1_RFXE define rather than a magic number. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-28dt/powerpc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/powerpc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-11edac: mpc85xx: add support for new MPCxxx/Pxxxx EDAC controllersAnton Vorontsov
Simply add proper IDs into the device table. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dave Jiang <djiang@mvista.com> Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11edac: add wissing pieces from MPC85xx -> FSL_SOC_BOOKEChristoph Egger
In 5753c082f66eca5be81f6bda85c1718c5eea6ada ("powerpc/85xx: Kconfig cleanup") menuconfig MPC85xx was replaced by FSL_SOC_BOOKE but some references insider the code were not adjusted accordingly. This patch adresses these missing pieces. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-07-27edac: mpc85xx: fix coldplug/hotplug module autoloadingAnton Vorontsov
The MPC85xx EDAC driver is missing module device aliases, so the driver won't load automatically on boot. This patch fixes the issue by adding proper MODULE_DEVICE_TABLE() macros. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dave Jiang <djiang@mvista.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-20edac: mpc85xx: add support for MPC8569 EDAC controllersAnton Vorontsov
Simply add a proper ID into the device table. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dave Jiang <djiang@mvista.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-02of/edac: fix build breakage in driversAnatolij Gustschin
Fixes build errors in EDAC drivers caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12edac: mpc85xx use resource_size instead of raw mathH Hartley Sweeten
Use resource_size() instead of arithmetic. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Dave Jiang <djiang@mvista.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12edac: mpc85xx improve SDRAM error reportingPeter Tyser
Add the ability to detect the specific data line or ECC line which failed when printing out SDRAM single-bit errors. An example of a single-bit SDRAM ECC error is below: EDAC MPC85xx MC1: Err Detect Register: 0x80000004 EDAC MPC85xx MC1: Faulty data bit: 59 EDAC MPC85xx MC1: Expected Data / ECC: 0x7f80d000_409effa0 / 0x6d EDAC MPC85xx MC1: Captured Data / ECC: 0x7780d000_409effa0 / 0x6d EDAC MPC85xx MC1: Err addr: 0x00031ca0 EDAC MPC85xx MC1: PFN: 0x00000031 Knowning which specific data or ECC line caused an error can be useful in tracking down hardware issues such as improperly terminated signals, loose pins, etc. Note that this feature is only currently enabled for 64-bit wide data buses, 32-bit wide bus support should be added. I don't have any 32-bit wide systems to test on. If someone has one and is willing to give this patch a shot with the check for a 64-bit data bus removed it would be much appreciated and I can re-submit with both 32 and 64 bit buses supported. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12edac: mpc85xx mask ecc syndrome correctlyPeter Tyser
With a 64-bit wide data bus only the lowest 8-bits of the ECC syndrome are relevant. With a 32-bit wide data bus only the lowest 16-bits are relevant on most architectures. Without this change, the ECC syndrome displayed can be mildly confusing, eg: EDAC MPC85xx MC1: syndrome: 0x25252525 When in reality the ECC syndrome is 0x25. A variety of Freescale manuals say a variety of different things about how to decode the CAPTURE_ECC (syndrome) register. I don't have a system with a 32-bit bus to test on, but I believe the change is correct. It'd be good to get an ACK from someone at Freescale about this change though. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11edac: mpc85xx fix build regression by removing unused debug codePeter Tyser
Some unused, unsupported debug code existed in the mpc85xx EDAC driver that resulted in a build failure when CONFIG_EDAC_DEBUG was defined: drivers/edac/mpc85xx_edac.c: In function 'mpc85xx_mc_err_probe': drivers/edac/mpc85xx_edac.c:1031: error: implicit declaration of function 'edac_mc_register_mcidev_debug' drivers/edac/mpc85xx_edac.c:1031: error: 'debug_attr' undeclared (first use in this function) drivers/edac/mpc85xx_edac.c:1031: error: (Each undeclared identifier is reported only once drivers/edac/mpc85xx_edac.c:1031: error: for each function it appears in.) Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11edac: mpc85xx fix bad page calculationPeter Tyser
Commit b4846251727a38a7f248e41308c060995371dd05 ("edac: mpc85xx add mpc83xx support") accidentally broke how a chip select's first and last page addresses are calculated. The page addresses are being shifted too far right by PAGE_SHIFT. This results in errors such as: EDAC MPC85xx MC1: Err addr: 0x003075c0 EDAC MPC85xx MC1: PFN: 0x00000307 EDAC MPC85xx MC1: PFN out of range! EDAC MC1: INTERNAL ERROR: row out of range (4 >= 4) EDAC MC1: CE - no information available: INTERNAL ERROR The vaule of PAGE_SHIFT is already being taken into consideration during the calculation of the 'start' and 'end' variables, thus it is not necessary to account for it again when setting a chip select's first and last page address. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29edac: i5400 fix missing CONFIG_PCI defineIra W. Snyder
When building without CONFIG_PCI the edac_pci_idx variable is unused, causing a build-time warning. Wrap the variable in #ifdef CONFIG_PCI, just like the rest of the PCI support. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24edac: mpc85xx add mpc83xx supportIra W. Snyder
Add support for the Freescale MPC83xx memory controller to the existing driver for the Freescale MPC85xx memory controller. The only difference between the two processors are in the CS_BNDS register parsing code, which has been changed so it will work on both processors. The L2 cache controller does not exist on the MPC83xx, but the OF subsystem will not use the driver if the device is not present in the OF device tree. I had to change the nr_pages calculation to make the math work out. I checked it on my board and did the math by hand for a 64GB 85xx using 64K pages. In both cases, nr_pages * PAGE_SIZE comes out to the correct value. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24edac: mpc85xx add P2020DS supportYang Shi
Based on Kumar's new compatible types patch, add P2020 into MPC85xx EDAC compatible lists so that EDAC can recognize P2020 meomry controller and L2 cache controller and export the relevant fields to sysfs. EDAC MPC85xx DDR3 support is needed if DDR3 memory stick is installed on a P2020DS board so that EDAC core can recognize DDR3 memory type. Signed-off-by: Yang Shi <yang.shi@windriver.com> Acked-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30edac: add DDR3 memory type for MPC85xx EDACYang Shi
Since some new MPC85xx SOCs support DDR3 memory now, so add DDR3 memory type for MPC85xx EDAC. Signed-off-by: Yang Shi <yang.shi@windriver.com> Cc: Doug Thompson <norsk5@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21edac: ppc mpc85xx fix mc err detectDave Jiang
Error found by Jeff Haran. The error detect register is 0s when no errors are detected. The check code is incorrect, so reverse check sense. Reported-by: Jeff Haran <jharan@Brocade.COM> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24edac: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: dougthompson@xmission.com Cc: bluesmoke-devel@lists.sourceforge.net Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-01-06edac: fix mpc85xx and add mpc8536 mpc8560Kumar Gala
All other compatibles that are uniquely identifying the processor use a prefix of the form fsl,mpc85...'. We add support for it so we can deprecate the older 'fsl,85...' that was improperly used here. Additionally added mpc8536 & mpc8560 to the compatible lists. This patch is based on Nate's 8572 patch. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Dave Jiang <djiang@mvista.com> Cc: Nate Case <ncase@xes-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16edac mpc85xx: add support for mpc8572Andrew Kilkenny
This adds support for the dual-core MPC8572 processor. We have to support making SPR changes on each core. Also, since we can have multiple memory controllers sharing an interrupt, flag the interrupts with IRQF_SHARED. Signed-off-by: Andrew Kilkenny <akilkenny@xes-inc.com> Signed-off-by: Nate Case <ncase@xes-inc.com> Acked-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25edac: mpc85xx fix pci ofdev 2nd passDave Jiang
Convert PCI err device from platform to open firmware of_dev to comply with powerpc schemes. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24edac: mpc85xx: fix building as a moduleKumar Gala
including of <asm/mpc85xx.h> causes build problems since it doesn't exist. Also removed warning: drivers/edac/mpc85xx_edac.c:45: warning: 'mpc85xx_ctl_name' defined but not used Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07drivers/edac: mpc85xx: add static scopeDoug Thompson
Made a previous global variable, static in scope Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07drivers-edac: add freescale mpc85xx driverDave Jiang
EDAC chip driver support for Freescale MPC85xx platforms. PPC based. Signed-off-by: Dave Jiang <djiang@mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
