path: root/drivers/edac/octeon_edac-lmc.c
2013-01-03Drivers: edac: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Mark Gross <mark.gross@intel.com> Cc: Jason Uhlenkott <juhlenko@akamai.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Tim Small <tim@buttersideup.com> Cc: Ranganathan Desikan <ravi@jetztechnologies.com> Cc: "Arvind R." <arvino55@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Daney <david.daney@cavium.com> Cc: Egor Martovetsky <egor@pasemi.com> Cc: Olof Johansson <olof@lixom.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-13MIPS/EDAC: Improve OCTEON EDAC support.David Daney
Some initialization errors are reported with the existing OCTEON EDAC support patch. Also some parts have more than one memory controller. Fix the errors and add multiple controllers if present. Signed-off-by: David Daney <david.daney@cavium.com>
2012-12-12MIPS: Cavium: Add EDAC support.Ralf Baechle
Drivers for EDAC on Cavium. Supported subsystems are: o CPU primary caches. These are parity protected only, so only error reporting. o Second level cache - ECC protected, provides SECDED. o Memory: ECC / SECDEC if used with suitable DRAM modules. The driver will will only initialize if ECC is enabled on a system so is safe to run on non-ECC memory. o PCI: Parity error reporting Since it is very hard to test this sort of code the implementation is very conservative and uses polling where possible for now. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Borislav Petkov <borislav.petkov@amd.com>
