[ Upstream commit 7088e29e0423d3195e09079b4f849ec4837e5a75 ]
The current code to convert a physical address mask to a grain
(defined as granularity in bytes) is:
e->grain = ~(mem_err->physical_addr_mask & ~PAGE_MASK);
This is broken in several ways:
1) It calculates to wrong grain values. E.g., a physical address mask
of ~0xfff should give a grain of 0x1000. Without considering
PAGE_MASK, there is an off-by-one. Things are worse when also
filtering it with ~PAGE_MASK. This will calculate to a grain with the
upper bits set. In the example it even calculates to ~0.
2) The grain does not depend on and is unrelated to the kernel's
page-size. The page-size only matters when unmapping memory in
memory_failure(). Smaller grains are wrongly rounded up to the
page-size, on architectures with a configurable page-size (e.g. arm64)
this could round up to the even bigger page-size of the hypervisor.
Fix this with:
e->grain = ~mem_err->physical_addr_mask + 1;
The grain_bits are defined as:
grain = 1 << grain_bits;
Change also the grain_bits calculation accordingly, it is the same
formula as in edac_mc.c now and the code can be unified.
The value in ->physical_addr_mask coming from firmware is assumed to
be contiguous, but this is not sanity-checked. However, in case the
mask is non-contiguous, a conversion to grain_bits effectively
converts the grain bit mask to a power of 2 by rounding it up.
Suggested-by: James Morse <james.morse@arm.com>
Signed-off-by: Robert Richter <rrichter@marvell.com>
Reviewed-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Cc: "linux-edac@vger.kernel.org" <linux-edac@vger.kernel.org>
Link: https://lkml.kernel.org/r/20191106093239.25517-11-rrichter@marvell.com
[ Upstream commit 8faa1cf6ed82f33009f63986c3776cc48af1b7b2 ]
Smatch complains about the cast of a u32 pointer to unsigned long:
drivers/edac/altera_edac.c:1878 altr_edac_a10_irq_handler()
warn: passing casted pointer '&irq_status' to 'find_first_bit()'
This code wouldn't work on a 64 bit big endian system because it would
read past the end of &irq_status.
[ bp: massage. ]
Fixes: 13ab8448d2c9 ("EDAC, altera: Add ECC Manager IRQ controller support")
Reviewed-by: Thor Thayer <thor.thayer@linux.intel.com>
Cc: James Morse <james.morse@arm.com>
Cc: kernel-janitors@vger.kernel.org
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Link: https://lkml.kernel.org/r/20190624134717.GA1754@mwanda
[ Upstream commit d8655e7630dafa88bc37f101640e39c736399771 ]
Commit 9da21b1509d8 ("EDAC: Poll timeout cannot be zero, p2") assumes
edac_mc_poll_msec to be unsigned long, but the type of the variable still
remained as int. Setting edac_mc_poll_msec can trigger out-of-bounds
write.
Reproducer:
# echo 1001 > /sys/module/edac_core/parameters/edac_mc_poll_msec
KASAN report:
BUG: KASAN: global-out-of-bounds in edac_set_poll_msec+0x140/0x150
Write of size 8 at addr ffffffffb91b2d00 by task bash/1996
CPU: 1 PID: 1996 Comm: bash Not tainted 5.2.0-rc6+ #23
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-2.fc30 04/01/2014
Call Trace:
dump_stack+0xca/0x13e
print_address_description.cold+0x5/0x246
__kasan_report.cold+0x75/0x9a
? edac_set_poll_msec+0x140/0x150
kasan_report+0xe/0x20
? dimmdev_location_show+0x30/0x30
? vfs_lock_file+0xe0/0xe0
? _raw_spin_lock+0x87/0xe0
param_attr_store+0x1b5/0x310
? param_array_set+0x4f0/0x4f0
module_attr_store+0x58/0x80
? module_attr_show+0x80/0x80
sysfs_kf_write+0x13d/0x1a0
kernfs_fop_write+0x2bc/0x460
? sysfs_kf_bin_read+0x270/0x270
? kernfs_notify+0x1f0/0x1f0
__vfs_write+0x81/0x100
vfs_write+0x1e1/0x560
ksys_write+0x126/0x250
? __ia32_sys_read+0xb0/0xb0
? do_syscall_64+0x1f/0x390
do_syscall_64+0xc1/0x390
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x7fa7caa5e970
Code: 73 01 c3 48 8b 0d 28 d5 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 99 2d 2c 00 00 75 10 b8 01 00 00 00 04
RSP: 002b:00007fff6acfdfe8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00007fa7caa5e970
RDX: 0000000000000005 RSI: 0000000000e95c08 RDI: 0000000000000001
RBP: 0000000000e95c08 R08: 00007fa7cad1e760 R09: 00007fa7cb36a700
R10: 0000000000000073 R11: 0000000000000246 R12: 0000000000000005
R13: 0000000000000001 R14: 00007fa7cad1d600 R15: 0000000000000005
The buggy address belongs to the variable:
edac_mc_poll_msec+0x0/0x40
Memory state around the buggy address:
ffffffffb91b2c00: 00 00 00 00 fa fa fa fa 00 00 00 00 fa fa fa fa
ffffffffb91b2c80: 00 00 00 00 fa fa fa fa 00 00 00 00 fa fa fa fa
>ffffffffb91b2d00: 04 fa fa fa fa fa fa fa 04 fa fa fa fa fa fa fa
ffffffffb91b2d80: 04 fa fa fa fa fa fa fa 00 00 00 00 00 00 00 00
ffffffffb91b2e00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fix it by changing the type of edac_mc_poll_msec to unsigned int.
The reason why this patch adopts unsigned int rather than unsigned long
is msecs_to_jiffies() assumes arg to be unsigned int. We can avoid
integer conversion bugs and unsigned int will be large enough for
edac_mc_poll_msec.
Reviewed-by: James Morse <james.morse@arm.com>
Fixes: 9da21b1509d8 ("EDAC: Poll timeout cannot be zero, p2")
Signed-off-by: Eiichi Tsukata <devel@etsukata.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
[ Upstream commit 585fb3d93d32dbe89e718b85009f9c322cc554cd ]
In edac_create_csrow_object(), the reference to the object is not
released when adding the device to the device hierarchy fails
(device_add()). This may result in a memory leak.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://lkml.kernel.org/r/1555554438-103953-1-git-send-email-bianpan2016@163.com
commit 8f18973877204dc8ca4ce1004a5d28683b9a7086 upstream.
The code "lchan = (lchan << 1) | ~lchan" for logical channel
intermediate decoding is wrong. The wrong intermediate decoding
result is {0xffffffff, 0xfffffffe}.
Fix it by replacing '~' with '!'. The correct intermediate
decoding result is {0x1, 0x2}.
Signed-off-by: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
CC: Aristeu Rozanski <aris@redhat.com>
CC: Mauro Carvalho Chehab <mchehab@kernel.org>
CC: linux-edac <linux-edac@vger.kernel.org>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20181009172025.18594-1-tony.luck@intel.com
commit 432de7fd7630c84ad24f1c2acd1e3bb4ce3741ca upstream.
The count of errors is picked up from bits 52:38 of the machine check
bank status register. But this is the count of *corrected* errors. If an
uncorrected error is being logged, the h/w sets this field to 0. Which
means that when edac_mc_handle_error() is called, the EDAC core will
carefully add zero to the appropriate uncorrected error counts.
[ Massage commit message. ]
Cc: Aristeu Rozanski <aris@redhat.com>
Cc: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
Link: http://lkml.kernel.org/r/20180928213934.19890-1-tony.luck@intel.com
[ Upstream commit 4708aa85d50cc6e962dfa8acf5ad4e0d290a21db ]
Make sure to use put_device() to free the initialised struct device so
that resources managed by driver core also gets released in the event of
a registration failure.
Signed-off-by: Johan Hovold <johan@kernel.org>
Cc: Denis Kirjanov <kirjanov@gmail.com>
Fixes: 2d56b109e3a5 ("EDAC: Handle error path in edac_mc_sysfs_init() properly")
Link: http://lkml.kernel.org/r/20180612124335.6420-1-johan@kernel.org
[ Upstream commit 6c974d4dfafe5e9ee754f2a6fba0eb1864f1649e ]
Make sure to free and deregister the addrmatch and chancounts devices
allocated during probe in all error paths. Also fix use-after-free in a
probe error path and in the remove success path where the devices were
being put before before deregistration.
Fixes: 356f0a30860d ("i7core_edac: change the mem allocation scheme to make Documentation/kobject.txt happy")
Link: http://lkml.kernel.org/r/20180612124335.6420-2-johan@kernel.org
[ Upstream commit 9ef20753e044f7468c4113e5aecd785419b0b3cc ]
The kbuild test robot reported the following warning:
drivers/edac/altera_edac.c: In function 'ocram_free_mem':
drivers/edac/altera_edac.c:1410:42: warning: cast from pointer to integer
of different size [-Wpointer-to-int-cast]
gen_pool_free((struct gen_pool *)other, (u32)p, size);
After adding support for ARM64 architectures, the unsigned long
parameter is 64 bits and causes a build warning on 64-bit configs. Fix
by casting to the correct size (unsigned long) instead of u32.
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Thor Thayer <thor.thayer@linux.intel.com>
Fixes: c3eea1942a16 ("EDAC, altera: Add Altera L2 cache and OCRAM support")
Link: http://lkml.kernel.org/r/1526317441-4996-1-git-send-email-thor.thayer@linux.intel.com
[ Upstream commit 68fa24f9121c04ef146b5158f538c8b32f285be5 ]
We should not call edac_mc_del_mc() if a corresponding call to
edac_mc_add_mc() has not been performed yet.
So here, we should go to err instead of err2 to branch at the right
place of the error handling path.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Link: http://lkml.kernel.org/r/20180107205400.14068-1-christophe.jaillet@wanadoo.fr
[ Upstream commit 25b223ddfe2a557307c05fe673e09d94ae950877 ]
The peripherals' RAS functionality only exist on the Arria10 SoCFPGA.
The Cyclone5 initialization generates EDAC warnings when the peripherals
aren't found in the device tree. Fix by checking for Arria10 in the init
functions.
Link: http://lkml.kernel.org/r/1491415262-5018-1-git-send-email-thor.thayer@linux.intel.com
commit b399151cb48db30ad1e0e93dd40d68c6d007b637 upstream.
x86_mask is a confusing name which is hard to associate with the
processor's stepping.
Additionally, correct an indent issue in lib/cpu.c.
Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com>
[ Updated it to more recent kernels. ]
Cc: bp@alien8.de
Cc: tony.luck@intel.com
Link: http://lkml.kernel.org/r/1514771530-70829-1-git-send-email-qianyue.zj@alibaba-inc.com
commit 544e92581a2ac44607d7cc602c6b54d18656f56d upstream.
Fix an uninitialized variable warning in the Octeon EDAC driver, as seen
in MIPS cavium_octeon_defconfig builds since v4.14 with Codescape GNU
Tools 2016.05-03:
drivers/edac/octeon_edac-lmc.c In function ‘octeon_lmc_edac_poll_o2’:
drivers/edac/octeon_edac-lmc.c:87:24: warning: ‘((long unsigned int*)&int_reg)[1]’ may \
be used uninitialized in this function [-Wmaybe-uninitialized]
if (int_reg.s.sec_err || int_reg.s.ded_err) {
Iinitialise the whole int_reg variable to zero before the conditional
assignments in the error injection case.
Signed-off-by: James Hogan <jhogan@kernel.org>
Acked-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Fixes: 1bc021e81565 ("EDAC: Octeon: Add error injection support")
Link: http://lkml.kernel.org/r/20171113161206.20990-1-james.hogan@mips.com
[ Upstream commit a8c8261425649da58bdf08221570e5335ad33a31 ]
In the i5000 and i5400 drivers, the NRECMEMB register is defined as a
16-bit value, which results in wrong shifts in the code, as reported by
sparse.
In the datasheets ([1], section 3.9.22.20 and [2], section 3.9.22.21),
this register is a 32-bit register. A u32 value for the register fixes
the wrong shifts warnings and matches the datasheet.
Also fix the mask to access to the CAS bits [27:16] in the i5000 driver.
[1]: https://www.intel.com/content/dam/doc/datasheet/5000p-5000v-5000z-chipset-memory-controller-hub-datasheet.pdf
[2]: https://www.intel.se/content/dam/doc/datasheet/5400-chipset-memory-controller-hub-datasheet.pdf
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Link: http://lkml.kernel.org/r/20170629005729.8478-1-jeremy.lefaure@lse.epita.fr
[ Upstream commit e61555c29c28a4a3b6ba6207f4a0883ee236004d ]
The MTR_DRAM_WIDTH macro returns the data width. It is sometimes used
as if it returned a boolean true if the width if 8. Fix the tests where
MTR_DRAM_WIDTH is misused.
Link: http://lkml.kernel.org/r/20170309011809.8340-1-jeremy.lefaure@lse.epita.fr
[ Upstream commit a8e9b186f153a44690ad0363a56716e7077ad28c ]
Add missing break statement in order to prevent the code from falling
through.
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Link: http://lkml.kernel.org/r/20171016174029.GA19757@embeddedor.com
[ Upstream commit 2287c63643f0f52d9d5452b9dc4079aec0889fe8 ]
We should save the return code from probe_one_instance() so that it can
be returned from the module init function. Otherwise, we'll be returning
the -ENOMEM from above.
Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/1484322741-41884-1-git-send-email-Yazen.Ghannam@amd.com
[ Upstream commit 1bd9900b8301fc505f032c90ea487824cf824e99 ]
Match one of the devices in amd64_cpuids[] before loading the module.
This is an additional sanity check against users trying to load
amd64_edac_mod on unsupported systems.
Link: http://lkml.kernel.org/r/1485537863-2707-9-git-send-email-Yazen.Ghannam@amd.com
[ Get rid of err_ret label, make it a bit more readable this way. ]
[ Upstream commit 75bf2f6478cab9b0c1d7f5f674a765d1e2ad530e ]
Currently, the IPID and Syndrome are printed on the same line as the
Address. There are cases when we can have a valid Syndrome but not a
valid Address.
For example, the MCA_SYND register can be used to hold more detailed
error info that the hardware folks can use. It's not just DRAM ECC
syndromes. There are some error types that aren't related to memory that
may have valid syndromes, like some errors related to links in the Data
Fabric, etc.
In these cases, the IPID and Syndrome are not printed at the same log
level as the rest of the stanza, so users won't see them on the console.
Console:
[Hardware Error]: CPU:16 (17:1:0) MC22_STATUS[Over|CE|MiscV|-|-|-|-|SyndV|-]: 0xd82000000002080b
[Hardware Error]: Power, Interrupts, etc. Extended Error Code: 2
Dmesg:
, Syndrome: 0x000000010b404000, IPID: 0x0001002e00000002
Print the IPID first and on a new line. The IPID should always be
printed on SMCA systems. The Syndrome will then be printed with the IPID
and at the same log level when valid:
[Hardware Error]: IPID: 0x0001002e00000002, Syndrome: 0x000000010b404000
Link: http://lkml.kernel.org/r/1487192182-2474-1-git-send-email-Yazen.Ghannam@amd.com
Pull EDAC updates from Borislav Petkov:
"A lot of movement in the EDAC tree this time around, coarse summary
below:
- Altera Arria10 enablement of NAND, DMA, USB, QSPI and SD-MMC FIFO
buffers (Thor Thayer)
- split the memory controller part out of mpc85xx and share it with a
new Freescale ARM Layerscape driver (York Sun)
- amd64_edac fixes (Yazen Ghannam)
- misc cleanups, refactoring and fixes all over the place"
* tag 'edac_for_4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (37 commits)
EDAC, altera: Add IRQ Flags to disable IRQ while handling
EDAC, altera: Correct EDAC IRQ error message
EDAC, amd64: Autoload module using x86_cpu_id
EDAC, sb_edac: Remove NULL pointer check on array pci_tad
EDAC: Remove NO_IRQ from powerpc-only drivers
EDAC, fsl_ddr: Fix error return code in fsl_mc_err_probe()
EDAC, fsl_ddr: Add entry to MAINTAINERS
EDAC: Move Doug Thompson to CREDITS
EDAC, I3000: Orphan driver
EDAC, fsl_ddr: Replace simple_strtoul() with kstrtoul()
EDAC, layerscape: Add Layerscape EDAC support
EDAC, fsl_ddr: Fix IRQ dispose warning when module is removed
EDAC, fsl_ddr: Add support for little endian
EDAC, fsl_ddr: Add missing DDR DRAM types
EDAC, fsl_ddr: Rename macros and names
EDAC, fsl-ddr: Separate FSL DDR driver from MPC85xx
EDAC, mpc85xx: Replace printk() with pr_* format
EDAC, mpc85xx: Drop setting/clearing RFXE bit in HID1
EDAC, altera: Rename MC trigger to common name
EDAC, altera: Rename device trigger to common name
Add the IRQF_ONESHOT and IRQF_TRIGGER_HIGH flags to disable the IRQ
while executing the IRQ handler. Remove the IRQF_SHARED because these
are not shared IRQs in the domain. Exposed when flooding IRQs.
Signed-off-by: Thor Thayer <tthayer@opensource.altera.com>
Link: http://lkml.kernel.org/r/1474582419-7053-2-git-send-email-tthayer@opensource.altera.com
Correct the error message sent out in the case of a single bit error IRQ
allocation.
Link: http://lkml.kernel.org/r/1474582419-7053-1-git-send-email-tthayer@opensource.altera.com
Reinstate driver autoloading now that PCI dependency is gone.
Link: http://lkml.kernel.org/r/1473984445-1726-2-git-send-email-Yazen.Ghannam@amd.com
Bank 4 is reserved on family 0x17 and shouldn't generate any MCE
records. However, broken hardware and software is not something unheard
of so warn about bank 4 errors. They shouldn't be coming from bank 4
naturally but users can still use mce_amd_inj to simulate errors from it
for testing purposed.
Also, avoid special handling in the injector mce_amd_inj like it is
being done on the older families.
[ bp: Rewrite commit message and merge into one patch. Use boot_cpu_data. ]
Reviewed-by: Aravind Gopalakrishnan <aravindksg.lkml@gmail.com>
Link: http://lkml.kernel.org/r/1473384591-5323-1-git-send-email-Yazen.Ghannam@amd.com
Link: http://lkml.kernel.org/r/1473384591-5323-2-git-send-email-Yazen.Ghannam@amd.com
The MCA_SYND and MCA_IPID registers contain valuable information and
should be included in MCE output. The MCA_SYND register contains
syndrome and other error information, and the MCA_IPID register will
uniquely identify the MCA bank's type without having to rely on system
software.
Link: http://lkml.kernel.org/r/1472680624-34221-2-git-send-email-Yazen.Ghannam@amd.com
Scalable MCA defines a number of IP types. An MCA bank on an SMCA
system is defined as one of these IP types. A bank's type is uniquely
identified by the combination of the HWID and MCATYPE values read from
its MCA_IPID register.
Add the required tables in order to be able to lookup error descriptions
based on a bank's type and the error's extended error code.
[ bp: Align comments, simplify a bit. ]
Link: http://lkml.kernel.org/r/1472741832-1690-1-git-send-email-Yazen.Ghannam@amd.com
The error descriptions defined for Fam17h can be reused for other SMCA
systems, so their names should reflect this.
Change f17h prefix to smca for error descriptions.
Link: http://lkml.kernel.org/r/1472673994-12235-4-git-send-email-Yazen.Ghannam@amd.com
Add missing SMCA error descriptions to the error descriptions arrays.
Link: http://lkml.kernel.org/r/1472673994-12235-3-git-send-email-Yazen.Ghannam@amd.com
Print SyndV bit status and print the raw value of the MCA_SYND register.
Further decoding of the syndrome from struct mce.synd can be done in
other places where appropriate, e.g. DRAM ECC.
Boris: make the error stanza more compact by putting the error address
and syndrome on the same line:
[Hardware Error]: Corrected error, no action required.
[Hardware Error]: CPU:2 (17:0:0) MC4_STATUS[-|CE|-|PCC|AddrV|-|-|SyndV|CECC]: 0x96204100001e0117
[Hardware Error]: Error Addr: 0x000000007f4c52e3, Syndrome: 0x0000000000000000
[Hardware Error]: Invalid IP block specified.
[Hardware Error]: cache level: L3/GEN, tx: DATA, mem-tx: RD
Link: http://lkml.kernel.org/r/1467633035-32080-2-git-send-email-Yazen.Ghannam@amd.com
pvt->pci_tad is a NUM_CHANNELS array of struct pci_dev pointers and
hence cannot be NULL, so the NULL pointer check on pci_tad is redundant.
Remove it.
Acked-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/20160908083801.14766-1-colin.king@canonical.com
We'd like to eventually remove NO_IRQ on powerpc, so remove usages of it
from powerpc-only drivers.
The pdata structs are kzalloc'ed, so we don't need to initialise those
to 0, we can just drop the assignments entirely.
Cc: Johannes Thumshirn <morbidrsa@gmail.com>
Cc: linuxppc-dev@ozlabs.org
Link: http://lkml.kernel.org/r/1473674436-19467-1-git-send-email-mpe@ellerman.id.au
Return negative error code from the edac_mc_add_mc() error handling case
instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Acked-by: York Sun <york.sun@nxp.com>
Link: http://lkml.kernel.org/r/1473350284-26482-1-git-send-email-weiyj.lk@gmail.com
Replace obsolete simple_strtoul() with kstrtoul().
Signed-off-by: York Sun <york.sun@nxp.com>
Link: http://lkml.kernel.org/r/1471990593-27536-1-git-send-email-york.sun@nxp.com
Add DDR EDAC driver for ARM-based compatible controllers. Both
big-endian and little-endian are supported, as specified in device tree.
Link: http://lkml.kernel.org/r/1471990465-27443-1-git-send-email-york.sun@nxp.com
When compiled as a module, removing it causes kernel warnings
when irq_dispose_mapping() is called. Instead of calling
irq_of_parse_and_map(), use platform_get_irq() to acquire the IRQ
number.
Cc: morbidrsa@gmail.com
Cc: oss@buserror.net
Cc: stuart.yoder@nxp.com
Link: http://lkml.kernel.org/r/1470779760-16483-8-git-send-email-york.sun@nxp.com
Get endianness from device tree. Both big endian and little endian are
supported. Default to big endian for backwards compatibility to MPC85xx.
Acked-by: Rob Herring <robh+dt@kernel.org>
Cc: devicetree@vger.kernel.org
Link: http://lkml.kernel.org/r/1470779760-16483-7-git-send-email-york.sun@nxp.com
The compatible DDR controllers may support DDR, DDR2, DDR3, DDR4 DRAM.
An individual controller doesn't support all of them. The EDAC driver
reads SDRAM_CFG to determine which mode is configured.
Add DDR4 and drop the defines used only in the mtype assignment.
Link: http://lkml.kernel.org/r/1470779760-16483-6-git-send-email-york.sun@nxp.com
Use FSL-specific prefix for macros, variables and functions.
Link: http://lkml.kernel.org/r/1470779760-16483-5-git-send-email-york.sun@nxp.com
The mpc85xx-compatible DDR controllers are used on ARM-based SoCs too.
Carve out the DDR part from the mpc85xx EDAC driver in preparation to
support both architectures.
Link: http://lkml.kernel.org/r/1470946525-3410-1-git-send-email-york.sun@nxp.com
Replace printk() with pr_err/pr_warn/pr_info macros.
Link: http://lkml.kernel.org/r/1470779760-16483-3-git-send-email-york.sun@nxp.com
[ Boris: unbreak strings for easier greppability. ]
On e500v1, read fault exception enable (RFXE) controls whether assertion
of core_fault_in causes a machine check interrupt. Assertion of
core_fault_in can result from uncorrectable data error, such as an L2
multi-bit ECC error. It can also occur from a system error if logic on
the integrated device signals a fault for nonfatal errors. RFXE bit is
cleared out of reset, and should be left clear for normal operation.
Assertion of core_fault_in does not cause a machine check.
RFXE is set specifically for RIO (Rapid IO) and PCI for book E to catch
the errors by machine check. With this bit set, the EDAC driver can't
get the interrupt in case of uncorrectable error. So this bit is cleared
in favor of EDAC. However, the benefit of catching such uncorrectable
error doesn't outweigh the other errors which may hang the system.
Besides, e500v2 has different errors masked by RFXE, and e500mc doesn't
support this bit. It is more reasonable to leave RFXE as is in the EDAC
driver, and leave the uncorrectable errors triggering machine check for
e500v1.
Suggested-by: Scott Wood <oss@buserror.net>
Link: http://lkml.kernel.org/r/1470779760-16483-2-git-send-email-york.sun@nxp.com
Rename the Memory Controller debug trigger to the same common name as
the EDAC devices.
Link: http://lkml.kernel.org/r/1471622666-15197-3-git-send-email-tthayer@opensource.altera.com
The L2 and OCRAM devices have different ecc trigger names than the other
EDAC devices (FIFO peripherals). Make them all the same and remove the
character array from the device structure.
Link: http://lkml.kernel.org/r/1471622666-15197-2-git-send-email-tthayer@opensource.altera.com
This is an entirely new driver instead of yet another set of patches
to sb_edac.c because:
1) Mapping from PCI devices to socket/memory controller is significantly
different. Skylake scatters devices on a socket across a number of
PCI buses.
2) There is an extra level of interleaving via the "mcroute" register
that would be a little messy to squeeze into the old driver.
3) Validation is getting too expensive. Changes to sb_edac need to
be checked against Sandy Bridge, Ivy Bridge, Haswell, Broadwell and
Knights Landing.
Acked-by: Aristeu Rozanski <aris@redhat.com>
Acked-by: Borislav Petkov <bp@suse.de>
According to the reference manual of MPC8572 and T4240, bit 31 of
PEX_ERR_CAP_STAT is W1C (write 1 to clear).
Add the corresponding write to PEX_ERR_CAP_STAT in order to fix the PCIe
error capture.
Tested on a T4240 processor.
Signed-off-by: Tillmann Heidsieck <theidsieck@leenox.de>
Acked-by: Johannes Thumshirn <jthumshirn@suse.de>
Link: http://lkml.kernel.org/r/20160815190849.29327-1-theidsieck@leenox.de
Replace the deprecated create_singlethread_workqueue() with
alloc_ordered_workqueue() with WQ_MEM_RECLAIM. This is the identity
conversion.
It's not recommended to stall it from memory pressure. Hence,
WQ_MEM_RECLAIM has been set to ensure forward progress under memory
pressure.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20160813164124.GA9077@Karyakshetra
Fix the following sparse warning:
drivers/edac/altera_edac.c:1649:23: warning:
symbol 'a10_eccmgr_ic_ops' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
Reviewed-by: Thor Thayer <tthayer@opensource.altera.com>
Cc: lkml <linux-kernel@vger.kernel.org>
Link: http://lkml.kernel.org/r/1470836667-11822-1-git-send-email-weiyj.lk@gmail.com
Add Altera Arria10 SD-MMC FIFO memory EDAC support. The SD-MMC is a
dual port RAM implementation which is different than any of the other
peripherals and therefore requires additional code.
Cc: dinguyen@opensource.altera.com
Link: http://lkml.kernel.org/r/1470753653-23465-3-git-send-email-tthayer@opensource.altera.com
Fam15hMod60h systems are using the channel decode of Fam15hMod30h which
gives incorrect results. Fam15hMod60h systems should use the generic
channel decode method plus a couple more cases.
Cc: Aravind Gopalakrishnan <aravindksg.lkml@gmail.com>
Link: http://lkml.kernel.org/r/1470236355-30039-1-git-send-email-Yazen.Ghannam@amd.com
Add Altera Arria10 QSPI FIFO memory support.
Link: http://lkml.kernel.org/r/1468512408-5156-9-git-send-email-tthayer@opensource.altera.com
