path: root/drivers/firewire/Makefile
2010-10-11ieee1394: move init_ohci1394_dma to drivers/firewire/Stefan Richter
because drivers/ieee1394/ will be deleted. Additional changes: - add some #include directives - adjust to use firewire/ohci.h instead of ieee1394/ohci1394.h, replace struct ti_ohci by a minimal struct ohci, replace quadlet_t from ieee1394_types.h by u32 - two or three trivial stylistic changes - __iomem annotation Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-07-27firewire: new driver: nosy - IEEE 1394 traffic snifferStefan Richter
This adds the traffic sniffer driver for Texas Instruments PCILynx/ PCILynx2 based cards. The use cases for nosy are analysis of nonstandard protocols and as an aid in development of drivers, applications, or firmwares. Author of the driver is Kristian Høgsberg. Known contributers are Jody McIntyre and Jonathan Woithe. Nosy programs PCILynx chips to operate in promiscuous mode, which is a feature that is not found in OHCI-1394 controllers. Hence, only special hardware as mentioned in the Kconfig help text is suitable for nosy. This is only the kernelspace part of nosy. There is a userspace interface to it, called nosy-dump, proposed to be added into the tools/ subdirectory of the kernel sources in a subsequent change. Kernelspace and userspave component of nosy communicate via a 'misc' character device file called /dev/nosy with a simple ioctl() and read() based protocol, as described by nosy-user.h. The files added here are taken from git://anongit.freedesktop.org/~krh/nosy commit ee29be97 (2009-11-10) with the following changes by Stefan Richter: - Kconfig and Makefile hunks are written from scratch. - Commented out version printk in nosy.c. - Included missing <linux/sched.h>, reported by Stephen Rothwell. "git shortlog nosy{-user.h,.c,.h}" from nosy's git repository: Jonathan Woithe (2): Nosy updates for recent kernels Fix uninitialised memory (needed for 2.6.31 kernel) Kristian Høgsberg (5): Pull over nosy from mercurial repo. Use a misc device instead. Add simple AV/C decoder. Don't break down on big payloads. Set parent device for misc device. As a low-level IEEE 1394 driver, its files are placed into drivers/firewire/ although nosy is not part of the firewire driver stack. I am aware of the following literature from Texas Instruments about PCILynx programming: SCPA020A - PCILynx 1394 to PCI Bus Interface TSB12LV21BPGF Functional Specification SLLA023 - Initialization and Asynchronous Programming of the TSB12LV21A 1394 Device Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@bitplanet.net>
2009-06-14firewire: net: add Kconfig item, rename driverStefan Richter
The driver is now called firewire-net. It might implement the transport of other networking protocols in the future, notably IPv6 per RFC 3146. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-06-14firewire: add IPv4 supportJay Fenlason
Implement IPv4 over IEEE 1394 as per RFC 2734 for the newer firewire stack. This feature has only been present in the older ieee1394 stack via the eth1394 driver. Still to do: - fix ipv4_priv and ipv4_node lifetime logic - fix determination of speeds and max payloads - fix bus reset handling - fix unaligned memory accesses - fix coding style - further testing/ improvement of fragment reassembly - perhaps multicast support Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (rebased, copyright note, changelog)
2009-06-05firewire: rename source filesStefan Richter
The source files of firewire-core, firewire-ohci, firewire-sbp2, i.e. "drivers/firewire/fw-*.c" are renamed to "drivers/firewire/core-*.c", "drivers/firewire/ohci.c", "drivers/firewire/sbp2.c". The old fw- prefix was redundant to the directory name. The new core- prefix distinguishes the files according to which driver they belong to. This change comes a little late, but still before further firewire drivers are added as anticipated RSN. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-27firewire: prefix modules with firewire- instead of fw-Stefan Richter
Of course everybody immediately associates "fw-" with FireWire, not firmware or firewall or whatever. But "firewire-" has a nice ring to it too. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Hoegsberg <krh@bitplanet.net>
2007-05-10firewire: Add to fw-core-y instead of assigning fw-core-objs in Makefile.Kristian Høgsberg
Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-04-30firewire: Rename fw-device-cdev.c to fw-cdev.c and move header to include/linux.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-03-20firewire: rename CONFIG_FW to CONFIG_FIREWIREStefan Richter
to avoid confusion with CONFIG_FW_LOADER. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@redhat.com>
2007-03-09firewire: Add SBP-2 protocol driver for storage devices.Kristian Høgsberg
2007-03-09firewire: Add driver for OHCI firewire host controllers.Kristian Høgsberg
2007-03-09firewire: Add device probing and sysfs integration.Kristian Høgsberg
2007-03-09firewire: Add core firewire stack.Kristian Høgsberg
