Decouple the creation and destruction of the net_device from the order
of discovery and removal of nodes with RFC 2734 unit directories since
there is no reliable order. The net_device is now created when the
first RFC 2734 unit on a card is discovered, and destroyed when the last
RFC 2734 unit on a card went away. This includes all remote units as
well as the local unit, which is therefore tracked as a peer now too.
Also, locking around the list of peers is slightly extended to guard
against peer removal. As a side effect, fwnet_peer.pdg_lock has become
superfluous and is deleted.
Peer data (max_rec, speed, node ID, generation) are updated more
carefully.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Change names of types, variables, functions.
Omit debug code.
Use get_unaligned*, put_unaligned*.
Annotate big endian data.
Handle errors in __init.
Change whitespace.
Implement IPv4 over IEEE 1394 as per RFC 2734 for the newer firewire
stack. This feature has only been present in the older ieee1394 stack
via the eth1394 driver.
Still to do:
- fix ipv4_priv and ipv4_node lifetime logic
- fix determination of speeds and max payloads
- fix bus reset handling
- fix unaligned memory accesses
- fix coding style
- further testing/ improvement of fragment reassembly
- perhaps multicast support
Signed-off-by: Jay Fenlason <fenlason@redhat.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (rebased, copyright note, changelog)
The IP-over-1394 driver will add child devices beneath card devices
which are not of type fw_device. Hence firewire-core's callbacks in
device_for_each_child() and device_find_child() need to check for the
device type now.
Initial version written by Jay Fenlason.
The source files of firewire-core, firewire-ohci, firewire-sbp2, i.e.
"drivers/firewire/fw-*.c"
are renamed to
"drivers/firewire/core-*.c",
"drivers/firewire/ohci.c",
"drivers/firewire/sbp2.c".
The old fw- prefix was redundant to the directory name. The new core-
prefix distinguishes the files according to which driver they belong to.
This change comes a little late, but still before further firewire
drivers are added as anticipated RSN.
