path: root/drivers/firewire/fw-cdev.c
2009-06-05firewire: rename source filesStefan Richter
The source files of firewire-core, firewire-ohci, firewire-sbp2, i.e. "drivers/firewire/fw-*.c" are renamed to "drivers/firewire/core-*.c", "drivers/firewire/ohci.c", "drivers/firewire/sbp2.c". The old fw- prefix was redundant to the directory name. The new core- prefix distinguishes the files according to which driver they belong to. This change comes a little late, but still before further firewire drivers are added as anticipated RSN. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-06-05firewire: reorganize header filesStefan Richter
The three header files of firewire-core, i.e. "drivers/firewire/fw-device.h", "drivers/firewire/fw-topology.h", "drivers/firewire/fw-transaction.h", are replaced by "drivers/firewire/core.h", "include/linux/firewire.h". The latter includes everything which a firewire high-level driver (like firewire-sbp2) needs besides linux/firewire-constants.h, while core.h contains the rest which is needed by firewire-core itself and by low- level drivers (card drivers) like firewire-ohci. High-level drivers can now also reside outside of drivers/firewire without having to add drivers/firewire to the header file search path in makefiles. At least the firedtv driver will be such a driver. I also considered to spread the contents of core.h over several files, one for each .c file where the respective implementation resides. But it turned out that most core .c files will end up including most of the core .h files. Also, the combined core.h isn't unreasonably big, and it will lose more of its contents to linux/firewire.h anyway soon when more firewire drivers are added. (IP-over-1394, firedtv, and there are plans for one or two more.) Furthermore, fw-ohci.h is renamed to ohci.h. The name of core.h and ohci.h is chosen with regard to name changes of the .c files in a follow-up change. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-05-17firewire: core: improve check for local nodeStefan Richter
My recently added test for a device being local in fw-cdev.c got it slightly wrong: Comparisons of node IDs are only valid if the generation is current, which I forgot to check. Normally, serialization by card->lock takes care of this, but a device in FW_DEVICE_GONE state will necessarily have a wrong generation and invalid node_id. The "is it local?" check is made 100% correct and simpler now by means of a struct fw_device flag which is set at fw_device creation. Besides the fw-cdev site which was to be fixed, there is another site which can make use of the new flag, and an RFC-2734 driver will benefit from it too. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add closure to async stream ioctlStefan Richter
This changes the as yet unreleased FW_CDEV_IOC_SEND_STREAM_PACKET ioctl to generate an fw_cdev_event_response event just like the other two ioctls for asynchronous request transmission do. This way, clients get feedback on successful or unsuccessful transmission. This also adds input validation for length, tag, channel, sy, speed. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: simplify FW_CDEV_IOC_SEND_REQUEST return valueStefan Richter
This changes the ioctl() return value of FW_CDEV_IOC_SEND_REQUEST and of the as yet unreleased FW_CDEV_IOC_SEND_BROADCAST_REQUEST. They used to return sizeof(struct fw_cdev_send_request *) + data_length which is obviously a failed attempt to emulate the return value of raw1394's respective interface which uses write() instead of ioctl(). However, the first summand, as size of a kernel pointer, is entirely meaningless to clients and the second summand is already known to clients. And the result does not resemble raw1394's write() return code anyway. So simplify it to a constant non-negative value, i.e. 0. The only dangers here would be that future client implementations check for error by ret != 0 instead of ret < 0 when running on top of an old kernel; or that current clients interpret ret = 0 or more as failure. But both are hypothetical cases which don't justify to return irritating values. While we touch this code, also remove "& 0x1f" from tcode in the call of fw_send_request. The tcode cannot be bigger than 0x1f at this point. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: fix race of ioctl_send_request with bus resetStefan Richter
The bus reset handler concurrently frees client->device->node. Use device->node_id instead. This is equivalent to device->node->node_id while device->generation is current. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: secure add_descriptor ioctlStefan Richter
The access permissions and ownership or ACL of /dev/fw* character device files will typically be set based on the device type of the respective nodes, as obtained by firewire-core from descriptors in the device's configuration ROM. An example policy is to deny write permission by default but grant write permission to files of AV/C video and audio devices and IIDC video devices. The FW_CDEV_IOC_ADD_DESCRIPTOR ioctl could be used to partly subvert such a policy: Find a device file with relaxed permissions, use the ioctl to add a descriptor with AV/C marker to the local node's ROM, thus gain access to the local node's character device file. (This is only possible if there are udev scripts installed which actively relax permissions for known device types and if there is a device of such a type connected.) Accessibility of the local node's device file is relevant to host security if the host contains two or more IEEE 1394 link layer controllers which are plugged into a single bus. Therefore change the ABI to deny FW_CDEV_IOC_ADD_DESCRIPTOR if the file belongs to a remote node. (This change has no impact on known implementers of the ABI: None of them uses the ioctl yet.) Also clarify the documentation: The ioctl affects all local nodes, not just one local node. Cc: stable@kernel.org Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: amendment to "add ioctl to query maximum transmission speed"Stefan Richter
The as yet unreleased FW_CDEV_IOC_GET_SPEED ioctl puts only a single integer into the parameter buffer. We can use ioctl()'s return value instead. (Also: Some whitespace change in firewire-cdev.h.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: implement asynchronous stream transmissionJay Fenlason
Allow userspace and other firewire drivers (fw-ipv4 I'm looking at you!) to send Asynchronous Transmit Streams as described in 7.8.3 of release 1.1 of the 1394 Open Host Controller Interface Specification. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (tweaks)
2009-03-24firewire: cdev: simplify a schedule_delayed_work wrapperStefan Richter
The kernel API documentation says that queue_delayed_work() returns 0 (only) if the work was already queued. The return codes of schedule_delayed_work() are not documented but the same. In init_iso_resource(), the work has never been queued yet, hence we can assume schedule_delayed_work() to be a guaranteed success there. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add ioctls for iso resource management, amendmentStefan Richter
Some fixes: - Remove stale documentation. - Fix a != vs. == thinko that got in the way of channel management. - Try bandwidth deallocation even if channel deallocation failed. A simplification: - fw_cdev_allocate_iso_resource.channels is now ordered like libdc1394's dc1394_iso_allocate_channel() channels_allowed argument. By the way, I looked closer at cards from NEC, TI, and VIA, and noticed that they all don't implement IEEE 1394a behaviour which is meant to deviate from IEEE 1212's notion of lock compare-swap. This means that we have to do two lock transactions instead of one in many cases where one transaction would already succeed on a fully 1394a compliant IRM. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: shut down iso context before freeing the bufferStefan Richter
DMA must be halted before we DMA-unmap and free the DMA buffer. Since we cannot rely on the client to stop the context before it closes the fd, we have to reorder fw_iso_buffer_destroy vs. fw_iso_context_destroy. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: replace some spin_lock_irqsave by spin_lock_irqStefan Richter
All of these functions are entered with IRQs enabled. Hence the unconditional spin_unlock_irq can be used. Function: Caller context: dequeue_event() client process, via read(2) fill_bus_reset_event() fw-device.c update worqueue job release_client_resource() client process, via ioctl(2) fw_device_op_release() client process, via close(2) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: extend transaction payload size checkStefan Richter
Make the size check of ioctl_send_request and ioctl_send_broadcast_request speed dependent. Also change the error return code from -EINVAL to -EIO to distinguish this from other errors concerning the ioctl parameters. Another payload size limit for which we don't check here though is the remote node's Bus_Info_Block.max_rec. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: restrict broadcast write requests to Units SpaceStefan Richter
We don't want random users write to Memory Space (e.g. PCs with physical DMA filters down) or to core CSRs like Reset_Start. This does not protect SBP-2 target CSRs. But properly behaving SBP-2 targets ignore broadcast write requests to these registers, and the maximum damage which can happen with laxer targets is DOS. But there are ways to create DOS situations anyway if there are devices with weak device file permissions (like audio/video devices) present at the same bus as an SBP-2 target. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add ioctl for broadcast write requestsJay Fenlason, Stefan Richter
Write transactions to the broadcast node ID are a convenient way to trigger functions of multiple nodes at once. IIDC is a protocol which can make use of this if multiple cameras with same command_regs_base are connected at the same bus. Based on Date: Wed, 10 Sep 2008 11:32:16 -0400 From: Jay Fenlason <fenlason@redhat.com> Subject: [patch] SEND_BROADCAST_REQUEST Changes: ioctl_send_request() and ioctl_send_broadcast_request() now share code. Broadcast speed corrected to S100. Check for proper tcode. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add ioctl to query maximum transmission speedStefan Richter
While the speed of asynchronous transactions is automatically chosen by the kernel, the speed of isochronous streams has to be chosen by the initiating client. In case of 1394a bus topologies, the maximum possible speed could be figured out with some effort by evaluation of the remote node's link speed field in the config ROM, the local node's link speed field, and the PHY speeds and topologic information in the local node's or IRM's topology map CSR. However, this does not work in case of 1394b buses. Hence add an ioctl to export the maximum speed which the kernel already determined. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add ioctls for manual iso resource managementStefan Richter
This adds ioctls for allocation and deallocation of a channel or/and bandwidth without auto-reallocation and without auto-deallocation. The benefit of these ioctls is that libraw1394-style isochronous resource management can be implemented without write access to the IRM's character device file. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: add ioctls for isochronous resource managementJay Fenlason, Stefan Richter
Based on Date: Tue, 18 Nov 2008 11:41:27 -0500 From: Jay Fenlason <fenlason@redhat.com> Subject: [Patch V4] Add ISO resource management support with several changes to the ABI and implementation. Only the part of the ABI which enables auto-reallocation and auto-deallocation is included here. This implements ioctls for kernel-assisted allocation of isochronous channels and isochronous bandwidth. The benefits are: - The client does not have to have write access to the /dev/fw* device corresponding to the IRM. - The client does not have to perform reallocation after bus resets. - Channel and bandwidth are deallocated by the kernel if the file is closed before the client deallocated the resources. Thus resources are released even if the client crashes. It is anticipated that future in-kernel code (firewire-core IRM code; the firewire port of firedtv), will use the fw-iso.c portions of this code too. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: David Moore <dcm@acm.org>
2009-03-24firewire: cdev: sort includesStefan Richter
2009-03-24firewire: cdev: unify names of struct types and of their instancesStefan Richter
to indicate that they are specializations of struct event or of struct client_resource, respectively. struct response was both an event and a client_resource; it is now split into struct outbound_transaction_resource and ~_event in order to document more explicitly which types of client resources exist. struct request and struct_request_event are renamed to struct inbound_transaction_resource and ~_event because requests and responses occur in outbound and in inbound transactions. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: reference-count client instancesStefan Richter
The lifetime of struct client instances must be longer than the lifetime of any client resource. This fixes a possible race between fw_device_op_release and transaction completions. It also prepares for new ioctls for isochronous resource management which will involve delayed processing of client resources. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Reviewed-by: David Moore <dcm@acm.org>
2009-03-24firewire: cdev: use list_first_entryStefan Richter
2009-03-24firewire: remove line breaks before function namesStefan Richter
type function_name(parameters); is nice to look at but was not used consistently. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: standardize a variable nameStefan Richter
"ret" is the new "retval". Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: address handler input validationStefan Richter
Like before my commit 1415d9189e8c59aa9c77a3bba419dcea062c145f, fw_core_add_address_handler() does not align the address region now. Instead the caller is required to pass valid parameters. Since one of the callers of fw_core_add_address_handler() is the cdev userspace interface, we now check for valid input. If the client is buggy, we give it a hint with -EINVAL. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: use an idr rather than a linked list for resourcesJay Fenlason
The current code uses a linked list and a counter for storing resources and the corresponding handle numbers. By changing to an idr we can be safe from counter wrap-around giving two resources the same handle. Furthermore, the deallocation ioctls now check whether the resource to be freed is of the intended type. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Some rework by Stefan R: - The idr API documentation says we get an ID within 0...0x7fffffff. Hence we can rest assured that idr handles fit into cdev handles. - Fix some races. Add a client->in_shutdown flag for this purpose. - Add allocation retry to add_client_resource(). - It is possible to use idr_for_each() in fw_device_op_release(). - Fix ioctl_send_response() regression. - Small style changes. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: fix race of fw_device_op_release with bus resetStefan Richter
Unlink the client from the fw_device earlier in order to prevent bus reset events being added to client->event_list during shutdown. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: cdev: tcodes input validationStefan Richter
The behaviour of fw-transaction.c::fw_send_request is ill-defined for any other tcodes than read/ write/ lock request tcodes. Therefore prevent requests with wrong tcodes from entering the transaction layer. Maybe fw_send_request should check them itself, but I am not inclined to change it and fw_fill_request from void-valued functions to ones which return error codes and pass those up. Besides, maybe fw_send_request is going to support one more tcode than ioctl_send_request in the future (TCODE_STREAM_DATA). Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: convert client_list_lock to mutexStefan Richter
So far it is only taken in non-atomic contexts. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-03-24firewire: add a client_list_lockJay Fenlason
This adds a client_list_lock, which only protects the device's client_list, so that future versions of the driver can call code that takes the card->lock while holding the client_list_lock. Adding this lock is much simpler than adding __ versions of all the functions that the future version may need. The one ordering issue is to make sure code never takes the client_list_lock with card->lock held. Since client_list_lock is only used in three places, that isn't hard. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Update fill_bus_reset_event() accordingly. Include linux/spinlock.h. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-10-15firewire: fix ioctl() return codeStefan Richter
Reported by Jay Fenlason: ioctl() did not return as intended - the size of data read into ioctl_send_request, - the number of datagrams enqueued by ioctl_queue_iso. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-10-15firewire: fix setting tag and sy in iso transmissionStefan Richter
Reported by Jay Fenlason: The iso packet control accessors in fw-cdev.c had bogus masks. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-08-02firewire: Preserve response data alignment bug when it is harmlessDavid Moore
Recently, a bug having to do with the alignment of transaction response data was fixed. However, some apps such as libdc1394 relied on the presence of that bug in order to function correctly. In order to stay compatible with old versions of those apps, this patch preserves the bug in cases where it is harmless to normal operation (such as the single quadlet read) due to a simple duplication of data. This guarantees maximum compatability for those users who are using the old app with the fixed kernel. Signed-off-by: David Moore <dcm@acm.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-07-20firewire: queue the right number of dataJiSheng Zhang
There will be 4 padding bytes in struct fw_cdev_event_response on some platforms The member:__u32 data will point to these padding bytes. While queue the response and data in complete_transaction in fw-cdev.c, it will queue like this: |response(excluding padding bytes)|4 padding bytes|4 padding bytes|data. It queue 4 extra bytes. That is to say it use "&response + sizeof(response)" while other place of kernel and userspace library use "&response + offsetof (typeof(response), data)". So it will lost the last 4 bytes of data. This patch can fix it while not changing the struct definition. Signed-off-by: JiSheng Zhang <jszhang3@mail.ustc.edu.cn> This fixes responses to outbound block read requests on 64bit architectures. Tested on i686, x86-64, and x86-64 with i686 userland, using firecontrol and gscanbus. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-06-19firewire: fill_bus_reset_event needs lock protectionStefan Richter
Callers of fill_bus_reset_event() have to take card->lock. Otherwise access to node data may oops if node removal is in progress. A lockless alternative would be - event->local_node_id = card->local_node->node_id; + tmp = fw_node_get(card->local_node); + event->local_node_id = tmp->node_id; + fw_node_put(tmp); and ditto with the other node pointers which fill_bus_reset_event() accesses. But I went the locked route because one of the two callers already holds the lock. As a bonus, we don't need the memory barrier anymore because device->generation and device->node_id are written in a card->lock protected section. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2008-05-20firewire: prevent userspace from accessing shut down devicesJay Fenlason
If userspace ignores the POLLERR bit from poll(), and only attempts to read() the device when POLLIN is set, it can still make ioctl() calls on a device that has been removed from the system. The node_id and generation returned by GET_INFO will be outdated, but INITIATE_BUS_RESET would still cause a bus reset, and GET_CYCLE_TIMER will return data. And if you guess the correct generation to use, you can send requests to a different device on the bus, and get responses back. This patch prevents open, ioctl, compat_ioctl, and mmap against shutdown devices. Signed-off-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: reread config ROM when device reset the busStefan Richter
When a device changes its configuration ROM, it announces this with a bus reset. firewire-core has to check which node initiated a bus reset and whether any unit directories went away or were added on this node. Tested with an IOI FWB-IDE01AB which has its link-on bit set if bus power is available but does not respond to ROM read requests if self power is off. This implements - recognition of the units if self power is switched on after fw-core gave up the initial attempt to read the config ROM, - shutdown of the units when self power is switched off. Also tested with a second PC running Linux/ieee1394. When the eth1394 driver is inserted and removed on that node, fw-core now notices the addition and removal of the IPv4 unit on the ieee1394 node. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-02-21firewire: fix NULL pointer deref. and resource leakStefan Richter
By supplying ioctl()s in the wrong order, a userspace client was able to trigger NULL pointer dereferences. Furthermore, by calling ioctl_create_iso_context more than once, new contexts could be created without ever freeing the previously created contexts. Thanks to Anders Blomdell for the report. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-02-16firewire: fix "kobject_add failed for fw* with -EEXIST"Stefan Richter
There is a race between shutdown and creation of devices: fw-core may attempt to add a device with the same name of an already existing device. http://bugzilla.kernel.org/show_bug.cgi?id=9828 Impact of the bug: Happens rarely (when shutdown of a device coincides with creation of another), forces the user to unplug and replug the new device to get it working. The fix is obvious: Free the minor number *after* instead of *before* device_unregister(). This requires to take an additional reference of the fw_device as long as the IDR tree points to it. And while we are at it, we fix an additional race condition: fw_device_op_open() took its reference of the fw_device a little bit too late, hence was in danger to access an already invalid fw_device. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-01-30firewire: enforce access order between generation and node ID, fix "giving ↵Stefan Richter
up on config rom" fw_device.node_id and fw_device.generation are accessed without mutexes. We have to ensure that all readers will get to see node_id updates before generation updates. Fixes an inability to recognize devices after "giving up on config rom", https://bugzilla.redhat.com/show_bug.cgi?id=429950 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Reviewed by Nick Piggin <nickpiggin@yahoo.com.au>. Verified to fix 'giving up on config rom' issues on multiple system and drive combinations that were previously affected. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2008-01-30firewire: fw-cdev: use device generation, not card generationStefan Richter
We have to use the fw_device.generation here, not the fw_card.generation, because the generation must never be newer than the node ID when we emit a transaction. This cannot be guaranteed with fw_card.generation. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Verified in concert with subsequent memory barriers patch to fix 'giving up on config rom' issues on multiple system and drive combinations that were previously affected. Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2007-10-17firewire: fw-cdev: reorder wakeup vs. spinlockJay Fenlason
Signed-off-by: Jay Fenlason <fenlason@redhat.com> Prompted by https://bugzilla.redhat.com/show_bug.cgi?id=323411 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: adopt read cycle timer ABI from raw1394Stefan Richter
This duplicates the read cycle timer feature of raw1394 (added in Linux 2.6.21) in firewire-core's userspace ABI. The argument to the ioctl is reordered though to ensure 32/64 bit compatibility. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-10-17firewire: fw-core: local variable shadows a global oneStefan Richter
Sparse warned about it although it was apparently harmless: drivers/firewire/fw-cdev.c:624:23: warning: symbol 'interrupt' shadows an earlier one include/asm/hw_irq.h:29:13: originally declared here Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-14fw-cdev __user annotationsAl Viro
2007-07-10firewire: support S100B...S400B and link slower than PHYStefan Richter
Use a speed probe to determine the speed over 1394b buses and of nodes which report a link speed less than their PHY speed. Log the effective maximum speed of newly created nodes in dmesg. Also, read the config ROM (except bus info block) at the maximum speed rather than S100. This isn't a real optimization though because we still only use quadlet read requests for the entire ROM. The patch also adds support for S1600 and S3200, although such hardware does not exist yet. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-06-21firewire: Only set client->iso_context if allocation was successful.Kristian Høgsberg
This patch fixes an OOPS on cdev release for an fd where iso context creation failed. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-31firewire: Change struct fw_cdev_iso_packet to not use bitfields.Kristian Høgsberg
The struct is part of the userspace interface and can not use bitfields. This patch replaces the bitfields with a __u32 'control' word and provides access macros to set the bits. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-05-27firewire: fix return codeJeff Garzik
Fix this warning on x86-64 drivers/firewire/fw-cdev.c:798: warning: initialization from incompatible pointer type by making the return code of ioctl_send_request() the same as all the other ioctl_xxx() return codes. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
