path: root/drivers/firewire/fw-ohci.c
2008-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: state userland requirements in Kconfig help firewire: avoid memleak after phy config transmit failure firewire: fw-ohci: TSB43AB22/A dualbuffer workaround firewire: queue the right number of data firewire: warn on unfinished transactions during card removal firewire: small fw_fill_request cleanup firewire: fully initialize fw_transaction before marking it pending firewire: fix race of bus reset with request transmission
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25firewire: fw-ohci: TSB43AB22/A dualbuffer workaroundStefan Richter
Isochronous reception in dualbuffer mode is reportedly broken with TI TSB43AB22A on x86-64. Descriptor addresses above 2G have been determined as the trigger: https://bugzilla.redhat.com/show_bug.cgi?id=435550 Two fixes are possible: - pci_set_consistent_dma_mask(pdev, DMA_31BIT_MASK); at least when IR descriptors are allocated, or - simply don't use dualbuffer. This fix implements the latter workaround. But we keep using dualbuffer on x86-32 which won't give us highmen (and thus physical addresses outside the 31bit range) in coherent DMA memory allocations. Right now we could for example also whitelist PPC32, but DMA mapping implementation details are expected to change there. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-07-14firewire: remove unused struct membersStefan Richter
2008-06-19firewire: fw-ohci: unify printk prefixesStefan Richter
The messages which can be enabled by fw-ohci's debug module parameter are changed from KERN_DEBUG to KERN_NOTICE level and uniformly prefixed with "firewire_ohci: ". This further simplifies communication with users when we ask them to capture debug messages. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-06-19firewire: fw-ohci: write selfIDBufferPtr before LinkControl.rcvSelfIDStefan Richter
OHCI 1.1 clause 5.10 requires that selfIDBufferPtr is valid when a 1 is written into LinkControl.rcvSelfID. This driver bug has so far not been known to cause harm because most chips obviously accept a later selfIDBufferPtr write, at least before HCControl.linkEnable is written. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2008-06-19firewire: fw-ohci: disable PHY packet reception into AR contextStefan Richter
We want the rcvPhyPkt bit in LinkControl off before we start using the chip. However, the spec says that the reset value of it is undefined. Hence switch it explicitly off. https://bugzilla.redhat.com/show_bug.cgi?id=244576#c48 shows that for example the nForce2 integrated FireWire controller seems to have it on by default. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-06-19firewire: fw-ohci: use of uninitialized data in AR handlerStefan Richter
header_length and payload_length are filled with random data if an unknown tcode was read from the AR buffer (i.e. if the AR buffer contained invalid data). We still need a better strategy to recover from this, but at least handle_ar_packet now doesn't return out of bound buffer addresses anymore. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: remove unused struct memberStefan Richter
request_generation is internal to fw-ohci and unneeded in fw_card. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: work around generation bug in TI controllers (fix AV/C ↵Stefan Richter
and more) Unlike the ohci1394 driver, fw-ohci uses the selfIDGeneration field of bus reset packets to determine the generation of incoming requests as per OHCI 1.1 clause 8.4.2.3. This is more precise --- provided that the controller inserts the correct generation. Texas Instruments chips often don't. This prevented the transmission of response packets, which for example broke AV/C transactions as used when communicating with miniDV cameras and any other AV/C devices. There is apparently no way to detect and adjust incorrect generations. Therefore we ignore the generation of bus reset packets from TI chips and use the generation of the self ID buffer instead. Alas this is received at a slightly wrong time. In rare cases, this could cause us to not respond to legitimate requests or to respond to expired requests. (The latter is less likely because the bus reset packet AR event is typically handled before the self ID complete event.) Bug reported by Mladen Kuntner, who was extraordinarily patient while dealing with the driver maintainers. Fix confirmed to be required and effective for TSB82AA2 and a TSB43AB22 or TSB43AB22A. https://bugzilla.redhat.com/show_bug.cgi?id=243081 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-04-18firewire: fw-ohci: extend logging of bus generations and node IDStefan Richter
Extend the logging of "AR evt_bus_reset, link internal" to "AR evt_bus_reset, generation ${selfIDGeneration}". That way we can check whether this generation matches the one seen in self ID complete event logging. See OHCI 1.1 clause 8.4.2.3. Also extend logging of "firewire_ohci: * selfIDs, generation *" by "local node ID ffc*" in self ID logging to make the local node in AT/AR event logs more obvious. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-04-18firewire: fw-ohci: conditionally log busReset interruptsStefan Richter
Add a debug option to watch bus reset interrupt events. Half of this patch is taken from Jarod Wilson's first version of the JMicron fix. BusReset interrupts are only generated if the respective module parameter flag was set before the controller is being initialized. Else we keep this event masked to reduce IRQ load in normal operation and to avoid potential problems with buggy chips. Note, this is unlike the other IRQ events whose logging can be enabled any time after chip initialization. This and the influence on what interrupts the chip generates is why I added an extra flag for it. Also, reorder the debug parameter flags according to their perceived usefulness. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-04-18firewire: fw-ohci: don't append to AT context when it's not activeJarod Wilson
I finally tracked down the issues with this JMicron PCI-e card in my possession to a failure to comply with section 7.2.3.2 of the OHCI 1.1 specification (thanks to Kristian for the pointer to illustrate that it is indeed a flaw in this card, not the driver). The controller should simply flush the packets we've appended to its AT queue if a bus reset occurs before they've been transmitted and we'll try again, but something goes wrong and the controller winds up hung. However, we can avoid the problem by simply checking if the IntEvent.busReset register had been set before we try appending to the AT context. When busReset is set, the AT context is completely halted until busReset is cleared, so there's no point in appending AT packets until the register is cleared. So at_context_queue_packet() now checks for busReset being set, and bails with an RCODE_GENERATION packet ack, which results in us trying to append the packet again after recognizing the fact there has been a bus reset, and clearing busReset. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: log regAccessFail eventsJarod Wilson
While trying to debug this piece of crap JMicron PCI-e controller in my possession, one thought was that perhaps I was encountering register access failures. I'm not, but logging them would be good, so we can see if they are a real problem we should be taking into account anywhere in the code. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (added list contact)
2008-04-18firewire: fw-ohci: make sure HCControl register LPS bit is setJarod Wilson
I've now witnessed multiple occasions where one of my controllers (a very poorly working JMicron PCIe card) fails to get its registers properly set up in ohci_enable(), apparently due to an occasionally very slow to initiate SClk. The easy fix for this problem is to add a tiny while loop to try again a time or three after initially enabling LPS before we move on (or give up). Of course, the card still isn't fully functional yet, but this gets it at least one tiny step closer... Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: missing PPC PMac feature calls in failure pathStefan Richter
Balance ohci_pmac_on and ohci_pmac_off if pci_driver.probe fails. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: untangle a mixed unsigned/signed expressionStefan Richter
and make another expression more readable. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: debug interrupt eventsStefan Richter
This adds debug printks for asynchronous transmission and reception and for self ID reception. They can be enabled at module load time, and at runtime via /sys/module/firewire_ohci/parameters/debug. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Also added: Logging of interrupt event codes and of cancelled AT packets. The code now depends on a Kconfig variable. This makes it easier to build firewire-ohci without the feature or to make it an option in the future. The variable is currently hidden and always on. This feature inflates firewire-ohci.ko by 7 kB = 27% on x86-64 and by 4 kB = 23% on i686. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: catch self_id_count == 0Stefan Richter
fw_core_handle_bus_reset() incorrectly relied on the assumption that self_id_count > 0. We check early in fw-ohci and discard the self ID complete event if self_id_count == 0 because a valid event always has at least one self ID packet in it (the one of the local node). Hence treat self_id_count == 0 like any other kind of invalid self ID buffer. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-04-18firewire: fw-ohci: add self ID error checkStefan Richter
Discard self ID buffer contents if - the selfIDError flag is set, - any of the self ID packets has bit errors. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-04-18firewire: fw-ohci: refactor probe, remove, suspend, resumeStefan Richter
Clean up shared code and variable names. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: switch on bus power after resume on PPC PMacStefan Richter
The platform feature calls in the suspend method switched off cable power, but the calls in the resume method did not switch it back on. Add the necessary feature call to .resume. Also add the corresponding call to .suspend to make .suspend's behavior explicitly the same on all PMacs. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-04-18firewire: fw-ohci: add option for remote debuggingStefan Richter
This way firewire-ohci can be used for remote debugging like ohci1394. Version with amendment from Fri, 11 Apr 2008 00:08:08 +0200. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Bernhard Kaindl <bk@suse.de>
2008-04-18firewire: remove superfluous reference countingStefan Richter
The card->kref became obsolete since patch "firewire: fix crash in automatic module unloading" added another counter of card users. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-27firewire: fw-ohci: plug dma memory leak in AR handlerJarod Wilson
There's an ugly little memory leak in firewire-ohci's ar_context_tasklet(), where we're not freeing up some of the memory we use for each ar_buffer, due to a moving pointer. The problem has been there for a while, but didn't get noticed until after converting the AR routines over to use coherent DMA and I started running into I/O stall- outs with the following message output repeatedly to the console: PCI-DMA: Out of IOMMU space for 53248 bytes at device 0000:04:09.0 Plugging this leak is definitely necessary, but unfortunately, isn't the entire answer to my problem, it only increases the amount of I/O that I can do before hitting the problem. Still working on tracking down the root cause.. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-03-14firewire: fw-ohci: shut up false compiler warning on PPC32Stefan Richter
Shut up "may be used uninitialised in this function" warnings due to PPC32's implementation of dma_alloc_coherent(). Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-03-14firewire: fw-ohci: use dma_alloc_coherent for ar_bufferJarod Wilson
Currently, we do nothing to guarantee we have a consistent DMA buffer for asynchronous receive packets. Rather than doing several sync's following a dma_map_single() to get consistent buffers, just switch to using dma_alloc_coherent(). Resolves constant buffer failures on my own x86_64 laptop w/4GB of RAM and likely to fix a number of other failures witnessed on x86_64 systems with 4GB of RAM or more. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-03-14firewire: fw-ohci: Apple UniNorth 1st generation supportStefan Richter
Mostly copied from ohci1394.c. Necessary for some older Macs, e.g. PowerBook G3 Pismo and early PowerBook G4 Titanium. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-03-14firewire: fw-ohci: PPC PMac platform codeStefan Richter
Copied from ohci1394.c. This code is necessary to prevent machine check exceptions when reloading or resuming the driver. Tested on a 1st generation PowerBook G4 Titanium, which also needs the pci_probe() hunk. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> I was able to reproduce the system exception on resume with a 3rd-gen Titanium PowerBook G4 667, and this patch does let the system resume successfully now. Not quite clear if there was possibly an updated version coming using pci_enable_device() instead of the pair of pmac_call_feature() calls, but either way, this is a definite must-have, at least for older ppc macs -- my Aluminum PowerBook G4/1.67 suspends and resumes without this patch just fine. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-03-14firewire: endianess annotationsStefan Richter
Kills warnings from 'make C=1 CHECKFLAGS="-D__CHECK_ENDIAN__" modules': drivers/firewire/fw-transaction.c:771:10: warning: incorrect type in assignment (different base types) drivers/firewire/fw-transaction.c:771:10: expected unsigned int [unsigned] [usertype] <noident> drivers/firewire/fw-transaction.c:771:10: got restricted unsigned int [usertype] <noident> drivers/firewire/fw-transaction.h:93:10: warning: incorrect type in assignment (different base types) drivers/firewire/fw-transaction.h:93:10: expected unsigned int [unsigned] [usertype] <noident> drivers/firewire/fw-transaction.h:93:10: got restricted unsigned int [usertype] <noident> drivers/firewire/fw-ohci.c:1490:8: warning: restricted degrades to integer drivers/firewire/fw-ohci.c:1490:35: warning: restricted degrades to integer drivers/firewire/fw-ohci.c:1516:5: warning: cast to restricted type Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-14firewire: endianess fixStefan Richter
The generation of incoming requests was filled in in wrong byte order on machines with big endian CPU. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-01-30firewire: fw-ohci: Dynamically allocate buffers for DMA descriptorsDavid Moore
Previously, the fw-ohci driver used fixed-length buffers for storing descriptors for isochronous receive DMA programs. If an application (such as libdc1394) generated a DMA program that was too large, fw-ohci would reach the limit of its fixed-sized buffer and return an error to userspace. This patch replaces the fixed-length ring-buffer with a linked-list of page-sized buffers. Additional buffers can be dynamically allocated and appended to the list when necessary. For a particular context, buffers are kept around after use and reused as necessary, so there is no allocation taking place after the DMA program is generated for the first time. In addition, the buffers it uses are coherent for DMA so there is no syncing required before and after writes. This syncing wasn't properly done in the previous version of the code. - This is the fourth version of my patch that replaces a fixed-length buffer for DMA descriptors with a dynamically allocated linked-list of buffers. As we discovered with the last attempt, new context programs are sometimes queued from interrupt context, making it unacceptable to call tasklet_disable() from context_get_descriptors(). This version of the patch uses ohci->lock for all locking needs instead of tasklet_disable/enable. There is a new requirement that context_get_descriptors() be called while holding ohci->lock. It was already held for the AT context, so adding the requirement for the iso context did not seem particularly onerous. In addition, this has the side benefit of allowing iso queue to be safely called from concurrent user-space threads, which previously was not safe. Signed-off-by: David Moore <dcm@acm.org> Signed-off-by: Kristian Høgsberg <krh@redhat.com> Signed-off-by: Jarod Wilson <jwilson@redhat.com> - Fixes the following issues: - Isochronous reception stopped prematurely if an application used a larger buffer. (Reproduced with coriander.) - Isochronous reception stopped after one or a few frames on VT630x in OHCI 1.0 mode. (Fixes reception in coriander, but dvgrab still doesn't work with these chips.) Patch update: struct member alignment, whitespace nits Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-01-30firewire: fw-ohci: CycleTooLong interrupt managementStefan Richter
The firewire-ohci driver so far lacked the ability to resume cycle master duty after that condition happened, as added to ohci1394 in Linux 2.6.18 by commit 57fdb58fa5a140bdd52cf4c4ffc30df73676f0a5. This ports this patch to fw-ohci. The "cycle too long" condition has been seen in practice - with IIDC cameras if a mode with packets too large for a speed is chosen, - sporadically when capturing DV on a VIA VT6306 card with ohci1394/ ieee1394/ raw1394/ dvgrab 2. https://bugzilla.redhat.com/show_bug.cgi?id=415841#c7 (This does not fix Fedora bug 415841.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-01-30firewire: fw-ohci: Bug fixes for packet-per-buffer supportDavid Moore
This patch corrects a number of bugs in the current OHCI 1.0 packet-per-buffer support: 1. Correctly deal with payloads that cross a page boundary. The previous version would not split the descriptor at such a boundary, potentially corrupting unrelated memory. 2. Allow user-space to specify multiple packets per struct fw_cdev_iso_packet in the same way that dual-buffer allows. This is signaled by header_length being a multiple of header_size. This multiple determines the number of packets. The payload size allocated per packet is determined by dividing the total payload size by the number of packets. 3. Make sync support work properly for packet-per-buffer. I have tested this patch with libdc1394 by forcing my OHCI 1.1 controller to use the packet-per-buffer support instead of dual-buffer. I would greatly appreciate testing by those who have a DV devices and other types of iso streamers to make sure I didn't cause any regressions. Stefan, with this patch, I'm hoping that libdc1394 will work with all your OHCI 1.0 controllers now. The one bit of future work that remains for packet-per-buffer support is the automatic compaction of short payloads that I discussed with Kristian. Signed-off-by: David Moore <dcm@acm.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2008-01-30firewire: fw-ohci: Fix for dualbuffer three-or-more buffersDavid Moore
This patch fixes the problem where different OHCI 1.1 controllers behave differently when a received iso packet straddles three or more buffers when using the dual-buffer receive mode. Two changes are made in order to handle this situation: 1. The packet sync DMA descriptor is given a non-zero header length and non-zero payload length. This is because zero-payload descriptors are not discussed in the OHCI 1.1 specs and their behavior is thus undefined. Instead we use a header size just large enough for a single header and a payload length of 4 bytes for this first descriptor. 2. As we process received packets in the context's tasklet, read the packet length out of the headers. Keep track of the running total of the packet length as "excess_bytes", so we can ignore any descriptors where no packet starts or ends. These descriptors may not have had their first_res_count or second_res_count fields updated by the controller so we cannot rely on those values. The main drawback of this patch is that the excess_bytes value might get "out of sync" with the packet descriptors if something strange happens to the DMA program. I'm not if such a thing could ever happen, but I appreciate any suggestions in making it more robust. Also, the packet-per-buffer support may need a similar fix to deal with issue 1, but I haven't done any work on that yet. Stefan, I'm hoping that with this patch, all your OHCI 1.1 controllers will work properly with an unmodified version of libdc1394. Signed-off-by: David Moore <dcm@acm.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-12-10firewire: OHCI 1.0 Isochronous Receive supportJarod Wilson
Third rendition of FireWire OHCI 1.0 Isochronous Receive support, using a zer-copy method similar to OHCI 1.1 which puts the IR data payload directly into the userspace buffer. The zero-copy implementation eliminates the video artifacts, audio popping, and buffer underrun problems seen with version 1 of this patch, as well as fixing a regression in OHCI 1.1 support introduced by version 2 of this patch. Successfully tested in OHCI 1.1 mode on the following chipsets: - NEC uPD72847 (rev 01), OHCI 1.1 (PCI) - Ti XIO2200(A) (rev 01), OHCI 1.1 (PCIe) - Ti TSB41AB2 (rev 01), OHCI 1.1 (PCI on SB Audigy) - Apple UniNorth 2 (rev 81), OHCI 1.1 (PowerBook G4 onboard) Successfully tested in OHCI 1.0 mode on the following chipsets: - Agere FW323 (rev 06), OHCI 1.0 (Mac Mini onboard) - Agere FW323 (rev 06), OHCI 1.0 (PCI) - Via VT6306 (rev 46), OHCI 1.0 (PCI) - NEC OrangeLink (rev 01), OHCI 1.0 (PCI) - NEC uPD72847 (rev 01), OHCI 1.1 (PCI) - Ti XIO2200(A) (rev 01), OHCI 1.1 (PCIe) The bulk of testing was done in an x86_64 system, but was also successfully sanity-tested on other systems, including a PPC(32) PowerBook G4 and an i686 EPIA M10k. Crude benchmarking (watching top during capture) puts the cpu utilization during capture on the EPIA's 1GHz Via C3 processor around 13%, which is down from 30% with the v1 code. Some implementation details: To maintain the same userspace API as dual-buffer mode, we set up two descriptors for every incoming packet. The first is an INPUT_MORE descriptor, pointing to a buffer large enough to hold just the packet's iso headers, immediately followed by an INPUT_LAST descriptor, pointing to a chunk of the userspace buffer big enough for the packet's data payload. With this setup, each incoming packet fills in these two descriptors in a manner that very closely emulates dual-buffer receive, to the point where the bulk of the handle_ir_* code is now identical between the two (and probably primed for some restructuring to share code between them). The only caveat I have at the moment is that neither of my OHCI 1.0 Via VT6307-based FireWire controllers work particularly well with this code for reasons I have yet to figure out. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-31firewire: Fix pci resume to not pass in a __be32 config rom.Kristian Høgsberg
The ohci_enable() function shared between pci_probe and pci_resume takes a host endian config rom, but ohci->config_rom is __be32. This sets up the config rom in the wrong endian on little endian machine, specifically, BusOptions will be initialized to a 0 max receive size. This patch changes the way we reuse the config rom so that we avoid this problem. Signed-off-by: Kristian Hoegsberg <krh@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-22firewire: fw-ohci: shut up a superfluous compiler warningStefan Richter
New warning since commit ab88ca488b8af66c3defa165874e81e695319a19, "firewire: fw-ohci: missing dma_unmap_single": drivers/firewire/fw-ohci.c: In function 'at_context_transmit': drivers/firewire/fw-ohci.c:609: warning: 'payload_bus' may be used uninitialized in this function Access to payload_bus is conditional on packet->payload_length > 0, and that won't change while in at_context_queue_packet. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-22firewire: fw-ohci: log a note about unsupported featuresStefan Richter
because there seems to be more time needed to implement this. Also, change related error return values to more appropriate ones. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-ohci: check for misconfigured bus (phyID == 63)Stefan Richter
Check NodeID.nodeNumber as per OHCI 1.1 clause 7.2.3.2. See also IEEE 1394a table 5B-1. Also, demote the "node ID not valid" message from error to notification as it is not an error condition. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-ohci: missing dma_unmap_singleStefan Richter
at_context_queue_packet() didn't clean up in an early exit path. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-10-17firewire: fw-ohci: log posted write errorsStefan Richter
2007-10-17firewire: fw-ohci: reorder includesStefan Richter
2007-10-17firewire: fw-ohci: fix includesStefan Richter
Add used includes, remove unused includes. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-ohci: enforce read order for selfID generationStefan Richter
It seems unlikely, but access to self_id_cpu[0] could at least in theory be deferred until after the loop over self_id_cpu[1..n] or even after the subsequent reg_read. Enforce the desired order by a read barrier. Also prevent the reg_read from being reordered relative to the for loop. This isn't necessary if the loop's conditional printk counts as an implicit barrier, but better make it explicit. (self_id_cpu[] is a coherent DMA buffer.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-09-07firewire: fw-ohci: ignore failure of pci_set_power_state (fix suspend ↵Stefan Richter
regression) Fixes (papers over) "Sleep problems with kernels >= 2.6.21 on powerpc", http://lkml.org/lkml/2007/8/25/155. The issue is that the FireWire controller's pci_dev.current_state of iBook G3 and presumably older PowerBooks is still in PCI_UNKNOWN instead of PCI_D0 when the firewire driver's .suspend method is called. Like it was suggested earlier in http://lkml.org/lkml/2006/10/24/13, we do not fail .suspend anymore if pci_set_power_state failed. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-08-02firewire: fw-ohci: dma_free_coherent needs IRQs enabledStefan Richter
2007-07-18firewire: fw-ohci: fix "scheduling while atomic"Stefan Richter
context_stop is called by bus_reset_tasklet, among else. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-07-18firewire: fw-ohci: flush MMIO write before msleepStefan Richter
2007-07-10firewire: missing newline in printkStefan Richter
Also remove some errno printouts which will be shown by infrastructure code anyway. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
