commit 6044565af458e7fa6e748bff437ecc49dea88d79 upstream.
Regression since commit 10389536742c, "firewire: core: check for 1394a
compliant IRM, fix inaccessibility of Sony camcorder":
The camcorder Canon MV5i generates lots of bus resets when asynchronous
requests are sent to it (e.g. Config ROM read requests or FCP Command
write requests) if the camcorder is not root node. This causes drop-
outs in videos or makes the camcorder entirely inaccessible.
https://bugzilla.redhat.com/show_bug.cgi?id=633260
Fix this by allowing any Canon device, even if it is a pre-1394a IRM
like MV5i are, to remain root node (if it is at least Cycle Master
capable). With the FireWire controller cards that I tested, MV5i always
becomes root node when plugged in and left to its own devices.
Reported-by: Ralf Lange
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit a1f805e5e73a8fe166b71c6592d3837df0cd5e2e upstream.
When handling an AR buffer that has been completely filled, we assumed
that its descriptor will not be read by the controller and can be
overwritten. However, when the last received packet happens to end at
the end of the buffer, the controller might not yet have moved on to the
next buffer and might read the branch address later. If we overwrite
and free the page before that, the DMA context will either go dead
because of an invalid Z value, or go off into some random memory.
To fix this, ensure that the descriptor does not get overwritten by
using only the actual buffer instead of the entire page for reassembling
the split packet. Furthermore, to avoid freeing the page too early,
move on to the next buffer only when some data in it guarantees that the
controller has moved on.
This should eliminate the remaining firewire-net problems.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Tested-by: Maxim Levitsky <maximlevitsky@gmail.com>
commit 85f7ffd5d2b320f73912b15fe8cef34bae297daf upstream.
When the controller had to split a received asynchronous packet into two
buffers, the driver tries to reassemble it by copying both parts into
the first page. However, if size + rest > PAGE_SIZE, i.e., if the yet
unhandled packets before the split packet, the split packet itself, and
any received packets after the split packet are together larger than one
page, then the memory after the first page would get overwritten.
To fix this, do not try to copy the data of all unhandled packets at
once, but copy the possibly needed data every time when handling
a packet.
This gets rid of most of the infamous crashes and data corruptions when
using firewire-net.
camcorder
commit 10389536742cefbedecb67a5b2906f155cf3a1c3 upstream.
Per IEEE 1394 clause 8.4.2.3, a contender for the IRM role shall check
whether the current IRM complies to 1394a-2000 or later. If not force a
compliant node (e.g. itself) to become IRM. This was implemented in the
older ieee1394 driver but not yet in firewire-core.
An older Sony camcorder (Sony DCR-TRV25) which implements 1394-1995 IRM
but neither 1394a-2000 IRM nor BM was now found to cause an
interoperability bug:
- Camcorder becomes root node when plugged in, hence gets IRM role.
- firewire-core successfully contends for BM role, proceeds to perform
gap count optimization and resets the bus.
- Sony camcorder ignores presence of a BM (against the spec, this is
a firmware bug), performs its idea of gap count optimization and
resets the bus.
- Preceding two steps are repeated endlessly, bus never settles,
regular I/O is practically impossible.
http://thread.gmane.org/gmane.linux.kernel.firewire.user/3913
This is an interoperability regression from the old to the new drivers.
Fix it indirectly by adding the 1394a IRM check. The spec suggests
three and a half methods to determine 1394a compliance of a remote IRM;
we choose the method of testing the Config_ROM.Bus_Info.generation
field. This is data that firewire-core should have readily available at
this point, i.e. does not require extra I/O.
Reported-by: Clemens Ladisch <clemens@ladisch.de> (missing 1394a check)
Reported-by: H. S. <hs.samix@gmail.com> (issue with Sony DCR-TRV25)
Tested-by: H. S. <hs.samix@gmail.com>
In isochronous transmit DMA descriptors, link the skip address pointer
back to the descriptor itself. When a cycle is lost, the controller
will send the packet in the next cycle, instead of terminating the
entire DMA program.
There are two reasons for this:
* This behaviour is compatible with the old IEEE1394 stack. Old
applications would not expect the DMA program to stop in this case.
* Since the OHCI driver does not report any uncompleted packets, the
context would stop silently; clients would not have any chance to
detect and handle this error without a watchdog timer.
Pieter Palmers notes:
"The reason I added this retry behavior to the old stack is because some
cards now and then fail to send a packet (e.g. the o2micro card in my
dell laptop). I couldn't figure out why exactly this happens, my best
guess is that the card cannot fetch the payload data on time. This
happens much more frequently when sending large packets, which leads me
to suspect that there are some contention issues with the DMA that fills
the transmit FIFO.
In the old stack it was a pretty critical issue as it resulted in a
freeze of the userspace application.
The omission of a packet doesn't necessarily have to be an issue. E.g.
in IEC61883 streams the DBC field can be used to detect discontinuities
in the stream. So as long as the other side doesn't bail when no
[packet] is present in a cycle, there is not really a problem.
I'm not convinced though that retrying is the proper solution, but it is
simple and effective for what it had to do. And I think there are no
reasons not to do it this way. Userspace can still detect this by
checking the cycle the descriptor was sent in."
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (changelog, comment)
In the transmit path of firewire-net (IPv4 over 1394), the following
race condition may occur:
- The networking soft IRQ inserts a datagram into the 1394 async
request transmit DMA.
- The 1394 async transmit completion tasklet runs to finish cleaning
up (unlink datagram from list of pending ones, release skb and
outbound 1394 transaction object) --- before the networking soft IRQ
had a chance to proceed and add the datagram to the list of pending
datagrams.
This caused a panic in the 1394 async transmit completion tasklet when
it dereferenced unitialized list heads:
http://bugzilla.kernel.org/show_bug.cgi?id=15077
The fix is to add checks in the tx soft IRQ and in the tasklet to
determine which of these two is the last referrer to the transaction
object. Then handle the cleanup of the object by the last referrer
rather than assuming that the tasklet is always the last one.
There is another similar race: Between said tasklet and fwnet_close,
i.e. at ifdown. However, that race is much less likely to occur in
practice and shall be fixed in a separate update.
Reported-by: Илья Басин <basinilya@gmail.com>
Unsurprisingly, Texas Instruments TSB43AB23 exhibits the same behaviour
as TSB43AB22/A in dual buffer IR DMA mode: If descriptors are located
at physical addresses above the 31 bit address range (2 GB), the
controller will overwrite random memory. With luck, this merely
prevents video reception. With only a little less luck, the machine
crashes.
We use the same workaround here as with TSB43AB22/A: Switch off the
dual buffer capability flag and use packet-per-buffer IR DMA instead.
Another possible workaround would be to limit the coherent DMA mask to
31 bits.
In Linux 2.6.33, this change serves effectively only as documentation
since dual buffer mode is not used for any controller anymore. But
somebody might want to re-enable it in the future to make use of
features of dual buffer DMA that are not available in packet-per-buffer
mode.
In Linux 2.6.32 and older, this update is vital for anyone with this
controller, more than 2 GB RAM, a 64 bit kernel, and FireWire video or
audio applications.
We have at least four reports:
http://bugzilla.kernel.org/show_bug.cgi?id=13808
http://marc.info/?l=linux1394-user&m=126154279004083
https://bugzilla.redhat.com/show_bug.cgi?id=552142
http://marc.info/?l=linux1394-user&m=126432246128386
Reported-by: Paul Johnson
Reported-by: Ronneil Camara
Reported-by: G Zornetzer
Reported-by: Mark Thompson
Cc: stable@kernel.org
Commit db5d247a "firewire: fix use of multiple AV/C devices, allow
multiple FCP listeners" introduced a regression into 2.6.33-rc3:
The core freed payloads of incoming requests to FCP_Request or
FCP_Response before a userspace driver accessed them.
We need to copy such payloads for each registered userspace client
and free the copies according to the lifetime rules of non-FCP client
request resources.
(This could possibly be optimized by reference counts instead of
copies.)
The presently only kernelspace driver which listens for FCP requests,
firedtv, was not affected because it already copies FCP frames into an
own buffer before returning to firewire-core's FCP handler dispatcher.
Presently, firewire-core only checks whether descriptors that are to be
added by userspace drivers to the local node's config ROM do not exceed
a size of 256 quadlets. However, the sum of the bare minimum ROM plus
all descriptors (from firewire-core, from firewire-net, from userspace)
must not exceed 256 quadlets.
Otherwise, the bounds of a statically allocated buffer will be
overwritten. If the kernel survives that, firewire-core will
subsequently be unable to parse the local node's config ROM.
(Note, userspace drivers can add descriptors only through device files
of local nodes. These are usually only accessible by root, unlike
device files of remote nodes which may be accessible to lesser
privileged users.)
Therefore add a test which takes the actual present and required ROM
size into account for all descriptors of kernelspace and userspace
drivers.
Update the Kconfig help texts of both stacks to encourage a general move
from the older to the newer drivers. However, do not label ieee1394 as
"Obsolete" yet, as the newer drivers have not been deployed as default
stack in the majority of Linux distributions yet, and those who start
doing so now may still want to install the old drivers as fallback for
unforeseen issues.
Since Linux 2.6.32, FireWire audio devices can be driven by the newer
firewire driver stack too, hence remove an outdated comment about audio
devices. Also remove comments about library versions since the 2nd
generation of libraw1394 and libdc1394 is now in common use; details on
library versions can be read at the wiki link from the help texts.
This is a minimal change meant for the short term: Never set the
ohci->use_dualbuffer flag to true.
There are two reasons to do so:
- Packet-per-buffer mode and dual-buffer mode do not behave the same
under certain circumstances, notably if several packets are covered
by a single fw_cdev_iso_packet descriptor.
http://marc.info/?l=linux1394-devel&m=124965653718313
Therefore the driver stack should not silently choose one or the
other mode but should leave the choice to the high-level driver
(regardless if kernel driver or userspace driver). Or simply always
only offer packet-per-buffer mode, since a considerable number of
controllers, even current ones, does not offer dual-buffer support.
- Even under circumstances where packet-per-buffer mode and
dual-buffer mode behave exactly the same --- notably when used
through libraw1394, libdc1394, as well as the current two kernel
drivers which use isochronous reception (firewire-net and firedtv)
--- we are still faced with the problem that several OHCI 1.1
controllers have bugs in dual-buffer mode. Although it looks like
we have identified most of those buggy controllers by now, we
cannot be quite sure about that.
So, use packet-per-buffer by default from now on. This change should
be followed up by a more complete solution: Either extend the
in-kernel API and the userspace ABI by a choice between the two IR modes
or remove all dual-buffer related code from firewire-ohci.
If copy_from_user in an FW_CDEV_IOC_SEND_RESPONSE ioctl failed, the
fw_request pointed to by the inbound_transaction_resource is no
longer referenced and needs to be freed.
Control of more than one AV/C device at once --- e.g. camcorders, tape
decks, audio devices, TV tuners --- failed or worked only unreliably,
depending on driver implementation. This affected kernelspace and
userspace drivers alike and was caused by firewire-core's inability to
accept multiple registrations of FCP listeners.
The fix allows multiple address handlers to be registered for the FCP
command and response registers. When a request for these registers is
received, all handlers are invoked, and the Firewire response is
generated by the core and not by any handler.
The cdev API does not change, i.e., userspace is still expected to send
a response for FCP requests; this response is silently ignored.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (changelog, rebased, whitespace)
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: ohci: handle receive packets with a data length of zero
Queueing to receive an ISO packet with a payload length of zero
silently does nothing in dualbuffer mode, and crashes the kernel in
packet-per-buffer mode. Return an error in dualbuffer mode, because
the DMA controller won't let us do what we want, and work correctly in
Signed-off-by: Jay Fenlason <fenlason@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
ieee1394: Use hweight32
firewire: cdev: reduce stack usage by ioctl_dispatch
firewire: ohci: 0 may be a valid DMA address
firewire: core: WARN on wrong usage of core transaction functions
firewire: core: optimize Topology Map creation
firewire: core: clarify generate_config_rom usage
firewire: optimize config ROM creation
firewire: cdev: normalize variable names
firewire: normalize style of queue_work wrappers
firewire: cdev: fix memory leak in an error path
kernel/irq/chip.c
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
firewire: ohci: pass correct iso xmit timestamps to core
firewire: ohci: Make cycleMatch ISO transmission work
Here is the final set of patches I used to get ffado to work with the
new firewire stack. With these patches, I was able to start ardour
and record from and playback to my PreSonus Inspire1394 from a
(mostly) Fedora 12 system.
Until now, firewire-ohci exposed only the transmit cycle of the last
transmitted packet at each isochronous transmit complete event. This
made it impossible for FFADO (FireWire audio drivers in userspace) to
synchronize audio-out streams. The fix is to store the timestamp of
each packet in the iso xmit event. As a bonus, the transfer status is
stored too.
Calling the START_ISO ioctl with a nonnegative cycle paramater has
never worked. Last night I got around to figuring out why. Most of
this patch is a big comment explaining why we enable an interrupt
source then don't actually do anything when we get one. As the
comment says, we should do more, but we don't have a way to tell
userspace what happened. . .
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (edited comment)
Replace a hardcoded buffer size by a sizeof union {}. This shrinks the
stack-allocated ioctl argument buffer from 256 to 40 bytes. (This is
not much, but subsequent stack usage particularly by the queue_iso ioctl
handler adds up.)
The new form is also easier to keep up to date than a hardcoded size if
more ioctls are added.
I was told that there are obscure architectures with non-coherent DMA
which may DMA-map to bus address 0. We shall not use 0 as a magic
number of uninitialized bus address variables.
The packet->payload_length > 0 test cannot be used either (except in
at_context_queue_packet) because local requests are not DMA-mapped
regardless of payload_length. Hence add a state flag to struct
fw_packet.
In the code path which creates request packets, clearly mark a switch
branch which must never be reached with a WARN.
In the code path which creates response packets, replace a BUG by a
friendlier to debug WARN.
firewire: sbp2: provide fallback if mgt_ORB_timeout is missing
ieee1394: add documentation entry to MAINTAINERS
ieee1394: update URLs in debugging-via-ohci1394.txt
The Topology Map of the local node was created in CPU byte order,
then a temporary big endian copy was created to compute the CRC,
and when a read request to the Topology Map arrived it had to be
converted to big endian byte order again.
We now generate it in big endian byte order in the first place.
This also rids us of 1000 bytes stack usage in tasklet context.
Move the static config ROM buffer into the scope of the two callers of
generate_config_rom(). That way the ROM length can be passed over as
return value rather than through a pointer argument.
It also becomes more obvious that accesses to the config ROM buffer have
to be serialized and how this is accomplished. And firewire-core.ko
shrinks a bit as well.
The config ROM image of the local node was created in CPU byte order,
then a temporary big endian copy was created to compute the CRC, and
finally the card driver created its own big endian copy.
We now generate it in big endian byte order in the first place to avoid
one byte order conversion and the temporary on-stack copy of the ROM
image (1000 bytes stack usage in process context). Furthermore, two
1000 bytes memset()s are replaced by one 1000 bytes - ROM length sized
memset.
The trivial fw_memcpy_{from,to}_be32() helpers are now superfluous and
removed. The newly added __compute_block_crc() function will be folded
into fw_compute_block_crc() in a subsequent change.
Unify some names:
- "e" for pointers to subtypes of struct event,
- "event" for struct members and pointers to struct event,
- "r" for pointers to subtypes of struct client_resource,
- "resource" for struct members and pointers to struct client_resource,
- other names for struct members and pointers to other types.
A few stylistic changes to unify some code patterns in the subsystem:
- The similar queue_delayed_work helpers fw_schedule_bm_work,
schedule_iso_resource, and sbp2_queue_work now have the same call
convention.
- Two conditional calls of schedule_iso_resource are factored into
another small helper.
- An sbp2_target_get helper is added as counterpart to
sbp2_target_put.
Object size of firewire-core is decreased a little bit, object size of
firewire-sbp2 remains unchanged.
The Unit_Characteristics entry of an SBP-2 unit directory is not
mandatory as far as I can tell. If it is missing, we would probably
fail to log in into the target because firewire-sbp2 would not wait for
status after it sent the login request.
The fix moves the cleanup of tgt->mgt_orb_timeout into a place where it
is executed exactly once before login, rather than 0..n times depending
on the target's config ROM. With targets with one or more
Unit_Characteristics entries, the result is the same as before.
If copy_from_user in an FW_CDEV_IOC_SEND_RESPONSE ioctl failed, an
inbound_transaction_resource instance is no longer referenced and needs
to be freed.
ieee1394: sbp2: remove a workaround for Momobay FX-3A
firewire: sbp2: remove a workaround for Momobay FX-3A
firewire: sbp2: fix status reception
firewire: core: fix topology map response handler
firewire: core: fix race with parallel PCI device probe
firewire: core: header file cleanup
firewire: ohci: fix Self ID Count register mask (safeguard against buffer overflow)
ieee1394: raw1394: Do not leak memory on failed trylock.
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits)
netxen: update copyright
netxen: fix tx timeout recovery
netxen: fix file firmware leak
netxen: improve pci memory access
netxen: change firmware write size
tg3: Fix return ring size breakage
netxen: build fix for INET=n
cdc-phonet: autoconfigure Phonet address
Phonet: back-end for autoconfigured addresses
Phonet: fix netlink address dump error handling
ipv6: Add IFA_F_DADFAILED flag
net: Add DEVTYPE support for Ethernet based devices
mv643xx_eth.c: remove unused txq_set_wrr()
ucc_geth: Fix hangs after switching from full to half duplex
ucc_geth: Rearrange some code to avoid forward declarations
phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs
drivers/net/phy: introduce missing kfree
drivers/net/wan: introduce missing kfree
net: force bridge module(s) to be GPL
Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded
Fixed up trivial conflicts:
- arch/x86/include/asm/socket.h
converted to <asm-generic/socket.h> in the x86 tree. The generic
header has the same new #define's, so that works out fine.
- drivers/net/tun.c
fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that
switched over to using 'tun->socket.sk' instead of the redundantly
available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks
to the TUN driver") which added a new 'tun->sk' use.
Noted in 'next' by Stephen Rothwell.
The inquiry delay does more harm than good in tests on a recent kernel.
Per SBP-2 clause 5.3, a target shall store 8...32 bytes of status
information. Trailing zeros after the first 8 bytes don't need to be
stored, they are implicit. Fix the status write handler to clear all
unwritten status data.
This register is 1 kBytes large. Adjust topology_map.length to prevent
registration of other response handlers in this region and to make sure
that we respond to requests to the upper half of the register.
The config ROM buffer received from generate_config_rom is a globally
shared static buffer. Extend the card_mutex protection in fw_add_card
until after the config ROM was copied into the card driver's buffer.
Otherwise, parallelized card driver probes may end up with ROM contents
that were meant for a different card.
firewire-ohci's card->driver->enable hook is safe to be called within
the card_mutex. Furthermore, it is safe to reorder card_list update
versus card enable, which simplifies the code a little.
fw_card_get, fw_card_put, fw_card_release are currently not exported for
use outside the firewire-core. Move their definitions/ declarations
from the subsystem header file to the core header file.
overflow)
The selfIDSize field of Self ID Count is 9 bits wide, and we are only
interested in the high 8 bits. Fix the mask accordingly. The
previously too large mask didn't do damage though because the next few
bits in the register are reserved and therefore zero with presently
existing hardware.
Also, check for the maximum possible self ID count of 252 (according to
OHCI 1.1 clause 11.2 and IEEE 1394a-2000 clause 4.3.4.1, i.e. up to four
self IDs of up to 63 nodes, even though IEEE 1394 up to edition 2008
defines only up to three self IDs per node). More than 252 self IDs
would only happen if the self ID receive DMA unit malfunctioned, which
would likely be caught by other self ID buffer checks. However, check
it early to be sure. More than 253 quadlets would overflow the Topology
Map CSR.
Reported-By: PaX Team
firewire: sbp2: fix freeing of unallocated memory
firewire: ohci: fix Ricoh R5C832, video reception
firewire: ohci: fix Agere FW643 and multiple cameras
firewire: core: fix crash in iso resource management
If a target writes invalid status (typically status of a command that
already timed out), firewire-sbp2 attempts to put away an ORB that
doesn't exist. https://bugzilla.redhat.com/show_bug.cgi?id=519772
In dual-buffer DMA mode, no video frames are ever received from R5C832
by libdc1394. Fallback to packet-per-buffer DMA works reliably.
http://thread.gmane.org/gmane.linux.kernel.firewire.devel/13393/focus=13476
Reported-by: Jonathan Cameron <jic23@cam.ac.uk>
An Agere FW643 OHCI 1.1 card works fine for video reception from one
camera but fails early if receiving from two cameras. After a short
while, no IR IRQ events occur and the context control register does not
react anymore. This happens regardless whether both IR DMA contexts are
dual-buffer or one is dual-buffer and the other packet-per-buffer.
This can be worked around by disabling dual buffer DMA mode entirely.
http://sourceforge.net/mailarchive/message.php?msg_name=4A7C0594.2020208%40gmail.com
(Reported by Samuel Audet.)
In another report (by Jonathan Cameron), an FW643 works OK with two
cameras in dual buffer mode. Whether this is due to different chip
revisions or different usage patterns (different video formats) is not
yet clear. However, as far as the current capabilities of
firewire-core's isochronous I/O interface are concerned, simply
switching off dual-buffer on non-working and working FW643s alike is not
a problem in practice. We only need to revisit this issue if we are
going to enhance the interface, e.g. so that applications can explicitly
choose modes.
Reported-by: Samuel Audet <samuel.audet@gmail.com>
This fixes a regression due to post 2.6.30 commit "firewire: core: do
not DMA-map stack addresses" 6fdc03709433ccc2005f0f593ae9d9dd04f7b485.
As David Moore noted, a previously correct sizeof() expression became
wrong since the commit changed its argument from an array to a pointer.
This resulted in an oops in ohci_cancel_packet in the shared workqueue
thread's context when an isochronous resource was to be freed.
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Acked-by: Neil Horman <nhorman@txudriver.com>
No need to put ethtool_ops in data, they should be const.
