path: root/drivers/firmware/dell_rbu.c
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-11firmware_class: make request_firmware_nowait more usefulJohannes Berg
Unfortunately, one cannot hold on to the struct firmware that request_firmware_nowait() hands off, which is needed in some cases. Allow this by requiring the callback to free it (via release_firmware). Additionally, give it a gfp_t parameter -- all the current users call it from a GFP_KERNEL context so the GFP_ATOMIC isn't necessary. This also marks an API break which is useful in a sense, although that is obviously not the primary purpose of this change. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: David Woodhouse <David.Woodhouse@intel.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-17dell_rbu: use scnprintf() instead of less secure sprintf()Pavel Roskin
Reading 0 bytes from /sys/devices/platform/dell_rbu/image_type or /sys/devices/platform/dell_rbu/packet_size by an ordinary user causes an oops. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25dell_rbu: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10dell_rbu: firmware data is constGreg Kroah-Hartman
Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-29firmware: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-16[PATCH] dell_rbu: fix error checkAkinobu Mita
platform_device_register_simple() returns error code as pointer when it fails. The return value should be checked by IS_ERR(). Cc: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] firmware/dell_rbu: handle sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] dell_rbu: printk() warning fixAndrew Morton
drivers/firmware/dell_rbu.c: In function 'packetize_data': drivers/firmware/dell_rbu.c:252: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'int' Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] pr_debug: dell_rbu: fix pr_debug argument warningsZach Brown
dell_rbu: fix pr_debug argument warnings Use size_t length modifier when outputting size_t and use %p instead of %lu for 'u8 *'. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] dell_rbu: fix Bug 5854Abhay Salunke
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=5854 Root cause: The dell_rbu driver creates entries in /sys/class/firmware/dell_rbu/ by calling request_firmware_nowait (without hotplug ) this function inturn starts a kernel thread which creates the entries in /sys/class/firmware/dell_rbu/loading , data and the thread waits on the user action to return control back to the callback fucntion of dell_rbu. The thread calls wait_on_completion which puts it in a D state until the user action happens. If there is no user action happening the load average goes up as the thread D state is taken in to account. Also after downloading the BIOS image the enrties go away momentarily but they are recreated from the callback function in dell_rbu. This causes the thread to get recreated causing the load average to permenently stay around 1. Fix: The dell_rbu also creates the entry /sys/devices/platform/dell_rbu/image_type at driver load time. The image type by default is mono if required the user can echo packet to image_type to make the BIOS update mechanism using packets. Also by echoing init in to image_type the /sys/class/firmware/dell_rbu entries can be created. The driver code was changed to not create /sys/class/firmware/dell_rbu entries during load time, and also to not create the above entries from the callback function. The entries are only created by echoing init to /sys/devices/platform/dell_rbu/image_type The user now needs to create the entries to download the image monolithic or packet. This fixes the issue since the kernel thread only is created when ever the user is ready to download the BIOS image; this minimizes the life span of the kernel thread and the load average goes back to normal. Signed off by Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-15[PATCH] dell_rbu: NULL noise removalAl Viro
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] dell_rbu: Adding BIOS memory floor supportAbhay Salunke
This patch has the changes to support the memory floor fix done in Dell BIOS. The BIOS incase of packet update mechanism would not accept packet placed in memory below a cretain address. This address is by default 128K but can change. The driver now can accept the memory floor if the user chooses to make it will try to allocate contiguous physical memory above the memory floor by allocating a set of packets till a valid memory allocation is made. All the allocates then are freed. This repeats for everty packet. This patch was created by Michael E Brown and has been tested on 2.6.14-rc5 Signed-of-by: Michael E Brown <Michael_E_Brown@Dell.com> Signed-off-by: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-11[PATCH] dell_rbu: changes in packet update mechanismAbhay Salunke
In the current dell_rbu code ver 2.0 the packet update mechanism makes the user app dump every individual packet in to the driver. This adds in efficiency as every packet update makes the /sys/class/firmware/dell_rbu/loading and data files to disappear and reappear again. Thus the user app needs to wait for the files to reappear to dump another packet. This slows down the packet update tremendously in case of large number of packets. I am submitting a new patch for dell_rbu which will change the way we do packet updates; In the new method the user app will create a new single file which has already packetized the rbu image and all the packets are now staged in this file. This driver also creates a new entry in /sys/devices/platform/dell_rbu/packet_size ; the user needs to echo the packet size here before downloading the packet file. The user should do the following: create one single file which has all the packets stacked together. echo the packet size in to /sys/devices/platform/dell_rbu/packet_size. echo 1 > /sys/class/firmware/dell_rbu/loading cat the packetfile > /sys/class/firmware/dell_rbu/data echo 0 > /sys/class/firmware/dell_rbu/loading The driver takes the file which came through /sys/class/firmware/dell_rbu/data and takes chunks of paket_size data from it and place in contiguous memory. This makes packet update process very efficient and fast. As all the packet update happens in one single operation. The user can still read back the downloaded file from /sys/devices/platform/dell_rbu/data. Signed-off-by: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] dell_rbu tidyAndrew Morton
Whitespace standardisation. Cc: Abhay Salunke <Abhay_Salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] dell_rbu: enhancements and fixesAbhay Salunke
BUG fixes: The driver used to allocate memory with spinlock held which has been fixed in this patch. The driver was printing the entire buffer when it received a invalid entry in image_type. The fix is to only print a warning message and not the buffer. Usability enhancements: It is possible that due to user error the /sys/class/firmware/dell_rbu entries might be missing, this can happen if the user does the following echo 1 > /sys/class/firmware/dell_rbu/loading echo 0 > /sys/class/firmware/dell_rbu/loading This will make the entries in /sys/class/firmware/ to disappear and the only way get them back was bby unloading and loading the driver. This patch makes the user recreate these entries by echoing init in to image_type. This patch has been tested with Libsmbios and Dell OpenManage. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] dell_rbu: new Dell BIOS update driverAbhay Salunke
Remote BIOS Update driver for updating BIOS images on Dell servers and desktops. See dell_rbu.txt for details. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
