path: root/drivers/firmware/pcdp.h
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2005-07-13[IA64] Make PCDP work again.David Mosberger-Tang
Mark's patch added "attribute((packed))" for pcdp_uart, without accounting for the fact that the structure definition _relied_ on implicit padding by 6 bytes. Fix is to make the padding explicit. Signed-off-by: David Mosberger-Tang <David.Mosberger@acm.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-28[IA64-SGI] pcdp: add PCDP pci interface supportMark Maule
Resend 2 with changes per Bjorn Helgaas comments. Changes from original: + Change globals to vga_console_iobase/vga_console_membase and make them unconditional. + Address style-related comments. Patch to extend the PCDP vga setup code to support PCI io/mem translations for the legacy vga ioport and ram spaces on architectures (e.g. altix) which need them. Summary of the changes: drivers/firmware/pcdp.c drivers/firmware/pcdp.h ----------------------- + add declaration for the spec-defined PCI interface struct (pcdp_if_pci) as well as support macros. + extend setup_vga_console() to know about pcdp_if_pci and add a couple of globals to hold the io and mem translation offsets if present. arch/ia64/kernel/setup.c ------------------------ + tweek early_console_setup() to allow multiple early console setup routines to be called. include/asm-ia64/vga.h ---------------------- + make VGA_MAP_MEM vga_console_membase aware Signed-off-by: Mark Maule <maule@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-23[PATCH] PCDP: handle tables that don't supply baud rateBjorn Helgaas
The HCDP specs (i.e., PCDP revision < 3) allow zero as a default value for baud rate and data bits. So if firmware doesn't supply them, let early_serial_console_init() probe for them rather than telling it the baud rate is zero. Also, update the URL for the PCDP spec. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
