commit df997abeebadaa4824271009e2d2b526a70a11cb upstream.
Add missing break statement in order to prevent the code from falling
through to case ISCSI_BOOT_TGT_NAME, which is unnecessary.
This bug was found thanks to the ongoing efforts to enable
-Wimplicit-fallthrough.
Fixes: b33a84a38477 ("ibft: convert iscsi_ibft module to iscsi boot lib")
Cc: stable@vger.kernel.org
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit f331e766c4be33f4338574f3c9f7f77e98ab4571 upstream.
Calls into UV firmware must be protected against concurrency, expose the
efi_runtime_lock to the UV platform, and use it to serialise UV BIOS
calls.
Signed-off-by: Hedi Berriche <hedi.berriche@hpe.com>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reviewed-by: Russ Anderson <rja@hpe.com>
Reviewed-by: Dimitri Sivanich <sivanich@hpe.com>
Reviewed-by: Mike Travis <mike.travis@hpe.com>
Cc: Andy Shevchenko <andy@infradead.org>
Cc: Bhupesh Sharma <bhsharma@redhat.com>
Cc: Darren Hart <dvhart@infradead.org>
Cc: linux-efi <linux-efi@vger.kernel.org>
Cc: platform-driver-x86@vger.kernel.org
Cc: stable@vger.kernel.org # v4.9+
Cc: Steve Wahl <steve.wahl@hpe.com>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/20190213193413.25560-5-hedi.berriche@hpe.com
[ Upstream commit ab2180a15ce54739fed381efb4cb12e78dfb1561 ]
Since commit:
ce2e6db554fa ("brcmfmac: Add support for getting nvram contents from EFI variables")
we have a device driver accessing the efivars API. Several functions in
the efivars API assume __efivars is set, i.e., that they will be accessed
only after efivars_register() has been called. However, the following NULL
pointer access was reported calling efivar_entry_size() from the brcmfmac
device driver:
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = 60bfa5f1
[00000008] *pgd=00000000
Internal error: Oops: 5 [#1] SMP ARM
Hardware name: NVIDIA Tegra SoC (Flattened Device Tree)
Workqueue: events request_firmware_work_func
PC is at efivar_entry_size+0x28/0x90
LR is at brcmf_fw_complete_request+0x3f8/0x8d4 [brcmfmac]
pc : [<c0c40718>] lr : [<bf2a3ef4>] psr: a00d0113
sp : ede7fe28 ip : ee983410 fp : c1787f30
r10: 00000000 r9 : 00000000 r8 : bf2b2258
r7 : ee983000 r6 : c1604c48 r5 : ede7fe88 r4 : edf337c0
r3 : 00000000 r2 : 00000000 r1 : ede7fe88 r0 : c17712c8
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 10c5387d Table: ad16804a DAC: 00000051
Disassembly showed that the local static variable __efivars is NULL,
which is not entirely unexpected given that it is a non-EFI platform.
So add a NULL pointer check to efivar_entry_size(), and to related
functions while at it. In efivars_register() a couple of sanity checks
are added as well.
Reported-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Eric Snowberg <eric.snowberg@oracle.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Julien Thierry <julien.thierry@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Nathan Chancellor <natechancellor@gmail.com>
Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: YiFei Zhu <zhuyifei1999@gmail.com>
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/20181129171230.18699-9-ard.biesheuvel@linaro.org
(commit b3879a4d3a31ef14265a52e8d941cf4b0f6627ae upstream)
The ARM decompressor is finicky when it comes to uninitialized variables
with local linkage, the reason being that it may relocate .text and .bss
independently when executing from ROM. This is only possible if all
references into .bss from .text are absolute, and this happens to be the
case for references emitted under -fpic to symbols with external linkage,
and so all .bss references must involve symbols with external linkage.
When building the ARM stub using clang, the initialized local variable
__chunk_size is optimized into a zero-initialized flag that indicates
whether chunking is in effect or not. This flag is therefore emitted into
.bss, which triggers the ARM decompressor's diagnostics, resulting in a
failed build.
Under UEFI, we never execute the decompressor from ROM, so the diagnostic
makes little sense here. But we can easily work around the issue by making
__chunk_size global instead.
However, given that the file I/O chunking that is controlled by the
__chunk_size variable is intended to work around known bugs on various
x86 implementations of UEFI, we can simply make the chunking an x86
specific feature. This is an improvement by itself, and also removes the
need to parse the efi= options in the stub entirely.
Tested-by: Arnd Bergmann <arnd@arndb.de>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
Link: http://lkml.kernel.org/r/1486380166-31868-8-git-send-email-ard.biesheuvel@linaro.org
[ Small readability edits. ]
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
(commit 41f1c48420709470c51ee0e54b6fb28b956bb4e0 upstream)
When building with CONFIG_EFI and CONFIG_EFI_STUB on ARM, the libstub
Makefile would use -mno-single-pic-base without checking it was
supported by the compiler. As the ARM (32-bit) clang backend does not
support this flag, the build would fail.
This changes the Makefile to check the compiler's support for
-mno-single-pic-base before using it, similar to c1c386681bd7 ("ARM:
8767/1: add support for building ARM kernel with clang").
Signed-off-by: Alistair Strachan <astrachan@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
[ND: adjusted due to missing commit ce279d374ff3 ("efi/libstub:
Only disable stackleak plugin for arm64")]
[ Upstream commit 33412b8673135b18ea42beb7f5117ed0091798b6 ]
Commit:
3ea86495aef2 ("efi/arm: preserve early mapping of UEFI memory map longer for BGRT")
deferred the unmap of the early mapping of the UEFI memory map to
accommodate the ACPI BGRT code, which looks up the memory type that
backs the BGRT table to validate it against the requirements of the UEFI spec.
Unfortunately, this causes problems on ARM, which does not permit
early mappings to persist after paging_init() is called, resulting
in a WARN() splat. Since we don't support the BGRT table on ARM anway,
let's revert ARM to the old behaviour, which is to take down the
early mapping at the end of efi_init().
Fixes: 3ea86495aef2 ("efi/arm: preserve early mapping of UEFI memory ...")
Link: http://lkml.kernel.org/r/20181114175544.12860-3-ard.biesheuvel@linaro.org
commit 91ee5b21ee026c49e4e7483de69b55b8b47042be upstream.
Clang may emit absolute symbol references when building in non-PIC mode,
even when using the default 'small' code model, which is already mostly
position independent to begin with, due to its use of adrp/add pairs
that have a relative range of +/- 4 GB. The remedy is to pass the -fpie
flag, which can be done safely now that the code has been updated to avoid
GOT indirections (which may be emitted due to the compiler assuming that
the PIC/PIE code may end up in a shared library that is subject to ELF
symbol preemption)
Passing -fpie when building code that needs to execute at an a priori
unknown offset is arguably an improvement in any case, and given that
the recent visibility changes allow the PIC build to pass with GCC as
well, let's add -fpie for all arm64 builds rather than only for Clang.
Tested-by: Matthias Kaehlcke <mka@chromium.org>
Link: http://lkml.kernel.org/r/20170818194947.19347-5-ard.biesheuvel@linaro.org
commit 696204faa6e8a318320ebb49d9fa69bc8275644d upstream.
The build commands for the ARM and arm64 EFI stubs strip the .debug
sections and other sections that may legally contain absolute relocations,
in order to inspect the remaining sections for the presence of such
relocations.
This leaves us without debugging symbols in the stub for no good reason,
considering that these sections are omitted from the kernel binary anyway,
and that these relocations are thus only consumed by users of the ELF
binary, such as debuggers.
So move to 'strip' for performing the relocation check, and if it succeeds,
invoke objcopy as before, but leaving the .debug sections in place. Note
that these sections may refer to ksymtab/kcrctab contents, so leave those
in place as well.
Link: http://lkml.kernel.org/r/1485868902-20401-11-git-send-email-ard.biesheuvel@linaro.org
commit 0426a4e68f18d75515414361de9e3e1445d2644e upstream.
To prevent the compiler from emitting absolute references to the section
markers when running in PIC mode, override the visibility to 'hidden' for
all contents of asm/sections.h
Link: http://lkml.kernel.org/r/20170818194947.19347-4-ard.biesheuvel@linaro.org
[ Upstream commit 61f0d55569463a1af897117ff47d202b0ccb2e24 ]
The following commit:
7e1550b8f208 ("efi: Drop type and attribute checks in efi_mem_desc_lookup()")
refactored the implementation of efi_mem_desc_lookup() so that the type
check is moved to the callers, one of which is the x86 version of
efi_arch_mem_reserve(), where we added a modified check that only takes
EFI_BOOT_SERVICES_DATA regions into account.
This is reasonable, since it is the only memory type that requires this,
but doing so uncovered some unexpected behavior in the ESRT code, which
permits the ESRT table to reside in other types of memory than what the
UEFI spec mandates (i.e., EFI_BOOT_SERVICES_DATA), and unconditionally
calls efi_mem_reserve() on the region in question. This may result in
errors such as
esrt: Reserving ESRT space from 0x000000009c810318 to 0x000000009c810350.
efi: Failed to lookup EFI memory descriptor for 0x000000009c810318
when the ESRT table is not in EFI_BOOT_SERVICES_DATA memory, but we try
to reserve it nonetheless.
So make the call to efi_mem_reserve() conditional on the memory type.
Cc: Peter Jones <pjones@redhat.com>
[ Upstream commit 3ea86495aef2f6de26b7cb1599ba350dd6a0c521 ]
The BGRT code validates the contents of the table against the UEFI
memory map, and so it expects it to be mapped when the code runs.
On ARM, this is currently not the case, since we tear down the early
mapping after efi_init() completes, and only create the permanent
mapping in arm_enable_runtime_services(), which executes as an early
initcall, but still leaves a window where the UEFI memory map is not
mapped.
So move the call to efi_memmap_unmap() from efi_init() to
arm_enable_runtime_services().
[will: fold in EFI_MEMMAP attribute check from Ard]
[ Upstream commit a7770ae194569e96a93c48aceb304edded9cc648 ]
The handling of empty DMI strings looks quite broken to me:
* Strings from 1 to 7 spaces are not considered empty.
* True empty DMI strings (string index set to 0) are not considered
empty, and result in allocating a 0-char string.
* Strings with invalid index also result in allocating a 0-char
string.
* Strings starting with 8 spaces are all considered empty, even if
non-space characters follow (sounds like a weird thing to do, but
I have actually seen occurrences of this in DMI tables before.)
* Strings which are considered empty are reported as 8 spaces,
instead of being actually empty.
Some of these issues are the result of an off-by-one error in memcmp,
the rest is incorrect by design.
So let's get it square: missing strings and strings made of only
spaces, regardless of their length, should be treated as empty and
no memory should be allocated for them. All other strings are
non-empty and should be allocated.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Fixes: 79da4721117f ("x86: fix DMI out of memory problems")
Cc: Parag Warudkar <parag.warudkar@gmail.com>
commit e78eef554a912ef6c1e0bbf97619dafbeae3339f upstream.
Since PSCI 1.0 allows the SMCCC version to be (indirectly) probed,
let's do that at boot time, and expose the version of the calling
convention as part of the psci_ops structure.
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
Tested-by: Greg Hackmann <ghackmann@google.com>
commit 09a8d6d48499f93e2abde691f5800081cd858726 upstream.
In order to call into the firmware to apply workarounds, it is
useful to find out whether we're using HVC or SMC. Let's expose
this through the psci_ops.
commit d68e3ba5303f7e1099f51fdcd155f5263da8569b upstream.
Entry into recent versions of ARM Trusted Firmware will invalidate the CPU
branch predictor state in order to protect against aliasing attacks.
This patch exposes the PSCI "VERSION" function via psci_ops, so that it
can be invoked outside of the PSCI driver where necessary.
[ Upstream commit 822f5845f710e57d7e2df1fd1ee00d6e19d334fe ]
The Intel Compute Stick STCK1A8LFC and Weibu F3C platforms both
log 2 error messages during boot:
efi: requested map not found.
esrt: ESRT header is not in the memory map.
Searching the web, this seems to affect many other platforms too.
Since these messages are logged as errors, they appear on-screen during
the boot process even when using the "quiet" boot parameter used by
distros.
Demote the ESRT error to a warning so that it does not appear on-screen,
and delete the error logging from efi_mem_desc_lookup; both callsites
of that function log more specific messages upon failure.
Out of curiosity I looked closer at the Weibu F3C. There is no entry in
the UEFI-provided memory map which corresponds to the ESRT pointer, but
hacking the code to map it anyway, the ESRT does appear to be valid with
2 entries.
Signed-off-by: Daniel Drake <drake@endlessm.com>
Acked-by: Peter Jones <pjones@redhat.com>
commit 89c5a2d34bda58319e3075e8e7dd727ea25a435c upstream.
The remapping result of memremap() should be freed with memunmap(), not kfree().
Signed-off-by: Pan Bian <bianpan2016@163.com>
Link: http://lkml.kernel.org/r/20171206095010.24170-3-ard.biesheuvel@linaro.org
commit af97a77bc01ce49a466f9d4c0125479e2e2230b6 upstream.
Thanks to the scripts/leaking_addresses.pl script, it was found that
some EFI values should not be readable by non-root users.
So make them root-only, and to do that, add a __ATTR_RO_MODE() macro to
make this easier, and use it in other places at the same time.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Dave Young <dyoung@redhat.com>
Link: http://lkml.kernel.org/r/20171206095010.24170-2-ard.biesheuvel@linaro.org
commit 540f4c0e894f7e46a66dfa424b16424cbdc12c38 upstream.
The UEFI Specification permits Graphics Output Protocol (GOP) instances
without direct framebuffer access. This is indicated in the Mode structure
with a PixelFormat enumeration value of PIXEL_BLT_ONLY. Given that the
kernel does not know how to drive a Blt() only framebuffer (which is only
permitted before ExitBootServices() anyway), we should disregard such
framebuffers when looking for a GOP instance that is suitable for use as
the boot console.
So modify the EFI GOP initialization to not use a PIXEL_BLT_ONLY instance,
preventing attempts later in boot to use an invalid screen_info.lfb_base
address.
Signed-off-by: Eugene Cohen <eugene@hp.com>
[ Moved the Blt() only check into the loop and clarified that Blt() only GOPs are unusable by the kernel. ]
Cc: leif.lindholm@linaro.org
Cc: lorenzo.pieralisi@arm.com
Fixes: 9822504c1fa5 ("efifb: Enable the efi-framebuffer platform driver ...")
Link: http://lkml.kernel.org/r/20170404152744.26687-2-ard.biesheuvel@linaro.org
[ Upstream commit 82bcd087029f6056506ea929f11af02622230901 ]
This patch adds a Qualcomm specific quirk to the arm_smccc_smc call.
On Qualcomm ARM64 platforms, the SMC call can return before it has
completed. If this occurs, the call can be restarted, but it requires
using the returned session ID value from the interrupted SMC call.
The quirk stores off the session ID from the interrupted call in the
quirk structure so that it can be used by the caller.
This patch folds in a fix given by Sricharan R:
https://lkml.org/lkml/2016/9/28/272
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
commit d1eb98143c56f24fef125f5bbed49ae0b52fb7d6 upstream.
On ARM and arm64, we use a dedicated mm_struct to map the UEFI
Runtime Services regions, which allows us to map those regions
on demand, and in a way that is guaranteed to be compatible
with incoming kernels across kexec.
As it turns out, we don't fully initialize the mm_struct in the
same way as process mm_structs are initialized on fork(), which
results in the following crash on ARM if CONFIG_CPUMASK_OFFSTACK=y
is enabled:
EFI Variables Facility v0.08 2004-May-17
Unable to handle kernel NULL pointer dereference at virtual address 00000000
Process swapper/0 (pid: 1)
__memzero()
check_and_switch_context()
virt_efi_get_next_variable()
efivar_init()
efivars_sysfs_init()
do_one_initcall()
This is due to a missing call to mm_init_cpumask(), so add it.
Link: http://lkml.kernel.org/r/1488395154-29786-1-git-send-email-ard.biesheuvel@linaro.org
commit c8f325a59cfc718d13a50fbc746ed9b415c25e92 upstream.
Some AArch64 UEFI implementations disable the MMU in ExitBootServices(),
after which unaligned accesses to RAM are no longer supported.
Commit:
abfb7b686a3e ("efi/libstub/arm*: Pass latest memory map to the kernel")
fixed an issue in the memory map handling of the stub FDT code, but
inadvertently created an issue with such firmware, by moving some
of the FDT manipulation to after the invocation of ExitBootServices().
Given that the stub's libfdt implementation uses the ordinary, accelerated
string functions, which rely on hardware handling of unaligned accesses,
manipulating the FDT with the MMU off may result in alignment faults.
So fix the situation by moving the update_fdt_memmap() call into the
callback function invoked by efi_exit_boot_services() right before it
calls the ExitBootServices() UEFI service (which is arguably a better
place for it anyway)
Note that disabling the MMU in ExitBootServices() is not compliant with
the UEFI spec, and carries great risk due to the fact that switching from
cached to uncached memory accesses halfway through compiler generated code
(i.e., involving a stack) can never be done in a way that is architecturally
safe.
Fixes: abfb7b686a3e ("efi/libstub/arm*: Pass latest memory map to the kernel")
Tested-by: Riku Voipio <riku.voipio@linaro.org>
Cc: mark.rutland@arm.com
Cc: matt@codeblueprint.co.uk
Link: http://lkml.kernel.org/r/1485971102-23330-2-git-send-email-ard.biesheuvel@linaro.org
commit 20b1e22d01a4b0b11d3a1066e9feb04be38607ec upstream.
With the following commit:
4bc9f92e64c8 ("x86/efi-bgrt: Use efi_mem_reserve() to avoid copying image data")
... efi_bgrt_init() calls into the memblock allocator through
efi_mem_reserve() => efi_arch_mem_reserve() *after* mm_init() has been called.
Indeed, KASAN reports a bad read access later on in efi_free_boot_services():
BUG: KASAN: use-after-free in efi_free_boot_services+0xae/0x24c
at addr ffff88022de12740
Read of size 4 by task swapper/0/0
page:ffffea0008b78480 count:0 mapcount:-127
mapping: (null) index:0x1 flags: 0x5fff8000000000()
Call Trace:
dump_stack+0x68/0x9f
kasan_report_error+0x4c8/0x500
kasan_report+0x58/0x60
__asan_load4+0x61/0x80
start_kernel+0x527/0x562
x86_64_start_reservations+0x24/0x26
x86_64_start_kernel+0x157/0x17a
start_cpu+0x5/0x14
The instruction at the given address is the first read from the memmap's
memory, i.e. the read of md->type in efi_free_boot_services().
Note that the writes earlier in efi_arch_mem_reserve() don't splat because
they're done through early_memremap()ed addresses.
So, after memblock is gone, allocations should be done through the "normal"
page allocator. Introduce a helper, efi_memmap_alloc() for this. Use
it from efi_arch_mem_reserve(), efi_free_boot_services() and, for the sake
of consistency, from efi_fake_memmap() as well.
Note that for the latter, the memmap allocations cease to be page aligned.
This isn't needed though.
Tested-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Mika Penttilä <mika.penttila@nextfour.com>
Fixes: 4bc9f92e64c8 ("x86/efi-bgrt: Use efi_mem_reserve() to avoid copying image data")
Link: http://lkml.kernel.org/r/20170105125130.2815-1-nicstange@gmail.com
commit abfb7b686a3e5be27bf81db62f9c5c895b76f5d1 upstream.
As reported by James Morse, the current libstub code involving the
annotated memory map only works somewhat correctly by accident, due
to the fact that a pool allocation happens to be reused immediately,
retaining its former contents on most implementations of the
UEFI boot services.
Instead of juggling memory maps, which makes the code more complex than
it needs to be, simply put placeholder values into the FDT for the memory
map parameters, and only write the actual values after ExitBootServices()
has been called.
Reported-by: James Morse <james.morse@arm.com>
Cc: Jeffrey Hugo <jhugo@codeaurora.org>
Fixes: ed9cc156c42f ("efi/libstub: Use efi_exit_boot_services() in FDT")
Link: http://lkml.kernel.org/r/1482587963-20183-2-git-send-email-ard.biesheuvel@linaro.org
commit a75dcb5848359f488c32c0aef8711d9bd37a77b8 upstream.
We should return -ENOMEM here, instead of success.
Fixes: 475fb4e8b2f4 ("efi / ACPI: load SSTDs from EFI variables")
Link: http://lkml.kernel.org/r/20161018143318.15673-9-matt@codeblueprint.co.uk
When building the ARM kernel with CONFIG_EFI=y, the following build
error may occur when using a less recent version of binutils (2.23 or
older):
STUBCPY drivers/firmware/efi/libstub/lib-sort.stub.o
00000000 R_ARM_ABS32 sort
00000004 R_ARM_ABS32 __ksymtab_strings
drivers/firmware/efi/libstub/lib-sort.stub.o: absolute symbol references not allowed in the EFI stub
(and when building with debug symbols, the list above is much longer, and
contains all the internal references between the .debug sections and the
actual code)
This issue is caused by the fact that objcopy v2.23 or earlier does not
support wildcards in its -R and -j options, which means the following
line from the Makefile:
STUBCOPY_FLAGS-y := -R .debug* -R *ksymtab* -R *kcrctab*
fails to take effect, leaving harmless absolute relocations in the binary
that are indistinguishable from relocations that may cause crashes at
runtime due to the fact that these relocations are resolved at link time
using the virtual address of the kernel, which is always different from
the address at which the EFI firmware loads and invokes the stub.
So, as a workaround, disable debug symbols explicitly when building the
stub for ARM, and strip the ksymtab and kcrctab symbols for the only
exported symbol we currently reuse in the stub, which is 'sort'.
Tested-by: Jon Hunter <jonathanh@nvidia.com>
Link: http://lkml.kernel.org/r/1476805991-7160-2-git-send-email-ard.biesheuvel@linaro.org
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- The Qualcomm external bus interface 2 (EBI2), used in some of their
mobile phone chips for connecting flash memory, LCD displays or
other peripherals
- Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for
the EFUSE based on that firmware interface.
- Perf support for the AppliedMicro X-Gene performance monitor unit
- Reset driver for STMicroelectronics STM32
- Reset driver for SocioNext UniPhier SoCs
Aside from these, there are minor updates to SoC-specific bus,
clocksource, firmware, pinctrl, reset, rtc and pmic drivers"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
bus: qcom-ebi2: depend on HAS_IOMEM
pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181
clk: mvebu: Add clk support for the orion5x SoC mv88f5181
dt-bindings: EXYNOS: Add Exynos5433 PMU compatible
clocksource: exynos_mct: Add the support for ARM64
perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver
Documentation: Add documentation for APM X-Gene SoC PMU DTS binding
MAINTAINERS: Add entry for APM X-Gene SoC PMU driver
bus: qcom: add EBI2 driver
bus: qcom: add EBI2 device tree bindings
rtc: rtc-pm8xxx: Add support for pm8018 rtc
nvmem: amlogic: Add Amlogic Meson EFUSE driver
firmware: Amlogic: Add secure monitor driver
soc: qcom: smd: Reset rx tail rather than tx
memory: atmel-sdramc: fix a possible NULL dereference
reset: hi6220: allow to compile test driver on other architectures
reset: zynq: add driver Kconfig option
reset: sunxi: add driver Kconfig option
reset: stm32: add driver Kconfig option
reset: socfpga: add driver Kconfig option
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull pstore updates from Kees Cook:
- Fix bug in module unloading
- Switch to always using spinlock over cmpxchg
- Explicitly define pstore backend's supported modes
- Remove bounce buffer from pmsg
- Switch to using memcpy_to/fromio()
- Error checking improvements
* tag 'pstore-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
ramoops: move spin_lock_init after kmalloc error checking
pstore/ram: Use memcpy_fromio() to save old buffer
pstore/ram: Use memcpy_toio instead of memcpy
pstore/pmsg: drop bounce buffer
pstore/ram: Set pstore flags dynamically
pstore: Split pstore fragile flags
pstore/core: drop cmpxchg based updates
pstore/ramoops: fixup driver removal
Pull EFI updates from Ingo Molnar:
"Main changes in this cycle were:
- Refactor the EFI memory map code into architecture neutral files
and allow drivers to permanently reserve EFI boot services regions
on x86, as well as ARM/arm64. (Matt Fleming)
- Add ARM support for the EFI ESRT driver. (Ard Biesheuvel)
- Make the EFI runtime services and efivar API interruptible by
swapping spinlocks for semaphores. (Sylvain Chouleur)
- Provide the EFI identity mapping for kexec which allows kexec to
work on SGI/UV platforms with requiring the "noefi" kernel command
line parameter. (Alex Thorlton)
- Add debugfs node to dump EFI page tables on arm64. (Ard Biesheuvel)
- Merge the EFI test driver being carried out of tree until now in
the FWTS project. (Ivan Hu)
- Expand the list of flags for classifying EFI regions as "RAM" on
arm64 so we align with the UEFI spec. (Ard Biesheuvel)
- Optimise out the EFI mixed mode if it's unsupported (CONFIG_X86_32)
or disabled (CONFIG_EFI_MIXED=n) and switch the early EFI boot
services function table for direct calls, alleviating us from
having to maintain the custom function table. (Lukas Wunner)
- Miscellaneous cleanups and fixes"
* 'efi-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits)
x86/efi: Round EFI memmap reservations to EFI_PAGE_SIZE
x86/efi: Allow invocation of arbitrary boot services
x86/efi: Optimize away setup_gop32/64 if unused
x86/efi: Use kmalloc_array() in efi_call_phys_prolog()
efi/arm64: Treat regions with WT/WC set but WB cleared as memory
efi: Add efi_test driver for exporting UEFI runtime service interfaces
x86/efi: Defer efi_esrt_init until after memblock_x86_fill
efi/arm64: Add debugfs node to dump UEFI runtime page tables
x86/efi: Remove unused find_bits() function
fs/efivarfs: Fix double kfree() in error path
x86/efi: Map in physical addresses in efi_map_region_fixed
lib/ucs2_string: Speed up ucs2_utf8size()
firmware-gsmi: Delete an unnecessary check before the function call "dma_pool_destroy"
x86/efi: Initialize status to ensure garbage is not returned on small size
efi: Replace runtime services spinlock with semaphore
efi: Don't use spinlocks for efi vars
efi: Use a file local lock for efivars
efi/arm*: esrt: Add missing call to efi_esrt_init()
efi/esrt: Use memremap not ioremap to access ESRT table in memory
Pull core SMP updates from Ingo Molnar:
"Two main change is generic vCPU pinning and physical CPU SMP-call
support, for Xen to be able to perform certain calls on specific
physical CPUs - by Juergen Gross"
* 'core-smp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
smp: Allocate smp_call_on_cpu() workqueue on stack too
hwmon: Use smp_call_on_cpu() for dell-smm i8k
dcdbas: Make use of smp_call_on_cpu()
xen: Add xen_pin_vcpu() to support calling functions on a dedicated pCPU
smp: Add function to execute a function synchronously on a CPU
virt, sched: Add generic vCPU pinning support
xen: Sync xen header
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into efi/core
Pull EFI fix from Matt Fleming:
* Fix a boot crash reported by Mike Galbraith and Mike Krinkin. The
new EFI memory map reservation code didn't align reservations to
EFI_PAGE_SIZE boundaries causing bogus regions to be inserted into
the global EFI memory map (Matt Fleming)
Mike Galbraith reported that his machine started rebooting during boot
after,
commit 8e80632fb23f ("efi/esrt: Use efi_mem_reserve() and avoid a kmalloc()")
The ESRT table on his machine is 56 bytes and at no point in the
efi_arch_mem_reserve() call path is that size rounded up to
EFI_PAGE_SIZE, nor is the start address on an EFI_PAGE_SIZE boundary.
Since the EFI memory map only deals with whole pages, inserting an EFI
memory region with 56 bytes results in a new entry covering zero
pages, and completely screws up the calculations for the old regions
that were trimmed.
Round all sizes upwards, and start addresses downwards, to the nearest
Additionally, efi_memmap_insert() expects the mem::range::end value to
be one less than the end address for the region.
Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Reported-by: Mike Krinkin <krinkin.m.u@gmail.com>
Tested-by: Mike Krinkin <krinkin.m.u@gmail.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux into next/drivers
Pull "Qualcomm ARM Based Driver Updates for v4.9" from Andy Gross:
* Silence smem probe defer messages
* Make scm explicitly non-modular
* Assorted SMD bug fixes and minor changes
* Add PM8018 RTC support
* tag 'qcom-drivers-for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux:
soc: qcom: smd: Represent smd edges as devices
soc: qcom: smd: Request irqs after parsing properties
soc: qcom: smd: Simplify multi channel handling
soc: qcom: smd: Correct compile stub prototypes
firmware: qcom_scm: make it explicitly non-modular
soc: qcom: smem: Silence probe defer error
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic into next/drivers
Pull "Amlogic drivers for v4.9" from Kevin Hilman:
- add secure monitor and eFuse driver
- add IR remote driver
* tag 'amlogic-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic:
media: rc: meson-ir: Add support for newer versions of the IR decoder
Pull EFI fixes from Ingo Molnar:
"This contains a Xen fix, an arm64 fix and a race condition /
robustization set of fixes related to ExitBootServices() usage and
boundary conditions"
* 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/efi: Use efi_exit_boot_services()
efi/libstub: Introduce ExitBootServices helper
efi/libstub: Allocate headspace in efi_get_memory_map()
efi: Fix handling error value in fdt_find_uefi_params
efi: Make for_each_efi_memory_desc_in_map() cope with running on Xen
Pull EFI updates from Matt Fleming:
"* Refactor the EFI memory map code into architecture neutral files
on x86, as well as ARM/arm64 - Matt Fleming
* Add ARM support for the EFI esrt driver - Ard Biesheuvel
* Make the EFI runtime services and efivar API interruptible by
swapping spinlocks for semaphores - Sylvain Chouleur
* Provide the EFI identity mapping for kexec which allows kexec to
line parameter - Alex Thorlton
* Add debugfs node to dump EFI page tables on arm64 - Ard Biesheuvel
* Merge the EFI test driver being carried out of tree until now in
the FWTS project - Ivan Hu
* Expand the list of flags for classifying EFI regions as "RAM" on
arm64 so we align with the UEFI spec - Ard Biesheuvel
* Optimise out the EFI mixed mode if it's unsupported (CONFIG_X86_32)
having to maintain the custom function table - Lukas Wunner
* Miscellaneous cleanups and fixes"
Currently, memory regions are only recorded in the memblock memory table
if they have the EFI_MEMORY_WB memory type attribute set. In case the
region is of a reserved type, it is also marked as MEMBLOCK_NOMAP, which
will leave it out of the linear mapping.
However, memory regions may legally have the EFI_MEMORY_WT or EFI_MEMORY_WC
attributes set, and the EFI_MEMORY_WB cleared, in which case the region in
question is obviously backed by normal memory, but is not recorded in the
memblock memory table at all. Since it would be useful to be able to
identify any UEFI reported memory region using memblock_is_memory(), it
makes sense to add all memory to the memblock memory table, and simply mark
it as MEMBLOCK_NOMAP if it lacks the EFI_MEMORY_WB attribute.
While implementing this, let's refactor the code slightly to make it easier
to understand: replace is_normal_ram() with is_memory(), and make it return
true for each region that has any of the WB|WT|WC bits set. (This follows
the AArch64 bindings in the UEFI spec, which state that those are the
attributes that map to normal memory)
Also, replace is_reserve_region() with is_usable_memory(), and only invoke
it if the region in question was identified as memory by is_memory() in the
first place. The net result is the same (only reserved regions that are
backed by memory end up in the memblock memory table with the MEMBLOCK_NOMAP
flag set) but carried out in a more straightforward way.
Finally, we remove the trailing asterisk in the EFI debug output. Keeping it
clutters the code, and it serves no real purpose now that we no longer
temporarily reserve BootServices code and data regions like we did in the
early days of EFI support on arm64 Linux (which it inherited from the x86
implementation)
Reviewed-by: Leif Lindholm <leif.lindholm@linaro.org>
Tested-by: James Morse <james.morse@arm.com>
Reviewed-by: James Morse <james.morse@arm.com>
This driver is used by the Firmware Test Suite (FWTS) for testing the UEFI
runtime interfaces readiness of the firmware.
This driver exports UEFI runtime service interfaces into userspace,
which allows to use and test UEFI runtime services provided by the
firmware.
This driver uses the efi.<service> function pointers directly instead of
going through the efivar API to allow for direct testing of the UEFI
runtime service interfaces provided by the firmware.
Details for FWTS are available from,
<https://wiki.ubuntu.com/FirmwareTestSuite>
Signed-off-by: Ivan Hu <ivan.hu@canonical.com>
Cc: joeyli <jlee@suse.com>
Cc: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
Register the debugfs node 'efi_page_tables' to allow the UEFI runtime
page tables to be inspected. Note that ARM does not have 'asm/ptdump.h'
[yet] so for now, this is arm64 only.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
"dma_pool_destroy"
The dma_pool_destroy() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Mike Waychison <mikew@google.com>
Cc: Michel Lespinasse <walken@google.com>
The purpose of the efi_runtime_lock is to prevent concurrent calls into
the firmware. There is no need to use spinlocks here, as long as we ensure
that runtime service invocations from an atomic context (i.e., EFI pstore)
cannot block.
So use a semaphore instead, and use down_trylock() in the nonblocking case.
We don't use a mutex here because the mutex_trylock() function must not
be called from interrupt context, whereas the down_trylock() can.
Cc: Sylvain Chouleur <sylvain.chouleur@gmail.com>
All efivars operations are protected by a spinlock which prevents
interruptions and preemption. This is too restricted, we just need a
lock preventing concurrency.
The idea is to use a semaphore of count 1 and to have two ways of
locking, depending on the context:
- In interrupt context, we call down_trylock(), if it fails we return
an error
- In normal context, we call down_interruptible()
Signed-off-by: Sylvain Chouleur <sylvain.chouleur@intel.com>
This patch replaces the spinlock in the efivars struct with a single lock
for the whole vars.c file. The goal of this lock is to protect concurrent
calls to efi variable services, registering and unregistering. This allows
us to register new efivars operations without having in-progress call.
ESRT support is built by default for all architectures that define
CONFIG_EFI. However, this support was not wired up yet for ARM/arm64,
since efi_esrt_init() was never called. So add the missing call.
On ARM and arm64, ioremap() and memremap() are not interchangeable like
on x86, and the use of ioremap() on ordinary RAM is typically flagged
as an error if the memory region being mapped is also covered by the
linear mapping, since that would lead to aliases with conflicting
cacheability attributes.
Since what we are dealing with is not an I/O region with side effects,
using ioremap() here is arguably incorrect anyway, so let's replace
it with memremap() instead.
We can use the new efi_mem_reserve() API to mark the ESRT table as
reserved forever and save ourselves the trouble of copying the data
out into a kmalloc buffer.
The added advantage is that now the ESRT driver will work across
kexec reboot.
Tested-by: Dave Young <dyoung@redhat.com> [kexec/kdump]
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> [arm]
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Now that efi.memmap is available all of the time there's no need to
allocate and build a separate copy of the EFI memory map.
Furthermore, efi.memmap contains boot services regions but only those
regions that have been reserved via efi_mem_reserve(). Using
efi.memmap allows us to pass boot services across kexec reboot so that
the ESRT and BGRT drivers will now work.
Today, it is not possible for drivers to reserve EFI boot services for
access after efi_free_boot_services() has been called on x86. For
ARM/arm64 it can be done simply by calling memblock_reserve().
Having this ability for all three architectures is desirable for a
couple of reasons,
1) It saves drivers copying data out of those regions
2) kexec reboot can now make use of things like ESRT
Instead of using the standard memblock_reserve() which is insufficient
to reserve the region on x86 (see efi_reserve_boot_services()), a new
API is introduced in this patch; efi_mem_reserve().
efi.memmap now always represents which EFI memory regions are
available. On x86 the EFI boot services regions that have not been
reserved via efi_mem_reserve() will be removed from efi.memmap during
This has implications for kexec, since it is not possible for a newly
kexec'd kernel to access the same boot services regions that the
initial boot kernel had access to unless they are reserved by every
kexec kernel in the chain.
While efi_memmap_init_{early,late}() exist for architecture code to
install memory maps from firmware data and for the virtual memory
regions respectively, drivers don't care which stage of the boot we're
at and just want to swap the existing memmap for a modified one.
efi_memmap_install() abstracts the details of how the new memory map
should be mapped and the existing one unmapped.
