path: root/drivers/firmware
2011-12-15Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft: ibft: Fix finding IBFT ACPI table on UEFI
2011-12-13ibft: Fix finding IBFT ACPI table on UEFIYinghai Lu
Found one system with UEFI/iBFT, kernel does not detect the iBFT during iscsi_ibft module loading. Root cause: on x86 (UEFI), we are calling of find_ibft_region() much earlier - specifically in setup_arch() before ACPI is enabled. Try to split acpi checking code out and call that later At that time ACPI iBFT already get permanent mapped with ioremap. So isa_virt_to_bus() will get wrong phys from right virt address. We could just skip that phys address printing. For legacy one, print the found address early. -v2: update comments and description according to Konrad. -v3: fix problem about module use case that is found by Konrad. -v4: use acpi_get_table() instead of acpi_table_parse() to handle module use case that is found by Konrad again.. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2011-12-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix S3/S4 problem on machines with VREF-pin mute-LED ALSA: hda_intel - revert a quirk that affect VIA chipsets ALSA: hda - Avoid touching mute-VREF pin for IDT codecs firmware: Sigma: Fix endianess issues firmware: Sigma: Skip header during CRC generation firmware: Sigma: Prevent out of bounds memory access ALSA: usb-audio - Support for Roland GAIA SH-01 Synthesizer ASoC: Supply dcs_codes for newer WM1811 revisions ASoC: Error out if we can't generate a LRCLK at all for WM8994 ASoC: Correct name of Speyside Main Speaker widget ASoC: skip resume of soc-audio devices without codecs ASoC: cs42l51: Fix off-by-one for reg_cache_size ASoC: drop support for PlayPaq with WM8510 ASoC: mpc8610: tell the CS4270 codec that it's the master ASoC: cs4720: use snd_soc_cache_sync() ASoC: SAMSUNG: Fix build error ASoC: max9877: Update register if either val or val2 is changed ASoC: Fix wrong define for AD1836_ADC_WORD_OFFSET
2011-11-29firmware: Sigma: Fix endianess issuesLars-Peter Clausen
Currently the SigmaDSP firmware loader only works correctly on little-endian systems. Fix this by using the proper endianess conversion functions. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-11-29firmware: Sigma: Skip header during CRC generationLars-Peter Clausen
The firmware header is not part of the CRC, so skip it. Otherwise the firmware will be rejected due to non-matching CRCs. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-11-29firmware: Sigma: Prevent out of bounds memory accessLars-Peter Clausen
The SigmaDSP firmware loader currently does not perform enough boundary size checks when processing the firmware. As a result it is possible that a malformed firmware can cause an out of bounds memory access. This patch adds checks which ensure that both the action header and the payload are completely inside the firmware data boundaries before processing them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-11-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: efivars: add missing parameter to efi_pstore_read()
2011-11-28efivars: add missing parameter to efi_pstore_read()Christoph Fritz
In the case where CONFIG_PSTORE=n, the function efi_pstore_read() doesn't have the correct list of parameters. This patch provides a definition of efi_pstore_read() with 'char **buf' added to fix this warning: "drivers/firmware/efivars.c:609: warning: initialization from". problem introduced in commit f6f8285132907757ef84ef8dae0a1244b8cde6ac Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: pstore: pass allocated memory region back to caller
2011-11-17pstore: pass allocated memory region back to callerKees Cook
The buf_lock cannot be held while populating the inodes, so make the backend pass forward an allocated and filled buffer instead. This solves the following backtrace. The effect is that "buf" is only ever used to notify the backends that something was written to it, and shouldn't be used in the read path. To replace the buf_lock during the read path, isolate the open/read/close loop with a separate mutex to maintain serialized access to the backend. Note that is is up to the pstore backend to cope if the (*write)() path is called in the middle of the read path. [ 59.691019] BUG: sleeping function called from invalid context at .../mm/slub.c:847 [ 59.691019] in_atomic(): 0, irqs_disabled(): 1, pid: 1819, name: mount [ 59.691019] Pid: 1819, comm: mount Not tainted 3.0.8 #1 [ 59.691019] Call Trace: [ 59.691019] [<810252d5>] __might_sleep+0xc3/0xca [ 59.691019] [<810a26e6>] kmem_cache_alloc+0x32/0xf3 [ 59.691019] [<810b53ac>] ? __d_lookup_rcu+0x6f/0xf4 [ 59.691019] [<810b68b1>] alloc_inode+0x2a/0x64 [ 59.691019] [<810b6903>] new_inode+0x18/0x43 [ 59.691019] [<81142447>] pstore_get_inode.isra.1+0x11/0x98 [ 59.691019] [<81142623>] pstore_mkfile+0xae/0x26f [ 59.691019] [<810a2a66>] ? kmem_cache_free+0x19/0xb1 [ 59.691019] [<8116c821>] ? ida_get_new_above+0x140/0x158 [ 59.691019] [<811708ea>] ? __init_rwsem+0x1e/0x2c [ 59.691019] [<810b67e8>] ? inode_init_always+0x111/0x1b0 [ 59.691019] [<8102127e>] ? should_resched+0xd/0x27 [ 59.691019] [<8137977f>] ? _cond_resched+0xd/0x21 [ 59.691019] [<81142abf>] pstore_get_records+0x52/0xa7 [ 59.691019] [<8114254b>] pstore_fill_super+0x7d/0x91 [ 59.691019] [<810a7ff5>] mount_single+0x46/0x82 [ 59.691019] [<8114231a>] pstore_mount+0x15/0x17 [ 59.691019] [<811424ce>] ? pstore_get_inode.isra.1+0x98/0x98 [ 59.691019] [<810a8199>] mount_fs+0x5a/0x12d [ 59.691019] [<810b9174>] ? alloc_vfsmnt+0xa4/0x14a [ 59.691019] [<810b9474>] vfs_kern_mount+0x4f/0x7d [ 59.691019] [<810b9d7e>] do_kern_mount+0x34/0xb2 [ 59.691019] [<810bb15f>] do_mount+0x5fc/0x64a [ 59.691019] [<810912fb>] ? strndup_user+0x2e/0x3f [ 59.691019] [<810bb3cb>] sys_mount+0x66/0x99 [ 59.691019] [<8137b537>] sysenter_do_call+0x12/0x26 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-11-15drivers/firmware/dmi_scan.c: make dmi_name_in_vendors more focusedJean Delvare
The current implementation of dmi_name_in_vendors() is an invitation to lazy coding and false positives [1]. Searching for a string in 8 know what you're looking for, so you should know where to look. strstr isn't fast, especially when it fails, so we should avoid calling it when it just can't succeed. Looking at the current users of the function, it seems clear to me that they are looking for a system or board vendor name, so let's limit dmi_name_in_vendors to these two DMI fields. This much better matches the function name, BTW. [1] We currently have code looking for short names in DMI data, such as "IBM", "ASUS" or "Acer". I let you guess what will happen the day other vendors ship products named, for example, "SCHREIBMEISTER", "PEGASUS" or "Acerola". Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (45 commits) [SCSI] Fix block queue and elevator memory leak in scsi_alloc_sdev [SCSI] scsi_dh_alua: Fix the time inteval for alua rtpg commands [SCSI] scsi_transport_iscsi: Fix documentation os parameter [SCSI] mv_sas: OCZ RevoDrive3 & zDrive R4 support [SCSI] libfc: improve flogi retries to avoid lport stuck [SCSI] libfc: avoid exchanges collision during lport reset [SCSI] libfc: fix checking FC_TYPE_BLS [SCSI] edd: Treat "XPRS" host bus type the same as "PCI" [SCSI] isci: overriding max_concurr_spinup oem parameter by max(oem, user) [SCSI] isci: revert bcn filtering [SCSI] isci: Fix hard reset timeout conditions. [SCSI] isci: No need to manage the pending reset bit on pending requests. [SCSI] isci: Remove redundant isci_request.ttype field. [SCSI] isci: Fix task management for SMP, SATA and on dev remove. [SCSI] isci: No task_done callbacks in error handler paths. [SCSI] isci: Handle task request timeouts correctly. [SCSI] isci: Fix tag leak in tasks and terminated requests. [SCSI] isci: Immediately fail I/O to removed devices. [SCSI] isci: Lookup device references through requests in completions. [SCSI] ipr: add definitions for additional adapter ...
2011-11-01Merge branch 'pstore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux * 'pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: pstore: make pstore write function return normal success/fail value pstore: change mutex locking to spin_locks pstore: defer inserting OOPS entries into pstore
2011-10-31drivers/firmware: Add module.h to google/gsmi.cPaul Gortmaker
This file really needs the full module.h header file present, but was just getting it implicitly before. Fix it up in advance so we avoid build failures once the cleanup commit is present. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31[SCSI] edd: Treat "XPRS" host bus type the same as "PCI"Michael Chan
PCI Express devices will return "XPRS" host bus type during BIOS EDD call. "XPRS" should be treated just like "PCI" so that the proper pci_dev symlink will be created. Scripts such as fcoe_edd.sh will then work correctly. Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-10-12pstore: make pstore write function return normal success/fail valueChen Gong
Currently pstore write interface employs record id as return value, but it is not enough because it can't tell caller if the write operation is successful. Pass the record id back via an argument pointer and return zero for success, non-zero for failure. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-16pstore: change mutex locking to spin_locksDon Zickus
pstore was using mutex locking to protect read/write access to the backend plug-ins. This causes problems when pstore is executed in an NMI context through panic() -> kmsg_dump(). This patch changes the mutex to a spin_lock_irqsave then also checks to see if we are in an NMI context. If we are in an NMI and can't get the lock, just print a message stating that and blow by the locking. All this is probably a hack around the bigger locking problem but it solves my current situation of trying to sleep in an NMI context. Tested by loading the lkdtm module and executing a HARDLOCKUP which will cause the machine to panic inside the nmi handler. Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-08firmware: fix google/gsmi.c build warningRandy Dunlap
Modify function parameter type to match expected type. Fixes a build warning: drivers/firmware/google/gsmi.c:473: warning: initialization from incompatible pointer type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-02Merge branch 'pstore-efi' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'pstore-efi' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: efivars: fix warnings when CONFIG_PSTORE=n
2011-08-02efivars: fix warnings when CONFIG_PSTORE=nTony Luck
drivers/firmware/efivars.c:161: warning: ‘utf16_strlen’ defined but not used utf16_strlen() is only used inside CONFIG_PSTORE - make this "static inline" to shut the compiler up [thanks to hpa for the suggestion]. drivers/firmware/efivars.c:602: warning: initialization from incompatible pointer type Between v1 and v2 of this patch series we decided to make the "part" number unsigned - but missed fixing the stub version of efi_pstore_write() Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-01Merge branch 'pstore-efi' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'pstore-efi' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: efivars: Introduce PSTORE_EFI_ATTRIBUTES efivars: Use string functions in pstore_write efivars: introduce utf16_strncmp efivars: String functions efi: Add support for using efivars as a pstore backend pstore: Allow the user to explicitly choose a backend pstore: Make "part" unsigned pstore: Add extra context for writes and erases pstore: Extend API for more flexibility in new backends
2011-07-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: updated Documentation/ja_JP/SubmittingPatches debugfs: add documentation for debugfs_create_x64 uio: uio_pdrv_genirq: Add OF support firmware: gsmi: remove sysfs entries when unload the module Documentation/zh_CN: Fix messy code file email-clients.txt driver core: add more help description for "path to uevent helper" driver-core: modify FIRMWARE_IN_KERNEL help message driver-core: Kconfig grammar corrections in firmware configuration DOCUMENTATION: Replace create_device() with device_create(). DOCUMENTATION: Update overview.txt in Doc/driver-model. pti: pti_tty_install documentation mispelling.
2011-07-25drivers/firmware/sigma.c needs MODULE_LICENSERandy Dunlap
Fix module tainting message: sigma: module license 'unspecified' taints kernel. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22efivars: Introduce PSTORE_EFI_ATTRIBUTESMike Waychison
Consolidate the attributes listed for pstore operations in one place, PSTORE_EFI_ATTRIBUTES. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22efivars: Use string functions in pstore_writeMike Waychison
Instead of open-coding the string operations for comparing the prefix of the variable names, use the provided utf16_* string functions. This patch also changes the calls to efi.set_variable to efivars->ops->set_variable so that the right function gets called in the case of gsmi (which doesn't have a valid efi structure). As well, make sure that we only consider variables with the right vendor string. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22efivars: introduce utf16_strncmpMike Waychison
Introduce utf16_strncmp which is used in the next patch. Semantics should be the same as the strncmp C function. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22efivars: String functionsMike Waychison
Fix the string functions in the efivars driver to be called utf16_* instead of utf8_* as the encoding is utf16, not utf8. As well, rename utf16_strlen to utf16_strnlen as it takes a maxlength argument and the name should be consistent with the standard C function names. utf16_strlen is still provided for convenience in a subsequent patch. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22efi: Add support for using efivars as a pstore backendMatthew Garrett
EFI provides an area of nonvolatile storage managed by the firmware. We can use this as a pstore backend to maintain copies of oopses, aiding diagnosis. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-01firmware: gsmi: remove sysfs entries when unload the moduleAxel Lin
This patch removes sysfs entries in gsmi_exit() and gsmi_init() error path. Also move the driver successfully loaded message to the end of gsmi_init() and return proper error if register_efivars() fails. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-29[SCSI] iscsi_ibft, be2iscsi, iscsi_boot: fix boot kobj data lifetime managementMike Christie
be2iscsi passes the boot functions its phba object which is allocated in the shost, but iscsi_ibft passes in a object allocated for each item to display. The problem is that iscsi_boot_sysfs was managing the lifetime of the object passed in and doing a kfree on release. This causes a double free for be2iscsi which frees the shost in its pci_remove. This patch fixes the problem by adding a release callback which the drivers can call kfree or a put() type of function (needed for be2iscsi which will do a get/put on the shost). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-28Merge branch 'driver-core-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Connector: Correctly set the error code in case of success when dispatching receive callbacks Connector: Set the CN_NETLINK_USERS correctly pti: PTI semantics fix in pti_tty_cleanup. pti: ENXIO error case memory leak PTI fix. pti: double-free security PTI fix drivers:misc: ti-st: fix skipping of change remote baud drivers/base/platform.c: don't mark platform_device_register_resndata() as __init_or_module st_kim: Handle case of no device found for ID 0 firmware: fix GOOGLE_SMI kconfig dependency warning
2011-06-09iscsi_ibft: iscsi_ibft_find unused variable iConnor Hansen
int i is only needed if CONFIG_ACPI is set so move it within a new ifdef so kernels without ACPI don't allocate space for nothing. Fixes warning too. Signed-off-by: Connor Hansen <cmdkhh@gmail.com> Signed-off-by: Peter Jones <pjones@redhat.com> [v2: Fixed warning when CONFIG_ACPI was defined] Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2011-06-07firmware: fix GOOGLE_SMI kconfig dependency warningRandy Dunlap
Is it meaningful/useful to enable EFI_VARS but not EFI? That's what GOOGLE_SMI does. Make it enable EFI also. Fixes this kconfig dependency warning: warning: (GOOGLE_SMI) selects EFI_VARS which has unmet direct dependencies (EFI) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits) debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning sysfs: remove "last sysfs file:" line from the oops messages drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION" memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION SYSFS: Fix erroneous comments for sysfs_update_group(). driver core: remove the driver-model structures from the documentation driver core: Add the device driver-model structures to kerneldoc Translated Documentation/email-clients.txt RAW driver: Remove call to kobject_put(). reboot: disable usermodehelper to prevent fs access efivars: prevent oops on unload when efi is not enabled Allow setting of number of raw devices as a module parameter Introduce CONFIG_GOOGLE_FIRMWARE driver: Google Memory Console driver: Google EFI SMI x86: Better comments for get_bios_ebda() x86: get_bios_ebda_length() misc: fix ti-st build issues params.c: Use new strtobool function to process boolean inputs debugfs: move to new strtobool ... Fix up trivial conflicts in fs/debugfs/file.c due to the same patch being applied twice, and an unrelated cleanup nearby.
2011-05-19Merge branches 'x86-reboot-for-linus' and 'x86-setup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Reorder reboot method preferences * 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, setup: Fix EDD3.0 data verification.
2011-05-19Merge branch 'stable/broadcom.ibft' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6 * 'stable/broadcom.ibft' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6: iscsi_ibft: search for broadcom specific ibft sign (v2)
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-06efivars: prevent oops on unload when efi is not enabledRandy Dunlap
efivars_exit() should check for efi_enabled and not undo allocations when efi is not enabled. Otherwise there is an Oops during module unload: calling efivars_init+0x0/0x1000 [efivars] @ 2810 EFI Variables Facility v0.08 2004-May-17 initcall efivars_init+0x0/0x1000 [efivars] returned 0 after 5120 usecs Oops: 0000 [#1] SMP DEBUG_PAGEALLOC last sysfs file: /sys/module/firmware_class/initstate CPU 1 Modules linked in: efivars(-) af_packet tun nfsd lockd nfs_acl auth_rpcgss sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT xt_tcpudp nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables x_tables ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf binfmt_misc dm_mirror dm_region_hash dm_log dm_multipath scsi_dh dm_mod snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep mousedev snd_seq joydev snd_seq_device mac_hid evdev snd_pcm usbkbd usbmouse usbhid snd_timer hid tg3 snd sr_mod pcspkr rtc_cmos soundcore cdrom iTCO_wdt processor sg dcdbas i2c_i801 rtc_core iTCO_vendor_support intel_agp snd_page_alloc thermal_sys rtc_lib intel_gtt 8250_pnp button hwmon unix ide_pci_generic ide_core ata_generic pata_acpi ata_piix sd_mod crc_t10dif ext3 jbd mbcache uhci_hcd ohci_hcd ssb mmc_core pcmcia pcmcia_core firmware_class ehci_hcd usbcore [last unloaded: dell_rbu] Pid: 2812, comm: rmmod Not tainted 2.6.39-rc6 #1 Dell Inc. OptiPlex 745 /0TY565 RIP: 0010:[<ffffffffa06a17f6>] [<ffffffffa06a17f6>] unregister_efivars+0x28/0x12c [efivars] RSP: 0018:ffff88005eedde98 EFLAGS: 00010283 RAX: ffffffffa06a23fc RBX: ffffffffa06a44c0 RCX: ffff88007c227a50 RDX: 0000000000000000 RSI: 00000055ac13db78 RDI: ffffffffa06a44c0 RBP: ffff88005eeddec8 R08: 0000000000000000 R09: ffff88005eeddd78 R10: ffffffffa06a4220 R11: ffff88005eeddd78 R12: fffffffffffff7d0 R13: 00007fff5a3aaec0 R14: 0000000000000000 R15: ffffffffa06a4508 FS: 00007fa8dcc4a6f0(0000) GS:ffff88007c200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000000 CR3: 000000005d148000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 2812, threadinfo ffff88005eedc000, task ffff88006754b000) Stack: ffff88005eeddec8 ffffffffa06a4220 0000000000000000 00007fff5a3aaec0 0000000000000000 0000000000000001 ffff88005eedded8 ffffffffa06a2418 ffff88005eeddf78 ffffffff810d3598 ffffffffa06a4220 0000000000000880 Call Trace: [<ffffffffa06a2418>] efivars_exit+0x1c/0xc04 [efivars] [<ffffffff810d3598>] sys_delete_module+0x2d6/0x368 [<ffffffff812d1db9>] ? lockdep_sys_exit_thunk+0x35/0x67 [<ffffffff810fcba1>] ? audit_syscall_entry+0x172/0x1a5 [<ffffffff81575082>] system_call_fastpath+0x16/0x1b Code: 5c c9 c3 55 48 89 e5 41 57 41 56 41 55 41 54 53 48 83 ec 08 0f 1f 44 00 00 4c 8b 67 48 48 89 fb 4c 8d 7f 48 49 81 ec 30 08 00 00 <4d> 8b ac 24 30 08 00 00 49 81 ed 30 08 00 00 eb 59 48 89 df 48 RIP [<ffffffffa06a17f6>] unregister_efivars+0x28/0x12c [efivars] RSP <ffff88005eedde98> CR2: 0000000000000000 ---[ end trace aa99b99090f70baa ]--- Matt apparently removed such a check in 2004 (with no reason given): * 17 May 2004 - Matt Domsch <Matt_Domsch@dell.com> * remove check for efi_enabled in exit but there have been several changes since then. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mike Waychison <mikew@google.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: <matthew.e.tolentino@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29Introduce CONFIG_GOOGLE_FIRMWAREMike Waychison
In order to keep Google's firmware drivers organized amongst themselves, all Google firmware drivers are gated on CONFIG_GOOGLE_FIRMWARE=y, which defaults to 'n' in the kernel build. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29driver: Google Memory ConsoleMike Waychison
This patch introduces the 'memconsole' driver. Our firmware gives us access to an in-memory log of the firmware's output. This gives us visibility in a data-center of headless machines as to what the firmware is doing. The memory console is found by the driver by finding a header block in the EBDA. The buffer is then copied out, and is exported to userland in the file /sys/firmware/log. Signed-off-by: San Mehat <san@google.com> Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29driver: Google EFI SMIMike Waychison
The "gsmi" driver bridges userland with firmware specific routines for accessing hardware. Currently, this driver only supports NVRAM and eventlog information. Deprecated functions have been removed from the driver, though their op-codes are left in place so that they are not re-used. This driver works by trampolining into the firmware via the smi_command outlined in the FADT table. Three protocols are used due to various limitations over time, but all are included herein. This driver should only ever load on Google boards, identified by either a "Google, Inc." board vendor string in DMI, or "GOOGLE" in the OEM strings of the FADT ACPI table. This logic happens in gsmi_system_valid(). Signed-off-by: Duncan Laurie <dlaurie@google.com> Signed-off-by: Aaron Durbin <adurbin@google.com> Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-27x86, setup: Fix EDD3.0 data verification.Gleb Natapov
Check for nonzero path in edd_has_edd30() has no sense. First, it looks at the wrong memory. Device path starts at offset 30 of the info->params structure which is at offset 8 from the beginning of info structure, but code looks at info + 4 instead. This was correct when code was introduced, but around v2.6.4 three more fields were added to edd_info structure (commit 66b61a5c in history.git). Second, even if it will check correct memory it will always succeed since at offset 30 (params->key) there will be non-zero values otherwise previous check would fail. The patch replaces this bogus check with one that verifies checksum. Signed-off-by: Gleb Natapov <gleb@redhat.com> Link: http://lkml.kernel.org/r/20110426082132.GG2265@redhat.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-19efivars: handle errors from register_efivars()Dan Carpenter
We should unwind and return an error if register_efivars() fails. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19efivars: memory leak on error in create_efivars_bin_attributes()Dan Carpenter
This is a cut and paste bug. We intended to free ->del_var and ->new_var but we only free ->new_var. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14iscsi_ibft: search for broadcom specific ibft sign (v2)Mike Christie
Broadcom iscsi offload firmware uses a non standard ibft sign of "BIFT". When we added support for boot, the anaconda team and I were using older firmware (I guess 4 years old), so boot does not work on current cards. This patch modifies the ibft search code to search for "BIFT" along with the other possible values. Broadcom has tested the patch and reported it works with their firmware. Mike has tested Chelsio and Intel cards. [v2: - Add ACPI_SIG_IBFT to ibft_signs - replace break with goto in find_ibft_in_mem innner loop.] Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
2011-03-22sigma-firmware: loader for Analog Devices' SigmaStudioMike Frysinger
Analog Devices' SigmaStudio can produce firmware blobs for devices with these DSPs embedded (like some audio codecs). Allow these device drivers to easily parse and load them. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
