path: root/drivers/fpga
2019-09-21fpga: altera-ps-spi: Fix getting of optional confd gpioPhil Reid
[ Upstream commit dec43da46f63eb71f519d963ba6832838e4262a3 ] Currently the driver does not handle EPROBE_DEFER for the confd gpio. Use devm_gpiod_get_optional() instead of devm_gpiod_get() and return error codes from altera_ps_probe(). Fixes: 5692fae0742d ("fpga manager: Add altera-ps-spi driver for Altera FPGAs") Signed-off-by: Phil Reid <preid@electromag.com.au> Signed-off-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31fpga-manager: altera-ps-spi: Fix build errorYueHaibing
commit 3d139703d397f6281368047ba7ad1c8bf95aa8ab upstream. If BITREVERSE is m and FPGA_MGR_ALTERA_PS_SPI is y, build fails: drivers/fpga/altera-ps-spi.o: In function `altera_ps_write': altera-ps-spi.c:(.text+0x4ec): undefined reference to `byte_rev_table' Select BITREVERSE to fix this. Reported-by: Hulk Robot <hulkci@huawei.com> Fixes: fcfe18f885f6 ("fpga-manager: altera-ps-spi: use bitrev8x4") Signed-off-by: YueHaibing <yuehaibing@huawei.com> Cc: stable <stable@vger.kernel.org> Acked-by: Moritz Fischer <mdf@kernel.org> Link: https://lore.kernel.org/r/20190708071356.50928-1-yuehaibing@huawei.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-12fpga: altera-cvp: Fix registration for CvP incapable devicesAndreas Puhm
[ Upstream commit 68f60538daa4bc3da5d0764d46f391916fba20fd ] The probe function needs to verify the CvP enable bit in order to properly determine if FPGA Manager functionality can be safely enabled. Fixes: 34d1dc17ce97 ("fpga manager: Add Altera CvP driver") Signed-off-by: Andreas Puhm <puhm@oregano.at> Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Moritz Fischer <mdf@kernel.org> Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-05-01fpga-manager: altera-ps-spi: preserve nCONFIG stateAnatolij Gustschin
commit 881c93c0fb73328845898344208fa0bf0d62cac6 upstream. If the driver module is loaded when FPGA is configured, the FPGA is reset because nconfig is pulled low (low-active gpio inited with GPIOD_OUT_HIGH activates the signal which means setting its value to low). Init nconfig with GPIOD_OUT_LOW to prevent this. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Moritz Fischer <mdf@kernel.org> Cc: stable <stable@vger.kernel.org> # 4.14+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-07fpga: region: release of_parse_phandle nodes after useIan Abbott
commit 0f5eb1545907edeea7672a9c1652c4231150ff22 upstream. Both fpga_region_get_manager() and fpga_region_get_bridges() call of_parse_phandle(), but nothing calls of_node_put() on the returned struct device_node pointers. Make sure to do that to stop their reference counters getting out of whack. Fixes: 0fa20cdfcc1f ("fpga: fpga-region: device tree control for FPGA") Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-19fpga: altera-cvp: remove DRIVER_ATTR() usageGreg Kroah-Hartman
It's better to be explicit and use the DRIVER_ATTR_RW() macro when defining a driver's sysfs file. This is part of a series to drop DRIVER_ATTR() from the tree entirely. Cc: linux-fpga@vger.kernel.org Reviewed-by: Moritz Fischer <mdf@kernel.org> Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-10fpga: altera-hps2fpga: fix multiple init of l3_remap_lockIan Abbott
The global spinlock `l3_remap_lock` is reinitialized every time the "probe" function `alt_fpga_bridge_probe()` is called. It should only be initialized once. Use `DEFINE_SPINLOCK()` to initialize it statically. Fixes: e5f8efa5c8bf ("ARM: socfpga: fpga bridge driver support") Cc: <stable@vger.kernel.org> # 4.10+ Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Reviewed-By: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-10fpga: altera-hps2fpga: add NULL check on of_match_device() return valueGustavo A. R. Silva
Check return value from call to of_match_device() in order to prevent a NULL pointer dereference. In case of NULL print error message and return -ENODEV Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Reviewed-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-10ARM: socfpga: explicitly request exclusive reset controlPhilipp Zabel
Commit a53e35db70d1 ("reset: Ensure drivers are explicit when requesting reset lines") started to transition the reset control request API calls to explicitly state whether the driver needs exclusive or shared reset control behavior. Convert all drivers requesting exclusive resets to the explicit API call so the temporary transition helpers can be removed. No functional changes. Cc: Alan Tull <atull@kernel.org> Cc: Moritz Fischer <moritz.fischer@ettus.com> Cc: linux-fpga@vger.kernel.org Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-By: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-10fpga: Convert to using %pOF instead of full_nameRob Herring
Now that we have a custom printf format specifier, convert users of full_name to use %pOF instead. This is preparation to remove storing of the full path string for each node. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Alan Tull <atull@kernel.org> Cc: Moritz Fischer <moritz.fischer@ettus.com> Cc: linux-fpga@vger.kernel.org Acked-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17fpga manager: Add Altera CvP driverAnatolij Gustschin
Add FPGA manager driver for loading Arria-V/Cyclone-V/Stratix-V and Arria-10 FPGAs via CvP. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17fpga-manager: altera-ps-spi: use bitrev8x4Joshua Clayton
Speed up bit reversal by using hardware bit reversal Add extra code to handle less than 4byte remnants, if any Signed-off-by: Joshua Clayton <stillcompiling@gmail.com> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17fpga manager: Add altera-ps-spi driver for Altera FPGAsJoshua Clayton
altera-ps-spi loads FPGA firmware over SPI, using the "passive serial" interface on Altera Arria 10, Cyclone V or Stratix V FPGAs. This is one of the simpler ways to set up an FPGA at runtime. The signal interface is close to unidirectional SPI with lsb first. Signed-off-by: Joshua Clayton <stillcompiling@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17Make FPGA a menuconfig to ease disabling it allVincent Legoll
No need to get into the submenu to disable all FPGA-related config entries Signed-off-by: Vincent Legoll <vincent.legoll@gmail.com> Acked-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-26fpga fr br: update supported version numbersMatthew Gerlach
The value in the version register of the altera freeze bridge controller changed from the beta value of 2 to the value of 0xad000003 in the official release of the IP. This patch supports the old and new version numbers, and the driver's probe function will fail if neither of the supported versions is found. Signed-off-by: Matthew Gerlach <matthew.gerlach@linux.intel.com> Reviewed-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-26fpga: region: release FPGA region reference in error pathTobias Klauser
If fpga_region_get_manager() fails in fpga_region_program_fpga(), a reference to the fpga_manager instance previously acquired through fpga_region_get() is retained. Make sure to properly release it in the error case by using a separate jump label which will call fpga_region_put() in before returning. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-26fpga altera-hps2fpga: disable/unprepare clock on error in ↵Tobias Klauser
alt_fpga_bridge_probe() If either _alt_hps2fpga_enable_set() or fpga_bridge_register() fail in alt_fpga_bridge_probe(), the clock remains enabled and prepared. Also, in the error path for _alt_hps2fpga_enable_set() a call to fpga_bridge_unregister() is made even though the bridge was not registered yet. Remove the unnecessary call to fpga_bridge_unregister() and call clk_disable_unprepare() in both error paths in order to make sure the clock gets properly disabled and unprepared. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08fpga: Add support for Xilinx LogiCORE PR DecouplerMoritz Fischer
This adds support for the Xilinx LogiCORE PR Decoupler soft-ip that does decoupling of PR regions in the FPGA fabric during partial reconfiguration. Signed-off-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: Sören Brinkmann <soren.brinkmann@xilinx.com> Cc: linux-kernel@vger.kernel.org Cc: devicetree@vger.kernel.org Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08fpga pr ip: Platform driver for Altera Partial Reconfiguration IP.Matthew Gerlach
This adds a platform bus driver for a fpga-mgr driver that uses the Altera Partial Reconfiguration IP component. Signed-off-by: Matthew Gerlach <matthew.gerlach@linux.intel.com> Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08fpga pr ip: Core driver support for Altera Partial Reconfiguration IP.Matthew Gerlach
Adding the core functions necessary for a fpga-mgr driver for the Altera Partial IP component. It is intended for these functions to be used by the various bus implementations like the platform bus or the PCIe bus. Signed-off-by: Matthew Gerlach <matthew.gerlach@linux.intel.com> Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08fpga: add config complete timeoutAlan Tull
Adding timeout for maximum allowed time for FPGA to go to operating mode after a FPGA region has been programmed. Signed-off-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08fpga manager: Add Xilinx slave serial SPI driverAnatolij Gustschin
The driver loads FPGA firmware over SPI, using the "slave serial" configuration interface on Xilinx FPGAs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Moritz Fischer <mdf@kernel.org> Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08fpga: altera_freeze_bridge: Constify opsMoritz Fischer
The ops are not changing, make them const. Signed-off-by: Moritz Fischer <mdf@kernel.org> Cc: Alan Tull <atull@kernel.org> Cc: linux-kernel@vger.kernel.org Cc: linux-fpga@vger.kernel.org Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17fpga: bridge: Replace open-coded list_for_each + list_entryMoritz Fischer
Replaces open-coded list_for_each() + list_entry() with macro list_for_each_entry() Signed-off-by: Moritz Fischer <mdf@kernel.org> Cc: linux-fpga@vger.kernel.org Cc: linux-kernel@vger.kernel.org Acked-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17fpga: Add support for Lattice iCE40 FPGAsJoel Holdsworth
This patch adds support to the FPGA manager for configuring the SRAM of iCE40LM, iCE40LP, iCE40HX, iCE40 Ultra, iCE40 UltraLite and iCE40 UltraPlus devices, through slave SPI. Signed-off-by: Joel Holdsworth <joel@airwebreathe.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17FPGA: Add TS-7300 FPGA managerFlorian Fainelli
Add support for loading bitstreams on the Altera Cyclone II FPGA populated on the TS-7300 board. This is done through the configuration and data registers offered through a memory interface between the EP93xx SoC and the FPGA via an intermediate CPLD device. The EP93xx SoC on the TS-7300 does not have direct means of configuring the on-board FPGA other than by using the special memory mapped interface to the CPLD. No other entity on the system can control the FPGA bitstream. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Alan Tull <atull@opensource.altera.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17fpga: region: Add fpga-region property 'encrypted-fpga-config'Moritz Fischer
Add fpga-region property to allow passing the fact that the bitstream is encrypted to the fpga-region and ultimately to the low-level driver. Signed-off-by: Moritz Fischer <mdf@kernel.org> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17fpga: zynq: Add support for encrypted bitstreamsMoritz Fischer
Add support for encrypted bitstreams. For this to work the system must be booted in secure mode. In order for on-the-fly decryption to work, the PCAP clock rate needs to be lowered via the PCAP_RATE_EN bit. Signed-off-by: Moritz Fischer <mdf@kernel.org> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17fpga: fix sparse warnings in fpga-mgr and fpga-bridgeDinh Nguyen
Fix up these sparse warnings: drivers/fpga/fpga-mgr.c:189:21: warning: symbol '__fpga_mgr_get' was not declared. Should it be static? drivers/fpga/fpga-bridge.c:30:12: warning: symbol 'bridge_list_lock' was not declared. Should it be static? Signed-off-by: Dinh Nguyen <dinguyen@kernel.org> Acked-by: Moritz Fischer <mdf@kernel.org> Signed-off-by: Alan Tull <atull@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-10fpga zynq: Use the scatterlist interfaceJason Gunthorpe
This allows the driver to avoid a high order coherent DMA allocation and memory copy. With this patch it can DMA directly from the kernel pages that the bitfile is stored in. Since this is now a gather DMA operation the driver uses the ISR to feed the chips DMA queue with each entry from the SGL. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-10fpga: Add scatterlist based programmingJason Gunthorpe
Requiring contiguous kernel memory is not a good idea, this is a limited resource and allocation can fail under normal work loads. This introduces a .write_sg op that supporting drivers can provide to DMA directly from dis-contiguous memory and a new entry point fpga_mgr_buf_load_sg that users can call to directly provide page lists. The full matrix of compatibility is provided, either the linear or sg interface can be used by the user with a driver supporting either interface. A notable change for drivers is that the .write op can now be called multiple times. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Alan Tull <atull@opensource.altera.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-10fpga zynq: Check the bitstream for validityJason Gunthorpe
There is no sense in sending a bitstream we know will not work, and with the variety of options for bitstream generation in Xilinx tools it is not terribly clear what the correct input should be. This is particularly important for Zynq since auto-correction was removed from the driver and the Zynq hardware only accepts a bitstream format that is different from what the Xilinx tools typically produce. Worse, the hardware provides no indication why the bitstream fails, it simply times out if the input is wrong. The best option here is to have the kernel print a message informing the user they are using a malformed bistream and programming failure isn't for any of the myriad of other reasons. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-10fpga zynq: Check for errors after completing DMAJason Gunthorpe
The completion did not check the interrupt status to see if any error bits were asserted, check error bits and dump some registers if things went wrong. A few fixes are needed to make this work, the IXR_ERROR_FLAGS_MASK was wrong, it included the done bits, which shows a bug in mask/unmask_irqs which were using the wrong bits, simplify all of this stuff. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-29fpga: Clarify how write_init works streaming modesJason Gunthorpe
This interface was designed for streaming, but write_init's buf argument has an unclear purpose. Define it to be the first bytes of the bitstream. Each driver gets to set how many bytes (at most) it wants to see. Short bitstreams will be passed through as-is, while long ones will be truncated. The intent is to allow drivers to peek at the header before the transfer actually starts. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Alan Tull <atull@opensource.altera.com>
2016-11-29fpga zynq: Fix incorrect ISR state on bootupJason Gunthorpe
It is best practice to clear and mask all interrupts before associating the IRQ, and this should be done after the clock is enabled. This corrects a bad result from zynq_fpga_ops_state on bootup where left over latched values in INT_STS_OFFSET caused it to report an unconfigured FPGA as configured. After this change the boot up operating state for an unconfigured FPGA reports 'unknown'. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Alan Tull <atull@opensource.altera.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
2016-11-29fpga zynq: Remove priv->devJason Gunthorpe
socfpga uses mgr->dev for debug prints, there should be consistency here, so standardize on that. The only other use was for dma which can be replaced with mgr->dev.parent. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Alan Tull <atull@opensource.altera.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
2016-11-29fpga zynq: Add missing \n to messagesJason Gunthorpe
Function dev_err doesn't add a newline at the end of the string. This will lead to a hard to read kernel log. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com> Reviewed-by: Matthias Brugger <mbrugger@suse.com> Acked-by: Alan Tull <atull@opensource.altera.com>
2016-11-29fpga: Add COMPILE_TEST to all driversJason Gunthorpe
Like Zynq the Altera drivers compile fine on x86 and others too, so make it easier to compile test this stuff. A10 requires REGMAP_MMIO to compile, so be explicit rather than relying on it via ARCH_SOCFPGA. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Alan Tull <atull@opensource.altera.com>
2016-11-17ARM: socfpga: checking the wrong variableDan Carpenter
This is a cut and paste bug. We had intended to check "sysmgr". Fixes: e5f8efa5c8bf ("ARM: socfpga: fpga bridge driver support") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10fpga-manager: Add Socfpga Arria10 supportAlan Tull
Add low level driver to support reprogramming FPGAs for Altera SoCFPGA Arria10. Signed-off-by: Alan Tull <atull@opensource.altera.com> Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10fpga: add altera freeze bridge supportAlan Tull
Add a low level driver for Altera Freeze Bridges to the FPGA Bridge framework. A freeze bridge is a bridge that exists in the FPGA fabric to isolate one region of the FPGA from the busses while that one region is being reprogrammed. Signed-off-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Matthew Gerlach <mgerlach@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ARM: socfpga: fpga bridge driver supportAlan Tull
Supports Altera SOCFPGA bridges: * fpga2sdram * fpga2hps * hps2fpga * lwhps2fpga Allows enabling/disabling the bridges through the FPGA Bridge Framework API functions. The fpga2sdram driver only supports enabling and disabling of the ports that been configured early on. This is due to a hardware limitation where the read, write, and command ports on the fpga2sdram bridge can only be reconfigured while there are no transactions to the sdram, i.e. when running out of OCRAM before the kernel boots. Device tree property 'init-val' configures the driver to enable or disable the bridge during probe. If the property does not exist, the driver will leave the bridge in its current state. Signed-off-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Matthew Gerlach <mgerlach@altera.com> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10fpga: fpga-region: device tree control for FPGAAlan Tull
FPGA Regions support programming FPGA under control of the Device Tree. Signed-off-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10fpga: add fpga bridge frameworkAlan Tull
This framework adds API functions for enabling/ disabling FPGA bridges under kernel control. This allows the Linux kernel to disable FPGA bridges during FPGA reprogramming and to enable FPGA bridges when FPGA reprogramming is done. This framework is be manufacturer-agnostic, allowing it to be used in interfaces that use the FPGA Manager Framework to reprogram FPGA's. The functions are: * of_fpga_bridge_get * fpga_bridge_put Get/put an exclusive reference to a FPGA bridge. * fpga_bridge_enable * fpga_bridge_disable Enable/Disable traffic through a bridge. * fpga_bridge_register * fpga_bridge_unregister Register/unregister a device-specific low level FPGA Bridge driver. Get an exclusive reference to a bridge and add it to a list: * fpga_bridge_get_to_list To enable/disable/put a set of bridges that are on a list: * fpga_bridges_enable * fpga_bridges_disable * fpga_bridges_put Signed-off-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10fpga-mgr: add fpga image information structAlan Tull
This patch adds a minor change in the FPGA Manager API to hold information that is specific to an FPGA image file. This change is expected to bring little, if any, pain. The socfpga and zynq drivers are fixed up in this patch. An FPGA image file will have particulars that affect how the image is programmed to the FPGA. One example is that current 'flags' currently has one bit which shows whether the FPGA image was built for full reconfiguration or partial reconfiguration. Another example is timeout values for enabling or disabling the bridges in the FPGA. As the complexity of the FPGA design increases, the bridges in the FPGA may take longer times to enable or disable. This patch adds a new 'struct fpga_image_info', moves the current 'u32 flags' to it. Two other image-specific u32's are added for the bridge enable/disable timeouts. The FPGA Manager API functions are changed, replacing the 'u32 flag' parameter with a pointer to struct fpga_image_info. Subsequent patches fix the existing low level FPGA manager drivers. Signed-off-by: Alan Tull <atull@opensource.altera.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10fpga: add method to get fpga manager from deviceAlan Tull
The intent is to provide a non-DT method of getting ahold of a FPGA manager to do some FPGA programming. This patch refactors of_fpga_mgr_get() to reuse most of it while adding a new method fpga_mgr_get() for getting a pointer to a fpga manager struct, given the device. Signed-off-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-08fpga manager: Add hardware dependency to Zynq driverJean Delvare
The Zynq FPGA manager driver serves no purpose on other architectures so hide it unless build-testing. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Alan Tull <atull@opensource.altera.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Cc: "Sören Brinkmann" <soren.brinkmann@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-04drivers/fpga/Kconfig: fix build failureSudip Mukherjee
While building m32r allmodconfig the build is failing with the error: ERROR: "bad_dma_ops" [drivers/fpga/zynq-fpga.ko] undefined! Xilinx Zynq FPGA is using DMA but there was no dependency while building. Link: http://lkml.kernel.org/r/1464346526-13913-1-git-send-email-sudipm.mukherjee@gmail.com Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Cc: Alan Tull <atull@opensource.altera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-24fpga manager: Fix firmware resource leak on errorTobias Klauser
If fpga_mgr_buf_load() fails, the firmware resource previously allocated by request_firmware() is leaked. Fix it by calling release_firmware() regardless of the return value of fpga_mgr_buf_load(). Found by the Coverity scanner (CID 1339653). Fixes: 6a8c3be7ec8e ("add FPGA manager core") Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Alan Tull <atull@opensource.altera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
