The PMIC device RC5T583 from RICOH supports 8 gpios.
Adding gpio driver for this device to access the pins
control through gpio library.
[grant.likely: slight cosmetic changes]
(Cherry-picked from mainline
e9fe32bcadb8a7a40411d77f168abd45941b049b)
Change-Id: Id11f0dec229a92ce0ddcf606376ff83b6e14ca90
Reviewed-on: http://git-master/r/105885
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6:
gpio_msm: Move Qualcomm MSM v2 gpio driver into drivers
gpio_msm: Move Qualcomm v6 MSM driver into drivers
msm: gpio: Fold register defs into C file
msm: gpiomux: Move public API to public header
msm: gpio: Remove ifdefs on gpio chip registers
msm: gpio: Remove chip-specific register definitions
msm: Remove chip-ifdefs for GPIO io mappings
msm: gpio: Remove unsupported devices
gpio: ab8500: fix MODULE_ALIAS for ab8500
of/gpio: export of_gpio_simple_xlate
git://codeaurora.org/quic/kernel/davidb/linux-msm into gpio/next
drivers/gpio/Kconfig
drivers/gpio/Makefile
Migrate the driver for the v7-based MSM chips into drivers/gpio. The
driver is unchanged, only moved.
Change-Id: I810db5b50b71cdca4e869aa0d0310f7f48781a55
Signed-off-by: David Brown <davidb@codeaurora.org>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Migrate the driver for the v6-based MSM chips into drivers/gpio. The
Change-Id: I03ba597b95b4d62b42da112a8efac88d67aa40f9
TPS65912 has five GPIOs that can be configured for different
purposes.
Signed-off-by: Margarita Olaya Cabrera <magi@slimlogic.co.uk>
Acked-by: Liam Girdwood <lrg@ti.com>
GPIO drivers are getting consolidated into drivers/gpio. While at it,
change the driver name to mpc5200-gpio* to avoid collisions.
DA9052 PMIC has 16 bit GPIO bus for peripheral control.
This patch add support for the GPIO pins on the DA9052.
Signed-off-by: David Dajun Chen <dchen@diasemi.com>
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
As part of the gpio driver consolidation, this patch moves the Tegra driver
into drivers/gpio
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Colin Cross <ccross@android.com>
Sort the gpio makefile and enforce the naming convention gpio-*.c for
gpio drivers.
v2: cleaned up filenames in Kconfig and comment blocks
v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc
The GPIO driver should reside in drivers/gpio.
v3: Change Kconfig option to def_bool y
v2: Make the Kconfig symbol a silent option, dependent on ARCH_EP93XX
GPIO drivers are getting moved to drivers/gpio for cleanup and
consolidation. This patch moves the plat-mxc driver. Follow up
patches will clean it up and make it a fine upstanding gpio driver.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
consolidation. This patch moves the mxs driver. Follow up patches
will clean it up and make it a fine upstanding example of a gpio
driver.
v2: Removed header file entirely and put struct definition directly
into driver. The struct isn't used anywhere else in the kernel.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
gpio/pch_gpio: Support new device ML7223
gpio: make gpio_{request,free}_array gpio array parameter const
GPIO: OMAP: move to drivers/gpio
GPIO: OMAP: move register offset defines into <plat/gpio.h>
gpio: Convert gpio_is_valid to return bool
gpio: Move the s5pc100 GPIO to drivers/gpio
gpio: Move the s5pv210 GPIO to drivers/gpio
gpio: Move the exynos4 GPIO to drivers/gpio
gpio: Move to Samsung common GPIO library to drivers/gpio
gpio/nomadik: add function to read GPIO pull down status
gpio/nomadik: show all pins in debug
gpio: move Nomadik GPIO driver to drivers/gpio
gpio: move U300 GPIO driver to drivers/gpio
langwell_gpio: add runtime pm support
gpio/pca953x: Add support for pca9574 and pca9575 devices
gpio/cs5535: Show explicit dependency between gpio_cs5535 and mfd_cs5535
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into gpio/next
Move OMAP GPIO driver to drivers/gpio. Builds whenever
CONFIG_ARCH_OMAP=y.
Signed-off-by: Kevin Hilman <khilman@ti.com>
The GPIO driver should reside in drivers/gpio/ for better
organization.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Move the Samsung s5pc100 SoC GPIO driver to drivers/gpio
Move the Samsung s5pv210 SoC GPIO driver to drivers/gpio
Move the Samsung Exynos4 series SoCs GPIO driver to drivers/gpio
It's common gpiolib for recent Samsung SoCs. Move to drivers/gpio
This moves the Nomadik GPIO driver out of arch/arm/plat-nomadik
and into the desired location indicated by the subsystem
maintainer.
[grant.likely: squashed with kconfig fixup]
This moves the U300 GPIO driver out of arch/arm/mach-u300 and into
the desired location indicated by the subsystem maintainer.
Allow GPIO_BASIC_MMIO_CORE to be used to provide an accessor library
for implementing GPIO drivers whilst abstracting the register access
detail. Based on a patch from Anton Vorontsov[1] and adapted to allow
bgpio_chip to be embedded in another structure.
Changes since v1:
- Register the gpio_chip in the platform device probe
1. https://lkml.org/lkml/2011/4/19/401
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
The build files for drivers/gpio has some wording and comments
about the directory being reserved exclusively for GPIO expanders
(according to the gpio.txt file these are on external busses) and
this has been false for some time. We already have PL061 and
Xilinx drivers which are in silicon and now I'm moving more
silicon drivers here, so delete this and reword it a bit.
To get rid of port expanders, the free GPIOs of ab8500
can be used. There are 42 GPIO pins. Out of which 16
are interrupt capable.This patch implements 16 virtual
IRQ mapped to 16 interrupt capable AB8500 GPIOs.
Signed-off-by: Bibek Basu <bibek.basu@stericsson.com>
[Renamed header file as per MFD structure]
ML7213 is a companion chip for Intel Atom E6xx series. This driver can be
used for OKI SEMICONDUCTOR ML7213 IOH(Input/Output Hub) which is for
IVI(In-Vehicle Infotainment) use. This driver can access the IOH's GPIO
device.
Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: Marc Zyngier <maz@misterjones.org>
Cc: Linus Walleij <linus.walleij@stericsson.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Rename the tc35892 core/gpio drivers to tc3589x to include
new variants in the same mfd core
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
This is needed for supporting the upcoming VX855 camera and OLPC DCON
drivers, as well as the advanced viafb features on non-OLPC hardware
based on this chip.
Based on earlier work by Harald Welte.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Topcliff PCH is the platform controller hub that is going to be used in
Intel's upcoming general embedded platform. All IO peripherals in
Topcliff PCH are actually devices sitting on AMBA bus. Topcliff PCH has
GPIO I/F. Using this I/F, it is able to access system devices connected
to GPIO.
[akpm@linux-foundation.org: ese DEFINE_PCI_DEVICE_TABLE (per Joe Perches)]
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Tomoya MORINAGA <morinaga526@dsn.okisemi.com>
Cc: Joe Perches <joe@perches.com>
Add support for generic 74x164 serial-in/parallel-out 8-bits shift
register. This driver can be used as a GPIO output expander.
[akpm@linux-foundation.org: remove unused local `refresh']
Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com>
Signed-off-by: Juhos Gabor <juhosg@openwrt.org>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The basic GPIO controllers may be found in various on-board FPGA and ASIC
solutions that are used to control board's switches, LEDs, chip-selects,
Ethernet/USB PHY power, etc.
These controllers may not provide any means of pin setup
(in/out/open drain).
The driver supports:
- 8/16/32/64 bits registers;
- GPIO controllers with clear/set registers;
- GPIO controllers with a single "data" register;
- Big endian bits/GPIOs ordering (mostly used on PowerPC).
Cc: David Brownell <david-b@pacbell.net>
Cc: Samuel Ortiz <sameo@linux.intel.com>,
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add support for the GPIOs on STMPE I/O Expanders.
[l.fu@pengutronix.de: fix set direction input]
[l.fu@pengutronix.de: set GPIO alternate function while requesting]
Acked-by: Luotao Fu <l.fu@pengutronix.de>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Add support for Semtech SX150-series I2C GPIO expanders. Compatible
models include:
8 bits: sx1508q
16 bits: sx1509q
Signed-off-by: Gregory Bean <gbean@codeaurora.org>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Trilok Soni <tsoni@codeaurora.org>
Update Kconfig and Makefile in drivers/gpio to discourage inappropriate
addition of platform-specific code.
[akpm@linux-foundation.org: fix tpyo]
Signed-by: David Brownell <dbrownell@users.sourceforge.net>
Add a GPIO driver to support the GPIOs on the TC35892 I/O Expander.
The Janz VMOD-TTL is a MODULbus daughterboard which fits onto any MODULbus
carrier board. It essentially consists of some various logic and a Zilog
Z8536 CIO Counter/Timer and Parallel IO Unit.
The board must be physically configured with jumpers to enable a user to
drive output signals. I am only interested in outputs, so I have made this
driver as simple as possible. It only supports a very minimal subset of the
features provided by the Z8536 chip.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
This patch adds a new GPIO driver for the RDC321x SoC GPIO controller.
Signed-off-by: Denis Turischev <denis@compulab.co.il>
The WM8994 has 11 GPIO lines.
Add the MAX7300-I2C variant of the MAX7301-SPI version. Both chips share
the same core logic, so the generic part of the in-kernel SPI-driver is
refactored into a generic part. The I2C and SPI specific funtions are
then wrapped into seperate drivers picking up the generic part.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Juergen Beisert <j.beisert@pengutronix.de>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
A GPIO driver for the Timberdale FPGA found on the Intel Atom board
Russellville.
The GPIO driver also has an IRQ-chip to support interrupts on the pins.
Signed-off-by: Richard Röjfors <richard.rojfors@mocean-labs.com>
This creates a CS5535/CS5536 GPIO driver which uses a gpio_chip backend
(allowing GPIO users to use the generic GPIO API if desired) while also
allowing architecture-specific users directly (via the cs5535_gpio_*
functions).
Tested on an OLPC machine. Some Leemotes also use CS5536 (with a mips
cpu), which is why this is in drivers/gpio rather than arch/x86.
Currently, it conflicts with older geode GPIO support; once MFGPT support
is reworked to also be more generic, the older geode code will be removed.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jordan Crouse <jordan@cosmicpenguin.net>
Reviewed-by: Alessandro Zummo <a.zummo@towertech.it>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
The Langwell chip is the IO hub for Intel Moorestown platform which has a
64-pin gpio block device inside. It is exposed as a dedicated PCI device.
We use it to control outside peripheral as well as to do IRQ demuxing.
The gpio block uses MSI to send level type interrupt to IOAPIC.
Signed-off-by: Alek Du <alek.du@intel.com>
