Recent pinctrl discussions concluded that gpiolib APIs
should in fact do whatever is required to mux a GPIO onto
pins.
This change is based on the work done by Stephen Warren in mainline
kernel.
commit 3e215d0a19c2a0c389bd9117573b6dd8e46f96a8
gpio: tegra: Hide tegra_gpio_enable/disable()
Recent pinctrl discussions concluded that gpiolib APIs should in fact do
whatever is required to mux a GPIO onto pins, by calling pinctrl APIs if
required. This change implements this for the Tegra GPIO driver, and removes
calls to the Tegra-specific APIs from drivers and board files.
Change-Id: I482ea5c177cf2ee6fa06ddac48b556f1508efacb
Reviewed-on: http://git-master/r/98466
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
irq_to_gpio is being removed. Replace the only use of that API by
the ARM Tegra sub-architecture.
Upstream v3.2 commit 470080015c1f8bbd15ba1486d5c4bd8a3e7fa79a
Change-Id: I9ba3ed66cc6262f14f1fdcfbb6eee78cfe818f7e
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83537
Reviewed-by: Simone Willett <swillett@nvidia.com>
Upstream v3.2 commit 438a99c078b1bc3c9aebd92e7928f2477311d3e5
Change-Id: I00f9df65565c3b086438818ea29d2337871655a8
Reviewed-on: http://git-master/r/83536
Fixing build warning as
kernel/drivers/gpio/gpio-tegra.c:217:
warning: initialization from incompatible pointer type
Change-Id: Ic03c1711cf93b4ada80adaf1589c6080e6166e90
Reviewed-on: http://git-master/r/83409
gpiolib spits out error messages if the underlying
driver does not implement the set_debounce api.
Add stub api since Tegra does not support
gpio debounce in hardware.
Bug 924471
Change-Id: Iadd4ddb41a3a028edf7d55fccf100c8d4bcb5fa2
Reviewed-on: http://git-master/r/75639
Export tegra_gpio_enable/disable api's to make them available
to loadable kernel modules.
Bug 845065
Change-Id: Ib17bd895fe03ffbf98fbf5e7e5d79dc3ec5f9235
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
GPIO based lp0 wakeup needed to support search for its irq
as well as GPIO bank irq in table. This is implemented
in this change.
lp0 wakeup irq enable using enable_irq_wake needs to be
called in specific drivers. Additionally, in some cases
wake irq needs to be updated in tegra wakeup table.
bug 890309
bug 902114
Change-Id: I983318172ffb020f565763cfe2bb29018223dcd0
Reviewed-on: http://git-master/r/64395
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rffcadeee341a73f2ea6d62e31d507e9a8dce5a0e
Added the range check into tegra_gpio_enable and tegra_gpio_disable
Bug 897387
Reviewed-on: http://git-master/r/62641
(cherry picked from commit 091b3906b2dd64cd58221e7e61a24a57dabad16c)
Change-Id: I9be8129397a1dccbea4a04f6b6ed7d4529bf45c3
Reviewed-on: http://git-master/r/63174
Rebase-Id: Rfaf0efdbc60208a56e4e4f073e3661ad1511694c
Create mapping from gpio to pingroup and set gpio to
normal or tristate
Bug 866633
Reviewed-on: http://git-master/r/56557
(cherry picked from commit 321ded98d41170b9e32d60177c6808492ccdf115)
Change-Id: I3d1b979717f1c6b208af3df0a7dfe603e5272d21
Reviewed-on: http://git-master/r/61120
Tested-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Rebase-Id: R5991c2cbc11aa35345fde7f08c0bfeb306e85e1e
It is possible for GPIO interrupt to occur when registering handler
since set_irq_chained_handler enables GPIO interrupt. Thus
all relevant variables are required to be initialized
before calling set_irq_chained_handler.
Also add initialization of interrupt status register.
Bug 884569
Reviewed-on: http://git-master/r/58218
(cherry picked from commit e03fe4cc1bf06fa6c32c0520e2ba31f009f9301d)
Change-Id: Ic76f95215b61d6e091ae1cfa11522f8af9c3eecd
Reviewed-on: http://git-master/r/60475
Reviewed-by: Daehyoung Ko <dko@nvidia.com>
Tested-by: Daehyoung Ko <dko@nvidia.com>
Rebase-Id: R5340918dccc1a8b1d95c5b629cc985f44d45fb67
Adding api to configure pins in gpio mode with init value before
gpio library is up. This will provide to configure the pins in
initial state and avoid any glitch in pins.
bug 876305
Reviewed-on: http://git-master/r/56630
(cherry picked from commit 9e357b69d25f96c13acb660860bcdf8e0ab0a1ef)
Change-Id: Ia14721c0bf96e1a45561139fdbbf2d995b9a4963
Reviewed-on: http://git-master/r/57265
Rebase-Id: Rc775d23898a6275d633e4474e6cf9b10395697e2
gpio_get_value only supports input pin.
extend the usage for output pin.
Bug 839772
Original-Change-Id: I5a8f5572148afde23e082af18f2e37377ae50bd1
Reviewed-on: http://git-master/r/36758
Tested-by: Seongho Joo <sjoo@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R021e8ff272e4cecd855a574b008dbf8663378970
For Linux 2.6.39, CONFIG_PM_SLEEP is the proper kernel configuration
parameter to use on Tegra for power management, and not CONFIG_PM.
CONFIG_PM does not have the required dependency on CONFIG_SUSPEND
necessary to pull in the CPU suspend/resume functionality used by
Tegra.
Also fixes compilation errors when CONFIG_PM and by implication
CONFIG_PM_SLEEP are not configured.
Change-Id: I8bb380ae7c6b22759bfbc223febc28f585111aad
Reviewed-on: http://git-master/r/40458
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R61d656cd67439aa9f466c381845d7a4685fc8648
Change SOC conditionals to make them more forward-looking.
Original-Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R77c675a1995116098b58f1f775bc7c3cc8722998
The number of gpio bank varies from arch to arch and in
this case, the gpio bank count should not fix to single
arch.
Making the gpio bank count based on number of gpio bank
available in a corresponding architecture.
Original-Change-Id: I16ece8945db519d73c702c8bb832b42cc0bf35fc
Reviewed-on: http://git-master/r/29625
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Rebase-Id: R31dcbc6e0511c4ace85979f059dabdb5b62d4270
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
The interrupt will be acked by the generic irq handler, there is
no need to ack it manually.
Change-Id: I48ffc78d90f7951afcfde849300fcbc0673a876a
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: I5cd5b83eb0a760826fc7443f06cd1e94bba359db
Change-Id: Ifd11daa6eac4ca747aba4a4d98f41270b7055bbb
mach/suspend.h is not used yet, and its functions will be replaced
with syscore ops. Delete it.
Change-Id: I7b32d3514e7f4427c7d5faa97c1954a7a2cc286c
Engineering names are more stable than marketing names. Hence, use them
for Device Tree compatible properties instead.
Add support for decoding gpios from the device tree
Acked-by: Olof Johansson <olof@lixom.net>
As part of the gpio driver consolidation, this patch moves the Tegra driver
into drivers/gpio
Acked-by: Colin Cross <ccross@android.com>
