path: root/drivers/gpio/gpio-tegra.c
2012-04-04gpio: tegra: Iterate over the correct number of banksStephen Warren
When Tegra30 support was added to the Tegra GPIO driver, a few places which iterated over all banks were not converted to use the variable tegra_gpio_bank_count rather than hard-coding the bank count. Fix this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net>
2012-04-04gpio: tegra: fix register address calculations for Tegra30Stephen Warren
Tegra20 and Tegra30 share the same register layout within registers, but the addresses of the registers is a little different. Fix the driver to cope with this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net>
2012-03-28Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO changes for v3.4 from Grant Likely: "Primarily gpio device driver changes with some minor side effects under arch/arm and arch/x86. Also includes a few core changes such as explicitly supporting (electrical) open source and open drain outputs and some help for parsing gpio devicetree properties." Fix up context conflict due to Laxman Dewangan adding sleep control for the tps65910 driver separately for gpio's and regulators. * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) gpio/ep93xx: Remove unused inline function and useless pr_err message gpio/sodaville: Mark broken due to core irqdomain migration gpio/omap: fix redundant decoding of gpio offset gpio/omap: fix incorrect update to context.irqenable1 gpio/omap: fix incorrect context restore logic in omap_gpio_runtime_* gpio/omap: fix missing dataout context save in _set_gpio_dataout_reg gpio/omap: fix _set_gpio_irqenable implementation gpio/omap: fix trigger type to unsigned gpio/omap: fix wakeup_en register update in _set_gpio_wakeup() gpio: tegra: tegra_gpio_config shouldn't be __init gpio/davinci: fix enabling unbanked GPIO IRQs gpio/davinci: fix oops on unbanked gpio irq request gpio/omap: Fix section warning for omap_mpuio_alloc_gc() ARM: tegra: export tegra_gpio_{en,dis}able gpio/gpio-stmpe: Fix the value returned by _get_value routine Documentation/gpio.txt: Explain expected pinctrl interaction GPIO: LPC32xx: Add output reading to GPO P3 GPIO: LPC32xx: Fix missing bit selection mask gpio/omap: fix wakeups on level-triggered GPIOs gpio/omap: Fix IRQ handling for SPARSE_IRQ ...
2012-03-19gpio: tegra: tegra_gpio_config shouldn't be __initStephen Warren
This function is called from non-__init context, just like tegra_gpio_enable()/disable(). Remove the __init annotation to avoid section mismatch warnings during compile. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-12ARM: tegra: export tegra_gpio_{en,dis}ableArnd Bergmann
These two functions are used in drivers that can be modules, so they need to be exported. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alan Ott <alan@signal11.us> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-02-26gpio: tegra: Fix build issue due to irq_domain rework.Stephen Warren
Commit 7da5a66 "irq_domain: Remove 'new' irq_domain in favour of the ppc one" changed the set of available irq domain APIs. Update the Tegra GPIO driver to account for those changes, to solve a build break. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06gpio: tegra: Parameterize the number of banksStephen Warren
Tegra20's GPIO controller has 7 banks, and Tegra30's controller has 8 banks. Allow the number of banks to be configured at run-time by the device tree. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06gpio: tegra: Dynamically allocate IRQ base, and support DTStephen Warren
Enhance the driver to dynamically allocate the base IRQ number, and create an IRQ domain for itself. The use of an IRQ domain ensures that any device tree node interrupts properties are correctly parsed. Describe interrupt-related properties in the device tree binding docs, and the contents of "child" node interrupts property. Update tegra*.dtsi to specify the required interrupt-related properties. Finally, remove the definition of TEGRA_GPIO_TO_IRQ; this macro no longer gives correct results since the IRQ numbers for GPIOs are dynamically allocated. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-01-02drivers/gpio/gpio-tegra.c: use devm_request_and_ioremapJulia Lawall
Reimplement a call to devm_request_mem_region followed by a call to ioremap or ioremap_nocache by a call to devm_request_and_ioremap. The semantic patch that makes this transformation is as follows: (http://coccinelle.lip6.fr/) // <smpl> @nm@ expression myname; identifier i; @@ struct platform_driver i = { .driver = { .name = myname } }; @@ expression dev,res,size; expression nm.myname; @@ -if (!devm_request_mem_region(dev, res->start, size, - \(res->name\|dev_name(dev)\|myname\))) { - ... - return ...; -} ... when != res->start ( -devm_ioremap(dev,res->start,size) +devm_request_and_ioremap(dev,res) | -devm_ioremap_nocache(dev,res->start,size) +devm_request_and_ioremap(dev,res) ) ... when any when != res->start // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-31Merge branch 'depends/rmk/gpio' into next/develArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/gpio.h arch/arm/plat-mxc/include/mach/gpio.h Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-13gpio/tegra: Convert to a platform deviceStephen Warren
v3: Make regs variable static. Remove empty init of tegra_gpio_banks. v2: Retrieve IRQ and memory addresses from resources instead of hard- coding them. Add back initialization of tegra_gpio_chip.of_node. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> [olof: switched probe routine to __devinit] Signed-off-by: Olof Johansson <olof@lixom.net>
2011-09-27ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h>Stephen Warren
This will eventually allow <mach/gpio.h> to be deleted. This mirrors LinusW's recent equivalent work on various other ARM platforms. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-24ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irqStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-24ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpioStephen Warren
irq_to_gpio is being removed. Replace the only use of that API by the ARM Tegra sub-architecture. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-05gpio/tegra: Use engineering names in DT compatible propertyStephen Warren
Engineering names are more stable than marketing names. Hence, use them for Device Tree compatible properties instead. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-15gpio/tegra: add devicetree supportGrant Likely
Add support for decoding gpios from the device tree Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Olof Johansson <olof@lixom.net>
2011-06-15gpio/tegra: Move Tegra gpio driver to drivers/gpioGrant Likely
As part of the gpio driver consolidation, this patch moves the Tegra driver into drivers/gpio Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Colin Cross <ccross@android.com>
