path: root/drivers/gpio/gpiolib.c
2008-05-24gpiolib: fix off by one errorsTrent Piepho
The last gpio belonging to a chip is chip->base + chip->ngpios - 1. Some places in the code, but not all, forgot the critical minus one. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30drivers: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gpiochip_reserve()Anton Vorontsov
Add a new function gpiochip_reserve() to reserve ranges of gpios that platform code has pre-allocated. That is, this marks gpio numbers which will be claimed by drivers that haven't yet been loaded, and thus are not available for dynamic gpio number allocation. [akpm@linux-foundation.org: remove unneeded __must_check] [david-b@pacbell.net: don't export gpiochip_reserve (section fix)] Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gpiolib: dynamic gpio number allocationAnton Vorontsov
If gpio_chip->base is negative during registration, gpiolib performs dynamic base allocation. This is useful for devices that aren't always present, such as GPIOs on hotplugged devices rather than mainboards. (This behavior was previously specified but not implemented.) To avoid using any numbers that may have been explicitly assigned but not yet registered, this dynamic allocation assigns GPIO numbers from the biggest number on down, instead of from the smallest on up. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gpio: define gpio_is_valid()Guennadi Liakhovetski
Introduce a gpio_is_valid() predicate; use it in gpiolib. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> [ use inline function; follow the gpio_* naming convention; work without gpiolib; all programming interfaces need docs ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gpiolib: better rmmod infrastructureGuennadi Liakhovetski
As long as one or more GPIOs on a gpio chip are used its driver should not be unloaded. The existing mechanism (gpiochip_remove failure) doesn't address that, since rmmod can no longer be made to fail by having the cleanup code report errors. Module usecounts are the solution. Assuming standard "initialize struct to zero" policies, this change won't affect SOC platform drivers. However, drivers for external chips (on I2C and SPI busses) should be updated if they can be built as modules. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> [ gpio_ensure_requested() needs to update module usecounts too ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05gpiolib: add gpio provider infrastructureDavid Brownell
Provide new implementation infrastructure that platforms may choose to use when implementing the GPIO programming interface. Platforms can update their GPIO support to use this. In many cases the incremental cost to access a non-inlined GPIO should be less than a dozen instructions, with the memory cost being about a page (total) of extra data and code. The upside is: * Providing two features which were "want to have (but OK to defer)" when GPIO interfaces were first discussed in November 2006: - A "struct gpio_chip" to plug in GPIOs that aren't directly supported by SOC platforms, but come from FPGAs or other multifunction devices using conventional device registers (like UCB-1x00 or SM501 GPIOs, and southbridges in PCs with more open specs than usual). - Full support for message-based GPIO expanders, where registers are accessed through sleeping I/O calls. Previous support for these "cansleep" calls was just stubs. (One example: the widely used pcf8574 I2C chips, with 8 GPIOs each.) * Including a non-stub implementation of the gpio_{request,free}() calls, making those calls much more useful. The diagnostic labels are also recorded given DEBUG_FS, so /sys/kernel/debug/gpio can show a snapshot of all GPIOs known to this infrastructure. The driver programming interfaces introduced in 2.6.21 do not change at all; this infrastructure is entirely below those covers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
