path: root/drivers/gpio/pca953x.c
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio/pca953x.c: Interrupt pin is active-lowDavid Jander
The interrupt pin of the PCA953x is active low, and on the rising edge no interrupt should be produced. Signed-off-by: David Jander <david@protonic.nl> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26gpio/pca953x: Add support for pca9574 and pca9575 devicesHaojian Zhuang
PCA957x is i2c gpio expander, and similar to PCA953x. Although register configurations are different between PCA957x and PCA953x. They can share a lot of components, such as IRQ handling, GPIO IN/OUT. So updating PCA953x driver to support PCA957x chips. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20gpio/pca953x: Use handle_simple_irq instead of handle_edge_irqErik Botö
Make pca953x driver use the simple irq handler since no hardware control is necessary and the driver lacks an irq_ack function. handle_edge_irq() calls chip->irq_ack() which crashes since this function does not exist. Signed-off-by: Erik Botö <erik.boto@pelagicore.com> Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-30gpio/pca953x: fix error handling path in probe() callBen Dooks
If the device fails to respond, then the error path tries to remove an interrupt that never got registered, which causes an backtrace from the interrupt handling code. Fix this by ensuring that the cleanup path has two labels and use the correct path as needed. fixes the following error: WARNING: at kernel/irq/manage.c:908 __free_irq+0x80/0x160() Trying to free already-free IRQ 0 Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-25gpio: Cleanup genirq namespaceThomas Gleixner
Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> LKML-Reference: <20110324212509.025730689@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-12Merge commit 'v2.6.38-rc8' into spi/nextGrant Likely
Conflicts: drivers/spi/pxa2xx_spi_pci.c
2011-02-24gpio/pca953x: Fix wrong pointer typeDirk Eibach
pca953x_get_alt_pdata() uses uint16_t* as result type for of_get_property(), but numeric of values are __be32. Checking for negative values is bogus because of-property values are unsigned by definition. Instead check for proper property size. v3: - assume big-endian properties - check property size v2: - removed bogus check for negative property values Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-11drivers/gpio/pca953x.c: add a mutex to fix race conditionRoland Stigge
Add a mutex to register communication and handling. Without the mutex, GPIOs didn't switch as expected when toggled in a fast sequence of status changes of multiple outputs. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Marc Zyngier <maz@misterjones.org> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13gpio: pca953x: irq_data conversionLennert Buytenhek
Converts irq_chips and flow handlers over to the new struct irq_data based irq_chip functions. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Cc: Alek Du <alek.du@intel.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26pca953x: pca953x driver fixes for x86 mrstAlek Du
Our Moorestown platform has two max7315 chips which is covered by pca953x i2c gpio driver. A while ago this driver got updated with nested irq thread support, and it broke the compatibity with "request_irq". For example, the gpio_keys.c driver can not work with this driver now. This patch fixes the issue by switching to generic_handle_irq. Also fix the irq_base issue: irq_base == 0 is valid, and a "-1" value should mean invalid. IRQ 0 is not a valid IRQ, irq_base of 0 is valid. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpiolib: make names array and its values constUwe Kleine-König
gpiolib doesn't need to modify the names and I assume most initializers use string constants that shouldn't be modified anyhow. [akpm@linux-foundation.org: fix drivers/gpio/cs5535-gpio.c] Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Kevin Wells <kevin.wells@nxp.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-27gpio: fix pca953x set_type 'scheduling while atomic' bugMarc Zyngier
Bill Gatliff reported the following bug when using the irq_chip facility of the pca953x driver on a PPC platform: BUG: scheduling while atomic: insmod/1530/0x00000002 He traced it back to an i2c transaction in pca953x_irq_set_type(), which can be called with interrupt disabled (from __setup_irq()). As the i2c controller can sleep while sending a message, this qualifies as a bad idea. This patch moves the i2c transaction to pca953x_irq_bus_sync_unlock(), where it is actually safe to send an i2c message. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Marc Zyngier <maz@misterjones.org> Reported-by: Bill Gatliff <bgat@billgatliff.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06gpio: pca953x.c: add interrupt handling capabilityMarc Zyngier
Most of the GPIO expanders controlled by the pca953x driver are able to report changes on the input pins through an *INT pin. This patch implements the irq_chip functionality (edge detection only). The driver has been tested on an Arcom Zeus. [akpm@linux-foundation.org: the compiler does inlining for us nowadays] Signed-off-by: Marc Zyngier <maz@misterjones.org> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Nate Case <ncase@xes-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23gpio: include <linux/gpio.h> not <asm/gpio.h>H Hartley Sweeten
Drivers should be including <linux/gpio.h> not <asm/gpio.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23gpio: pca953x: add support for MAX7315Alek Du
MAX7315 is pin and software compatible with PCA9534, so add it to the I2C device ID table of pca953x driver. http://www.datasheetcatalog.org/datasheet/maxim/MAX7315.pdf Signed-off-by: Alek Du <alek.du@intel.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18gpio: pca953x: Add support for PCA9556Nate Case
PCA9556 is the software-compatible predecessor to the PCA9557, so add it to the supported I2C device ID table. Signed-off-by: Nate Case <ncase@xes-inc.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18gpio: pca953x: Get platform_data from OpenFirmwareNate Case
On OpenFirmware platforms, it makes the most sense to get platform_data from the device tree. Make an attempt to translate OF node properties into platform_data struct before bailing out. Note that the implementation approach taken differs from other device drivers that make use of device tree information. This is because I2C chips are already registered automatically by of_i2c, so we can get by with a small translator function in the driver. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: kfree(NULL) is legal] Signed-off-by: Nate Case <ncase@xes-inc.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18pca953x: support GPIOLIB GPIO namingDaniel Silverstone
Add support to the PCA953x driver to use the GPIOLIB naming facility for GPIOs. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> Cc: Ben Gardner <bgardner@wabtec.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15gpio: fix probe() error return in gpio driver probesBen Dooks
A number of drivers in drivers/gpio return -ENODEV when confronted with missing setup parameters such as the platform data. However, returning -ENODEV causes the driver layer to silently ignore the driver as it assumes the probe did not find anything and was only speculative. To make life easier to discern why a driver is not being attached, change to returning -EINVAL, which is a better description of the fact that the driver data was not valid. Also add a set of dev_dbg() statements to the error paths to provide an better explanation of the error as there may be more that one point in the driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06gpio: pca953x handles more chips, i2c fault codesDavid Brownell
Minor updates to the pca953x GPIO expander driver: handle several more compatible parts, and stop assuming that the I2C layer's return codes are garbage (that's now been fixed). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Eric Miao <eric.miao@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio: i2c expanders use subsys_initDavid Brownell
Make the I2C external GPIO expander drivers register themselves at subsys_initcall() time when they're statically linked. SOC-integrated GPIOs are available starting very early -- early in arch_initcall() at latest, but often even before initcalls start to run -- so this improves consistency, so more subsystems can rely on GPIOs in their own subsys_initcall() code. (This isn't a theoretical problem. This is one of several patches needed to resolve oopsing observed when statically linking kernels on a DaVinci EVM. Its pcf857x GPIOs needed to be available well before some other drivers initialized.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: sysfs interfaceDavid Brownell
This adds a simple sysfs interface for GPIOs. /sys/class/gpio /export ... asks the kernel to export a GPIO to userspace /unexport ... to return a GPIO to the kernel /gpioN ... for each exported GPIO #N /value ... always readable, writes fail for input GPIOs /direction ... r/w as: in, out (default low); write high, low /gpiochipN ... for each gpiochip; #N is its first GPIO /base ... (r/o) same as N /label ... (r/o) descriptive, not necessarily unique /ngpio ... (r/o) number of GPIOs; numbered N .. N+(ngpio - 1) GPIOs claimed by kernel code may be exported by its owner using a new gpio_export() call, which should be most useful for driver debugging. Such exports may optionally be done without a "direction" attribute. Userspace may ask to take over a GPIO by writing to a sysfs control file, helping to cope with incomplete board support or other "one-off" requirements that don't merit full kernel support: echo 23 > /sys/class/gpio/export ... will gpio_request(23, "sysfs") and gpio_export(23); use /sys/class/gpio/gpio-23/direction to (re)configure it, when that GPIO can be used as both input and output. echo 23 > /sys/class/gpio/unexport ... will gpio_free(23), when it was exported as above The extra D-space footprint is a few hundred bytes, except for the sysfs resources associated with each exported GPIO. The additional I-space footprint is about two thirds of the current size of gpiolib (!). Since no /dev node creation is involved, no "udev" support is needed. Related changes: * This adds a device pointer to "struct gpio_chip". When GPIO providers initialize that, sysfs gpio class devices become children of that device instead of being "virtual" devices. * The (few) gpio_chip providers which have such a device node have been updated. * Some gpio_chip drivers also needed to update their module "owner" field ... for which missing kerneldoc was added. * Some gpio_chips don't support input GPIOs. Those GPIOs are now flagged appropriately when the chip is registered. Based on previous patches, and discussion both on and off LKML. A Documentation/ABI/testing/sysfs-gpio update is ready to submit once this merges to mainline. [akpm@linux-foundation.org: a few maintenance build fixes] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04gpio: pca953x (i2c) handles max7310 tooDavid Brownell
The pca953x driver can handle another 8-bit I/O expander, the max7310. This patch adds that chip to the list of supported IDs in that driver, and expands the Kconfig helptext accordingly. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: pca953x driver handles pca9554 tooDavid Brownell
Teach drivers/gpio/pca953x.c about PCA9554, another compatible chip. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01gpio: pca953x: add support for pca9555 I2C I/O expanderWill Newton
Add support for pca9555 I2C I/O expander. As the comment suggests this part is software compatible with the pca9539. Signed-off-by: Will Newton <will.newton@imgtec.com> Cc: "eric miao" <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-28gpiolib: i2c/spi drivers: handle rmmod betterGuennadi Liakhovetski
Use the newly introduced owner field in struct gpio_chip to protect the current (small) set of non-SOC GPIO drivers from being unloaded while any of their GPIOs are in use. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> [ add mcp23s08 and pcf857x ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10gpio/pca953x bugfix: mark as can_sleepArnaud Patard
The pca953x driver is an I2C driver so gpio_chip->can_sleep should be set. This lets upper layers know they should use the gpio_*_cansleep() calls to access values, and may not access them from nonsleeping contexts. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: "eric miao" <eric.y.miao@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: handle pca953{4,5,6,7,8} tooGuennadi Liakhovetski
This third part of an extension to support more pca953x chips updates the logic to handle the smaller register widths used by the 4-bit and 8-bit parts, and to use the chip type to determine how many GPIOs it provides. As long as we don't support interrupt and reset capabilities, those size issues are the only software-visible differences between these parts. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: rename pca953x symbolsGuennadi Liakhovetski
This second part of an extension to support more pca953x chips renames the C and Kconfig symbols. All affected files were updated by sed, except for a couple of obvious exceptions. It also updates the Kconfig helptext. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: rename pca9539 driverGuennadi Liakhovetski
First part of an extension to let the pca9539 driver support more chips, starting with pca9534, pca9535, pca9536, pca9537, and pca9538. This renames the files and modifies the Makefile. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
