[ Upstream commit b5a41620bb88efb9fb31a4fa5e652e3d5bead7d4 ]
[Description]
port spdif fix to staging:
spdif hardwired to afmt inst 1.
spdif func pointer
spdif resource allocation (reserve last audio endpoint for spdif only)
Signed-off-by: Charlene Liu <charlene.liu@amd.com>
Reviewed-by: Dmytro Laktyushkin <Dmytro.Laktyushkin@amd.com>
Acked-by: Bhawanpreet Lakha <Bhawanpreet.Lakha@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit e5382701c3520b3ed66169a6e4aa6ce5df8c56e0 ]
[Why]
The vm config will be clear to 0 when system enter S4. It will
cause hubbub didn't know how to fetch data when system resume.
The flip always pending because earliest_inuse_address and
request_address are different.
[How]
Reprogram VM config when system resume
Signed-off-by: Lewis Huang <Lewis.Huang@amd.com>
Reviewed-by: Jun Lei <Jun.Lei@amd.com>
Acked-by: Eric Yang <eric.yang2@amd.com>
Acked-by: Leo Li <sunpeng.li@amd.com>
[ Upstream commit d68a74541735e030dea56f72746cd26d19986f41 ]
[why]
As a fail-safe, in case 'set FEC_READY' DPCD write fails, a HW shadow
register should be cleared and the internal FEC stat should be set to
'not ready'. This is to make sure HW settings will be consistent with
FEC_READY state on the RX.
Signed-off-by: Nikola Cornij <nikola.cornij@amd.com>
Reviewed-by: Joshua Aberback <Joshua.Aberback@amd.com>
Acked-by: Chris Park <Chris.Park@amd.com>
[ Upstream commit 88eac241a1fc500ce5274a09ddc4bd5fc2b5adb6 ]
[Why]
Specifically to one panel,
TCON is able to accept active video signal quickly, but
the Source Driver requires 2-3 frames of extra time.
It is a Panel issue since TCON needs to take care of
all Sink requirements including Source Driver. But in
this case it does not.
Customer is asking to add fixed T7 delay as panel
workaround.
[How]
Add monitor specific patch to add T7 delay
Signed-off-by: Anthony Koo <anthony.koo@amd.com>
Reviewed-by: Charlene Liu <Charlene.Liu@amd.com>
It's large and doesn't need contiguous memory. Fixes
allocation failures in some cases.
v2: kvfree the memory.
Reviewed-by: Andrey Grodzovsky <andrey.grodzovsky@amd.com>
[Why]:
Some active dongles have DP++ port and DP port at the same time. Current
code doesn't cover DP++ case and processes as default DVI case, in which
audio is disabled. Because of dual mode, DP case is also treat as DVI case
for the other port.
[How]:
According DP 1.4 spec, add DP++ procedure similar with HDMI case. Also
add None dongle type for DP case.
Signed-off-by: Dale Zhao <dale.zhao@amd.com>
Reviewed-by: Wenjing Liu <wenjing.liu@amd.com>
[Why]
Previously assume eDP sink present if connector present. Do not
need to enforce this restriction. Fix issue where driver attempt
to read link setting even though no edp connected.
{How]
Only read link setting after reading connection status.
Signed-off-by: Eric Yang <Eric.Yang2@amd.com>
Reviewed-by: Yongqiang Sun <yongqiang.sun@amd.com>
[Why]
For boards that support eDP but do not have a physical eDP
display connected an ASSERT will be thrown. This is not a
critical failure and shouldn't be treated as such.
[How]
Drop the assertion.
Signed-off-by: Zhan Liu <zhan.liu@amd.com>
Reviewed-by: Nicholas Kazlauskas <Nicholas.Kazlauskas@amd.com>
[Why]
In dm_helpers_parse_edid_caps, there is a corner case where no speakers
can be allocated even though the audio mode count is greater than 0.
Enabling audio when no speaker allocations exists can cause issues in
the video stream.
[How]
Add a check to not enable audio unless one or more speaker allocations
exist (since doing this can cause issues in the video stream).
Signed-off-by: Alvin Lee <alvin.lee2@amd.com>
[Why]
It is possible (but very unlikely) that constructing dc fails
before current_state is created.
We support 666 color depth in some scenarios, but this
isn't handled in get_norm_pix_clk. It uses exactly the
same pixel clock as the 888 case.
[How]
Check for non null current_state before destructing.
Add case for 666 color depth to get_norm_pix_clk to
avoid assertion.
Signed-off-by: Julian Parkin <julian.parkin@amd.com>
[Why]
On some platforms, the encoder id 3 is not populated. So the encoders
are not stored in right order as index (id: 0, 1, 2, 4, 5) at pool. This
would cause encoders id 4 & id 5 to fail when finding corresponding
audio device, defaulting to the first available audio device. As result,
we cannot stream audio into two DP ports with encoders id 4 & id 5.
[How]
It need to create enough audio device objects (0 - 5) to perform matching.
Then use encoder engine id to find matched audio device.
Signed-off-by: Tai Man <taiman.wong@amd.com>
[why]
When the system is going into suspend, set_backlight gets called
after the eDP got blanked. Since smooth brightness is enabled,
the driver will make a call into the DMCU to ramp the brightness.
The DMCU would try to enable ABM to do so. But since the display is
blanked, this ends up causing ABM1_ACE_DBUF_REG_UPDATE_PENDING to
get stuck at 1, which results in a dead lock in the DMCU firmware.
[how]
Disable brightness ramping when the eDP display is blanked.
Signed-off-by: Zi Yu Liao <ziyu.liao@amd.com>
Reviewed-by: Eric Yang <eric.yang2@amd.com>
Acked-by: Anthony Koo <Anthony.Koo@amd.com>
[Why]
When launch D10.2, driver will write DPCD 0x107 with 0x00
[How]
Read MAX_DOWNSPREAD (0x0003h) then keep in current
link settings
Signed-off-by: Derek Lai <Derek.Lai@amd.com>
Reviewed-by: Tony Cheng <Tony.Cheng@amd.com>
Before accessing it's vtable, check that stream_encoder is non-null.
Signed-off-by: Ilya Bakoulin <Ilya.Bakoulin@amd.com>
Reviewed-by: Eric Bernstein <Eric.Bernstein@amd.com>
using passive dongle
[Why]
Fixes issue when we have a display connected using a passive
dongle and then emulate over it using a DP connection at 1 x 1.62 Ghz.
System hangs because register bus returns back 0xFFFFFFFF for all
register reads after setting register DIG_BE_CNTL in
dcn10_link_encoder_connect_dig_be_to_fe(). Hang occurs later
when trying to do a register read.
[How]
At the start of the emulation, dc_link_set_preferred_link_settings()
and dp_retrain_link_dp_test() is called, even though it is connected
using a passive dongle.
Add an extra condition in dp_retrain_link_dp_test() to check for
link->dongle_max_pix_clk > 0. This is the only way we know if the
connection is using passive dongle so we don't retrain DP.
Signed-off-by: Samson Tam <Samson.Tam@amd.com>
[Why]
There are certain MST displays (i.e. Dell P2715Q)
that although have the MST feature set to off may still
report it is a branch device and a non-zero
value for downstream port present.
This can lead to us incorrectly classifying a
dp dongle connection as being active and
disabling the audio endpoint for the display.
[How]
Modified the placement and
condition used to assign
the is_branch_dev bit.
Signed-off-by: Harmanprit Tatla <harmanprit.tatla@amd.com>
Reviewed-by: Aric Cyr <aric.cyr@amd.com>
[WHY] dc sw clock implementation of navi10 and raven are not exact the
same. dcccg, dchub reference clock initialization is done after dc calls
vbios dispcontroller_init table. for raven family, before
dispcontroller_init is called by dc, the ref clk values are referred
by sw clock implementation and program asic register using wrong
values. this causes dchub pstate error. This need provide valid ref
clk values. for navi10, since dispcontroller_init is not called,
dchubbub_global_timer_enable = 0, hubbub2_get_dchub_ref_freq will
hit aeert. this need remove hubbub2_get_dchub_ref_freq from this
location and move to dcn20_init_hw.
[HOW] for all asic, initialize dccg, dchub ref clk with data from
vbios firmware table by default. for raven asic family, use these data
from vbios, for asic which support sw dccg component, like navi10,
read ref clk by sw dccg functions and update the ref clk.
Signed-off-by: hersen wu <hersenxs.wu@amd.com>
[Why]
In order to give pin notifications to the sound driver from DM we need
to know whether audio is enabled on a stream and what pin it's using
from DC.
[How]
Expose the instance via stream status if it's a mapped resource for
the stream. It will be -1 if there's no audio mapped.
Cc: Leo Li <sunpeng.li@amd.com>
Cc: Harry Wentland <harry.wentland@amd.com>
Signed-off-by: Nicholas Kazlauskas <nicholas.kazlauskas@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
On 32-bit architectures, dividing a 64-bit integer in the kernel
leads to a link error:
ERROR: "__udivdi3" [drivers/gpu/drm/amd/amdgpu/amdgpu.ko] undefined!
ERROR: "__divdi3" [drivers/gpu/drm/amd/amdgpu/amdgpu.ko] undefined!
Change the two recently introduced instances to a multiply+shift
operation that is also much cheaper on 32-bit architectures.
We can do that here, since both of them are really 32-bit numbers
that change a few percent.
Fixes: bedbbe6af4be ("drm/amd/display: Move link functions from dc to dc_link")
Fixes: f18bc4e53ad6 ("drm/amd/display: update calculated bounding box logic for NV")
Acked-by: Slava Abramov <slava.abramov@amd.com>
Tested-by: Slava Abramov <slava.abramov@amd.com>
kmemdup is introduced to duplicate a region of memory in a neat way.
Rather than kmalloc/kzalloc + memcpy, which the programmer needs to
write the size twice (sometimes lead to mistakes), kmemdup improves
readability, leads to smaller code and also reduce the chances of mistakes.
Suggestion to use kmemdup rather than using kmalloc/kzalloc + memcpy.
Reviewed-by: Christian König <Christian.Koenig@amd.com>
Reviewed-by: Emil Velikov <emil.velikov@collabora.com>
Signed-off-by: Fuqian Huang <huangfq.daxian@gmail.com>
We may need to sleep for up to 80ms
(8ms per each of up to 10 loop iterations):
/* First DPCD read after VDD ON can fail if the particular board
* does not have HPD pin wired correctly. So if DPCD read fails,
* which it should never happen, retry a few times. Target worst
* case scenario of 80 ms.
Switch udelay to msleep to avoid limits on arm.
Reviewed-by: Nicholas Kazlauskas <nicholas.kazlauskas@amd.com>
Reviewed-by: Hawking Zhang <Hawking.Zhang@amd.com>
Backmerge drm-next and fix up conflicts due to drmP.h removal.
Currently vmid is decided internally inside dc. With the introduction
of new asics we are required to coordinate vmid use with external
components.
This change converts vmid logic to a DAL module allowing vmid to be
passed in as a parameter to DC.
Signed-off-by: Dmytro Laktyushkin <Dmytro.Laktyushkin@amd.com>
[why]
Current policy assumes virtual DPCD peer device as
an individual MST branch device with 1 input and 1 output.
However this is only true for virtual DP-to-DP peer device.
In general there are three types of virtual DP peer devices.
1. Sink peer device with virtual DPCD.
2. Virtual DP-to-DP Peer device with virtual DPCD.
3. Virtual DP-to-HDMI Protocol Converter Peer Device with
Virtual DPCD.
So we should break the assumption and handle all three types.
[how]
DP-to-DP peer device will have virtual DPCD cap upstream.
Sink peer device will have virtual DPCD on the logical port.
Dp to HDMI protocol converter peer device will have virtual DPCD
on its converter port.
For DSC capable Synaptics non VGA port we workaround by enumerating
a virutal DPCD peer device on its upstream
even if it doesn't have one.
Signed-off-by: Wenjing Liu <Wenjing.Liu@amd.com>
[Why]
Almost every function in DC that works with stream state expects that
the current state on the stream is the one that it should be writing
out. These functions are typically triggered by specifying a particular
stream update - but the actual contents of the stream update itself
are ignored, leaving it to the DM to actually update the stream state
itself.
The problem with doing this in DM is a matter of timing. On Linux
most of this is incorrectly done in atomic check, when we actually want
it to be done during atomic commit tail while access to DC is locked.
To give an example, a commit requesting to modify color management
state for DM could come in, be rejected, but still have modified
the actual system state for the stream since it's shared memory. The
next time color management gets programmed it'll use the rejected
color management info - which might not even still be around if it's
a custom transfer function.
So a reasonable place to perform this is within DC itself and this is
the model that's currently in use for surface updates. DC can even
compare the current system state to the incoming surface update to
determine update level, something that can't currnetly be done with the
framework for stream updates.
[How]
Duplicate the framework used for surface updates for stream updates
as well. Copy all the updates after checking the update type.
Reviewed-by: Harry Wentland <Harry.Wentland@amd.com>
Should do full update when display writeback is updated.
Reviewed-by: Duke Du <Duke.Du@amd.com>
[why]
dsc adjustment is allowed via stream update sequence.
dsc enablement is only allowed via commit stream sequence.
with the current unified dsc set function, it is hard
to determine which sequence it is called by.
The solution is to decouple dsc adjustment out of enablement
sequence so we can handle them separately.
[how]
decouple dsc adjustment out of enablement.
Reviewed-by: Nikola Cornij <Nikola.Cornij@amd.com>
* add plane state null checks
* add and set update surface flags
[Why & How]
Reuse existent code path (dcn1+) and in order to do that apply de gamma
in 1D blender LUT and re use MPC OGAM.
Follow up is required.
Signed-off-by: Vitaly Prosyak <vitaly.prosyak@amd.com>
Reviewed-by: Aric Cyr <Aric.Cyr@amd.com>
Acked-by: Krunoslav Kovac <Krunoslav.Kovac@amd.com>
Acked-by: Vitaly Prosyak <Vitaly.Prosyak@amd.com>
[why]
A few of the new DSC DPCD caps were introduced by a DP 1.4a SCR in order
to give DSC branch decoders a chance to expose their maximum throughput
and maximum line width limitations.
Reviewed-by: Wenjing Liu <Wenjing.Liu@amd.com>
[why]
The current policy will always enable DSC to 12 bpp
regardless of if the current bandwidth is enough for MST displays.
This logic is not optimal because user will get lower quality output
if DSC compression is enabled.
This change to is to implement a DSC MST bandwidth fair share
algorithm so we will dynamically decide if DSC is needed and what
quality (target bpp) is needed to fairly destribute the MST bandwidth
in one MST topology. This will allow user to see the most optimal
image quality with the given bandwidth.
[how]
We will start with lowest bandwidth possible and run a
Max-Min fairness algorithm to fairly distribute the available
bandwidth. If there is still remaining bandwidth, we will try to fit
the timing without DSC compression.
Acked-by: Hawking Zhang <Hawking.Zhang@amd.com>
[why]
There are ASICs that have fewer DSC engines than pipes, which makes
DSC a resource that should be used only if required.
[how]
Acquire DSC HW resource if required by stream and release when not
required anymore.
[why]
Currently link bandwidth is calculated in various places using the same
multi-step formula. Doing this in one common place makes sure the same
formula will indeed be applied to all link bandwidth calculations.
It also makes it possible to apply link-setting-specific adjustments
that affect effective link bandwidth.
[how]
Replace all implementations of link bandwidth calculation with a call
to a function.
[Why]
link-specific functions should reside in dc_link.c
[How]
Move them there.
Signed-off-by: Chris Park <Chris.Park@amd.com>
Add support for DCN2 DSC (Display Stream Compression)
HW Blocks:
| HUBBUB || HUBP | <-- | MMHUBBUB |
v |
| DPP | | DWB |
v ^
| MPC | |
v |
| OPP | <--> | DSC | |
v |
| OPTC | --------------
v
| DIO | | DCCG |
v2: rebase (Alex)
Signed-off-by: Harry Wentland <harry.wentland@amd.com>
Core DC changes for DCN2.
Add DCN2 resource definition and HW Sequencer changes.
This reverts commit 6e5155ae6b66054db35d8f3c64f9863b9d0466c1.
Revert this to apply the version that includes DCN2 support.
This reverts commit 11cd74cdb98aa6f4d6f54a0082dd28e0d4743746.
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for v5.3:
UAPI Changes:
Cross-subsystem Changes:
- Add code to signal all dma-fences when freed with pending signals.
- Annotate reservation object access in CONFIG_DEBUG_MUTEXES
Core Changes:
- Assorted documentation fixes.
- Use irqsave/restore spinlock to add crc entry.
- Move code around to drm_client, for internal modeset clients.
- Make drm_crtc.h and drm_debugfs.h self-contained.
- Remove drm_fb_helper_connector.
- Add bootsplash to todo.
- Fix lock ordering in pan_display_legacy.
- Support pinning buffers to current location in gem-vram.
- Remove the now unused locking functions from gem-vram.
- Remove the now unused kmap-object argument from vram helpers.
- Stop checking return value of debugfs_create.
- Add atomic encoder enable/disable helpers.
- pass drm_atomic_state to atomic connector check.
- Add atomic support for bridge enable/disable.
- Add self refresh helpers to core.
Driver Changes:
- Add extra delay to make MTP SDM845 work.
- Small fixes to virtio, vkms, sii902x, sii9234, ast, mcde, analogix, rockchip.
- Add zpos and ?BGR8888 support to meson.
- More removals of drm_os_linux and drmP headers for amd, radeon, sti, r128, r128, savage, sis.
- Allow synopsis to unwedge the i2c hdmi bus.
- Add orientation quirks for GPD panels.
- Edid cleanups and fixing handling for edid < 1.2.
- Add runtime pm to stm.
- Handle s/r in dw-hdmi.
- Add hooks for power on/off to dsi for stm.
- Remove virtio dirty tracking code, done in drm core.
- Rework BO handling in ast and mgag200.
Tiny conflict in drivers/gpu/drm/amd/display/dc/clk_mgr/clk_mgr.c,
needed #include <linux/slab.h> to make it compile.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
From: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/0e01de30-9797-853c-732f-4a5bd6e61445@linux.intel.com
[Why]
Found issue in EDID Emulation where if we connect a display using
a passive HDMI-DP dongle, disconnect it and then try to emulate
a display using DP, we could not see 4K modes. This was because
on a disconnect, dongle_max_pix_clk was still set so when we
emulate using DP, in dc_link_validate_mode_timing(), it would
think we were still using a dongle and limit the modes we support.
[How]
In dc_link_detect(), set dongle_max_pix_clk to 0 when we detect
a hotplug out ( if new_connection_type = dc_connection_none ).
[Description]
The spec does not allow POST_LT_ADJ_GRANTED to be set when TPS4 is used.
Signed-off-by: abdoulaye berthe <abdoulaye.berthe@amd.com>
[WHY]
By the time output csc matrix is being programmed, stream connection to
OPP has been established, but this information has not been relayed back
to HUBP.
Signed-off-by: Wesley Chalmers <Wesley.Chalmers@amd.com>
Reviewed-by: Anthony Koo <Anthony.Koo@amd.com>
Currently vmid is decided internally inside dc. This makes it
difficult to use vmid use with external components.
This change moves vmid logic outside dc and allowing vmid to be
[Why]
VBios sometimes reports incorrect object type as encoder instead of
connector
[How]
Change error message to debug message
Signed-off-by: Jordan Lazare <Jordan.Lazare@amd.com>
These are no longer needed, Also added RESERVED bits.
Acked-by: Harry Wentland <Harry.Wentland@amd.com>
[Why]
HPD not going to be high if Panel VDD is off
And all AUX transaction will fail :(
[How]
1. Power on VDD before attempting detection if it isn't already on
2. Improve the robustness by having a retry mechanism on the
first DPCD read after VDD on. If a particular board always holds
HPD high incorrectly, the AUX access may fail, so we can retry
in those scenarios. This change would only improve logic
since it prevents AUX failure leading to bad resolution on internal
panel.
3. We should never need to re-detect internal panel, so logic
is re-arranged a bit to skip earlier.
Signed-off-by: Anthony Koo <Anthony.Koo@amd.com>
[Why]
itself.
[How]
[WHY]
Some panels return a link rate of 0 (unknown) in DPCD 0. In this case,
an appropriate mode cannot be set, and certain panels will show
corruption as they are forced to use a mode they do not support.
[HOW]
Read DPCD 10 in the case where supported link rate from DPCD 0 is
unknown, and pass that value on to the reported link rate.
This re-introduces behaviour present in previous versions that appears
to have been accidentally removed.
Signed-off-by: Tao.Huang <Tao.Huang@amd.com>
