[Why]
In order to give pin notifications to the sound driver from DM we need
to know whether audio is enabled on a stream and what pin it's using
from DC.
[How]
Expose the instance via stream status if it's a mapped resource for
the stream. It will be -1 if there's no audio mapped.
Cc: Leo Li <sunpeng.li@amd.com>
Cc: Harry Wentland <harry.wentland@amd.com>
Signed-off-by: Nicholas Kazlauskas <nicholas.kazlauskas@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[Why]
To send sdp message immediately from a single slot.
[How]
Modify the generic SDP message interface, and use GSP4 to send immediate
sdp message.
Signed-off-by: Leo (Hanghong) Ma <hanghong.ma@amd.com>
Reviewed-by: Harry Wentland <Harry.Wentland@amd.com>
Acked-by: Bhawanpreet Lakha <Bhawanpreet.Lakha@amd.com>
Add support for DCN2 DSC (Display Stream Compression)
HW Blocks:
| HUBBUB || HUBP | <-- | MMHUBBUB |
v |
| DPP | | DWB |
v ^
| MPC | |
v |
| OPP | <--> | DSC | |
v |
| OPTC | --------------
v
| DIO | | DCCG |
v2: rebase (Alex)
Signed-off-by: Harry Wentland <harry.wentland@amd.com>
Core DC changes for DCN2.
[Why]
In the previous implementation DRR event sometimes came
in during FP2 region which is a keep-out zone. This
would cause the frame not to latch until the next frame
which resulted in heavy flicker. To fix this we need
to make sure that it triggers in the BP.
[How]
1. Remove DRR programming during flip
2. Setup manual trigger for DRR event and trigger it
after surface programming is complete
Signed-off-by: Eryk Brol <eryk.brol@amd.com>
Reviewed-by: Aric Cyr <Aric.Cyr@amd.com>
Acked-by: Leo Li <sunpeng.li@amd.com>
We'll need the ability to copy a dc_stream_state for some features.
Implement it here.
Signed-off-by: Wenjing Liu <Wenjing.Liu@amd.com>
Reviewed-by: Jun Lei <Jun.Lei@amd.com>
[Why]
We need to add DP SDP message test debugfs to make sdp message test
more convenient and efficient.
[How]
Add a DM accessible SDP interface for custom data.
Reviewed-by: Roman Li <Roman.Li@amd.com>
[Why]
Current periodic interrupt start point calc in optc
is not clear.
[How]
1. DM convert delta time to lines number and dc will calculate the
start position as per lines number and interrupt type.
2. hwss calculates the start point as per line offset.
3. optc programs vertical interrupts register as per start point
and interrupt source.
Signed-off-by: Yongqiang Sun <yongqiang.sun@amd.com>
Reviewed-by: Tony Cheng <Tony.Cheng@amd.com>
[Why]
If we determine the stream we are trying to commit
matches HW, we want to try to optimize.
[How]
Try to acquire the HW resources that are already enabled
and optimize.
Also skip backend reprogramming
Signed-off-by: Anthony Koo <Anthony.Koo@amd.com>
We need to calcualte vline position in DC for DCN.
in program_timing_sync, after all the pipes are
grouped, store timing sync info in dc_stream_status
Signed-off-by: Su Sung Chung <Su.Chung@amd.com>
[Why]
Enhanced sync need to use vertical_interrupt1.
[How]
Add vertical_interrupt1 source to irq manger,
Implment setup vline interrupt interface.
Signed-off-by: Fatemeh Darbehani <fatemeh.darbehani@amd.com>
[Why]
The function dc_commit_updates_for_stream had a parameter called
plane_states. It was never used. It was getting in the way
of some cleanup work
[How]
Remove it
Signed-off-by: David Francis <David.Francis@amd.com>
Reviewed-by: Leo Li <sunpeng.li@amd.com>
[Why]
This fixes an regression introduced by:
drm/amd/display: add stream ID and otg instance in dc_stream_state
During driver initialization, a null pointer deref is raised. This is
caused by searching for a stream status in the dc->current_state before
the dc_state swap happens at the end of dc_commit_state_no_check().
Since the swap has not happened, the dc_state to be swapped in should
be searched, and not dc->current_state.
[How]
Add a function that searches for the stream status within the given
dc_state, instead of dc->current_state. Use that before the state swap
happens in dc_commit_state_no_check().
Also remove duplicate occurrences of this function in amdgpu_dm.c.
Signed-off-by: Leo Li <sunpeng.li@amd.com>
Acked-by: Nicholas Kazlauskas <Nicholas.Kazlauskas@amd.com>
[Why]
It's not being used anywhere.
[How]
Remove it.
Reviewed-by: David Francis <David.Francis@amd.com>
[why]
stream ID allows DMs to avoid memory address comparisons to compare
stream equality.
otg_instance allows DC to more rigorously define when otg_instance
can change. specifically, it is now defined to be only mutable when dc_stream_state
changes. This is better than a "get status" function which prevents efficient
caching of otherwise very stable information.
[how]
stream ID follows similar pattern to sink ID, which is already implemented
otg_instance is an output which occurs on all dc_stream modification functions
Signed-off-by: Jun Lei <Jun.Lei@amd.com>
Acked-by: Aric Cyr <Aric.Cyr@amd.com>
[Why]
Backlight is conceptually a property of links, not streams.
All backlight programming is done on links, but there is a
stream property bl_pwm_level that is used to restore backlight
on dpms on and s3 resume. This is unnecessary, as backlight
is already restored by hardware with no driver intervention.
[How]
Remove bl_pwm_level, and the stream argument to set_backlight
Acked-by: Anthony Koo <Anthony.Koo@amd.com>
[why]
dc_stream_state containing a pointer to sink is poor design.
Sink describes the display, and the specifications or capabilities
it has. That information is irrelevant for dc_stream_state, which describes
hardware state, and is generally used for hardware programming. It
could further be argued that dc_sink itself is just a convenience dc
provides, and DC should be perfectly capable of programming hardware
without any dc_sinks (for example, emulated sinks).
[how]
Phase 1:
Deprecate use of dc_sink pointer in dc_stream. Most references are trivial
to remove, but some call sites are risky (such as is_timing_changed) with
no obvious logical replacement. These will be removed in follow up change.
Add dc_link pointer to dc_stream. This is the typical reason DC really needed
sink pointer, and most call sites are replaced with this.
DMs also need minor updates, as all 3 DMs leverage stream->sink for
some functionality. this is replaced instead by a pointer to private data
inside dc_stream_state, which is used by DMs as a quality of life improvment
for some key functionality. it allows DMs to set pointers have to their own objects
which associate OS objects to dc_stream_states (such as DisplayTarget
and amdgpu_dm_connector). Without the private pointer, DMs would be
forced to perform a lookup for callbacks.
Acked-by: David Francis <David.Francis@amd.com>
Dithering needs to be enabled or disabled as requested. If
dc_stream_update->dither_option is non-null, program the FMT blocks.
Signed-off-by: SivapiriyanKumarasamy <sivapiriyan.kumarasamy@amd.com>
Reviewed-by: Anthony Koo <Anthony.Koo@amd.com>
Reviewed-by: Krunoslav Kovac <Krunoslav.Kovac@amd.com>
* Use provided infopacket in stream (if valid) instead of reconstructing
in set_vendor_info_packet()
* Use proper format for enums
* Use dc info packet struct instead
Signed-off-by: Harmanprit Tatla <Harmanprit.Tatla@amd.com>
Acked-by: Krunoslav Kovac <Krunoslav.Kovac@amd.com>
[Why]
dc_state has an array of dc_stream_status that contain
pointers to the dc_plane_state and other useful information
Confusingly, dc_stream_state also contains a dc_stream_status
called status. This struct was partially initialized and
used in a few places
[How]
stream->status.link has been replaced with stream->sink->link.
If a stream does not have a sink, or a sink does not have a link,
something has gone seriously wrong
All other properties of stream->status were zeroed by kzalloc
and never initialized, so they have been replaced by the number 0
This is a refactor: no functional change is intended
Acked-by: Tony Cheng <Tony.Cheng@amd.com>
[Why]
During S4/S3 stress test it is possible to resume from S4 without
calling mode set on eDP, meaning high level optimization flag is not
reset. If this is followed by an S3 resume call, driver will see
optimization flag is set and consume it and think backend is powered
on when in fact it is not.
This results in PHY being off in sequence where
S4->Resume->S3->Resume->ApplyOpt->black screen.
[How]
Move optimization flag to stream instead of a DC flag.
Add csc_transform struct to dc_stream_update, and program if set when
updating streams
Add gamut remap to dc_stream_update struct, and program if set when updating
streams.
Signed-off-by: Alvin lee <alvin.lee3@amd.com>
Acked-by: Harry Wentland <harry.wentland@amd.com>
- program infoframe for Stereo
- program stereo flip control registers properly
v2: Add missing license headers
Acked-by: Alex Deucher <alexander.deucher@amd.com>
enable flag
Signed-off-by: Samson Tam <Samson.Tam@amd.com>
Remove dependency on internal sink map and instead
use existing stream and plane state
[Why]
Cursor boosting is done via CNVC_CUR register which is DPP, not HUBP
Previous commit was implementing it in HUBP functions,
and also breaking diags tests.
[How]
1. Undo original commit as well as Eric's diags test fix, almost completely
2. Move programming to DPP and call via new dc_stream function
3. Also removing cur_rom_en from dpp_cursor_attributes and programming
as part of normal cursor attributes as it depends on cursor color format
Signed-off-by: Krunoslav Kovac <Krunoslav.Kovac@amd.com>
- Removed dal/dm/dc loggers from linux, switched to kernel prints
- Modified functions that used these directly to use macros
- dc_logger support is completely dropped from Linux
Basic framework:
- caps for reporting dynamic HDR metadata support
- allocation of frame buffer memory and storage
Linux doesn't know lid state, better to check dig enable
value from register.
For legacy enable boot up with lid closed, eDP information couldn't be
read correctly via SBIOS_SCRATCH_3 results in eDP cannot be light up
properly when open lid.
Check lid state instead can resolve the issue.
Reviewed-by: Eric Yang <eric.yang2@amd.com>
Remove some unnecessary TF definitions from update structures
Updated HDR Static Metadata to directly take info packet raw
Updating Infopacket does not require Passive
Block FP16 scaling in validate_resources codepath.
Signed-off-by: Julian Parkin <jparkin@amd.com>
root cause:
DMCU try to perform a smoothness brightness change.Incorrect initial
brightness level causes the 1 sec dim.
Change:
Cache brightness level in stream, and clear it when edp backlight on.
If brightness level in stream is 0, set brightness with ramp value is 0.
DMCU will set the brightness without smoothness transition.
v2: squash in null pointer fix (Harry)
Time stamping will be part of surface, and will be updated when address is flipped.
FreeSync parameters will be attached to stream, as it adjusts the timing dynamically.
Fix bug and make changes from review 132656
Avoid hanging DMCU by setting abm level only when OTG unblanked
Brightness could not be changed for some panels whose DPCD_version is below 1.2
Now psr_version is added into stream, and it copies from the displayTarget's psr_version.
It checks if the stream's psr_versio is non-zero and sets the vsc info packet revision now.
Signed-off-by: Xingyue Tao <xingyue.tao@amd.com>
We will need this to disable dither for CRC capture.
Signed-off-by: Leo (Sunpeng) Li <sunpeng.li@amd.com>
There's no good place in DC to cover all place where stream signal should
be updated. update_stream_signal depends on timing which comes from DM.
Add display to the name for consistency.
Signed-off-by: Samuel Li <Samuel.Li@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
