[ Upstream commit 055e547478a11a6360c7ce05e2afc3e366968a12 ]
In dcn*_clock_source_create when dcn20_clk_src_construct fails allocated
clk_src needs release.
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 89cb5614736b9b5d3b833ca2237d10da6b4b0395 ]
[why]
With Scatter Gather enabled, HUBP underflows during MPO enabled video
playback. hubp_init has a register write that fixes this problem, but
the register is cleared when HUBP gets power gated.
[how]
Make a call to hubp_init during enable_plane, so that the fix can
be applied after HUBP powers back on again.
Signed-off-by: Zi Yu Liao <ziyu.liao@amd.com>
Reviewed-by: Tony Cheng <Tony.Cheng@amd.com>
Acked-by: Bhawanpreet Lakha <Bhawanpreet.Lakha@amd.com>
[ Upstream commit 21ffcc94d5b3dc024fedac700f1e7f9dacf4ab4f ]
[Why]
DC configures the GSL group for the pipe when pipe_split is enabled
and we're switching flip types (buffered <-> immediate flip) on DCN2.
In order to record what GSL group the pipe is using DC stores it in
the pipe's stream_res. DM is not aware of this internal grouping, nor
is DC resource.
So when DM creates a dc_state context and passes it to DC the current
GSL group is lost - DM never knew about it in the first place.
After 3 immediate flips we run out of GSL groups and we're no longer
able to correctly perform *any* flip for multi-pipe scenarios.
[How]
The gsl_group needs to be copied to the new context.
DM has no insight into GSL grouping and could even potentially create
a brand new context without referencing current hardware state. So this
makes the most sense to have happen in DC.
There are two places where DC can apply a new context:
- dc_commit_state
- dc_commit_updates_for_stream
But what's shared between both of these is apply_ctx_for_surface.
This logic only matters for DCN2, so it can be placed in
dcn20_apply_ctx_for_surface. Before doing any locking (where the GSL
group is setup) we can copy over the GSL groups before committing the
new context.
Signed-off-by: Nicholas Kazlauskas <nicholas.kazlauskas@amd.com>
Reviewed-by: Hersen Wu <hersen.wu@amd.com>
Acked-by: Leo Li <sunpeng.li@amd.com>
[ Upstream commit 75c35000235f3662f2810e9a59b0c8eed045432e ]
[why]
DSC should be powered-on only on as-needed basis, i.e. if the mode
requires it
[how]
Loop over all the DSCs at driver init time and power-gate each
Signed-off-by: Nikola Cornij <nikola.cornij@amd.com>
Reviewed-by: Nevenko Stupar <Nevenko.Stupar@amd.com>
undefined SW FP routines
commit 0f0727d971f6fdf8f1077180d495ddb9928f0c8b upstream.
arch/x86/Makefile disables SSE and SSE2 for the whole kernel. The
AMDGPU drivers modified in this patch re-enable SSE but not SSE2. Turn
on SSE2 to support emitting double precision floating point instructions
rather than calls to non-existent (usually available from gcc_s or
compiler_rt) floating point helper routines for Clang.
This was originally landed in:
commit 10117450735c ("drm/amd/display: add -msse2 to prevent Clang from emitting libcalls to undefined SW FP routines")
but reverted in:
commit 193392ed9f69 ("Revert "drm/amd/display: add -msse2 to prevent Clang from emitting libcalls to undefined SW FP routines"")
due to bugreports from GCC builds. Add guards to only do so for Clang.
Link: https://bugs.freedesktop.org/show_bug.cgi?id=109487
Link: https://github.com/ClangBuiltLinux/linux/issues/327
Suggested-by: Sedat Dilek <sedat.dilek@gmail.com>
Suggested-by: Sami Tolvanen <samitolvanen@google.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gustavoars/linux
Pull Wimplicit-fallthrough enablement from Gustavo A. R. Silva:
"This marks switch cases where we are expecting to fall through, and
globally enables the -Wimplicit-fallthrough option in the main
Makefile.
Finally, some missing-break fixes that have been tagged for -stable:
- drm/amdkfd: Fix missing break in switch statement
- drm/amdgpu/gfx10: Fix missing break in switch statement
With these changes, we completely get rid of all the fall-through
warnings in the kernel"
* tag 'Wimplicit-fallthrough-5.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gustavoars/linux:
Makefile: Globally enable fall-through warning
drm/i915: Mark expected switch fall-throughs
drm/amd/display: Mark expected switch fall-throughs
drm/amdkfd/kfd_mqd_manager_v10: Avoid fall-through warning
perf/x86/intel: Mark expected switch fall-throughs
mtd: onenand_base: Mark expected switch fall-through
afs: fsclient: Mark expected switch fall-throughs
afs: yfsclient: Mark expected switch fall-throughs
can: mark expected switch fall-throughs
firewire: mark expected switch fall-throughs
In preparation to enabling -Wimplicit-fallthrough, mark switch
cases where we are expecting to fall through.
Warning level 3 was used: -Wimplicit-fallthrough=3
This patch is part of the ongoing efforts to enable -Wimplicit-fallthrough.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[why]
In pipe split issue occurs when we program immediate flip while vsync flip is pending
[how]
Don't program immediate flip until flip is no longer pending
Signed-off-by: Alvin Lee <alvin.lee2@amd.com>
Reviewed-by: Jaehyun Chung <Jaehyun.Chung@amd.com>
[Why]
Some display's hsync width is lower than the minimum dcn20 is set
to support right now. This will cause optc1_validate_timing to fail which
eventually will result in wrong set mode. This was set to 8 as per
HW team's request for no valid reason.
[How]
Changing min_h_sync_width to 4 will let us validate timing for
preffered mode and light up the headset. This change was made
to Vega 10 before for a similar issue.
Signed-off-by: Fatemeh Darbehani <fatemeh.darbehani@amd.com>
Reviewed-by: Joshua Aberback <Joshua.Aberback@amd.com>
Acked-by: Aric Cyr <Aric.Cyr@amd.com>
[Why]
Hardware docs state that we must wait until the GPUVM context is ready
after programming it.
[How]
Poll until the valid bit of PAGE_TABLE_BASE_ADDR_LO32 is set to 1 after
programming it.
v2: fix include for udelay (Alex)
Signed-off-by: Julian Parkin <julian.parkin@amd.com>
Reviewed-by: Charlene Liu <Charlene.Liu@amd.com>
[why]
The current code will not wait for the entire frame
after global unlock.
This causes dsc dynamic target bpp update corruption when
there is a surface update immediately happens after this.
[how]
Wait for the entire whole frame after unlock before continuing
the rest of stream and surface update.
Signed-off-by: Wenjing Liu <Wenjing.Liu@amd.com>
Reviewed-by: Jun Lei <Jun.Lei@amd.com>
[why]
Currently logical values are swapped in HW, causing
system aperture to be undefined, so VA and PA cannot co-exist
[how]
program values correctly
Signed-off-by: Jun Lei <Jun.Lei@amd.com>
Reviewed-by: Yongqiang Sun <yongqiang.sun@amd.com>
We're not expected to enter the default case, but not returning a
default value here is incorrect.
Signed-off-by: Dmytro Laktyushkin <Dmytro.Laktyushkin@amd.com>
Reviewed-by: Eric Bernstein <Eric.Bernstein@amd.com>
[why]
Due to limitation in SMU/PPLIB, it is not possible to know Fmax @ Vmin for DCFCLK.
This causes issues at high display configurations where extra headroom of DCFCLK
can enable P-state switching
[how]
Use existing override logic. If override not defined, then force
min = 507
Reviewed-by: Eric Yang <eric.yang2@amd.com>
A regression caused dsc to never get disabled in certain situations.
Reviewed-by: Nikola Cornij <Nikola.Cornij@amd.com>
[why]
Some values were not being converted or bit-shifted properly for
HW registers, causing black screen
[how]
Fix up the values before programming HW
Signed-off-by: Jun Lei <jun.lei@amd.com>
Reviewed-by: Anthony Koo <Anthony.Koo@amd.com>
[WHY] dc sw clock implementation of navi10 and raven are not exact the
same. dcccg, dchub reference clock initialization is done after dc calls
vbios dispcontroller_init table. for raven family, before
dispcontroller_init is called by dc, the ref clk values are referred
by sw clock implementation and program asic register using wrong
values. this causes dchub pstate error. This need provide valid ref
clk values. for navi10, since dispcontroller_init is not called,
dchubbub_global_timer_enable = 0, hubbub2_get_dchub_ref_freq will
hit aeert. this need remove hubbub2_get_dchub_ref_freq from this
location and move to dcn20_init_hw.
[HOW] for all asic, initialize dccg, dchub ref clk with data from
vbios firmware table by default. for raven asic family, use these data
from vbios, for asic which support sw dccg component, like navi10,
read ref clk by sw dccg functions and update the ref clk.
Signed-off-by: hersen wu <hersenxs.wu@amd.com>
Workaround for now to avoid underflow.
The uclk switch time should really be bumped up to 404, but doing so
would expose p-state hang issues for higher bandwidth display
configurations.
Signed-off-by: Leo Li <sunpeng.li@amd.com>
dcn20_acquire_idle_pipe_for_layer
clang complains that 'false' is a not a pointer:
drivers/gpu/drm/amd/amdgpu/../display/dc/dcn20/dcn20_resource.c:2428:10: error: expression which evaluates to zero treated as a null pointer constant of type 'struct pipe_ctx *' [-Werror,-Wnon-literal-null-conversion]
return false;
Changing it to 'NULL' looks like the right thing that will shut up
the warning and make it easier to read, while not changing behavior.
Fixes: 7ed4e6352c16 ("drm/amd/display: Add DCN2 HW Sequencer and Resource")
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
As previously fixed for dml in commit 4769278e5c7f ("amdgpu/dc/dml:
Support clang option for stack alignment") and calcs in commit
cc32ad8f559c ("amdgpu/dc/calcs: Support clang option for stack
alignment"), dcn20 uses an option that is not available with clang:
clang: error: unknown argument: '-mpreferred-stack-boundary=4'
scripts/Makefile.build:281: recipe for target 'drivers/gpu/drm/amd/amdgpu/../display/dc/dcn20/dcn20_resource.o' failed
Use the same trick that we have in the other two files.
On 32-bit architectures, dividing a 64-bit integer in the kernel
leads to a link error:
ERROR: "__udivdi3" [drivers/gpu/drm/amd/amdgpu/amdgpu.ko] undefined!
ERROR: "__divdi3" [drivers/gpu/drm/amd/amdgpu/amdgpu.ko] undefined!
Change the two recently introduced instances to a multiply+shift
operation that is also much cheaper on 32-bit architectures.
We can do that here, since both of them are really 32-bit numbers
that change a few percent.
Fixes: bedbbe6af4be ("drm/amd/display: Move link functions from dc to dc_link")
Fixes: f18bc4e53ad6 ("drm/amd/display: update calculated bounding box logic for NV")
Acked-by: Slava Abramov <slava.abramov@amd.com>
Tested-by: Slava Abramov <slava.abramov@amd.com>
Without this header, we get a compiler error in some configurations:
.../dc/dcn20/dcn20_hwseq.c: In function 'dcn20_hwss_wait_for_blank_complete':
.../dc/dcn20/dcn20_hwseq.c:1493:3: error: implicit declaration of function 'udelay' [-Werror=implicit-function-declaration]
Note: the use of udelay itself may be problematic, as can occupy
the CPU for 200ms in a busy-loop here.
There are a couple of spelling mistakes in dm_error messages and
a comment. Fix these.
Inconsistent indentation and mixed use of brackets.
Signed-off-by: Ernst Sjöstrand <ernstp@gmail.com>
Backmerge drm-next and fix up conflicts due to drmP.h removal.
during navi10 bring up, dwb causes system hang.
to continue debug major issue, disable dwb by
set num-dwb = 0. the hang issue is not reproduced now
by enable num-dwb =1. dc source is shared by all os.
win needs num-dwb = 1.
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Roman Li <Roman.Li@amd.com>
[Why]
For debugging underflow issues it can be useful to have asserts when the
underflow initially occurs.
[How]
Read the underflow status registers after actions that have a high risk
of causing underflow and assert that no underflow occurred. If underflow
occurred, clear the bit.
Signed-off-by: Thomas Lim <Thomas.Lim@amd.com>
Currently vmid is decided internally inside dc. With the introduction
of new asics we are required to coordinate vmid use with external
components.
This change converts vmid logic to a DAL module allowing vmid to be
passed in as a parameter to DC.
[Description]
dcn2 use fixed clocks and not program DPP CLK or Disp_CLK.
Signed-off-by: Charlene Liu <charlene.liu@amd.com>
Reviewed-by: Dmytro Laktyushkin <Dmytro.Laktyushkin@amd.com>
[WHY]
This is meant to make it clearer that 0xf is not a valid OPP ID, and
that code making use of OPP IDs should not accept this value.
Signed-off-by: Wesley Chalmers <Wesley.Chalmers@amd.com>
expose this function for future use
Implementation of DCN3 DIO Link Encoder including
dpcs register headers.
Signed-off-by: Eric Bernstein <eric.bernstein@amd.com>
[why]
Existing behavior has overlapping ranges resulting in path
dependent SMU selection
[how]
Make ranges non-overlapping, resulting in non-path dependent
selection
required for new checks.
[Why]
The output_bpp pipe parameter was assigned an incorrect value
(color depth enum), and subsequently used to overwrite
the OutputBpp parameter calculated by DML. Seems like this had no
effect except with DSC enabled, which would make DML produce
bad outputs.
[How]
Removed assignment to OutputBpp, fixed output_bpp assignment,
and properly set ForcedOutputLinkBPP instead of OutputBpp.
Also removed condition in DML that prevented forcing of
Output BPP with DSC enabled.
Signed-off-by: Ilya Bakoulin <Ilya.Bakoulin@amd.com>
[why]
VM implemenation is missing conversion from HW values in hubbub
DM not passing actual PTB during flip
[how]
add proper HW conversion from logical values
fix cases where we programmed VA even though we are in PA
plumb in PTB from DM
[why]
Currently DSC power gating is disabled by default because the power
transition doesn't happen, causing a crash on some systems
[how]
Fix the lack of power state transition and enable DSC power gating
by default.
Reviewed-by: Martin Leung <Martin.Leung@amd.com>
[why]
dsc adjustment is allowed via stream update sequence.
dsc enablement is only allowed via commit stream sequence.
with the current unified dsc set function, it is hard
to determine which sequence it is called by.
The solution is to decouple dsc adjustment out of enablement
sequence so we can handle them separately.
[how]
decouple dsc adjustment out of enablement.
[why]
current DML logic uses currently trained setting for number
of dp lanes in DML calculations. this is obviously flawed since
just because 1 lane is in use doesn't mean only 1 lane can be used
this causes mode validation to fail depending on current state,
which is incorrect
[how]
DML should always assume 4 lanes are available. validation of
bandwidth is not supposed to be handled by DML, since we do
link validation without DML already
also, DML is expecting there to be a copy of the max state, this
state is removed when update_bounding_box is called to update
actual SKU clocks. fix this as well by duping last state.
Acked-by: Eric Yang <eric.yang2@amd.com>
[WHY]
DCN code should make as few references to DCE as possible
[HOW]
Copy DCE110 implementation of find_first_free_match_stream_enc_for_link
into DCN10
[WHY]
From DCE110 onward, we have the ability to assign DIG BE and FE
separately for any display connector type; before, we could only do this
for DP.
[why]
With DSC power gating enabled, one of the register reads times out occasionally,
causing a DSC test to fail.
[how]
Disable DSC power gating in Diags.
NOTE: This has to be reverted once the problems with DSC power gating are
resolved.
[Why]
We want a test pattern to show up on screen when we're blanked and have
visual confirm enabled, for debugging. Raven does this, it's a mistake that
Navi does not.
[How]
- in "blank_pixel_data", set appropriate DPG pattern for visual confirm
- refactor DPG calls out of "enable_stream_timing"
Signed-off-by: Joshua Aberback <joshua.aberback@amd.com>
* add plane state null checks
* add and set update surface flags
[Description]
Features that are desirable for minimizing the Global Sync Period:
DRR and lateflip
DCN2.0 LB BPP should be 48 or 16BPC and max cursor width should be 256.
Also use populate_dml_pipes as functions pointer instead of using it directly
A regression was introduced when we set correct tile size
for the gfx9 swizzle mode. This resulted in incorrect
macro tile size.
[Why]
Plane disable gets calls when we enable blank. On DCN2, we blank by using
DPG to display a black colour instead of using OTG blank. DPG runs off the
OPP clock, therefore we shouldn't disable the OPP clock when disabling the
plane. We do need to disable the OPP clock when disabling the entire pipe,
that will be addressed in a separate commit.
It looks like mpo isn't properly disabled during odm, this change is
meant to fix that.
dwb fixes.
Reviewed-by: Duke Du <Duke.Du@amd.com>
[Description]
dcn20 has num_dwb =1 in the res cap, but not created.
