Add helper to get the drm_fb_helper struct of a CMA framebuffer
object (struct drm_fbdev_cma). This is useful to use other
fb_helper functions like drm_fb_helper_set_suspend.
Use the newly created wrapper drm_fb_helper functions instead of calling
core fbdev functions directly. They also simplify the fb_info creation.
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Remaining manual work in the drm core&helpers. Nothing special here,
no surprises.
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
This function takes two locks, both of them the wrong ones. This
wasn't an oversight from my fb locking rework since both patches
landed in parallel. We really only need fb_lock when walking that
list, since everything we can reach from that is refcounted properly
already.
v2: Drop unused dev spotted by 0day.
Cc: Rob Clark <robdclark@gmail.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
What is passed to drm_fb_helper_fill_var() should be fb_width/fb_height,
rather than the surface size.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
To implement hotplug detection in a race-free manner, drivers must call
drm_kms_helper_poll_init() before hotplug events can be triggered. Such
events can be triggered right after any of the encoders or connectors
are initialized. At the same time, if the drm_fb_helper_hotplug_event()
helper is used by a driver, then the poll helper requires some parts of
the FB helper to be initialized to prevent a crash.
At the same time, drm_fb_helper_init() requires information that is not
necessarily available at such an early stage (number of CRTCs and
connectors), so it cannot be used yet.
Add a new helper, drm_fb_helper_prepare(), that initializes the bare
minimum needed to allow drm_kms_helper_poll_init() to execute and any
subsequent hotplug events to be processed properly.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Thierry Reding <treding@nvidia.com>
There's no need for this to be modifiable. Make it const so that it can
be put into the .rodata section.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
All drm_fb_helper_restore_fbdev_mode() call sites, save one, do the same
locking. Simplify this into drm_fb_helper_restore_fbdev_mode_unlocked().
This function is only used in drm_fb_cma_helper.c.
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
Correct spelling typo in various part of drivers
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
into drm-next
KMS driver for TI LCD controller
* 'tilcdc-next' of git://people.freedesktop.org/~robclark/linux:
drm/tilcdc: add support for LCD panels (v5)
drm/tilcdc: add encoder slave (v2)
drm/i2c: nxp-tda998x (v3)
drm/tilcdc: add TI LCD Controller DRM driver (v4)
drm/nouveau: use i2c encoder helper wrappers
drm: i2c encoder helper wrappers
drm/cma: add debugfs helpers
drm: small fix in drm_send_vblank_event()
drm: Don't set the plane->fb to NULL on successfull set_plane
drm/cma-helper: fixup compilation
drivers/gpu/drm/Kconfig
drivers/gpu/drm/Makefile
drivers/gpu/drm/drm_fb_cma_helper.c
/me grabs a few brown paper bags
So it looks like I've broken compilation in
commit 6aed8ec3f76a22217c9ae183d32b1aa990bed069
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Sun Jan 20 17:32:21 2013 +0100
drm: review locking for drm_fb_helper_restore_fbdev_mode
Fix it up again.
v2: Only deref fbdev_cma once we're sure it's non-NULL, noticed by
Thierry Reding.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Add helper to display fb's which can be used directly in drm_info_list:
static struct drm_info_list foo_debugfs_list[] = {
{ "fb", drm_fb_cma_debugfs_show, 0 },
to display information about CMA fb objects, as well as a
drm_gem_cma_describe() which can be used if the driver bothers to keep
a list of CMA GEM objects.
Fix it up again.
The fb helper lost its support for reallocating an fb completely, so
no need to return special success values any more.
Reviewed-by: Rob Clark <robdclark@gmail.com>
This should be done in the drivers for two reasons:
- it gets in the way of fastboot efforts
- it links the fb helpers with the crtc helpers instead of going
through the real interface vfuncs, forcing i915 to fake all the
->disable callbacks used by the crtc helper to avoid ugly Oopsen
v2: Resolve conflicts since drivers still call
drm_fb_helper_single_add_all_connectors.
... it's required. Fix up exynos and the cma helper, and add a
corresponding WARN_ON to drm_fb_helper_restore_fbdev_mode.
Note that tegra calls the fbdev cma helper restore function also from
it's driver-load callback. Which is a bit against current practice,
since usually the call is only from ->lastclose, and initial setup is
done by drm_fb_helper_initial_config.
Also add the relevant drm DocBook entry.
v2: Add promised WARN to restore_fbdev_mode.
We have two classes of framebuffer
- Created by the driver (atm only for fbdev), and the driver holds
onto the last reference count until destruction.
- Created by userspace and associated with a given fd. These
framebuffers will be reaped when their assoiciated fb is closed.
Now these two cases are set up differently, the framebuffers are on
different lists and hence destruction needs to clean up different
things. Also, for userspace framebuffers we remove them from any
current usage, whereas for internal framebuffers it is assumed that
the driver has done this already.
Long story short, we need two different ways to cleanup such drivers.
Three functions are involved in total:
- drm_framebuffer_remove: Convenience function which removes the fb
from all active usage and then drops the passed-in reference.
- drm_framebuffer_unregister_private: Will remove driver-private
framebuffers from relevant lists and drop the corresponding
references. Should be called for driver-private framebuffers before
dropping the last reference (or like for a lot of the drivers where
the fbdev is embedded someplace else, before doing the cleanup
manually).
- drm_framebuffer_cleanup: Final cleanup for both classes of fbs,
should be called by the driver's ->destroy callback once the last
reference is gone.
This patch just rolls out the new interfaces and updates all drivers
(by adding calls to drm_framebuffer_unregister_private at all the
right places)- no functional changes yet. Follow-on patches will move
drm core code around and update the lifetime management for
framebuffers, so that we are no longer required to keep framebuffers
alive by locking mode_config.mutex.
I've also updated the kerneldoc already.
vmwgfx seems to again be a bit special, at least I haven't figured out
how the fbdev support in that driver works. It smells like it's
external though.
v2: The i915 driver creates another private framebuffer in the
load-detect code. Adjust its cleanup code, too.
Reviewed-by: Rob Clark <rob@ti.com>
With more fine-grained locking we can no longer rely on the big
mode_config lock to prevent concurrent access to mode resources
like framebuffers. Instead a framebuffer becomes accessible to
other threads as soon as it is added to the relevant lookup
structures. Hence it needs to be fully set up by the time drivers
call drm_framebuffer_init.
This patch here is the drivers part of that reorg. Nothing really fancy
going on safe for three special cases.
- exynos needs to be careful to properly unref all handles.
- nouveau gets a resource leak fixed for free: one of the error
cases didn't cleanup the framebuffer, which is now moot since
the framebuffer is only registered once it is fully set up.
- vmwgfx requires a slight reordering of operations, I'm hoping I didn't
break anything (but it's refcount management only, so should be safe).
v2: Split out exynos, since it's a bit more hairy than expected.
v3: Drop bogus cirrus hunk noticed by Richard Wilbur.
v4: Split out vmwgfx since there's a small change in return values.
Reviewed-by: Rob Clark <rob@ti.com> (core + omapdrm)
The drm_gem_cma_create() function never returns NULL but rather an error
encoded in the return value using the ERR_PTR() macro. Callers therefore
need to check for errors using the IS_ERR() macro. This change allows
drivers to handle contiguous DMA allocation failures gracefully.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
The debug message showing the resolution of a framebuffer to be
allocated is missing a closing parenthesis.
This patchset introduces a set of helper function for implementing the KMS
framebuffer layer for drivers which use the DRM GEM CMA helper function.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
[Make DRM_KMS_CMA_HELPER a boolean Kconfig option]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
