Pull drm updates from Dave Airlie:
"I Was Almost Tempted To Capitalise Every Word, but then I decided I
couldn't read it myself!
I've also got one pull request for the sti driver outstanding. It
relied on a commit in Greg's tree and I didn't find out in time, that
commit is in your tree now so I might send that along once this is
merged.
I also had the accidental misfortune to have access to a Skylake on my
desk for a few days, and I've had to encourage Intel to try harder,
which seems to be happening now.
Here is the main drm-next pull request for 4.4.
Highlights:
New driver:
vc4 driver for the Rasberry Pi VPU.
(From Eric Anholt at Broadcom.)
Core:
Atomic fbdev support
Atomic helpers for runtime pm
dp/aux i2c STATUS_UPDATE handling
struct_mutex usage cleanups.
Generic of probing support.
Documentation:
Kerneldoc for VGA switcheroo code.
Rename to gpu instead of drm to reflect scope.
i915:
Skylake GuC firmware fixes
HPD A support
VBT backlight fallbacks
Fastboot by default for some systems
FBC work
BXT/SKL workarounds
Skylake deeper sleep state fixes
amdgpu:
Enable GPU scheduler by default
New atombios opcodes
GPUVM debugging options
Stoney support.
Fencing cleanups.
radeon:
More efficient CS checking
nouveau:
gk20a instance memory handling improvements.
Improved PGOB detection and GK107 support
Kepler GDDR5 PLL statbility improvement
G8x/GT2xx reclock improvements
new userspace API compatiblity fixes.
virtio-gpu:
Add 3D support - qemu 2.5 has it merged for it's gtk backend.
msm:
Initial msm88896 (snapdragon 8200)
exynos:
HDMI cleanups
Enable mixer driver byt default
Add DECON-TV support
vmwgfx:
Move to using memremap + fixes.
rcar-du:
Add support for R8A7793/4 DU
armada:
Remove support for non-component mode
Improved plane handling
Power savings while in DPMS off.
tda998x:
Remove unused slave encoder support
Use more HDMI helpers
Fix EDID read handling
dwhdmi:
Interlace video mode support for ipu-v3/dw_hdmi
Hotplug state fixes
Audio driver integration
imx:
More color formats support.
tegra:
Minor fixes/improvements"
[ Merge fixup: remove unused variable 'dev' that had all uses removed in
commit 4e270f088011: "drm/gem: Drop struct_mutex requirement from
drm_gem_mmap_obj" ]
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (764 commits)
drm/vmwgfx: Relax irq locking somewhat
drm/vmwgfx: Properly flush cursor updates and page-flips
drm/i915/skl: disable display side power well support for now
drm/i915: Extend DSL readout fix to BDW and SKL.
drm/i915: Do graphics device reset under forcewake
drm/i915: Skip fence installation for objects with rotated views (v4)
vga_switcheroo: Drop client power state VGA_SWITCHEROO_INIT
drm/amdgpu: group together common fence implementation
drm/amdgpu: remove AMDGPU_FENCE_OWNER_MOVE
drm/amdgpu: remove now unused fence functions
drm/amdgpu: fix fence fallback check
drm/amdgpu: fix stoping the scheduler timeout
drm/amdgpu: cleanup on error in amdgpu_cs_ioctl()
drm/i915: Fix locking around GuC firmware load
drm/amdgpu: update Fiji's Golden setting
drm/amdgpu: update Fiji's rev id
drm/amdgpu: extract common code in vi_common_early_init
drm/amd/scheduler: don't oops on failure to load
drm/amdgpu: don't oops on failure to load (v2)
drm/amdgpu: don't VT switch on suspend
Since
commit 131e663bd6f1055caaff128f9aa5071d227eeb72
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Thu Jul 9 23:32:33 2015 +0200
drm/gem: rip out drm vma accounting for gem mmaps
there is no need for this any more.
v2: Fixup compile noise spotted by 0-day build.
Link: http://mid.gmane.org/1444894601-5200-9-git-send-email-daniel.vetter@ffwll.ch
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Since David Herrmann's mmap vma manager rework we don't need to grab
dev->struct_mutex any more to prevent races when looking up the mmap
offset. Drop it and instead don't forget to use the unref_unlocked
variant (since the drm core still cares).
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Rob Clark <robdclark@gmail.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
This function takes two locks, both of them the wrong ones. This
wasn't an oversight from my fb locking rework since both patches
landed in parallel. We really only need fb_lock when walking that
list, since everything we can reach from that is refcounted properly
already.
v2: Drop unused dev spotted by 0day.
Fix warnings related to size_t when building for 64-bit architectures:
drivers/gpu/drm/drm_gem_cma_helper.c: In function ‘drm_gem_cma_create’:
drivers/gpu/drm/drm_gem_cma_helper.c:114:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘size_t’ [-Wformat=]
size);
drivers/gpu/drm/drm_gem_cma_helper.c: In function ‘drm_gem_cma_describe’:
drivers/gpu/drm/drm_gem_cma_helper.c:393:4: warning: format ‘%d’ expects argument of type ‘int’, but argument 8 has type ‘size_t’ [-Wformat=]
off, &cma_obj->paddr, cma_obj->vaddr, obj->size);
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
drm_gem_object_release() called later in the drm_gem_cma_free_object()
function already calls this, so there's no need to do this explicitly.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Thierry Reding <treding@nvidia.com>
This function is similar to drm_gem_cma_dumb_create() but targetted at
kernel internal users so that they can override the pitch and size
requirements of the dumb buffer.
It is important to make this difference because the IOCTL says that the
pitch and size fields are to be considered outputs and therefore should
not be used in computations of the framebuffer size. Internal users may
still want to use this code to avoid duplication and at the same time
pass on additional, driver-specific restrictions on the pitch and size.
While at it, convert the R-Car DU driver, the single user that overrides
the pitch, to use the new internal helper.
Most of the functions already have the beginnings of kerneldoc comments
but are using the wrong opening marker. Use the correct opening marker
and flesh out the comments so that they can be integrated with the DRM
DocBook document.
Allows importing dma_reservation_objects from a dma-buf.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Makes the code a bit more readable.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Use the %pad printk specifier to print dma_addr_t variables. This fixes
warnings on platforms where dma_addr_t has a different size than int or
size_t.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
The GEM CMA helpers uses a custom mmap implementation based on
remap_pfn_range(). While this works when the buffer DMA and physical
addresses are identical, it fails to take IOMMU into account and tries
to mmap the buffer to userspace using the DMA virtual address instead of
the physical address. This results in mapping random physical pages when
the device is behind an IOMMU.
Use the DMA mapping dma_mmap_writecombine() function instead.
Tested-by: Philipp Zabel <philipp.zabel@gmail.com>
The sg_table made when gem cma is created isn't used anywhere. The sgt
of struct drm_gem_cma_object will have only sg_tabel imported.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Pull drm tree changes from Dave Airlie:
"This is the main drm pull request, I have some overlap with sound and
arm-soc, the sound patch is acked and may conflict based on -next
reports but should be a trivial fixup, which I'll leave to you!
Highlights:
- new drivers:
MSM driver from Rob Clark
- non-drm:
switcheroo and hdmi audio driver support for secondary GPU
poweroff, so drivers can use runtime PM to poweroff the GPUs. This
can save 5 or 6W on some optimus laptops.
- drm core:
combined GEM and TTM VMA manager
per-filp mmap permission tracking
initial rendernode support (via a runtime enable for now, until we get api stable),
remove old proc support,
lots of cleanups of legacy code
hdmi vendor infoframes and 4k modes
lots of gem/prime locking and races fixes
async pageflip scaffolding
drm bridge objects
- i915:
Haswell PC8+ support and eLLC support, HDMI 4K support, initial
per-process VMA pieces, watermark reworks, convert to generic hdmi
infoframes, encoder reworking, fastboot support,
- radeon:
CIK PM support, remove 3d blit code in favour of DMA engines,
Berlin GPU support, HDMI audio fixes
- nouveau:
secondary GPU power down support for optimus laptops, lots of
fixes, use MSI, VP3 engine support
- exynos:
runtime pm support for g2d, DT support, remove non-DT,
- tda998x i2c driver:
lots of fixes for sync issues
- gma500:
lots of cleanups
- rcar:
add LVDS support, fbdev emulation,
- tegra:
just minor fixes"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (684 commits)
drm/exynos: Fix build error with exynos_drm_connector.c
drm/exynos: Remove non-DT support in exynos_drm_fimd
drm/exynos: Remove non-DT support in exynos_hdmi
drm/exynos: Remove non-DT support in exynos_drm_g2d
drm/exynos: Remove non-DT support in exynos_hdmiphy
drm/exynos: Remove non-DT support in exynos_ddc
drm/exynos: Make Exynos DRM drivers depend on OF
drm/exynos: Consider fallback option to allocation fail
drm/exynos: fimd: move platform data parsing to separate function
drm/exynos: fimd: get signal polarities from device tree
drm/exynos: fimd: replace struct fb_videomode with videomode
drm/exynos: check a pixel format to a particular window layer
drm/exynos: fix fimd pixel format setting
drm/exynos: Add NULL pointer check
drm/exynos: Remove redundant error messages
drm/exynos: Add missing of.h header include
drm/exynos: Remove redundant NULL check in exynos_drm_buf
drm/exynos: add device tree support for rotator
drm/exynos: Add missing includes
drm/exynos: add runtime pm interfaces to g2d driver
All the gem based kms drivers really want the same function to
destroy a dumb framebuffer backing storage object.
So give it to them and roll it out in all drivers.
This still leaves the option open for kms drivers which don't use GEM
for backing storage, but it does decently simplify matters for gem
drivers.
Acked-by: Inki Dae <inki.dae@samsung.com>
Cc: Intel Graphics Development <intel-gfx@lists.freedesktop.org>
Cc: Ben Skeggs <skeggsb@gmail.com>
Reviwed-by: Rob Clark <robdclark@gmail.com>
Cc: Alex Deucher <alexdeucher@gmail.com>
Acked-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Use the new vma manager instead of the old hashtable. Also convert all
drivers to use the new convenience helpers. This drops all the
(map_list.hash.key << PAGE_SHIFT) non-sense.
Locking and access-management is exactly the same as before with an
additional lock inside of the vma-manager, which strictly wouldn't be
needed for gem.
v2:
- rebase on drm-next
- init nodes via drm_vma_node_reset() in drm_gem.c
v3:
- fix tegra
v4:
- remove duplicate if (drm_vma_node_has_offset()) checks
- inline now trivial drm_vma_node_offset_addr() calls
v5:
- skip node-reset on gem-init due to kzalloc()
- do not allow mapping gem-objects with offsets (backwards compat)
- remove unneccessary casts
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
PTR_RET is now deprecated. Use PTR_ERR_OR_ZERO instead.
We can use prime helpers instead.
Instead of using the dma_buf functionality for GEM CMA, we can use prime
helpers if we can provide low-level hook functions for GEM CMA.
The drm_gem_mmap_obj() has to be protected with dev->struct_mutex,
but some caller functions do not. So it adds mutex lock to missing
callers and adds assertion to check whether drm_gem_mmap_obj() is
called with mutex lock or not.
Signed-off-by: YoungJun Cho <yj44.cho@samsung.com>
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
The CMA-specific mapping code will be used to implement dma-buf mmap
support.
Signed-off-by: Rob Clark <robdclark@gmail.com>
This allows creating a GEM CMA object without an associated DMA memory
buffer, and will be used to implement DRM PRIME support.
Add helper to display fb's which can be used directly in drm_info_list:
static struct drm_info_list foo_debugfs_list[] = {
{ "fb", drm_fb_cma_debugfs_show, 0 },
to display information about CMA fb objects, as well as a
drm_gem_cma_describe() which can be used if the driver bothers to keep
a list of CMA GEM objects.
Many embedded drm devices do not have a IOMMU and no dedicated
memory for graphics. These devices use CMA (Contiguous Memory
Allocator) backed graphics memory. This patch provides helper
functions to be able to share the code. The code technically does
not depend on CMA as the backend allocator, the name has been chosen
because CMA makes for a nice, short but still descriptive function
prefix.
Tested-by: Lars-Peter Clausen <lars@metafoo.de>
[Make DRM_GEM_CMA_HELPER a boolean Kconfig option]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
