commit 7c420636860a719049fae9403e2c87804f53bdde upstream.
Some machines have an lvds child device in vbt even though a panel is
not attached. To make detection more reliable we now also check the lvds
config bits available in the vbt.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1665766
Cc: stable@vger.kernel.org
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190416114607.1072-1-patrik.r.jakobsson@gmail.com
No one looks at it, only i915/gma500 lvds even bother to fill it
out. I guess a very old plan was to use this for filtering modes,
but that's already done within the edid parser.
v2: Move misplaced hunk to this patch.
Reviewed-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-18-git-send-email-daniel.vetter@ffwll.ch
The functions pci_dev_put() and psb_intel_i2c_destroy() test whether
their argument is NULL and then return immediately.
Thus the tests around their calls are not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Link: http://patchwork.freedesktop.org/patch/msgid/f1a0fd83-4320-f3db-e1bb-3b9832a4429f@users.sourceforge.net
Done with coccinelle for the most part. However, it thinks '...' is
part of the semantic patch, so I put an 'int DOTDOTDOT' placeholder
in its place and got rid of it with sed afterwards.
identifier dev, encoder, funcs;
int drm_encoder_init(struct drm_device *dev,
struct drm_encoder *encoder,
const struct drm_encoder_funcs *funcs,
int encoder_type
+ ,const char *name, int DOTDOTDOT
int encoder_type
expression E1, E2, E3, E4;
drm_encoder_init(E1, E2, E3, E4
+ ,NULL
v2: Add ', or NULL...' to @name kernel doc (Jani)
Annotate the function with __printf() attribute (Jani)
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449670818-2966-1-git-send-email-ville.syrjala@linux.intel.com
I want to remove the core ones since with atomic drivers system
suspend/resume is solved much differently. And there's only 2 drivers
(nouveau besides gma500) really using them.
v2: Fixup build noise 0day reported.
Cc: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449218769-16577-13-git-send-email-daniel.vetter@ffwll.ch
Reviewed-by: Thierry Reding <treding@nvidia.com> (v1)
They are not to be modified.
Generated using the semantic patch:
const struct drm_crtc_helper_funcs *
- struct drm_crtc_helper_funcs *
+ const struct drm_crtc_helper_funcs *
const struct drm_encoder_helper_funcs *
- struct drm_encoder_helper_funcs *
+ const struct drm_encoder_helper_funcs *
const struct drm_connector_helper_funcs *
- struct drm_connector_helper_funcs *
+ const struct drm_connector_helper_funcs *
const struct drm_plane_helper_funcs *
- struct drm_plane_helper_funcs *
+ const struct drm_plane_helper_funcs *
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Introduce generic functions to register and unregister connectors. This
provides a common place to add and remove associated user space
interfaces.
Signed-off-by: Thomas Wood <thomas.wood@intel.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Now that CRTC's have a primary plane, there's no need to track the
framebuffer in the CRTC. Replace all references to the CRTC fb with the
primary plane's fb.
This patch was generated by the Coccinelle semantic patching tool using
the following rules:
@@ struct drm_crtc C; @@
- (C).fb
+ C.primary->fb
@@ struct drm_crtc *C; @@
- (C)->fb
+ C->primary->fb
v3: Generate patch via coccinelle. Actual removal of crtc->fb has been
moved to a subsequent patch.
v2: Fixup several lingering crtc->fb instances that were missed in the
first patch iteration. [Rob Clark]
Signed-off-by: Matt Roper <matthew.d.roper@intel.com>
Reviewed-by: Rob Clark <robdclark@gmail.com>
With the recent addition of locking checks in
commit 62ff94a5492175759546f8bc61383189d6b49122
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
AuthorDate: Thu Jan 23 22:18:47 2014 +0100
drm/crtc-helper: remove LOCKING from kerneldoc
drm_add_edid_modes started to WARN about the mode_config.mutex not
being held in the lvds and dp initialization code.
Now since this is init code locking is fairly redudant if it wouldn't
be for the drm core registering sysfs files a bit early. And the
locking WARNINGs nicely enforce that indeed all access to the mode
lists are properly protected. And a full audit shows that only i915
and gma500 touch the modes lists at init time.
Hence I've opted to wrap up this entire mode detection sequence for
fixed panels with the mode_config mutex for both lvds and edp outputs.
Acked-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
The psb_intel_encoder is generic and should be named appropriately
The psb_intel_connector is generic and should be named appropriately
The psb_intel_crtc is generic and should be named appropriately
Signed-off-by: Rob Clark <rob@ti.com>
Introduce the eDP support into the driver.
This has been reworked a bit because kernel driver proper uses encoder/connectors
while the legacy Intel driver uses the old output stuff.
It also diverges on the backlight handling. The legacy Intel driver adds a panel
abstraction based upon the i915 one. It's only really used for backlight bits
and we have a perfectly good backlight abstraction which can extend instead.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
[ported to upstream driver, redid backlight abstraction]
Signed-off-by: Alan Cox <alan@linux.intel.com>
The passed mode must not be modified by the operation, make it const.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
In particular clean up the errata handling and correct the crtc masks. We do
this a bit differently using our device abstraction for neatness.
This doesn't address the ACPI opregion and hotplug plumbing, nor the IRQ related
changes that will need. It touches on backlight init but the full backlight
support is not in this change set.
Introduce a panel presence check for Cedartrail. Non netbook devices don't
necessarily have a panel attached.
cdv_intel_lvds_set_brightness() is only used in commented out code in
cdv_set_brightness().
Replace psb_intel_output with psb_intel_encoder and psb_intel_connector.
Things will need to be cleaned up and tested so consider this an initial
patch for Cedarview.
Again this is similar but has some differences so we have a set of plug in
support. This does make the driver bigger than is needed in some respects
but the tradeoff for maintainability is huge.
