Now that CRTC's have a primary plane, there's no need to track the
framebuffer in the CRTC. Replace all references to the CRTC fb with the
primary plane's fb.
This patch was generated by the Coccinelle semantic patching tool using
the following rules:
@@ struct drm_crtc C; @@
- (C).fb
+ C.primary->fb
@@ struct drm_crtc *C; @@
- (C)->fb
+ C->primary->fb
v3: Generate patch via coccinelle. Actual removal of crtc->fb has been
moved to a subsequent patch.
v2: Fixup several lingering crtc->fb instances that were missed in the
first patch iteration. [Rob Clark]
Signed-off-by: Matt Roper <matthew.d.roper@intel.com>
Reviewed-by: Rob Clark <robdclark@gmail.com>
The psb_intel_crtc is generic and should be named appropriately
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
The use of pointer sender should be after the NULL check.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
Signed-off-by: Rob Clark <rob@ti.com>
Drop the NULL test for dev since it never be NULL.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Introduce the eDP support into the driver.
This has been reworked a bit because kernel driver proper uses encoder/connectors
while the legacy Intel driver uses the old output stuff.
It also diverges on the backlight handling. The legacy Intel driver adds a panel
abstraction based upon the i915 one. It's only really used for backlight bits
and we have a perfectly good backlight abstraction which can extend instead.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
[ported to upstream driver, redid backlight abstraction]
drivers/built-in.o: In function `mdfld_dsi_connector_set_property':
mdfld_dsi_output.c:(.text+0x6e909): undefined reference to `mdfld_set_brightness'
make: *** [.tmp_vmlinux1] Error 1
Nobody uses 'config' parameter.
We need to merge this ahead of some of the cleanup because a lot of needed
cleanup spans both new and old chips. If we try and clean up and the merge
we end up fighting ourselves.
[With a load of the cleanup stuff folded in, register stuff reworked sanely]
