path: root/drivers/gpu/drm/i915/i915_drv.h
2012-04-02drm/i915: disable ppgtt on snb when dmar is enabledDaniel Vetter
Totally unexpected that this regressed. Luckily it sounds like we just need to have dmar disable on the igfx, not the entire system. At least that's what a few days of testing between Tony Vroon and me indicates. Reported-by: Tony Vroon <tony@linx.net> Cc: Tony Vroon <tony@linx.net> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43024 Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-04-01drm/i915: allow to select rc6 modes via kernel parameterEugeni Dodonov
This allows to select which rc6 modes are to be used via kernel parameter, via a bitmask parameter. E.g.: - to enable rc6, i915_enable_rc6=1 - to enable rc6 and deep rc6, i915_enable_rc6=3 - to enable rc6 and deepest rc6, use i915_enable_rc6=5 - to enable rc6, deep and deepest rc6, use i915_enable_rc6=7 Please keep in mind that the deepest RC6 state really should NOT be used by default, as it could potentially worsen the issues with deep RC6. So do enable it only when you know what you are doing. However, having it around could help solving possible future rc6-related issues and their debugging on user machines. Note that this changes behavior - previously, value of 1 would enable both RC6 and deep RC6. Now it should only enable RC6 and deep/deepest RC6 stages must be enabled manually. v2: address Chris Wilson comments and clean up the code. References: https://bugs.freedesktop.org/show_bug.cgi?id=42579 Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Ben Widawsky <benjamin.widawsky@intel.com> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-29drm/i915: i2c: unconditionally set up gpio fallbackDaniel Vetter
This way we can simplify the setup and teardown a bit. Because we don't actually allocate anything anymore for the force_bit case, we can now convert that into a boolean. Also and the functionality supported by the bit-banging together with what gmbus can do, so that this doesn't randomly change any more. v2: Chris Wilson noticed that I've mixed up && and & ... v3: Clarify an if block as suggested by Eugeni Dodonov. Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-29drm/i915: merge gmbus and gpio i2c adpater into oneDaniel Vetter
... and directly call the newly exported i2c bit-banging functions. The code is still pretty convoluted because we only set up the gpio i2c stuff when actually falling back, resulting in more complexity than necessary. This will be fixed up in the next patch. v2: Use exported i2c_bit_algo vtable instead of exported functions. Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-29drm/i915: merge struct intel_gpio into struct intel_gmbusDaniel Vetter
When we set up the gpio fallback, we always have a 1:1 relationship with an intel_gmbus. Exploit that to store all gpio related data in there, too. This is a preparation step to merge the tw i2c adapters controlling the same bus into one. Just mundane code-munging in this patch. Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-29drm/i915: add dev_priv to intel_gmbusDaniel Vetter
This way we can free up the bus->adaptor.algo_data pointer and make it available for use with the bitbanging fallback algo. Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-27drm/i915: error_buffer->ring should be signedDaniel Vetter
gcc seems to get uber-anal recently about these things. Clarification from Dan Carpenter: "Sorry, I should have said that it's not a gcc warning, it's a smatch thing. But also it's not uber-anal. It's the exact level of anality which is required to make the == -1 test work. You can compare unsigned int and longs to -1 and it works but for smaller types it doesn't." Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-15drm/i915: Record the position of the request upon errorChris Wilson
So that we can tally the request against the command sequence in the ringbuffer, or merely jump to the interesting locations. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-15drm/i915: Record the in-flight requests at the time of a hangChris Wilson
Being able to tally the list of outstanding requests with the sequence of commands in the ringbuffer is often useful evidence with respect to driver corruption. Note that since this is the umpteenth per-ring data structure to be added to the error state, I've coallesced the nearby loops (the ringbuffer and batchbuffer) into a single structure along with the list of requests. A later task would be to refactor the ring register state into the same structure. v2: Fix pretty printing of requests so that they are parsed correctly by intel_error_decode and use the 0x%08x format for seqno for consistency Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-15drm/i915: Record the tail at each request and use it to estimate the headChris Wilson
By recording the location of every request in the ringbuffer, we know that in order to retire the request the GPU must have finished reading it and so the GPU head is now beyond the tail of the request. We can therefore provide a conservative estimate of where the GPU is reading from in order to avoid having to read back the ring buffer registers when polling for space upon starting a new write into the ringbuffer. A secondary effect is that this allows us to convert intel_ring_buffer_wait() to use i915_wait_request() and so consolidate upon the single function to handle the complicated task of waiting upon the GPU. A necessary precaution is that we need to make that wait uninterruptible to match the existing conditions as all the callers of intel_ring_begin() have not been audited to handle ERESTARTSYS correctly. By using a conservative estimate for the head, and always processing all outstanding requests first, we prevent a race condition between using the estimate and direct reads of I915_RING_HEAD which could result in the value of the head going backwards, and the tail overflowing once again. We are also careful to mark any request that we skip over in order to free space in ring as consumed which provides a self-consistency check. Given sufficient abuse, such as a set of unthrottled GPU bound cairo-traces, avoiding the use of I915_RING_HEAD gives a 10-20% boost on Sandy Bridge (i5-2520m): firefox-paintball 18927ms -> 15646ms: 1.21x speedup firefox-fishtank 12563ms -> 11278ms: 1.11x speedup which is a mild consolation for the performance those traces achieved from exploiting the buggy autoreported head. v2: Add a few more comments and make request->tail a conservative estimate as suggested by Daniel Vetter. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> [danvet: resolve conflicts with retirement defering and the lack of the autoreport head removal (that will go in through -fixes).] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-14drm/i915: Fix race condition in accessing GMBUSYufeng Shen
GMBUS has several ports and each has it's own corresponding I2C adpater. When multiple I2C adapters call gmbus_xfer() at the same time there is a race condition in using the underlying GMBUS controller. Fixing this by adding a mutex lock when calling gmbus_xfer(). v2: Moved gmbus_mutex below intel_gmbus and added comments. Rebased to drm-intel-next-queued. Signed-off-by: Yufeng Shen <miletus@chromium.org> [danvet: Shortened the gmbus_mutex comment a bit and add the patch revision comment to the commit message.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-14drm/i915: add a "force-dvi" HDMI audio modeWu Fengguang
When HDMI-DVI converter is used, it's not only necessary to turn off audio, but also to disable HDMI_MODE_SELECT and video infoframe. Since the DVI mode is mainly tied to audio functionality from end user POV, add a new "force-dvi" audio mode: xrandr --output HDMI1 --set audio force-dvi Note that most users won't need to set this and happily rely on the EDID based DVI auto detection. Reported-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-13drm/i915: fixup seqno allocation logic for lazy_requestDaniel Vetter
Currently we reserve seqnos only when we emit the request to the ring (by bumping dev_priv->next_seqno), but start using it much earlier for ring->oustanding_lazy_request. When 2 threads compete for the gpu and run on two different rings (e.g. ddx on blitter vs. compositor) hilarity ensued, especially when we get constantly interrupted while reserving buffers. Breakage seems to have been introduced in commit 6f392d548658a17600da7faaf8a5df25ee5f01f6 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Sat Aug 7 11:01:22 2010 +0100 drm/i915: Use a common seqno for all rings. This patch fixes up the seqno reservation logic by moving it into i915_gem_next_request_seqno. The ring->add_request functions now superflously still return the new seqno through a pointer, that will be refactored in the next patch. Note that with this change we now unconditionally allocate a seqno, even when ->add_request might fail because the rings are full and the gpu died. But this does not open up a new can of worms because we can already leave behind an outstanding_request_seqno if e.g. the caller gets interrupted with a signal while stalling for the gpu in the eviciton paths. And with the bugfix we only ever have one seqno allocated per ring (and only that ring), so there are no ordering issues with multiple outstanding seqnos on the same ring. v2: Keep i915_gem_get_seqno (but move it to i915_gem.c) to make it clear that we only have one seqno counter for all rings. Suggested by Chris Wilson. v3: As suggested by Chris Wilson use i915_gem_next_request_seqno instead of ring->oustanding_lazy_request to make the follow-up refactoring more clearly correct. Also improve the commit message with issues discussed on irc. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=45181 Tested-by: Nicolas Kalkhof nkalkhof()at()web.de Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-12drm/i915: check gtfifodbg after possibly failed writesBen Widawsky
If we don't have a sufficient number of free entries in the FIFO, we proceed to do a write anyway. With this check we should have a clue if that write actually failed or not. After some discussion with Daniel Vetter regarding his original complaint, we agreed upon this. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-10Merge remote-tracking branch 'airlied/drm-fixes' into drm-intel-next-queuedDaniel Vetter
Back-merge from drm-fixes into drm-intel-next to sort out two things: - interlaced support: -fixes contains a bugfix to correctly clear interlaced configuration bits in case the bios sets up an interlaced mode and we want to set up the progressive mode (current kernels don't support interlaced). The actual feature work to support interlaced depends upon (and conflicts with) this bugfix. - forcewake voodoo to workaround missed IRQ issues: -fixes only enabled this for ivybridge, but some recent bug reports indicate that we need this on Sandybridge, too. But in a slightly different flavour and with other fixes and reworks on top. Additionally there are some forcewake cleanup patches heading to -next that would conflict with currrent -fixes. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-09drm/i915: enable ppgttDaniel Vetter
We want to unconditionally enable ppgtt for two reasons: - Windows uses this on snb and later. - We need the basic hw support to work before we can think about real per-process address spaces and other cool features we want. But Chris Wilson was complaining all over irc and intel-gfx that this will blow up if we don't have a module option to disable it. Hence add one, to prevent this. ppgtt support seems to slightly change the timings and make crashy things slightly more or less crashy. Now in my testing and the testing this got on troublesome snb machines, it seems to have improved things only. But on ivb it makes quite a few crashes happen much more often, see https://bugs.freedesktop.org/show_bug.cgi?id=41353 Luckily Eugeni Dodonov seems to have a set of workarounds that fix this issue. v2: Don't try to enable ppgtt on pre-snb. v3: Pimp commit message and make Chris Wilson less grumpy by adding a module option. v4: New try at making Chris Wilson happy. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-09drm/i915: ppgtt binding/unbinding supportDaniel Vetter
This adds support to bind/unbind objects and wires it up. Objects are only put into the ppgtt when necessary, i.e. at execbuf time. Objects are still unconditionally put into the global gtt. v2: Kill the quick hack and explicitly pass cache_level to ppgtt_bind like for the global gtt function. Noticed by Chris Wilson. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-09drm/i915: initialization/teardown for the aliasing ppgttDaniel Vetter
This just adds the setup and teardown code for the ppgtt PDE and the last-level pagetables, which are fixed for the entire lifetime, at least for the moment. v2: Kill the stray debug printk noted by and improve the pte definitions as suggested by Chris Wilson. v3: Clean up the aperture stealing code as noted by Ben Widawsky. v4: Paint the init code in a more pleasing colour as suggest by Chris Wilson. v5: Explain the magic numbers noticed by Ben Widawsky. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-09drm/i915: dump even more into the error_stateDaniel Vetter
Chris Wilson and me have again stared at funny error states and it's been pretty clear from the start that something was seriously amiss. The seqnos last seen by the cpu were a few hundred behind those that the gpu could have possibly emitted last before it died ... Chris now tracked it down (hopefully, definit verdict's still out), but in hindsight we'd have found the bug by simply dumping the cpu side tracking of the ring head and tail registers. Fix this and prevent an identical time-waster in the future. Because the hangs always involved semaphores in one way or another, we've tried to dump the mbox registers, but couldn't find any inconsistencies. Still, dump them too. Reviewed-and-wanted-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-02-08drm/i915: swizzling support for snb/ivbDaniel Vetter
We have to do this manually. Somebody had a Great Idea. I've measured speed-ups just a few percent above the noise level (below 5% for the best case), but no slowdows. Chris Wilson measured quite a bit more (10-20% above the usual snb variance) on a more recent and better tuned version of sna, but also recorded a few slow-downs on benchmarks know for uglier amounts of snb-induced variance. v2: Incorporate Ben Widawsky's preliminary review comments and elaborate a bit about the performance impact in the changelog. v3: Add a comment as to why we don't need to check the 3rd memory channel. v4: Fixup whitespace. Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-29drm/i915: add per-ring fault reg to error_stateDaniel Vetter
This was pretty handy when figuring out what exactly went wrong with ppgtt and it might also be useful when we stop filling the entire gart with scratch page entries. Also add the gen6+ DONE reg while at it. v2: Chris Wilson suggested to allocate the error_state with kzalloc for better paranoia. Also kill existing spurious clears of the error_state while at it. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-29drm/i915: Separate fence pin counting from normal bind pin countingChris Wilson
In order to correctly account for reserving space in the GTT and fences for a batch buffer, we need to independently track whether the fence is pinned due to a fenced GPU access in the batch or whether the buffer is pinned in the aperture. Currently we count the fenced as pinned if the buffer has already been seen in the execbuffer. This leads to a false accounting of available fence registers, causing frequent mass evictions. Worse, if coupled with the change to make i915_gem_object_get_fence() report EDADLK upon fence starvation, the batchbuffer can fail with only one fence required... Fixes intel-gpu-tools/tests/gem_fenced_exec_thrash Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38735 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Tested-by: Paul Neumann <paul104x@yahoo.de> [danvet: Resolve the functional conflict with Jesse Barnes sprite patches, acked by Chris Wilson on irc.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-29drm/i915: collect more per ring error stateDaniel Vetter
Based on a patch by Ben Widawsky, but with different colors for the bikeshed. In contrast to Ben's patch this one doesn't add the fault regs. Afaics they're for the optional page fault support which - we're not enabling - and which seems to be unsupported by the hw team. Recent bspec lacks tons of information about this that the public docs released half a year back still contain. Also dump ring HEAD/TAIL registers - I've recently seen a few error_state where just guessing these is not good enough. v2: Also dump INSTPM for every ring. v3: Fix a few really silly goof-ups spotted by Chris Wilson. Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-29drm/i915: refactor ring error state capture to use arraysDaniel Vetter
The code already got unwieldy and we want to dump more per-ring registers. Only functional change is that we now also capture the video ring registers on ilk. v2: fixup a refactor fumble spotted by Chris Wilson. Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-26drm/i915: argument to control retiring behaviorBen Widawsky
Sometimes it may be the case when we idle the gpu or wait on something we don't actually want to process the retiring list. This patch allows callers to choose the behavior. Reviewed-by: Keith Packard <keithp@keithp.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-19drm/i915: protect force_wake_(get|put) with the gt_lockDaniel Vetter
The problem this patch solves is that the forcewake accounting necessary for register reads is protected by dev->struct_mutex. But the hangcheck and error_capture code need to access registers without grabbing this mutex because we hold it while waiting for the gpu. So a new lock is required. Because currently the error_state capture is called from the error irq handler and the hangcheck code runs from a timer, it needs to be an irqsafe spinlock (note that the registers used by the irq handler (neglecting the error handling part) only uses registers that don't need the forcewake dance). We could tune this down to a normal spinlock when we rework the error_state capture and hangcheck code to run from a workqueue. But we don't have any read in a fastpath that needs forcewake, so I've decided to not care much about overhead. This prevents tests/gem_hangcheck_forcewake from i-g-t from killing my snb on recent kernels - something must have slightly changed the timings. On previous kernels it only trigger a WARN about the broken locking. v2: Drop the previous patch for the register writes. v3: Improve the commit message per Chris Wilson's suggestions. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2012-01-17drm/i915: add a LLC feature flag in device descriptionEugeni Dodonov
LLC is not SNB/IVB-specific, so we should check for it in a more generic way. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Eric Anholt <eric@anholt.net> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-17drm/i915: kill i915_mem.cDaniel Vetter
Some decent history digging indicates that this was to be used for the GLX_MESA_allocate_memory extension but never actually implemented for any released i915 userspace code. So just rip it out. v2: Fixup the Makefile. Acked-by: Dave Airlie <airlied@gmail.com> Cc: Keith Whitwell <keithw@vmware.com> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-03drm/i915: add SNB and IVB video sprite support v6Jesse Barnes
The video sprites support various video surface formats natively and can handle scaling as well. So add support for them using the new DRM core sprite support functions. v2: use drm specific fourcc header and defines v3: address Daniel's comments: - don't take struct mutex around register access (only needed for regs in the GT power well) - don't hold struct mutex across vblank waits - fix up update_plane API (pass obj instead of GTT offset) - add interlaced defines for sprite regs - drop unnecessary 'reg' variables - comment double buffered reg flushing Also fix w/h confusion when writing the scaling reg. v4: more fixes, address more comments from Daniel, and include Hai's fix - prevent divide by zero in scaling calculation (Hai Lan) - update to Ville's new DRM_FORMAT_* types - fix sprite watermark handling (calc based on CRTC size, separate from normal display wm) - remove private refcounts now that the fb cleanups handles things v5: add linear surface support v6: remove color key clearing & setting from update_plane For this version, I tested DPMS since it came up in the last review; DPMS off/on works ok when a video player is working under X, but for power saving we'll probably want to do something smarter. I'll leave that for a separate patch on top. Likewise with the refcounting/fb layer handling, which are really separate cleanups. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2012-01-03drm/i915: Clean up multi-threaded forcewake patchKeith Packard
We learned that the ECOBUS register was inside the GT power well, and so *did* need force wake to be read, so it gets removed from the list of 'doesn't need force wake' registers. That means the code reading ECOBUS after forcing the mt_force_wake function to be called needs to use I915_READ_NOTRACE; it doesn't need to do more force wake fun as it's already done it manually. This also adds a comment explaining why the MT forcewake testing code only needs to call mt_forcewake_get/put and not disable RC6 manually -- the ECOBUS read will return 0 if the device is in RC6 and isn't using MT forcewake, causing the test to work correctly. Signed-off-by: Keith Packard <keithp@keithp.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-12-19drm/i915: check ACTHD of all ringsDaniel Vetter
Otherwise hangcheck spuriously fires when running blitter/bsd-only workloads. Contrary to a similar patch by Ben Widawsky this does not check INSTDONE of the other rings. Chris Wilson implied that in a failure to detect a hang, most likely because INSTDONE was fluctuating. Thus only check ACTHD, which as far as I know is rather reliable. Also, blitter and bsd rings can't launch complex tasks from a single instruction (like 3D_PRIM on the render with complex or even infinite shaders). This fixes spurious gpu hang detection when running tests/gem_hangcheck_forcewake on snb/ivb. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: enable semaphores on per-device defaultsEugeni Dodonov
This adds a default setting for semaphores parameter, and enables semaphores by default on IVB. For now, as semaphores interaction with VTd causes random issues on SNB, we do not enable them by default. But they can still be enabled via the semaphores=1 kernel parameter. v2: enables semaphores on SNB when IO remapping is disabled, with base on Keith Packard patch. CC: Daniel Vetter <daniel.vetter@ffwll.ch> CC: Ben Widawsky <ben@bwidawsk.net> CC: Keith Packard <keithp@keithp.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Chris Wilson <chris@chris-wilson.co.uk> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42696 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=40564 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38862 Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: By default, enable RC6 on IVB and SNB when reasonableKeith Packard
RC6 should always work on IVB, and should work on SNB whenever IO remapping is disabled. RC6 never works on Ironlake. Make the default value for the parameter follow these guidelines. Setting the value to either 0 or 1 will force the specified behavior. Signed-off-by: Keith Packard <keithp@keithp.com> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38567 Cc: Ted Phelps <phelps@gnusto.com> Cc: Peter <pab1612@gmail.com> Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz> Cc: Andrew Lutomirski <luto@mit.edu>
2011-12-16drm/i915: prevent division by zero when asking for chipset powerEugeni Dodonov
This prevents an in-kernel division by zero which happens when we are asking for i915_chipset_val too quickly, or within a race condition between the power monitoring thread and userspace accesses via debugfs. The issue can be reproduced easily via the following command: while ``; do cat /sys/kernel/debug/dri/0/i915_emon_status; done This is particularly dangerous because it can be triggered by a non-privileged user by just reading the debugfs entry. This issue was also found independently by Konstantin Belousov <kostikbel@gmail.com>, who proposed a similar patch. Reported-by: Konstantin Belousov <kostikbel@gmail.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Keith Packard <keithp@keithp.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-11-23drm/i915: add multi-threaded forcewake supportKeith Packard
On IVB C0+ with newer BIOSes, the forcewake handshake has changed. There's now a bitfield for different driver components to keep the GT powered on. On Linux, we centralize forcewake handling in one place, so we still just need a single bit, but we need to use the new registers if MT forcewake is enabled. This needs testing on affected machines. Please reply with your tested-by if you had problems after a BIOS upgrade and this patch fixes them. v2: force MT mode. shift by 16 v3: set MT force wake bits then check ECOBUS Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42923 Tested-by: Manoj Iyer <manoj.iyer@canonical.com> Tested-by: Robert Hooker <robert.hooker@canonical.com> Tested-by: Keith Packard <keithp@keithp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-11-10drm/i915: Module parameters using '-1' as default must be signed typeKeith Packard
Testing i915_panel_use_ssc for the default value was broken, so the driver would never autodetect the correct value. Signed-off-by: Keith Packard <keithp@keithp.com> Reviewed-by: Michel Alexandre Salim <salimma@fedoraproject.org> Tested-by: Michel Alexandre Salim <salimma@fedoraproject.org> Cc: stable@kernel.org
2011-11-03drm/i915: add constants to size fence arrays and fieldsDaniel Vetter
In preparation of to support 32 fences on Ivybdrigde. Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-10-20i915: Move i915_read/write out of lineAndi Kleen
With the tracing code in there they are far too big to inline. .text savings compared to a non force inline kernel: i915_restore_display 4393 12036 +7643 i915_save_display 4295 11459 +7164 i915_handle_error 2979 6666 +3687 i915_driver_irq_handler 2923 5086 +2163 i915_ringbuffer_info 458 1661 +1203 i915_save_vga - 1200 +1200 i915_driver_irq_uninstall 453 1624 +1171 i915_driver_irq_postinstall 913 2078 +1165 ironlake_enable_drps 719 1872 +1153 i915_restore_vga - 1142 +1142 intel_display_capture_error_state 784 2030 +1246 intel_init_emon 719 2016 +1297 and more ... [AK: these are older numbers, with the new SNB forcewake checks it will be even worse] Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-10-20drm/i915: support 3 pipes on IVB+Jesse Barnes
Well almost anyway. IVB has 3 planes, pipes, transcoders, and FDI interfaces, but only 2 pipe PLLs. So two of the pipes must use the same pipe timings (e.g. 2 DP plus one other, or two HDMI with the same mode and one other, etc.). Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-By: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-By: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-10-20drm/i915: Remove "i2c_speed" nonsense from child device tableAdam Jackson
I have no evidence for this byte being used this way, and lots of counterexamples. Restore the struct to its empirical definition and patch up gmbus setup to match. Signed-off-by: Adam Jackson <ajax@redhat.com> Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-10-20Merge branch 'fix-pch-refclk' into fooKeith Packard
2011-10-20Merge branch 'edp-training-fixes' into drm-intel-nextKeith Packard
Conflicts: drivers/gpu/drm/i915/intel_dp.c Just whitespace change conflicts
2011-10-06drm/i915: Move eDP panel fixed mode from dev_priv to intel_dpKeith Packard
This value doesn't come directly from the VBT, and so is rather specific to the particular DP output. Signed-off-by: Keith Packard <keithp@keithp.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2011-10-06drm/i915: Correct eDP panel power sequencing delay computationsKeith Packard
Store the panel power sequencing delays in the dp private structure, rather than the global device structure. Who knows, maybe we'll get more than one eDP device in the future. From the eDP spec, we need the following numbers: T1 + T3 Power on to Aux Channel operation (panel_power_up_delay) This marks how long it takes the panel to boot up and get ready to receive aux channel communications. T8 Video signal to backlight on (backlight_on_delay) Once a valid video signal is being sent to the device, it can take a while before the panel is actuall showing useful data. This delay allows the panel to get something reasonable up before the backlight is turned on. T9 Backlight off to video off (backlight_off_delay) Turning the backlight off can take a moment, so this delay makes sure there is still valid video data on the screen. T10 Video off to power off (panel_power_down_delay) Presumably this delay allows the panel to perform an orderly shutdown of the display. T11 + T12 Power off to power on (panel_power_cycle_delay) So, once you turn the panel off, you have to wait a while before you can turn it back on. This delay is usually the longest in the entire sequence. Neither the VBIOS source code nor the hardware documentation has a clear mapping between the delay values they provide and those required by the eDP spec. The VBIOS code actually uses two different labels for the delay values in the five words of the relevant VBT table. **** MORE LATER *** Look at both the current hardware register settings and the VBT specified panel power sequencing timings. Use the maximum of the two delays, to make sure things work reliably. If there is no VBT data, then those values will be initialized to zero, so we'll just use the values as programmed in the hardware. Note that the BIOS just fetches delays from the VBT table to place in the hardware registers, so we should get the same values from both places, except for rounding. VBT doesn't provide any values for T1 or T2, so we'll always just use the hardware value for that. The panel power up delay is thus T1 + T2 + T3, which should be sufficient in all cases. The panel power down delay is T1 + T2 + T12, using T1+T2 as a proxy for T11, which isn't available anywhere. For the backlight delays, the eDP spec says T6 + T8 is the delay from the end of link training to backlight on and T9 is the delay from backlight off until video off. The hardware provides a 'backlight on' delay, which I'm taking to be T6 + T8 while the VBT provides something called 'T7', which I'm assuming is s On the macbook air I'm testing with, this yields a power-up delay of over 200ms and a power-down delay of over 600ms. It all works now, but we're frobbing these power controls several times during mode setting, making the whole process take an awfully long time. Signed-off-by: Keith Packard <keithp@keithp.com>
2011-09-28drm/i915: Initialize PCH refclks at modeset init timeKeith Packard
The reference clock configuration must be done before any mode setting can occur as all outputs must be disabled to change anything. Initialize the clocks after turning everything off during the initialization process. Also, re-initialize the refclk at resume time. Signed-off-by: Keith Packard <keithp@keithp.com>
2011-09-27drv/i915: Pull display_clock_mode out of VBT tableKeith Packard
This tells the driver whether a CK505 clock source is available on pre-PCH hardware. If so, it should be used as the non-SSC source, leaving the internal clock for use as the SSC source. Signed-off-by: Keith Packard <keithp@keithp.com> Reviewed-by: Chris Wison <chris@chris-wilson.co.uk>
2011-09-21drm/i915: pass ELD to HDMI/DP audio driverWu Fengguang
Add ELD support for Intel Eaglelake, IbexPeak/Ironlake, SandyBridge/CougarPoint and IvyBridge/PantherPoint chips. ELD (EDID-Like Data) describes to the HDMI/DP audio driver the audio capabilities of the plugged monitor. It's built and passed to audio driver in 2 steps: (1) at get_modes time, parse EDID and save ELD to drm_connector.eld[] (2) at mode_set time, write drm_connector.eld[] to the Transcoder's hw ELD buffer and set the ELD_valid bit to inform HDMI/DP audio driver This patch is tested OK on G45/HDMI, IbexPeak/HDMI and IvyBridge/HDMI+DP. Test scheme: plug in the HDMI/DP monitor, and run cat /proc/asound/card0/eld* to check if the monitor name, HDMI/DP type, etc. show up correctly. Minor imperfection: the GEN5_AUD_CNTL_ST/DIP_Port_Select field always reads 0 (reserved). Without knowing the port number, I worked it around by setting the ELD_valid bit for ALL the three ports. It's tested to not be a problem, because the audio driver will find invalid ELD data and hence rightfully abort, even when it sees the ELD_valid indicator. Thanks to Zhenyu and Pierre-Louis for a lot of valuable help and testing. CC: Zhao Yakui <yakui.zhao@intel.com> CC: Wang Zhenyu <zhenyu.z.wang@intel.com> CC: Jeremy Bush <contractfrombelow@gmail.com> CC: Christopher White <c.white@pulseforce.com> CC: Pierre-Louis Bossart <pierre-louis.bossart@intel.com> CC: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-09-19Drivers: i915: Fix all space related issues.Akshay Joshi
Various issues involved with the space character were generating warnings in the checkpatch.pl file. This patch removes most of those warnings. Signed-off-by: Akshay Joshi <me@akshayjoshi.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-08-15Not all systems expose a firmware or platform mechanism for changing the ↵Matthew Garrett
backlight intensity on i915, so add native driver support. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> Tested-by: Michel Alexandre Salim <salimma@fedoraproject.org> Tested-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-07-29Merge branch 'drm-intel-fixes' into drm-intel-nextKeith Packard
