path: root/drivers/gpu/drm/i915/i915_gem_clflush.h
2017-07-27drm/i915: Force CPU synchronisation even if userspace requests ASYNCChris Wilson
The goal here was to minimise doing any thing or any check inside the kernel that was not strictly required. For a userspace that assumes complete control over the cache domains, the kernel is usually using outdated information and may trigger clflushes where none were required. However, swapping is a situation where userspace has no knowledge of the domain transfer, and will leave the object in the CPU cache. The kernel must flush this out to the backing storage prior to use with the GPU. As we use an asynchronous task tracked by an implicit fence for this, we also need to cancel the ASYNC flag on the object so that the object will wait for the clflush to complete before being executed. This also absolves userspace of the responsibility imposed by commit 77ae9957897d ("drm/i915: Enable userspace to opt-out of implicit fencing") that its needed to ensure that the object was out of the CPU cache prior to use on the GPU. Fixes: 77ae9957897d ("drm/i915: Enable userspace to opt-out of implicit fencing") Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=101571 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Cc: Jason Ekstrand <jason@jlekstrand.net> Reviewed-by: Jason Ekstrand <jason@jlekstrand.net> Link: https://patchwork.freedesktop.org/patch/msgid/20170721145037.25105-5-chris@chris-wilson.co.uk Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> (cherry picked from commit 0f46daa1a273779a0b73d768a788ca3f04238f9c) Cc: stable@vger.kernel.org Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2017-05-03drm/i915: Mark up clflushes as belonging to an unordered timelineChris Wilson
2 clflushes on two different objects are not ordered, and so do not belong to the same timeline (context). Either we use a unique context for each, or we reserve a special global context to mean unordered. Ideally, we would reserve 0 to mean unordered (DMA_FENCE_NO_CONTEXT) to have the same semantics everywhere. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20170503093924.5320-1-chris@chris-wilson.co.uk
2017-02-22drm/i915: Perform object clflushing asynchronouslyChris Wilson
Flushing the cachelines for an object is slow, can be as much as 100ms for a large framebuffer. We currently do this under the struct_mutex BKL on execution or on pageflip. But now with the ability to add fences to obj->resv for both flips and execbuf (and we naturally wait on the fence before CPU access), we can move the clflush operation to a workqueue and signal a fence for completion, thereby doing the work asynchronously and not blocking the driver or its clients. v2: Introduce i915_gem_clflush.h and use a new name, split out some extras into separate patches. Suggested-by: Akash Goel <akash.goel@intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Cc: Matthew Auld <matthew.auld@intel.com> Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20170222114049.28456-5-chris@chris-wilson.co.uk
