This reverts commit 4a684a4117abd756291969336af454e8a958802f.
Userland has always been required to set the object's domain to GTT
before using it through a GTT mapping, it's not something that the
kernel is supposed to enforce. (The pagefault support is so that we
can handle multiple mappings without userland having to pin across
them, not so that userland can use GTT after GPU domains without
telling the kernel).
Fixes 19.2% +/- 0.8% (n=6) performance regression in cairo-gl
firefox-talos-gfx on my T420 latop.
Signed-off-by: Keith Packard <keithp@keithp.com>
Along the fast path for relocation handling, we attempt to copy directly
from the user data structures whilst holding our mutex. This causes
lockdep to warn about circular lock dependencies if we need to pagefault
the user pages. [Since when handling a page fault on a mmapped bo, we
need to acquire the struct mutex whilst already holding the mm
semaphore, it is then verboten to acquire the mm semaphore when already
holding the struct mutex. The likelihood of the user passing in the
relocations contained in a GTT mmaped bo is low, but conceivable for
extreme pathology.] In order to force the mm to return EFAULT rather
than handle the pagefault, we therefore need to disable pagefaults
across the relocation fast path.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: stable@kernel.org
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Apply the trivial conflicting regression fixes, but keep GPU semaphores
enabled.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem_execbuffer.c
... as if we are only reading from it, we can do that concurrently with
the queue flip.
Andi Kleen narrowed his GPU hangs on his Sugar Bay (SNB desktop) rev 09
down to the use of GPU semaphores, and we already know that they appear
broken up to Huron River (mobile) rev 08. (I'm optimistic that disabling
GPU semaphores is simply hiding another bug by the latency and
side-effects of the additional device interaction it introduces...)
However, use of semaphores is a massive performance improvement... Only
as long as the system remains stable. Enable at your peril.
Reported-by: Andi Kleen <andi-fd@firstfloor.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33921
This seems to be running stably on my test laptop, so hopefully the
reported hangs where just symptoms of other bugs.
Userspace has a legitimate requirement to use a delta that points to
outside of the target bo, and so we need to enable this. (As this is an
abi break, albeit a relaxation of the current restrictions, mark the change
with a new flag.)
The code paths for modesetting are growing in complexity as we may need
to move the buffers around in order to fit the scanout in the aperture.
Therefore we face a choice as to whether to thread the interruptible status
through the entire pinning and unbinding code paths or to add a flag to
the device when we may not be interrupted by a signal. This does the
latter and so fixes a few instances of modesetting failures under stress.
As we just need a temporary array whilst performing the relocations for
the execbuffer, first attempt to allocate using kmalloc even if it is
not of order page-0. This avoids the overhead of remapping the
discontiguous array and so gives a moderate boost to execution
throughput.
Dave Airlie spotted that we had a potential bug should we ever rearrange
the drm_i915_gem_object so not the base drm_gem_object was not its first
member. He noticed that we often convert the return of
drm_gem_object_lookup() immediately into drm_i915_gem_object and then
check the result for nullity. This is only valid when the base object is
the first member and so the superobject has the same address. Play safe
instead and use the compiler to convert back to the original return
address for sanity testing.
A lot of minor tweaks to fix the tracepoints, improve the outputting for
ftrace, and to generally make the tracepoints useful again. It is a start
and enough to begin identifying performance issues and gaps in our
coverage.
Merge important suspend and resume regression fixes and resolve the
small conflict.
drivers/gpu/drm/i915/i915_dma.c
There are I915_NUM_RINGS-1 inter-ring synchronisation counters, but we
were clearing I915_NUM_RINGS of them. Oops.
Reported-by: Jiri Slaby <jirislaby@gmail.com>
Tested-by: Jiri Slaby <jirislaby@gmail.com>
Move code around and invoke iomem annotation in a few more places in
order to silence sparse. Still a few more iomem annotations to go...
Hopefully, this is a temporary measure whilst the root cause is
understood. At the moment, we experience a hard hang whilst looping
urbanterror that has been identified as a result of the use of
semaphores, but so far only on SNB mobile.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=32752
Tested-by: mengmeng.meng@intel.com
After reordering the sequence of relocating objects, commit 6fe4f1404,
we can no longer rely on seeing all reloc targets prior to performing
the relocation. As a result we were ignoring the need to flush objects
from the render cache and invalidate the sampler caches, resulting in
rendering glitches. So we need to clear the relocation domains earlier.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
On the fault path, commit 6fe4f140 introduction a regression whereby it
changed the sequence of the objects but continued to use the original
ordering of relocation entries. The result was that incorrect GTT offsets
were being fed into the execbuffer causing lots of misrendering and
potential hangs.
As the mappable portion of the aperture is always a small subset at the
start of the GTT, it is allocated preferentially by drm_mm. This is
useful in case we ever need to map an object later. However, if you have
a large object that can consume the entire mappable region of the
GTT this prevents the batchbuffer from fitting and so causing an error.
Instead allocate all those that require a mapping up front in order to
improve the likelihood of finding sufficient space to bind them.
Before releasing the lock in order to copy the relocation list from user
pages, we need to drop all the object references as another thread may
usurp and execute another batchbuffer before we reacquire the lock.
However, the code was buggy and failed to clear the list...
... in order to avoid a BUG() and potential unbounded waits.
We need to ensure that writes through the GTT land before any
modification to the MMIO registers and so must impose a mandatory write
barrier when flushing the GTT domain. This was revealed by relaxing the
write ordering by experimentally mapping the registers and the GATT as
write-combining.
The relative-to-general state default is useless as it means having to
rewrite the streaming kernels for each batch. Relative-to-surface is
more useful, as that stream usually needs to be rewritten for each
batch. And absolute addressing mode, vital if you start streaming
state, is also only available by adjusting the register...
As we provide a list of all objects that will be accessed from the
batchbuffer, we can build a lut of the handles associated with those
objects for this invocation and use that to avoid the overhead of
looking up those objects again for every relocation.
The cost of building and searching a small hash table is much less than
that of acquiring a spinlock, searching a radix tree and manipulating an
atomic refcnt per relocation.
Userspace should not have been declaring that it needed fenced GPU
access with gen4+ as those GPUs have no fenced commands, but to be on
the safe side it is easier to ignore userspace in case they did.
The bulk of the change is to convert the growing list of rings into an
array so that the relationship between the rings and the semaphore sync
registers can be easily computed.
With this change, every batchbuffer can use all available fences (save
pinned and scanout, of course) without ever stalling the gpu!
In theory. Currently the actual pipelined update of the register is
disabled due to some stability issues. However, just the deferred update
is a significant win.
Based on a series of patches by Daniel Vetter.
The premise is that before every access to a buffer through the GTT we
have to declare whether we need a register or not. If the access is by
the GPU, a pipelined update to the register is made via the ringbuffer,
and we track the last seqno of the batches that access it. If by the
CPU we wait for the last GPU access and update the register (either
to clear or to set it for the current buffer).
One advantage of being able to pipeline changes is that we can defer the
actual updating of the fence register until we first need to access the
object through the GTT, i.e. we can eliminate the stall on set_tiling.
This is important as the userspace bo cache does not track the tiling
status of active buffers which generate frequent stalls on gen3 when
enabling tiling for an already bound buffer.
This makes the various rings more consistent by removing the anomalous
handing of the rendering ring execbuffer dispatch.
As the error occurred on the current object, it means that its state was
not changed and so it should be excluded from the unwind.
Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Besides the minimal improvement in reducing the execbuffer overhead, the
real benefit is clarifying a few routines.
A number of dragons have been seen lurking within the execbuffer code.
The first step is then to isolate them from the rest and begin to
scrutinise them in depth. Suggested by Daniel Vetter.
