I stumbled over this magic bit in the gen3 INSTPM:
Bit11 Interrupt-Based AGPBUSY# Enable:
‘0’ = Pending GMCH interrupts will not cause AGPBUSY# assertion.
‘1’ = Pending GMCH interrupts will cause AGPBUSY# assertion and hence
can cause the CPU to exit C3. There is no suppression of cacheable
writes.
Note that in either case in C3 the interrupts are not lost. They will be
forwarded to the ICH when the GMCH is out of C3.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: stable@kernel.org
Using PM latency request turns out to be very fragile and only works for
some systems, depending upon the ACPI implementation. However, I've
stumbled across a promising bit in INSTPM: "Interrupt-Based AGPBUSY#".
This reverts commit b0b544cd37c060e261afb2cf486296983fcb56da.
drivers/gpu/drm/i915/i915_irq.c: In function ‘ironlake_irq_postinstall’:
drivers/gpu/drm/i915/i915_irq.c:1618: warning: unused variable ‘pipe’
Grab the latest stabilisation bits from -fixes and some suspend and
resume fixes from linus.
drivers/gpu/drm/i915/i915_drv.h
We can enable some safely, but FDI and transcoder interrupts can occur
and block other interrupts from being detected (like port hotplug
events). So keep them disabled by default (they can be re-enabled for
debugging display bringup, but should generally be off).
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
We had some conversions over to the _PIPE macros, but didn't get
everything. So hide the per-pipe regs with an _ (still used in a few
places for legacy) and add a few _PIPE based macros, then make sure
everyone uses them.
[update: remove usage of non-existent no-op macro]
[update 2: keep modesetting suspend/resume code, update to new reg names]
[ickle: stylistic cleanups for checkpatch and taste]
A lot of minor tweaks to fix the tracepoints, improve the outputting for
ftrace, and to generally make the tracepoints useful again. It is a start
and enough to begin identifying performance issues and gaps in our
coverage.
Merge resume fixes from -fixes and an important fix for SDVO GMBUS.
Hugh Dickins found that characters in xterm were going missing and oft
delayed. Being the curious type, he managed to associate this with the
new high-precision vblank patches; disabling these he found, restored
the orderliness of his characters.
The oddness begins when one realised that Hugh was not using vblanks at
all on his system (fvwm and some xterms). Instead, all he had to go on
were warning of a pipe underrun, curiously enough at around 60Hz. He
poked and found that in addition to the underrun warning, the hardware
was flagging the start of a new frame, a vblank, which in turn was
kicking off the pending vblank processing code.
There is little we can do for the underruns on Hugh's machine, a
Crestline [965GM], which must have its FIFO watermarks set to 8.
However, we do not need to process the vblank if we know that they are
disabled...
Reported-by: Hugh Dickins <hughd@google.com>
Merge important suspend and resume regression fixes and resolve the
small conflict.
drivers/gpu/drm/i915/i915_dma.c
error_bo and pinned_bo could be used uninitialised if there were no
active buffers.
Caught by kmemcheck.
If the driver calls into the kernel to wait for a breadcrumb to pass,
but hasn't enabled interrupts, fallback to polling the breadcrumb value.
Reported-by: Chris Clayton <chris2553@googlemail.com>
Tested-by: Chris Clayton <chris2553@googlemail.com>
Hangcheck and error recovery is only used by GEM.
Reported-by: Herbert Xu <herbert@gondor.apana.org.au>
945 class hardware has an interesting quirk in which the vblank
interrupt is not raised if the CPU is in a low power state. (We also
suspect that the memory bus is clocked to the CPU/c-state and not the
GPU so there are secondary starvation issues.) In order to prevent the
most obvious issue of the low of the vblank interrupt (stuttering
compositing that only updates when the mouse is moving) is to install a
PM QoS request to prevent low c-states whilst the GPU is active.
Whilst we had no older batches on the active list, everything was fine.
However, if the GPU is free running and the requests are only being
reaped by the periodic retirer, than the current seqno may not be at the
start of the list. In this case we need to select the first batch after
the last seqno written by the gpu and not inclusive of the seqno.
FDI and the transcoders can fail for various reasons, so detect those
conditions and report on them.
Otherwise we may consume 20% of the CPU just handling IRQs whilst
rendering. Ouch.
Add an interrupt handler for switching graphics frequencies and handling
PM interrupts. This should allow for increased performance when busy
and lower power consumption when idle.
v2: Change IS_IRONLAKE to IS_GEN5 to adapt to 2.6.37
This patch adds new functions for use by the drm core:
.get_vblank_timestamp() provides a precise timestamp
for the end of the most recent (or current) vblank
interval of a given crtc, as needed for the DRI2
implementation of the OML_sync_control extension.
It is a thin wrapper around the drm function
drm_calc_vbltimestamp_from_scanoutpos() which does
almost all the work.
.get_scanout_position() provides the current horizontal
and vertical video scanout position and "in vblank"
status of a given crtc, as needed by the drm for use by
drm_calc_vbltimestamp_from_scanoutpos().
The patch modifies the pageflip completion routine
to use these precise vblank timestamps as the timestamps
for pageflip completion events.
This code has been only tested on a HP-Mini Netbook with
Atom processor and Intel 945GME gpu. The codepath for
(IS_G4X(dev) || IS_GEN5(dev) || IS_GEN6(dev)) gpu's
has not been tested so far due to lack of hardware.
Signed-off-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Restore PIPE_CONTROL once again just for Ironlake, as it appears that
MI_USER_INTERRUPT does not have the same coherency guarantees, that is
on Ironlake the interrupt following a GPU write is not guaranteed to
arrive after the write is coherent from the CPU, as it does on the
other generations.
Reported-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Reported-by: Shuang He <shuang.he@intel.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=32402
In order to enforce the correct memory barriers for irq get/put, we need
to perform the actual counting using atomic operations.
The workaround is hideous and we are using the STORE_DWORD on all other
generations on all other rings, so use for the gen5 render ring as
well.
The bulk of the change is to convert the growing list of rings into an
array so that the relationship between the rings and the semaphore sync
registers can be easily computed.
Having seen the effects of erroneous fencing on the batchbuffer, a
useful sanity check is to record the fence registers at the time of an
error.
A glorified s/obj_priv/obj/ with a net reduction of over a 100 lines and
many characters!
When trying to diagnose mysterious errors on resume, capture the
display register contents as well.
The pinned buffers are useful for diagnosing errors in setting up state
for the chipset, which may not necessarily be 'active' at the time of
the error, e.g. the cursor buffer object.
... and so hide the flushes from tracing.
We only ever used the PRB0, neglecting the secondary ring buffers, and
now with the advent of multiple engines with separate ring buffers we
need to excise the anachronisms from our code (and be explicit about
which ring we mean where). This is doubly important in light of the
FORCEWAKE required to read ring buffer registers on SandyBridge.
... as it has been replaced by per-ring waiters.
This holds error state from the main graphics arbiter mainly involving
the DMA engine and address translation.
Currently, we believe the GPU is idle if just the RENDER ring is idle.
This is obviously wrong if we only using either the BLT or the BSD
rings and so masking genuine hangs.
Preparing the ringbuffer for adding new commands can fail (a timeout
whilst waiting for the GPU to catch up and free some space). So check
for any potential error before overwriting HEAD with new commands, and
propagate that error back to the user where possible.
The ringbuffer keeps a pointer to the parent device, so we can use that
instead of passing around the pointer on the stack.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits)
vmwgfx: Implement a proper GMR eviction mechanism
drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2
drm/radeon/kms: properly compute group_size on 6xx/7xx
drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker
drm/radeon/kms/evergreen: set the clear state to the blit state
drm/radeon/kms: don't poll dac load detect.
gpu: Add Intel GMA500(Poulsbo) Stub Driver
drm/radeon/kms: MC vram map needs to be >= pci aperture size
drm/radeon/kms: implement display watermark support for evergreen
drm/radeon/kms/evergreen: add some additional safe regs v2
drm/radeon/r600: fix tiling issues in CS checker.
drm/i915: Move gpu_write_list to per-ring
drm/i915: Invalidate the to-ring, flush the old-ring when updating domains
drm/i915/ringbuffer: Write the value passed in to the tail register
agp/intel: Restore valid PTE bit for Sandybridge after bdd3072
drm/i915: Fix flushing regression from 9af90d19f
drm/i915/sdvo: Remove unused encoding member
i915: enable AVI infoframe for intel_hdmi.c [v4]
drm/i915: Fix current fb blocking for page flip
drm/i915: IS_IRONLAKE is synonymous with gen == 5
Fix up conflicts in
- drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the
new simplified stack-based kmap_atomic() interface
- drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL
removal cleanups.
Keep the current interface but ignore the KM_type and use a stack based
approach.
The advantage is that we get rid of crappy code like:
#define __KM_PTE \
(in_nmi() ? KM_NMI_PTE : \
in_irq() ? KM_IRQ_PTE : \
KM_PTE0)
and in general can stop worrying about what context we're in and what kmap
slots might be appropriate for that.
The downside is that FRV kmap_atomic() gets more expensive.
For now we use a CPP trick suggested by Andrew:
#define kmap_atomic(page, args...) __kmap_atomic(page)
to avoid having to touch all kmap_atomic() users in a single patch.
[ not compiled on:
- mn10300: the arch doesn't actually build with highmem to begin with ]
[akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c]
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Based on an original patch by Zhenyu Wang, this initializes the BLT ring for
SandyBridge and enables support for user execbuffers.
Cc: Zhenyu Wang <zhenyuw@linux.intel.com>
