commit 3573c4103f7a486838bb6b5b8353788103f91802 upstream.
v2: add a CPT-specific macro, make code cleaner
v3: fix commit message
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41272
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Keith Packard <keithp@keithp.com>
Change-Id: Ibebaa677dcb502f900d3571e7a65eafed3796418
Reviewed-on: http://git-master/r/74159
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
commit 9ca1d10d748e56964de95e3ed80211b192f56cf4 upstream.
Unlike the previous one, I don't have known testcases it fixes. I'd
rather not go through the same debug cycle on whatever testcases those
might be.
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 406478dc911e16677fbd9c84d1d50cdffbc031ab upstream.
Fixes rendering failures in Unigine Tropics and Sanctuary and the mesa
"fire" demo.
commit c4f9c4c2b3f1831e932e04db992cf6fe92c2a95a upstream.
It's needed for 3 pipe support as well as just regular functionality
(e.g. DisplayPort).
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Tested-by: Adam Jackson <ajax@redhat.com>
Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Robert Hooker <robert.hooker@canonical.com>
commit 65a21cd65316145f9302594be8e69074369e1050 upstream.
The cursor regs have moved around, add the offsets and new macros for
getting at them.
Tested-By: Eugeni Dodonov <eugeni.dodonov@intel.com>
Reviewed-By: Eugeni Dodonov <eugeni.dodonov@intel.com>
Prior to Ivybridge, the GFX_MODE would default to 0x800, meaning that
MI_FLUSH would flush the TLBs in addition to the rest of the caches
indicated in the MI_FLUSH command. However starting with Ivybridge, the
register defaults to 0x2800 out of reset, meaning that to invalidate the
TLB we need to use PIPE_CONTROL. Since we're not doing that yet, go
back to the old default so things work.
v2: don't forget to actually *clear* the new bit
Reviewed-by: Eric Anholt <eric@anholt.net>
Tested-by: Kenneth Graunke <kenneth@whitecape.org>
CPT pipe select is different from previous generations (using two bits
instead of one). All of the paths from intel_disable_pch_ports were
not making this distinction.
Mode setting with pipe A turned off would then also force all outputs
on pipe B to get turned off as the disable code would mistakenly
decide that all of these outputs were on pipe A and turn them off.
This is an extension of the CPT DP disable fix (why didn't I fix this then?)
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Expose the SNB+ cache sharing policy register in debugfs. The new file,
i915_cache_sharing, has 4 values, 0-3, with 0 being "max uncore
resources" and 3 being the minimum. Exposing this control should make
benchmarking easier and help us choose a good default.
This makes it easier to add support for other infoframes (e.g. SPD,
vendor specific).
These bits moved around on SNB and above.
v2: again with the git send-email fail
v3: add macros for getting per-pipe override & enable bits
v4: enable phase sync pointer on SNB and IVB configs as well
On Ironlake and above, we have per-transcoder DIP registers, so use them
for sending DIPs like AVI infoframes on ILK and above.
On CougarPoint and PantherPoint PCH chips, the timing generator may fail
to start after DP training completes. This is due to a bug in the
FDI autotraining detect logic (which will stall the timing generator and
re-enable it once training completes), so disable it to avoid silent DP
mode setting failures.
Display port pipe selection on CPT is not done with a bit in the
output register, rather it is controlled by a couple of bits in the
separate transcoder register which indicate which display port output
is connected to the transcoder.
This patch replaces the simplistic macro DP_PIPE_ENABLED with the
rather more complicated function dp_pipe_enabled which checks the
output register to see if that is enabled, and then goes on to either
check the output register pipe selection bit (on non-CPT) or the
transcoder DP selection bits (on CPT).
Before this patch, any time the mode of pipe A was changed, any
display port outputs on pipe B would get disabled as
intel_disable_pch_ports would ensure that the mode setting operation
could occur on pipe A without interference from other outputs
connected to that pch port
Reviewed-by: Adam Jackson <ajax@redhat.com>
The read back of the available FIFO entries is vital for system
stability, but extremely costly. However, we only need a guide so as to
avoid eating into the reserved entries and since we are the only
consumer we can cache the read of the count from the last write.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
Persistent mode is intended for use with front-buffer rendering, such as
X, where it is necessary to detect writes to the scanout either by the
GPU or through the CPU's fence, and recompress the dirty regions on the
fly. (By comparison to the back-buffer rendering, the scanout is always
recompressed after a page-flip.)
References: https://bugs.freedesktop.org/show_bug.cgi?id=33487
References: https://bugs.freedesktop.org/show_bug.cgi?id=31742
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
The ring frequency scaling table tells the PCU to treat certain GPU
frequencies as if they were a given CPU frequency for purposes of
scaling the ring frequency. Normally the PCU will scale the ring
frequency based on the CPU P-state, but with the table present, it will
also take the GPU frequency into account.
The main downside of keeping the ring frequency high while the CPU is
at a low frequency (or asleep altogether) is increased power
consumption. But then if you're keeping your GPU busy, you probably
want the extra performance.
v2:
- add units to debug table header (from Eric)
- use tsc_khz as a fallback if the cpufreq driver doesn't give us a freq
(from Chris)
v3:
- fix comments & debug output
- remove unneeded force wake get/put
Tested-by: Eric Anholt <eric@anholt.net>
...we need to apply exactly the same workaround for missing interrupts
from BSD as for the BLT ring, apparently.
See also commit 498e720b96379d8ee9c294950a01534a73defcf3
(drm/i915: Fix gen6 (SNB) missed BLT ring interrupts).
Reported-and-tested-by: nkalkhof@web.de
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38529
Ibex Peak and CougarPoint already require a different setting (added
here), and future chips will likely follow that precedent.
Reviewed-by: Keith Packard <keithp@keithp.com>
Some of the bits have changed, including one we were setting that enables
a VGA test mode, preventing pipe B from working at all. So add a new
IVB specific function with the right bits.
They have been moved from the ringbuffer groups to their own group it
looks like. Fixes GPU hangs on gnome startup.
Add new interrupt handling functions for Ivy Bridge.
A0 stepping chips need to use manual training, but the bits have all
moved. So fix things up so we can at least train FDI for VGA links.
The render P-state handling code requires reading from a GT register.
This means that FORCEWAKE must be written to, a resource which is shared
and should be protected by struct_mutex. Hence we can not manipulate
that register from within the interrupt handling and so must delegate
the task to a workqueue.
This commit changed an internal radeon structure, that meant a new driver
in -next had to be fixed up, merge in the commit and fix up the driver.
Also fixes a trivial nouveau merge.
drivers/gpu/drm/nouveau/nouveau_mem.c
This reverts commit 951f3512dba5bd44cda3e5ee22b4b522e4bb09fb
drm/i915: Do not handle backlight combination mode specially
since this commit introduced other regressions due to untouched LBPC
register, e.g. the backlight dimmed after resume.
In addition to the revert, this patch includes a fix for the original
issue (weird backlight levels) by removing the wrong bit shift for
computing the current backlight level.
Also, including typo fixes (lpbc -> lbpc).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34524
Acked-by: Indan Zupancic <indan@nul.nu>
Cc: <stable@kernel.org>
Apply the trivial conflicting regression fixes, but keep GPU semaphores
enabled.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem_execbuffer.c
Whilst the GT is powered down (rc6), writes to MMADDR are placed in a
FIFO by the System Agent. This is a limited resource, only 64 entries, of
which 20 are reserved for Display and PCH writes, and so we must take
care not to queue up too many writes. To avoid this, there is counter
which we can poll to ensure there are sufficient free entries in the
fifo.
"Issuing a write to a full FIFO is not supported; at worst it could
result in corruption or a system hang."
Reported-and-Tested-by: Matt Turner <mattst88@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34056
I stumbled over this magic bit in the gen3 INSTPM:
Bit11 Interrupt-Based AGPBUSY# Enable:
‘0’ = Pending GMCH interrupts will not cause AGPBUSY# assertion.
‘1’ = Pending GMCH interrupts will cause AGPBUSY# assertion and hence
can cause the CPU to exit C3. There is no suppression of cacheable
writes.
Note that in either case in C3 the interrupts are not lost. They will be
forwarded to the ICH when the GMCH is out of C3.
Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: stable@kernel.org
Merge in the conflicting eDP fix.
drivers/gpu/drm/i915/i915_irq.c
drivers/gpu/drm/i915/intel_display.c
In order to prevent "crushed blacks" on TVs, the range of the RGB output
may be limited to 16-235. This used to be available through Xorg under
the "Broadcast RGB" option, so reintroduce support for KMS.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34543
The current code does not follow Intel documentation: It misses some things
and does other, undocumented things. This causes wrong backlight values in
certain conditions. Instead of adding tricky code handling badly documented
and rare corner cases, don't handle combination mode specially at all. This
way PCI_LBPC is never touched and weird things shouldn't happen.
If combination mode is enabled, then the only downside is that changing the
brightness has a greater granularity (the LBPC value), but LBPC is at most
254 and the maximum is in the thousands, so this is no real functional loss.
A potential problem with not handling combined mode is that a brightness of
max * PCI_LBPC is not bright enough. However, this is very unlikely because
from the documentation LBPC seems to act as a scaling factor and doesn't look
like it's supposed to be changed after boot. The value at boot should always
result in a bright enough screen.
IMPORTANT: However, although usually the above is true, it may not be when
people ran an older (2.6.37) kernel which messed up the LBPC register, and
they are unlucky enough to have a BIOS that saves and restores the LBPC value.
Then a good kernel may seem to not work: Max brightness isn't bright enough.
If this happens people should boot back into the old kernel, set brightness
to the maximum, and then reboot. After that everything should be fine.
For more information see the below links. This fixes bugs:
http://bugzilla.kernel.org/show_bug.cgi?id=23472
http://bugzilla.kernel.org/show_bug.cgi?id=25072
Signed-off-by: Indan Zupancic <indan@nul.nu>
Tested-by: Alex Riesen <raa.lkml@gmail.com>
Grab the latest stabilisation bits from -fixes and some suspend and
resume fixes from linus.
Disable any PCH ports associated with a pipe when disabling it. This
should prevent transcoder disable failures due to ports still being on.
[ickle: introduce *_PIPE_ENABLED() macro]
We had some conversions over to the _PIPE macros, but didn't get
everything. So hide the per-pipe regs with an _ (still used in a few
places for legacy) and add a few _PIPE based macros, then make sure
everyone uses them.
[update: remove usage of non-existent no-op macro]
[update 2: keep modesetting suspend/resume code, update to new reg names]
[ickle: stylistic cleanups for checkpatch and taste]
The specs say to do so.
Apply the SandyBridge stability fixes from -fixes.
The i915 driver normally assumes the video bios has configured several
of the LVDS panel registers, and it just inherits the values. If the
vbios has not run, several of these will need to be setup. So we need to
check that the LVDS sync polarity is correctly configured per any
available modelines (e.g. EDID) and adjust if not, issuing a warning as
we do.
Signed-off-by: Mark Hayter <mdhayter@chromium.org>
These make us increase our frequency much more readily, and decrease
them only after significant idle time, resulting in a 20% performance
increase for nexuiz.
pointer
We need to unlock the phase sync pointer enable bit before we can
actually enable the phase sync pointer workaround on Ironlake.
With assertions to check transcoder and reference clock state.
Add plane enable/disable functions to prevent duplicated code and allow
us to easily check for plane enable/disable requirements (such as pipe
enable, plane status, pll status etc).
Without this change, blits to the front buffer won't invalidate FBC
state, causing us to scan out stale data. Make sure we update these
bits on every FBC enable, since they may get clobbered if we shut off
the display.
References: https://bugzilla.kernel.org/show_bug.cgi?id=26932
Add a couple of missing workaround bits for ILK & SNB. These disable
clock gating on a couple of units that would otherwise prevent FBC from
working.
FDI and the transcoders can fail for various reasons, so detect those
conditions and report on them.
Re-enable rc6 support on Ironlake for power savings. Adds a debugfs
file to check current RC state, adds a missing workaround for Ironlake
MI_SET_CONTEXT instructions, and renames MCHBAR_RENDER_STANDBY to
RSTDBYCTL to match the docs.
Keep RC6 and the power context disabled on pre-ILK. It only seems to
hang and doesn't save any power.
Otherwise we may consume 20% of the CPU just handling IRQs whilst
rendering. Ouch.
This patch actually makes the watermark code even uglier (if that's
possible), but has the advantage of sharing code between SNB and ILK at
least. Longer term we should refactor the watermark stuff into its own
file and clean it up now that we know how it's supposed to work.
Supporting WM2 on my Vaio reduced power consumption by around 0.5W, so
this patch is definitely worthwhile (though it also needs lots of test
coverage).
[ickle: pass the watermark structs arounds]
