commit 551bd3368a7b3cfef01edaade8970948d178d40a upstream.
With Sphinx 2.0 (or prior versions with the deprecation warnings fixed) the
docs build fails with:
Documentation/gpu/i915.rst:403: WARNING: Title level inconsistent:
Global GTT Fence Handling
reST markup error:
Documentation/gpu/i915.rst:403: (SEVERE/4) Title level inconsistent:
I "fixed" it by changing the subsections in i915.rst, but that didn't seem
like the correct change. It turns out that a couple of i915 files create
their own subsections in kerneldoc comments using apostrophes as the
heading marker:
Layout
That breaks the normal subsection marker ordering, and newer Sphinx is
rather more strict about enforcing that ordering. So fix the offending
comments to make Sphinx happy.
(This is unfortunate, in that kerneldoc comments shouldn't need to be aware
of where they might be included in the heading hierarchy, but I don't see
a better way around it).
Cc: stable@vger.kernel.org # v4.14+
Acked-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit e528c2affcf216b3d02b22004895cb678769629b upstream.
This patch fixes the macros used for defining the DFLEXDPMLE
register bit fields. This accounts for changes in the spec.
Fixes: a2bc69a1a9d6 ("drm/i915/icl: Add register definition for DFLEXDPMLE")
Cc: Animesh Manna <animesh.manna@intel.com>
Cc: Paulo Zanoni <paulo.r.zanoni@intel.com>
Cc: Jose Roberto de Souza <jose.souza@intel.com>
Cc: <stable@vger.kernel.org> # v4.19+
Signed-off-by: Manasi Navare <manasi.d.navare@intel.com>
Reviewed-by: José Roberto de Souza <jose.souza@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20181023191248.26418-1-manasi.d.navare@intel.com
(cherry picked from commit b4335ec0a3ee6229a570755f8fb95dc8a7c694f2)
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
This patch fixes the PPS4 and PPS5 register definition macros that were
resulting into an incorect MMIO address.
Fixes: 2efbb2f099fb ("i915/dp/dsc: Add DSC PPS register definitions")
Cc: Anusha Srivatsa <anusha.srivatsa@intel.com>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Reviewed-by: Anusha Srivatsa <anusha.srivatsa@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180824014807.14681-1-manasi.d.navare@intel.com
(cherry picked from commit 5df52391ddbed869c7d67b00fbb013bd64334115)
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Since Haswell we have no color range indication either in the pipe or
port registers for DP. Instead, there's a separate register for setting
the DP Main Stream Attributes (MSA) directly. The MSA register
definition makes no references to colorimetry, just a vague reference to
the DP spec. The connection to the color range was lost.
Apparently we've failed to set the proper MSA bit for limited, or CEA,
range ever since the first DDI platforms. We've started setting other
MSA parameters since commit dae847991a43 ("drm/i915: add
intel_ddi_set_pipe_settings").
Without the crucial bit of information, the DP sink has no way of
knowing the source is actually transmitting limited range RGB, leading
to "washed out" colors. With the colorimetry information, compliant
sinks should be able to handle the limited range properly. Native
(i.e. non-LSPCON) HDMI was not affected because we do pass the color
range via AVI infoframes.
Though not the root cause, the problem was made worse for DDI platforms
with commit 55bc60db5988 ("drm/i915: Add "Automatic" mode for the
"Broadcast RGB" property"), which selects limited range RGB
automatically based on the mode, as per the DP, HDMI and CEA specs.
After all these years, the fix boils down to flipping one bit.
[Per testing reports, this fixes DP sinks, but not the LSPCON. My
educated guess is that the LSPCON fails to turn the CEA range MSA into
AVI infoframes for HDMI.]
Reported-by: Michał Kopeć <mkopec12@gmail.com>
Reported-by: N. W. <nw9165-3201@yahoo.com>
Reported-by: Nicholas Stommel <nicholas.stommel@gmail.com>
Reported-by: Tom Yan <tom.ty89@gmail.com>
Tested-by: Nicholas Stommel <nicholas.stommel@gmail.com>
References: https://bugs.freedesktop.org/show_bug.cgi?id=100023
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=107476
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94921
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: <stable@vger.kernel.org> # v3.9+
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180814060001.18224-1-jani.nikula@intel.com
(cherry picked from commit dc5977da99ea28094b8fa4e9bacbd29bedc41de5)
The register for 0xe420 is unable to hold any value, including
this bit. The documentation is also mixed between having a
register bit for toggle and having a state command setup
for it. Apparently the register toggle is deprecated.
Remove the register toggle as evidence shows it's futile.
The thing remaining is an apology and humble request for
Mesa folks to resurrect their state setup for this as they
were on right track from start.
This reverts commit 0bf059f3532bb39c52d917142206a8554fc2f1c5.
Fixes: 0bf059f3532b ("drm/i915/icl: WaEnableFloatBlendOptimization")
References: HSDES#1406393558
Cc: Oscar Mateo <oscar.mateo@intel.com>
Cc: Anuj Phogat <anuj.phogat@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Lionel Landwerlin <lionel.g.landwerlin@intel.com>
Signed-off-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://patchwork.freedesktop.org/patch/msgid/20180730120636.26958-1-mika.kuoppala@linux.intel.com
(cherry picked from commit c358514ba8da9e235876db1628cedd19a35803c6)
RC model has these parameters that correspond with each of
15 ranges of RC buffer threshold value in the RC model.
The three elements are range_min_qp, range_max_qp and
range_bpg_offset.
Add the Rate Control range values for eDP/MIPI and DP case.
The actual values are calculated usung a helper function.
This patch adds the shifts to registers where the value will
be written during atomic commit.
v2:
- Use _MMIO_PIPE() instead of _MMIO(_PICK()) (Manasi)
- Combine shifts (Manasi)
Cc: Jose Souza <jose.souza@intel.com>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: Ville Syrjala <ville.syrjala@linux.intel.com>
Cc: Manasi Navare <manasi.d.navare@intel.com>
Signed-off-by: Anusha Srivatsa <anusha.srivatsa@intel.com>
Reviewed-by: Manasi Navare <manasi.d.navare@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1531861861-10950-4-git-send-email-anusha.srivatsa@intel.com
Add register defines and shifts that control the RC buffer threshold
between encoder and decoder for eDP/MIPI and DP cases.
v2:
- Use _MMIO_PIPE() instead of _MMIO_(_PICK()) (Manasi)
Link: https://patchwork.freedesktop.org/patch/msgid/1531861861-10950-3-git-send-email-anusha.srivatsa@intel.com
Display Stream Compression(DSC) has a set of Picture
Parameter Set(PPS) components that the encoder must
communicate to the decoder.
This patch adds register definitions to
the PPS parameters for eDP/MIPI case and Display Port.
v2:
- Use _MMIO_PIPE instead of _MMIO(_PICK()). (Manasi)
- Use DSC constants as arguments. (Manasi)
Cc: Lucas De Marchi <lucas.demarchi@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1531861861-10950-2-git-send-email-anusha.srivatsa@intel.com
The Picture Parameter Set metadata for DSC has to be sent
to the panel through secondary data packets. Add the error
correction registers, data registers and control registers
for the same.
The control registers for transcoders A and B are already
defined and will be reused for Icelake purpose. This patch adds
Control register for EDP and transcoder C apart from adding the
PPS data and error registers.
v2: reuse MMIO_TRANS2 for _PPS_DATA and _PPS_ECC.
The _MMIO_TRANS2(pipe, reg) macro definition takes care of the eDp case
Link: https://patchwork.freedesktop.org/patch/msgid/1531861861-10950-1-git-send-email-anusha.srivatsa@intel.com
Support for Burst read in HW is added for HDCP2.2 compliance
requirement.
This patch enables the burst read for all the gmbus read of more than
511Bytes, on capable platforms.
v2:
Extra line is removed.
v3:
Macro is added for detecting the BURST_READ Support [Jani]
Runtime detection of the need for burst_read [Jani]
Calculation enhancement.
v4:
GMBUS0 reg val is passed from caller [ville]
Removed a extra var [ville]
Extra brackets are removed [ville]
Implemented the handling of 512Bytes Burst Read.
v5:
Burst read max length is fixed at 767Bytes [Ville]
v6:
Collecting the received reviewed-by.
Signed-off-by: Ramalingam C <ramalingam.c@intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/1530192889-5789-3-git-send-email-ramalingam.c@intel.com
GMBUS HW supports 511Bytes as Max Bytes per single RD/WR op. Instead of
enabling the 511Bytes per RD/WR cycle on legacy platforms for no
absolute ROIs, this change allows the max bytes per op upto 511Bytes
from Gen9 onwards.
v2:
No Change.
v3:
Inline function for max_xfer_size and renaming of the macro.[Jani]
v4:
Extra brackets removed [ville]
Commit msg is modified.
v5:
Collecting the Reviewed-By received.
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1530192889-5789-2-git-send-email-ramalingam.c@intel.com
Now that our stolen memory is already reserved by the x86 subsystem
(since commit "x86/gpu: reserve ICL's graphics stolen memory"), make
use of it.
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com>
Cc: x86@kernel.org
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180504203252.28048-2-paulo.r.zanoni@intel.com
This patch defines AUX lane registers for PORT_PCS_DW1,
PORT_TX_DW2, PORT_TX_DW4, PORT_TX_DW5 used during
dsi enabling.
v2: Review comments from Jani N:
- Define _ICL_PORT_PCS_DW1_AUX_A for consistency
- Three spaces for bitfield definition.
Signed-off-by: Madhav Chauhan <madhav.chauhan@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1530798591-2077-8-git-send-email-madhav.chauhan@intel.com
This register used to power down individual lanes for
DDI/DSI ports. Bitfields to power up/down various
combinations of lanes are also added in this patch.
- Use override instead of "override" for bitfields
- Define mask for override bitfield
- Define PWR_DOWN_LN* macros shifted in place
v3: Correct PWR_DOWN_LN_MASK value (Jani N)
Link: https://patchwork.freedesktop.org/patch/msgid/1530798591-2077-6-git-send-email-madhav.chauhan@intel.com
This patch defines DSI IO mode control register and it's bits
used while enabling IO power for DSI.
Link: https://patchwork.freedesktop.org/patch/msgid/1530798591-2077-4-git-send-email-madhav.chauhan@intel.com
Escape Clock is used for LP communication across the DSI
Link. To achieve the constant frequency of the escape clock
from the variable DPLL frequency output, a variable divider(M)
is needed. This patch programs the same.
v2: (Jani N) Don't end line with "(".
Link: http://patchwork.freedesktop.org/patch/msgid/1530798591-2077-3-git-send-email-madhav.chauhan@intel.com
This patch adds the new registers and corresponding bit definitions
which will be used for programming/enable DSI PLL.
- Fix spaces while defining ICL_ESC_CLK_DIV_MASK
- Define shift and mask for bitfields.
Link: https://patchwork.freedesktop.org/patch/msgid/1530795727-28644-2-git-send-email-madhav.chauhan@intel.com
Adjust the EIR clearing to cope with the edge triggered IIR
on i965/g4x. To guarantee an edge in the ISR master error bit
we temporarily mask everything in EMR. As some of the EIR bits
can't even be directly cleared we also borrow a trick from
i915_clear_error_registers() and permanently mask any bit that
remains high. No real thought given to how we might unmask them
again once the cause for the error has been clered. I suppose
on pre-g4x GPU reset will reinitialize EMR from scratch.
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180611200258.27121-3-ville.syrjala@linux.intel.com
Reviewed-by: Imre Deak <imre.deak@intel.com>
Prints live state of psr1.Extending the existing
PSR2 live state function to cover psr1.
Tested on KBL with psr2 and psr1 panel.
v2: rebase
v3: DK
Rename psr2_live_status to psr_source_status.
v4: DK
Move EDP_PSR_STATUS_STATE_SHIFT below EDP_PSR_STATUS_STATE_MASK.
Pass seq to psr_source_status, handle source status prints in
psr_source_status.
v5: Fixed CI warning messages
v6:
Remove extra space in the title before the colon.(DK)
Rebase. (Jani)
v7: Use tabs for indenting the values.(Jani)
v8: Addressed dk's review comments.
Cc: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
Reviewed-by: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
Signed-off-by: Vathsala Nagaraju <vathsala.nagaraju@intel.com>
Signed-off-by: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1530086910-15914-1-git-send-email-vathsala.nagaraju@intel.com
Try to describe what the pick variants do, and which to prefer. No
functional changes.
Link: https://patchwork.freedesktop.org/patch/msgid/20180629102039.2435-1-jani.nikula@intel.com
This patch addresses Interrupts from south display engine (SDE).
ICP has two registers - SHOTPLUG_CTL_DDI and SHOTPLUG_CTL_TC.
Introduce these registers and their intended values.
Introduce icp_irq_handler().
The icp_irq_postinstall() takes care of
enabling all PCH interrupt sources, to unmask
them as needed with SDEIMR, as is done
done by ibx_irq_pre_postinstall() for earlier platforms.
We do not need to explicitly call the ibx_irq_pre_postinstall().
Also, while changing these,
s/CPT/PPT/CPT-CNP comment.
v2:
- remove redundant register defines.(Lucas)
- Change register names to be more consistent with
previous platforms (Lucas)
v3:
-Reorder bit defines to a more appropriate location.
Change the comments. Confirm in the commit message that
icp_irq_postinstall() need not go to
ibx_irq_pre_postinstall() and ibx_irq_postinstall()
as in earlier platforms. (Paulo)
Cc: Lucas De Marchi <lucas.de.marchi@gmail.com>
Reviewed-by: Lucas De Marchi <lucas.demarchi@intel.com>
Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
[Paulo: coding style bikesheds and rebases].
Link: https://patchwork.freedesktop.org/patch/msgid/1530046343-30649-1-git-send-email-anusha.srivatsa@intel.com
Add the definition for ICL power wells and their mapping to power
domains. On ICL there are 3 power well control registers, we'll select
the correct one based on higher bits of the power well ID. The offset
for the control and status flags within this register is based on the
lower bits of the ID as on older platforms.
As the DC state programming is also the same as on old platforms we can
reuse the corresponding helpers. For this we mark here the DC-off power
well as shared among multiple platforms.
Other than the above the delta between old platforms and ICL:
- Pipe C has its own power well, so we can save some additional power in the
pipe A+B and (non-eDP) pipe A configurations.
- Power wells for port E/F DDI/AUX IO and Thunderbolt 1-4 AUX IO
v2:
- Rebase on drm-tip after prep patch for this was merged there as
requested by Paulo.
- Actually add the new AUX and DDI power well control regs (Rakshmi)
v3:
- Fix power well register names in code comments
- Add TBT AUX->power well 3 dependency
v4:
- Rebase
v5:
- Detach AUX power wells from the INIT power domain. These power wells
can only be enabled in a TC/TBT connected state and otherwise not
needed during driver initialization.
v6:
- Use _MMIO_PORT(...) instead _MMIO(_PICK(...)) (Paulo)
Fix checkpatch warnings.
Cc: Rakshmi Bhatia <rakshmi.bhatia@intel.com>
Signed-off-by: Imre Deak <imre.deak@intel.com>
Reviewed-by: Animesh Manna <animesh.manna@intel.com> (v1)
Link: https://patchwork.freedesktop.org/patch/msgid/20180626142232.22361-1-imre.deak@intel.com
Sink can be configured to calculate the CRC over the static frame and
compare with the CRC calculated and transmited in the VSC SDP by
source, if there is a mismatch sink will do a short pulse in HPD
and set DP_PSR_LINK_CRC_ERROR in DP_PSR_ERROR_STATUS.
Spec: 7723
v6:
andling DP_PSR_LINK_CRC_ERROR here and remove "bdw+" from commit
message
v4:
patch moved to after 'drm/i915/psr: Avoid PSR exit max time timeout'
to avoid touch in 2 patches EDP_PSR_DEBUG.
v3:
disabling PSR instead of exiting on error
Signed-off-by: José Roberto de Souza <jose.souza@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180626201644.21932-5-jose.souza@intel.com
Alpha blending with alpha 0 and 0xff passes through
alpha math and rounding logic causing differences
compared to fully transparent or opaque plane,resulting
in CRC mismatch.
This WA on icl and above enables hardware to bypass alpha
math and rounding for per pixel alpha values of 00 and 0xff
v2: Fix patchwork checkpatch warnings.
Signed-off-by: Vandita Kulkarni <vandita.kulkarni@intel.com>
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1529594036-25036-1-git-send-email-vandita.kulkarni@intel.com
Some MG PLL registers have fields that need to be preserved at their HW
default or BIOS programmed values. So make sure we preserve them.
v2:
- Add comment to icl_mg_pll_write() explaining the need for register
masks. (Vandita)
- Fix patchwork checkpatch warning.
v3:
- Rebase on drm-tip.
Cc: Vandita Kulkarni <vandita.kulkarni@intel.com>
Cc: James Ausmus <james.ausmus@intel.com>
Reviewed-by: James Ausmus <james.ausmus@intel.com> (v1)
Reviewed-by: Vandita Kulkarni <vandita.kulkarni@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180619164115.7835-1-imre.deak@intel.com
This patch enables hotplug interrupts for DP over TBT output on TC
ports. The TBT interrupts are enabled and handled irrespective of the
actual output type which could be DP Alternate, DP over TBT, native DP
or native HDMI.
Link: https://patchwork.freedesktop.org/patch/msgid/20180616000530.5357-3-paulo.r.zanoni@intel.com
The hotplug interrupts for the ports can be routed to either North
Display or South Display depending on the output mode. DP Alternate or
DP over TBT outputs will have hotplug interrupts routed to the North
Display while interrupts for legacy modes will be routed to the South
Display in PCH. This patch adds hotplug interrupt handling support for
DP Alternate mode.
[Paulo: coding style changes]
Link: https://patchwork.freedesktop.org/patch/msgid/20180616000530.5357-2-paulo.r.zanoni@intel.com
The Graphics System Event(GSE) interrupt bit has a new location in the
GU_MISC_INTERRUPT_{IIR, ISR, IMR, IER} registers. Since GSE was the only
DE_MISC interrupt that was enabled, with this change we don't enable/handle
any of DE_MISC interrupts for gen11. Credits to Paulo for pointing out
the register change.
v2: from DK
raw_reg_[read/write], branch prediction hint and drop platform check (Mika)
v3: From DK
Early re-enable of master interrupt (Chris)
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
[Paulo: bikesheds and rebases]
Link: https://patchwork.freedesktop.org/patch/msgid/20180616000530.5357-1-paulo.r.zanoni@intel.com
While I don't see any issue with the way these macros are being called
today, let's protect them against operator precedence issues before
they happen.
Link: https://patchwork.freedesktop.org/patch/msgid/20180612235654.7914-4-paulo.r.zanoni@intel.com
Since I'm touching the file I might as well fix this class of errors
since they are just a few. Also drive-by fix the styling of the
VLV_TURBO_SOC_OVERRIDE definitions instead of just the spaces before
the tabs.
Link: https://patchwork.freedesktop.org/patch/msgid/20180612235654.7914-3-paulo.r.zanoni@intel.com
Because OCD.
Now seriously, commit 1aa920ea0e85 ("drm/i915: add register macro
definition style guide") has finally established a coding standard to
be followed by the rest of the file, and I've been trying to request
everybody to adhere to that since then. The problem is that when
someone adds a new line to a register that has the wrong style, these
people generally propagate the wrong style and I have to keep asking
them to drive-by fix the whole register, which is not something I like
to do and also creates extra work for them. Or I can ignore the
propagation of the wrong coding style and feel anxious about it. On
top of that, we now have our CI happily reminding us about these
problems, which makes everything worse.
So IMHO the best way to proceed is to fix the spacing issues in the
file once and for all. Contributors will stop propagating the bad
style when adding new bits to registers that already have bad style,
we will stop asking them to redo their patches and the CI emails will
become more relevant by having less semi-false errors.
Yes, there will be some pain involved for backporters, but at least
spacing issues like that are easy to spot and fix in the patch files.
This patch was generated by:
../../../../scripts/checkpatch.pl -f --strict --types SPACING \
--fix-inplace i915_reg.h
I manually checked the output and everything seems sane.
v2: Single conflict around the addition of DP_TP_CTL_LINK_TRAIN_PAT4.
Acked-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180618180943.894-1-paulo.r.zanoni@intel.com
Having the w/a registers as an open-coded table leaves a trap for the
unwary; it would be easy to miss incrementing the LRI counter when
adding a new register to the list. Instead, pull the list of registers
into a table, so that we only need add new registers to that table
rather than try and remember important side-effects of earlier chunks of
GPU instructions.
Suggested-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180618094150.30895-1-chris@chris-wilson.co.uk
The SF and clipper units mishandle the provoking vertex in some cases,
which can cause misrendering with shaders that use flat shaded inputs.
There are chicken bits in 3D_CHICKEN3 (for SF) and FF_SLICE_CHICKEN
(for the clipper) that work around the issue. These registers are
unfortunately not part of the logical context (even the power context),
and so we must reload them every time we start executing in a context.
Bugzilla: https://bugs.freedesktop.org/103047
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20180615190605.16238-1-chris@chris-wilson.co.uk
DP spec 1.4 supports training pattern set 4 (TPS4) for HBR3 link
rate. This will be used in link training's channel equalization
phase if supported by both source and sink.
This patch adds the helpers to check if HBR3 is supported and uses
TPS4 in training pattern selection during link training.
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180611222655.5696-2-paulo.r.zanoni@intel.com
This commit just adds the register addresses and the basic skeleton of
the code. The next commits will expand on more specific functions.
Link: https://patchwork.freedesktop.org/patch/msgid/20180522002558.29262-15-paulo.r.zanoni@intel.com
Add support for DP_AUX_E. Here we also introduce the bits for the AUX
power well E, however ICL power well support is still not enabled yet,
so the power well is not used.
Signed-off-by: James Ausmus <james.ausmus@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180612002512.29783-2-paulo.r.zanoni@intel.com
ICP has GPIO pin 1/2 mapped to combo-phy ports & GPIO pins 9/10/11/12
mapped to tc ports[1-4].
This patch defines GPIOCTL registers for GPIO pins 9-12 & uses them in GPIO
pin mapping table.
Cc: Madhav Chauhan <madhav.chauhan@intel.com>
Signed-off-by: Mahesh Kumar <mahesh1.kumar@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180612002512.29783-1-paulo.r.zanoni@intel.com
There is a problem with kbl up to rev E0 where a heavy
memory/fabric traffic from adjacent engine(s) can cause an engine
reset to fail. This traffic can be from normal memory accesses
or it can be from heavy polling on a semaphore wait.
For engine hogging causing a fail, we already fallback to
full reset. Which effectively stops all engines and thus
we only add a workaround documentation.
For the semaphore wait loop poll case, we add one microsecond
poll interval to semaphore wait to guarantee bandwidth for
the reset preration. The side effect is that we make semaphore
completion latencies also 1us longer.
v2: Let full reset handle the adjacent engine idling (Chris)
v3: Skip render engine (Joonas), please checkpatch on define (Mika)
References: https://bugs.freedesktop.org/show_bug.cgi?id=106684
References: VTHSD#2227190, HSDES#1604216706, BSID#0917
Link: https://patchwork.freedesktop.org/patch/msgid/20180607172444.17080-1-mika.kuoppala@linux.intel.com
PLLs are the source clocks for the DDIs so in order
to determine the ddi clock we need to check the PLL
configuration.
This gets a little tricky for ICL since there is
no register bit that maps directly to the link clock.
So this patch creates a separate function in intel_dpll_mgr.c
to obtain the write array PLL Params and compares the set
pll_params with the table to get the corresponding link
clock.
v2:
- Fix the encoder type check (DK).
- Improve our error checking, return a sane value (Mika, Paulo).
- Fix table entries (Paulo).
Cc: Mika Kahola <mika.kahola@intel.com>
Reviewed-by: Mika Kahola <mika.kahola@intel.com>
Signed-off-by: Lucas De Marchi <lucas.demarchi@intel.com>
[Paulo: implement v2]
Link: https://patchwork.freedesktop.org/patch/msgid/20180523224444.19017-1-paulo.r.zanoni@intel.com
DFLEXDPMLE register is required to tell the FIA hardware which
main links of DP are enabled on TCC Connectors. FIA uses this
information to program PHY to Controller signal mapping.
This register is applicable in both TC connector's Alternate mode
as well as DP connector mode.
v2:
* Remove _ICL prefix since the reg is first introduced
in ICL (Paulo)
* s/ICL/icl in commit message (Lucas)
Link: https://patchwork.freedesktop.org/patch/msgid/1527275032-4555-1-git-send-email-manasi.d.navare@intel.com
Set up the SKL+ scaler initial phase registers correctly. Otherwise
we start fetching the data from the center of the first pixel instead
of the top-left corner, which obviously then leads to right/bottom edges
replicating data excessively as the data runs out half a pixel too soon.
Cc: Vidya Srinivas <vidya.srinivas@intel.com>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180521185613.5097-2-ville.syrjala@linux.intel.com
Reviewed-By: Vidya Srinivas <vidya.srinivas@intel.com>
Use MCURSOR_ instead of CURSOR_ as the prefix for the non-845/865
cursor defines consistently, and move the pipe CSC enable bit next
to the other non-845/865 cursor defines.
v2: Take care of gvt uses as well
v3: Another gvt use popped up
Link: https://patchwork.freedesktop.org/patch/msgid/20180131143709.875-1-ville.syrjala@linux.intel.com
Reviewed-by: Mika Kahola <mika.kahola@intel.com> #v2
Like we do for encoder let's make the plane->get_hw_state() return
the pipe to which the plane is currently attached. We don't currently
allow planes to move between the pipes, but perhaps one day we will.
In either case this makes the code more uniform and perhaps makes
intel_plane_mapping_ok() slightly more clear.
Note that for i965 and g4x planes A and B still have pipe select bits
but they're hardwired to pipe A and B respectively. This means we can
safely interpret those bits just like on gen2/3. This allows the
same readout code work for plane C (which can still be assigned
to eiter pipe on i965) should we ever expose it.
g4x no longer allows moving the cursor planes between the pipes,
but the pipe select bits can still be set in the register. Thus
we have to ignore those bits. OTOH i965 still allows the cursors
to move between pipes thus we have to trust the bits there.
Link: https://patchwork.freedesktop.org/patch/msgid/20180130203807.13721-3-ville.syrjala@linux.intel.com
Prevents an error in the GAM unit. Also known as WaGamTlbPendError
References: HSDES#1406463099
References: HSDES#1406465643
Signed-off-by: Oscar Mateo <oscar.mateo@intel.com>
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1527285939-20113-12-git-send-email-oscar.mateo@intel.com
Enables blend optimization for floating point RTs
v2: Rebased on top of the WA refactoring
v3: Added References (Mika)
Link: https://patchwork.freedesktop.org/patch/msgid/1527285939-20113-5-git-send-email-oscar.mateo@intel.com
Disable blend embellishment in RCC.
Also, some other registers style fixed in passing.
v4:
- Fixed in B0
- Mentioned style fixes in commit message
References: HSDES#2006665173
Link: https://patchwork.freedesktop.org/patch/msgid/1527285939-20113-4-git-send-email-oscar.mateo@intel.com
Redirects the state cache to the CS Command buffer section for
performance reasons.
v2: Rebased
v3: Rebased on top of the WA refactoring
References: HSDES#1604325460
Link: https://patchwork.freedesktop.org/patch/msgid/1527285939-20113-3-git-send-email-oscar.mateo@intel.com
Revert to the legacy implementation.
v2: GEN7_ROW_CHICKEN2 is masked
v3:
- Rebased
- Renamed to Wa_2006611047
- A0 and B0 only
v4:
- Add spaces around '<<' (and fix the surrounding code as well)
- Mark the WA as pre-prod
v5: Rebased on top of the WA refactoring
v6: Added References (Mika)
v7: Fixed in B0
References: HSDES#2006611047
Link: https://patchwork.freedesktop.org/patch/msgid/1527285939-20113-2-git-send-email-oscar.mateo@intel.com
For psr block #9, the vbt description has moved to options [0-3] for
TP1,TP2,TP3 Wakeup time from decimal value without any change to vbt
structure. Since spec does not mention from which VBT version this
change was added to vbt.bsf file, we cannot depend on bdb->version check
to change for all the platforms.
There is RCR inplace for GOP team to provide the version number
to make generic change. Since Kabylake with bdb version 209 is having this
change, limiting this change to gen9_bc and version 209+ to unblock google.
Tested on skl(bdb version 203,without options) and
kabylake(bdb version 209,212) having new options.
bspec 20131
v2: (Jani and Rodrigo)
move the 165 version check to intel_bios.c
v3: Jani
Move the abstraction to intel_bios.
v4: Jani
Rename tp*_wakeup_time to have "us" suffix.
For values outside range[0-3],default to max 2500us.
Old decimal value was wake up time in multiples of 100us.
v5: Jani and Rodrigo
Handle option 2 in default condition.
Print oustide range value.
For negetive values default to 2500us.
v6: Jani
Handle default first and then fall through for case 2.
v7: Rodrigo
Apply this change for IS_GEN9_BC and vbt version > 209
v8: Puthik
Add new function vbt_psr_to_us.
v9: Jani
Change to v7 version as it's more readable.
DK
add comment /*fall through*/ after case2.
Cc: Puthikorn Voravootivat <puthik@chromium.org>
Cc: José Roberto de Souza <jose.souza@intel.com>
Signed-off-by: Maulik V Vaghela <maulik.v.vaghela@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1526981243-2745-1-git-send-email-vathsala.nagaraju@intel.com
L3Bank could be fused off in hardware for debug purpose, and it
is possible that subslice is enabled while its corresponding L3Bank pairs
are disabled. In such case, if MCR packet control register(0xFDC) is
programed to point to a disabled bank pair, a MMIO read into L3Bank range
will return 0 instead of correct values.
However, this is not going to be the case in any production silicon.
Therefore, we only check at initialization and issue a warning should
this really happen.
References: HSDES#1405586840
v2:
- use fls instead of find_last_bit (Chris)
- use is_power_of_2() instead of counting bit set (Chris)
v3:
- rebase on latest tip
v5:
- Added references (Mika)
- Move local variable into scope where they are used (Ursulin)
- use a new local variable to reduce long line of code (Ursulin)
v6:
- Some coding style and use more local variables for clearer
logic (Ursulin)
Cc: Michel Thierry <michel.thierry@intel.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com>
Signed-off-by: Yunwei Zhang <yunwei.zhang@intel.com>
Reviewed-by: Oscar Mateo <oscar.mateo@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1526683285-24861-1-git-send-email-yunwei.zhang@intel.com
