path: root/drivers/gpu/drm/i915/intel_hdmi.c
2018-08-28drm/i915: Free write_buf that we allocated with kzalloc.Rodrigo Vivi
We use kzalloc to allocate the write_buf that we use for i2c transfer on hdcp write. But it seems that we are forgetting to free the memory that is not needed after i2c transfer is completed. Reported-by: Brian J Wood <brian.j.wood@intel.com> Fixes: 2320175feb74 ("drm/i915: Implement HDCP for HDMI") Cc: Ramalingam C <ramalingam.c@intel.com> Cc: Sean Paul <seanpaul@chromium.org> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Rodrigo Vivi <rodrigo.vivi@intel.com> Cc: <stable@vger.kernel.org> # v4.17+ Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Link: https://patchwork.freedesktop.org/patch/msgid/20180823205136.31310-1-rodrigo.vivi@intel.com (cherry picked from commit 62d3a8deaa10b8346d979d0dabde56c33b742afa) Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
2018-08-20Merge tag 'mfd-next-4.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "New Drivers: - Add Cirrus Logic Madera Codec (CS47L35, CS47L85 and CS47L90/91) driver - Add ChromeOS EC CEC driver - Add ROHM BD71837 PMIC driver New Device Support: - Add support for Dialog Semi DA9063L PMIC variant to DA9063 - Add support for Intel Ice Lake to Intel-PLSS-PCI - Add support for X-Powers AXP806 to AXP20x New Functionality: - Add support for USB Charging to the ChromeOS Embedded Controller - Add support for HDMI CEC to the ChromeOS Embedded Controller - Add support for HDMI CEC to Intel HDMI - Add support for accessory detection to Madera devices - Allow individual pins to be configured via DT' wlf,csnaddr-pd - Provide legacy platform specific EEPROM/Watchdog commands; rave-sp Fix-upsL - Trivial renaming/spelling fixes; cros_ec, da9063-* - Convert to Managed Resources (devm_*); da9063-*, ti_am335x_tscadc - Transition to helper macros/functions; da9063-* - Constify; kempld-core - Improve error path/messages; wm8994-core - Disable IRQs locally instead of relying on USB subsystem; dln2 - Remove unused code; rave-sp - New exports; sec-core Bug Fixes: - Fix possible false I2C transaction error; arizona-core - Fix declared memory area size; hi655x-pmic - Fix checksum type; rave-sp - Fix incorrect default serial port configuration: rave-sp - Fix incorrect coherent DMA mask for sub-devices; sm501" * tag 'mfd-next-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (60 commits) mfd: madera: Add register definitions for accessory detect mfd: sm501: Set coherent_dma_mask when creating subdevices mfd: bd71837: Devicetree bindings for ROHM BD71837 PMIC mfd: bd71837: Core driver for ROHM BD71837 PMIC media: platform: cros-ec-cec: Fix dependency on MFD_CROS_EC mfd: sec-core: Export OF module alias table mfd: as3722: Disable auto-power-on when AC OK mfd: axp20x: Support AXP806 in I2C mode mfd: axp20x: Add self-working mode support for AXP806 dt-bindings: mfd: axp20x: Add "self-working" mode for AXP806 mfd: wm8994: Allow to configure CS/ADDR Pulldown from dts mfd: wm8994: Allow to configure Speaker Mode Pullup from dts mfd: rave-sp: Emulate CMD_GET_STATUS on device that don't support it mfd: rave-sp: Add legacy watchdog ping command translation mfd: rave-sp: Add legacy EEPROM access command translation mfd: rave-sp: Initialize flow control and parity of the port mfd: rave-sp: Fix incorrectly specified checksum type mfd: rave-sp: Remove unused defines mfd: hi655x: Fix regmap area declared size for hi655x mfd: ti_am335x_tscadc: Fix struct clk memory leak ...
2018-07-27Merge branches 'ib-mfd-4.19', 'ib-mfd-gpio-pinctrl-4.19', ↵Lee Jones
'ib-mfd-i915-media-platform-4.19' and 'ib-mfd-regulator-4.19', tag 'ib-platform-chrome-mfd-move-cros-ec-transport-for-4.19' into ibs-for-mfd-merged Immutable branch (mfd, chrome) due for the v4.19 window Immutable Branch which moves the cros_ec_i2c and cros_ec_spi transport drivers from mfd to platform/chrome. Changes in arm are a simple rename in defconfigs. Change in input is a rename in help text.
2018-07-13drm/i915: hdmi: add CEC notifier to intel_hdmiNeil Armstrong
This patchs adds the cec_notifier feature to the intel_hdmi part of the i915 DRM driver. It uses the HDMI DRM connector name to differentiate between each HDMI ports. The changes will allow the i915 HDMI code to notify EDID and HPD changes to an eventual CEC adapter. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2018-06-28Merge tag 'drm-intel-next-2018-06-20' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-intel into drm-next Chris is doing many reworks that allow us to get full-ppgtt supported on all platforms back to HSW. As well many other fix and improvements, Including: - Use GEM suspend when aborting initialization (Chris) - Change i915_gem_fault to return vm_fault_t (Chris) - Expand VMA to Non gem object entities (Chris) - Improve logs for load failure, but quite logging on fault injection to avoid noise on CI (Chris) - Other page directory handling fixes and improvements for gen6 (Chris) - Other gtt clean-up removing redundancies and unused checks (Chris) - Reorder aliasing ppgtt fini (Chris) - Refactor of unsetting obg->mm.pages (Chris) - Apply batch location restrictions before pinning (Chris) - Ringbuffer fixes for context restore (Chris) - Execlist fixes on freeing error pointer on allocation error (Chris) - Make closing request flush mandatory (Chris) - Move GEM sanitize from resume_early to resume (Chris) - Improve debug dumps (Chris) - Silent compiler for selftest (Chris) - Other execlists changes to improve hangcheck and reset. - Many gtt page directory fixes and improvements (Chris) - Reorg context workarounds (Chris) - Avoid ERR_PTR dereference on selftest (Chris) Other GEM related work: - Stop trying to reset GPU if reset failed (Mika) - Add HW workaround for KBL to fix GPU reset (Mika) - Fix context ban and hang accounting for client (Mika) - Fixes on OA perf (Michel, Jani) - Refactor on GuC log mechanisms (Piotr) - Enable provoking vertex fix on Gen9 system (Kenneth) More ICL patches for Display enabling: - ICL - 10-bit support for HDMI (RK) - ICL - Start adding TBT PLL (Paulo) - ICL - DDI HDMK level selection (Manasi) - ICL - GMBUS GPIO pin mapping fix (Mahesh) - ICL - Adding DP_AUX_E support (James) - ICL - Display interrupts handling (DK) Other display fixes and improvements: - Fix sprite destination color keying on SKL+ (Ville) - Fixes and improvements on PCH detection, specially for non PCH systems (Jani) - Document PCH_NOP (Lucas) - Allow DBLSCAN user modes with eDP/LVDS/DSI (Ville) - Opregion and ACPI cleanup and organization (Jani) - Kill delays when activation psr (Rodrigo) - ...and a consequent fix of the psr activation flow (DK) - Fix HDMI infoframe setting (Imre) - Fix Display interrupts and modes on old gens (Ville) - Start switching to kernel unsigned int types (Jani) - Introduction to Amber Lake and Whiskey Lake platforms (Jose) - Audio clock fixes for HBR3 (RK) - Standardize i915_reg.h definitions according to our doc and checkpatch (Paulo) - Remove unused timespec_to_jiffies_timeout function (Arnd) - Increase the scope of PSR wake fix for other VBTs out there (Vathsala) - Improve debug msgs with prop name/id (Ville) - Other clean up on unecessary cursor size defines (Ville) - Enforce max hdisplay/hblank_start limits on HSW/BDW (Ville) - Make ELD pointers constant (Jani) - Fix for PSR VBT parse (Colin) - Add warn about unsupported CDCLK rates (Imre) Signed-off-by: Dave Airlie <airlied@redhat.com> # gpg: Signature made Thu 21 Jun 2018 07:12:10 AM AEST # gpg: using RSA key FA625F640EEB13CA # gpg: Good signature from "Rodrigo Vivi <rodrigo.vivi@intel.com>" # gpg: aka "Rodrigo Vivi <rodrigo.vivi@gmail.com>" # gpg: WARNING: This key is not certified with a trusted signature! # gpg: There is no indication that the signature belongs to the owner. # Primary key fingerprint: 6D20 7068 EEDD 6509 1C2C E2A3 FA62 5F64 0EEB 13CA Link: https://patchwork.freedesktop.org/patch/msgid/20180625165622.GA21761@intel.com
2018-06-22Merge tag 'drm-misc-next-2018-06-21' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next drm-misc-next for 4.19: UAPI Changes: - Add writeback connector (Brian Starkey/Liviu Dudau) - Add "content type" property to HDMI connectors (Stanislav Lisovskiy) Cross-subsystem Changes: - some devicetree Docs update - fix compile breakage on ION due to the dma-buf cleanups (Christian König) Core Changes: - Reject over-sized allocation requests early (Chris Wilson) - gem-fb-helper: Always do implicit sync (Daniel Vetter) - dma-buf cleanups (Christian König) Driver Changes: - Fixes for the otm8009a panel driver (Philippe Cornu) - Add Innolux TV123WAM panel driver support (Sandeep Panda) - Move GEM BO to drm_framebuffer in few drivers (Daniel Stone) - i915 pinning improvements (Chris Wilson) - Stop consulting plane->fb/crtc in a few drivers (Ville Syrjälä) Signed-off-by: Dave Airlie <airlied@redhat.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180621105428.GA20795@juma
2018-06-20drm/i915/icl: Add 10-bit support for hdmiRadhakrishna Sripada
Starting Icelake silicon supports 10-bpc hdmi to support certain media workloads. Currently hdmi supports 8 and 12 bpc. Plumbed in support for 10 bit hdmi. Cc: James Ausmus <james.ausmus@intel.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Paulo Zanoni <paulo.r.zanoni@intel.com> Cc: Manasi Navare <manasi.d.navare@intel.com> Cc: Rodrigo Vivi <rodrigo.vivi@intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Radhakrishna Sripada <radhakrishna.sripada@intel.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180522002558.29262-18-paulo.r.zanoni@intel.com
2018-06-19drm/i915: Allow DBLSCAN user modes with eDP/LVDS/DSIVille Syrjälä
When encountering a connector with the scaling mode property both intel and modesetting ddxs sometimes add tons of DBLSCAN modes to the output's mode list. The idea presumably being that since the output will be going through the panel fitter anyway we can pretend to use any kind of mode. Sadly that means we can't reject user modes with the DBLSCAN flag until we know whether we're going to be using the panel's native mode or the user mode directly. Doing otherwise means X clients using xf86vidmode/xrandr will get a protocol error (and often self terminate as a result) when the kernel refuses to use the requested mode with the DBLSCAN flag. To undo the regression we'll move the DBLSCAN checks into the connector->mode_valid() and encoder->compute_config() hooks. Cc: stable@vger.kernel.org Cc: Vito Caputo <vcaputo@pengaru.com> Reported-by: Vito Caputo <vcaputo@pengaru.com> Fixes: e995ca0b8139 ("drm/i915: Provide a device level .mode_valid() hook") References: https://lkml.org/lkml/2018/5/21/715 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180524125403.23445-1-ville.syrjala@linux.intel.com Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=106804 Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> (cherry picked from commit e4dd27aadd205417a2e9ea9902b698a0252ec3a0) Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2018-06-18drm/i915/hdmi: switch to kernel unsigned int typesJani Nikula
We have fairly mixed uintN_t vs. uN usage throughout the driver, but try to stick to kernel types at least where it's more prevalent. Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/d8b79de3d52e1fcaeabf3abfbb2ed99c4397ff2b.1528794959.git.jani.nikula@intel.com
2018-06-15drm/i915: s/IS_G4X && !IS_GM45/IS_G45/Ville Syrjälä
We have IS_G45 these days. Let's use it instead of the 'IS_G4X && !IS_GM45' construct. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180614180500.2565-1-ville.syrjala@linux.intel.com Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
2018-06-14drm/i915/ddi: Removed unused var from hsw_write_infoframe()Imre Deak
Cc: Vandita Kulkarni <vandita.kulkarni@intel.com> Cc: Paulo Zanoni <paulo.r.zanoni@intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180613170710.15080-6-imre.deak@intel.com
2018-06-14drm/i915/ddi: Check transcoder instead of port when setting HDMI infoframeImre Deak
The only requirement by BSpec for setting the HDMI infoframes is on DDI platforms to do that before enabling the HDMI transcoder function, see VIDEO_DIP_CTL bit 16. Accordingly check for the transcoder function disabled state instead of the port's disabled state on DDI platforms. This is needed by the next patch as it will set the infoframe during crtc disabling where the port is still enabled. Suggested-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Vandita Kulkarni <vandita.kulkarni@intel.com> Cc: Paulo Zanoni <paulo.r.zanoni@intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180613170710.15080-4-imre.deak@intel.com
2018-06-13drm/i915: Allow DBLSCAN user modes with eDP/LVDS/DSIVille Syrjälä
2018-06-12drm/i915/icl: fix gmbus gpio pin mappingMahesh Kumar
ICP has GPIO pin 1/2 mapped to combo-phy ports & GPIO pins 9/10/11/12 mapped to tc ports[1-4]. This patch defines GPIOCTL registers for GPIO pins 9-12 & uses them in GPIO pin mapping table. Cc: Anusha Srivatsa <anusha.srivatsa@intel.com> Cc: Madhav Chauhan <madhav.chauhan@intel.com> Cc: Lucas De Marchi <lucas.demarchi@intel.com> Reviewed-by: Lucas De Marchi <lucas.demarchi@intel.com> Signed-off-by: Mahesh Kumar <mahesh1.kumar@intel.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180612002512.29783-1-paulo.r.zanoni@intel.com
2018-05-17drm/i915: Clean up SDVO pipe select bitsVille Syrjälä
Clean up the SDVO pipe select bits. To make the whole situation a bit less ugly we'll start to share the same code between .get_hw_state() and the port state asserts. v2: Order the defines shift,mask,value (Jani) Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180514172423.9302-3-ville.syrjala@linux.intel.com
2018-05-17i915: content-type property for HDMI connectorStanislav Lisovskiy
Added encoding of drm content_type property from drm_connector_state within AVI infoframe in order to properly handle external HDMI TV content-type setting. This requires also manipulationg ITC bit, as stated in HDMI spec. v2: * Moved helper function which attaches content type property to the drm core, as was suggested. Removed redundant connector state initialization. v3: * Removed caps in drm_content_type_enum_list. After some discussion it turned out that HDMI Spec 1.4 was wrongly assuming that IT Content(itc) bit doesn't affect Content type states, however itc bit needs to be manupulated as well. In order to not expose additional property for itc, for sake of simplicity it was decided to bind those together in same "content type" property. v4: * Added it_content checking in intel_digital_connector_atomic_check. Fixed documentation for new content type enum. v5: * Moved patch revision's description to commit messages. v6: * Minor naming fix for the content type enumeration string. v7: * Fix parameter name for documentation and parameter alignment in order not to get warning. Added Content Type description to new HDMI connector properties section. v8: * Thrown away unneeded numbers from HDMI content-type property description. Switch to strings desription instead of plain definitions. v9: * Moved away hdmi specific content-type enum from drm_connector_state. Content type property should probably not be bound to any specific connector interface in drm_connector_state. Same probably should be done to hdmi_picture_aspect_ration enum which is also contained in drm_connector_state. Added special helper function to get derive hdmi specific relevant infoframe fields. v10: * Added usage description to HDMI properties kernel doc. v11: * Created centralized function for filling HDMI AVI infoframe, based on correspondent DRM property value. Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Stanislav Lisovskiy <stanislav.lisovskiy@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180515135928.31092-3-stanislav.lisovskiy@intel.com [vsyrjala: clean up checkpatch multiple blank lines warnings] Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
2018-03-23drm/i915: Don't spew errors when resetting HDMI scrambling/bit clock ratio failsVille Syrjälä
When we're disabling the HDMI link we try to reset the scrambling and TMDS bit clock ratio back to the default values. This will fail if the sink has already been disconnected. Thus we should not print an error message when resetting the scrambling/TMDS bit clock ratio fail during disable. During enable we do want the error, and during disable we may still want to know what happended for debug purposes so let's use DRM_DEBUG_KMS() there. v2: Remember them consts v3: Go back to just one function and print the errors/debugs from callers (Shashank) Cc: Shashank Sharma <shashank.sharma@intel.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=105644 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=105655 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180322154707.22103-1-ville.syrjala@linux.intel.com Reviewed-by: Shashank Sharma <shashank.sharma@intel.com>
2018-03-06drm/i915: Reinitialize sink scrambling/TMDS clock ratio on HPDVille Syrjälä
The LG 4k TV I have doesn't deassert HPD when I turn the TV off, but when I turn it back on it will pulse the HPD line. By that time it has forgotten everything we told it about scrambling and the clock ratio. Hence if we want to get a picture out if it again we have to tell it whether we're currently sending scrambled data or not. Implement that via the encoder->hotplug() hook. v2: Force a full modeset to not follow the HDMI 2.0 spec more closely (Shashank) [pushed with whitespace fixes to make sparse happy] Cc: Shashank Sharma <shashank.sharma@intel.com> Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Lyude Paul <lyude@redhat.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180117192149.17760-1-ville.syrjala@linux.intel.com
2018-02-16Merge tag 'topic/hdcp-2018-02-13' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next Add HDCP support to i915 drm driver. * tag 'topic/hdcp-2018-02-13' of git://anongit.freedesktop.org/drm/drm-misc: (26 commits) drm/i915: fix misalignment in HDCP register def drm/i915: Reauthenticate HDCP on failure drm/i915: Detect panel's hdcp capability drm/i915: Optimize HDCP key load drm/i915: Retry HDCP bksv read drm/i915: Connector info in HDCP debug msgs drm/i915: Stop encryption for repeater with no sink drm/i915: Handle failure from 2nd stage HDCP auth drm/i915: Downgrade hdcp logs from INFO to DEBUG_KMS drm/i915: Restore HDCP DRM_INFO when with no downstream drm/i915: Check for downstream topology errors drm/i915: Start repeater auth on READY/CP_IRQ drm/i915: II stage HDCP auth for repeater only drm/i915: Extending HDCP for HSW, BDW and BXT+ drm/i915/dp: Fix compilation of intel_dp_hdcp_check_link drm/i915: Only disable HDCP when it's active drm/i915: Don't allow HDCP on PORT E/F drm/i915: Implement HDCP for DisplayPort drm/i915: Implement HDCP for HDMI drm/i915: Add function to output Aksv over GMBUS ...
2018-02-16Merge tag 'drm-misc-next-2018-02-13' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next drm-misc-next for 4.17: UAPI Changes: - drm/vc4: Expose performance counters to userspace (Boris) Cross-subsystem Changes: - MAINTAINERS: Linus to maintain panel-arm-versatile in -misc (Linus) Core Changes: - Only use swiotlb when necessary (Chunming) Driver Changes: - drm/panel: Add support for ARM Versatile panels (Linus) - pl111: Improvements around versatile panel support (Linus) ---------------------------------------- Tagged on 2018-02-06: drm-misc-next for 4.17: UAPI Changes: - Validate mode flags + type (Ville) - Deprecate unused mode flags PIXMUX, BCAST (Ville) - Deprecate unused mode types BUILTIN, CRTC_C, CLOCK_C, DEFAULT (Ville) Cross-subsystem Changes: - MAINTAINERS: s/Daniel/Maarten/ for drm-misc (Daniel) Core Changes: - gem: Export gem functions for drivers to use (Samuel) - bridge: Introduce bridge timings in drm_bridge (Linus) - dma-buf: Allow exclusive fence to be bundled in fence array when calling reservation_object_get_fences_rcu (Christian) - dp: Add training pattern 4 and HBR3 support to dp helpers (Manasi) - fourcc: Add alpha bit to formats to avoid driver format LUTs (Maxime) - mode: Various cleanups + add new device-wide .mode_valid hook (Ville) - atomic: Fix state leak when non-blocking commits fail (Leo) NOTE: IIRC, this was cross-picked to -fixes so it might fall out - crc: Allow polling on the data fd (Maarten) Driver Changes: - bridge/vga-dac: Add THS8134* support (Linus) - tinydrm: Various MIPI DBI improvements/cleanups (Noralf) - bridge/dw-mipi-dsi: Cleanups + use create_packet helper (Brian) - drm/sun4i: Add Display Engine frontend support (Maxime) - drm/sun4i: Add zpos support + increase num planes from 2 to 4 (Maxime) - various: Use drm_mode_get_hv_timing() to fill plane clip rectangle (Ville) - stm: Add 8-bit clut support, add dsi phy v1.31 support, +fixes (Phillipe) Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Chunming Zhou <david1.zhou@amd.com> Cc: Samuel Li <Samuel.Li@amd.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Noralf Trønnes <noralf@tronnes.org> Cc: Brian Norris <briannorris@chromium.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Ville Syrjala <ville.syrjala@linux.intel.com> Cc: Christian König <christian.koenig@amd.com> Cc: Manasi Navare <manasi.d.navare@intel.com> Cc: Philippe Cornu <philippe.cornu@st.com> Cc: Leo (Sunpeng) Li <sunpeng.li@amd.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> * tag 'drm-misc-next-2018-02-13' of git://anongit.freedesktop.org/drm/drm-misc: (115 commits) drm/radeon: only enable swiotlb path when need v2 drm/amdgpu: only enable swiotlb alloc when need v2 drm: add func to get max iomem address v2 drm/vc4: Expose performance counters to userspace drm: Print the pid when debug logging an ioctl error. drm/stm: ltdc: remove non-alpha color formats on layer 2 for older hw drm/stm: ltdc: add non-alpha color formats drm/bridge/synopsys: dsi: Add 1.31 version support drm/bridge/synopsys: dsi: Add read feature drm/pl111: Support multiple endpoints on the CLCD drm/pl111: Support variants with broken VBLANK drm/pl111: Support variants with broken clock divider drm/pl111: Handle the Versatile RGB/BGR565 mode drm/pl111: Properly detect the ARM PL110 variants drm/panel: Add support for ARM Versatile panels drm/panel: Device tree bindings for ARM Versatile panels drm/bridge: Rename argument from crtc to bridge drm/crc: Add support for polling on the data fd. drm/sun4i: Use drm_mode_get_hv_timing() to populate plane clip rectangle drm/rcar-du: Use drm_mode_get_hv_timing() to populate plane clip rectangle ...
2018-01-30drm/i915/cnl: Add HPD support for Port F.Rodrigo Vivi
On CNP boards that are using DDI F, bit 25 (SDE_PORTE_HOTPLUG_SPT) is representing the Digital Port F hotplug line when the Digital Port F hotplug detect input is enabled. v2: Reuse all existent structure instead of adding a new HPD_PORT_F pointing to pin of port E. v3: Use IS_CNL_WITH_PORT_F so we can start upstreaming this right now. If that SKU ever get a proper name we come back and update it. v4: Rebase on top of digital connected port using encoder instead of port. v5: Moved IS_CNL_WITH_PORT_F definition to the PCI IDs patch. Cc: Lucas De Marchi <lucas.demarchi@intel.com> Cc: Manasi Navare <manasi.d.navare@intel.com> Cc: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180129232223.766-8-rodrigo.vivi@intel.com
2018-01-30drm/i915/cnl: Add right GMBUS pin number for HDMI on Port F.Rodrigo Vivi
On CNP Pin 3 is for misc of Port F usage depending on the configuration. For CNL that uses Port F, pin 3 is the one. v2: Make it more generic and update commit message. Cc: Anusha Srivatsa <anusha.srivatsa@intel.com> Cc: Lucas De Marchi <lucas.demarchi@intel.com> Cc: Manasi Navare <manasi.d.navare@intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180129232223.766-6-rodrigo.vivi@intel.com
2018-01-29drm/i915: Provide a device level .mode_valid() hookVille Syrjälä
We never support certain mode flags etc. Reject those early on in the mode_config.mode_valid() hook. That allows us to remove some duplicated checks from the connector .mode_valid() hooks, and it guarantees that we never see those flags even from user mode as the mode_config.mode_valid() hooks gets executed for those as well. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171114183258.16976-11-ville.syrjala@linux.intel.com Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2018-01-19drm/i915/icp: add ICP gmbus and gpio supportAnusha Srivatsa
In ICP, there are three TC ports and 3 DDI ports. v2: - Correct Pin mapping. v3: - Update pin mapping into per platform implementation rather than previous approach of port wise mapping. v4: - Update GMBUS_NUM_PINS (Paulo) v5: - rebase. v6: - Update function name, GMBUS_PIN_NUM (Paulo) v7 (from Paulo): - Make it apply. v8 (from Paulo): - Maintain consistent if ladder ordering. Suggested by: Ville Syrjala <ville.syrjala@linux.intel.com> Cc: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Anusha Srivatsa <anusha.srivatsa@intel.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20180111180010.24357-8-paulo.r.zanoni@intel.com
2018-01-19drm/i915: Ignore TMDS clock limit for DP++ when EDID override is setAbdiel Janulgue
4K modes testing by using dummy EDID data has never been working properly on boxes with DP++ (dual-mode) adaptors. The reason for this is that those modes got pruned during hdmi mode validation. intel_hdmi_mode_valid returns CLOCK_HIGH because the pixel clock reported by the 4k mode is higher than dual port TMDS clock limit. However 4k injection does work properly on machines that don't have DP++ adapters because the mode is never validated against the DP++ TMDS clock limit. v2: Don't detect the DP++ limits when we're testing using overridden EDIDs. Make sure to check for the override condition after respecting the value of drm_dp_dual_mode_detect (Jani Nikula). Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=101649 Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Jani Nikula <jani.nikula@intel.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Abdiel Janulgue <abdiel.janulgue@linux.intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171215102055.11729-1-abdiel.janulgue@linux.intel.com
2018-01-18drm/i915: Extending HDCP for HSW, BDW and BXT+Ramalingam C
This patch extends the Key load process and hdcp initialization for few more capable intel platforms i.e. HSW, BDW and BXT+. Signed-off-by: Ramalingam C <ramalingam.c@intel.com> [seanpaul fixed checkpatch issues] Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: https://patchwork.freedesktop.org/patch/msgid/1516254488-4971-2-git-send-email-ramalingam.c@intel.com
2018-01-09drm/i915: Don't allow HDCP on PORT E/FSean Paul
Port E doesn't have HDCP support, and Port F is disabled. Don't setup the hdcp shim on those. Reviewed-by: Daniel Vetter <daniel@ffwll.ch> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: https://patchwork.freedesktop.org/patch/msgid/20180109185401.16911-1-seanpaul@chromium.org
2018-01-09drm/i915: Try EDID bitbanging on HDMI after failed readStefan Brüns
The ACK/NACK implementation as found in e.g. the G965 has the falling clock edge and the release of the data line after the ACK for the received byte happen at the same time. This is conformant with the I2C specification, which allows a zero hold time, see footnote [3]: "A device must internally provide a hold time of at least 300 ns for the SDA signal (with respect to the V IH(min) of the SCL signal) to bridge the undefined region of the falling edge of SCL." Some HDMI-to-VGA converters apparently fail to adhere to this requirement and latch SDA at the falling clock edge, so instead of an ACK sometimes a NACK is read and the slave (i.e. the EDID ROM) ends the transfer. The bitbanging releases the data line for the ACK only 1/4 bit time after the falling clock edge, so a slave will see the correct value no matter if it samples at the rising or the falling clock edge or in the center. Fallback to bitbanging is already done for the CRT connector. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92685 Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Cc: stable@vger.kernel.org Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: https://patchwork.freedesktop.org/patch/msgid/a39f080b-81a5-4c93-b3f7-7cb0a58daca3@rwthex-w2-a.rwth-ad.de
2018-01-08drm/i915: Implement HDCP for HDMISean Paul
This patch adds HDCP support for HDMI connectors by implementing the intel_hdcp_shim. Nothing too special, just a bunch of DDC reads/writes. Changes in v2: - Rebased on drm-intel-next Changes in v3: - Initialize new worker Changes in v4: - Remove SKL_ prefix from most register names (Daniel) - Wrap sanity checks in WARN_ON (Daniel) - Consolidate the enable/disable functions into one toggle fn - Use intel_hdcp_init (Daniel) Changes in v5: - checkpatch whitespace nits Changes in v6: - None Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Ramalingam C <ramalingam.c@intel.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: https://patchwork.freedesktop.org/patch/msgid/20180108195545.218615-9-seanpaul@chromium.org
2017-12-08Merge airlied/drm-next into drm-intel-next-queuedRodrigo Vivi
Chris requested this backmerge for a reconciliation on drm_print.h between drm-misc-next and drm-intel-next-queued Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
2017-12-05drm/i915: add platform tag to WALucas De Marchi
v2: add more missing platform tags v3: change tag to cnp rather than using gen9,gen10 Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Lucas De Marchi <lucas.demarchi@intel.com> Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171205190118.7088-2-lucas.demarchi@intel.com
2017-12-05drm/i915: follow single notation for workaround numberLucas De Marchi
v2: Allow to have or omit space before platform Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Lucas De Marchi <lucas.demarchi@intel.com> Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171205190118.7088-1-lucas.demarchi@intel.com
2017-12-04Merge tag 'drm-intel-next-2017-11-17-1' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-intel into drm-next More change sets for 4.16: - Many improvements for selftests and other igt tests (Chris) - Forcewake with PUNIT->PMIC bus fixes and robustness (Hans) - Define an engine class for uABI (Tvrtko) - Context switch fixes and improvements (Chris) - GT powersavings and power gating simplification and fixes (Chris) - Other general driver clean-ups (Chris, Lucas, Ville) - Removing old, useless and/or bad workarounds (Chris, Oscar, Radhakrishna) - IPS, pipe config, etc in preparation for another Fast Boot attempt (Maarten) - OA perf fixes and support to Coffee Lake and Cannonlake (Lionel) - Fixes around GPU fault registers (Michel) - GEM Proxy (Tina) - Refactor of Geminilake and Cannonlake plane color handling (James) - Generalize transcoder loop (Mika Kahola) - New HW Workaround for Cannonlake and Geminilake (Rodrigo) - Resume GuC before using GEM (Chris) - Stolen Memory handling improvements (Ville) - Initialize entry in PPAT for older compilers (Chris) - Other fixes and robustness improvements on execbuf (Chris) - Improve logs of GEM_BUG_ON (Mika Kuoppala) - Rework with massive rename of GuC functions and files (Sagar) - Don't sanitize frame start delay if pipe is off (Ville) - Cannonlake clock fixes (Rodrigo) - Cannonlake HDMI 2.0 support (Rodrigo) - Add a GuC doorbells selftest (Michel) - Add might_sleep() check to our wait_for() (Chris) Many GVT changes for 4.16: - CSB HWSP update support (Weinan) - GVT debug helpers, dyndbg and debugfs (Chuanxiao, Shuo) - full virtualized opregion (Xiaolin) - VM health check for sane fallback (Fred) - workload submission code refactor for future enabling (Zhi) - Updated repo URL in MAINTAINERS (Zhenyu) - other many misc fixes * tag 'drm-intel-next-2017-11-17-1' of git://anongit.freedesktop.org/drm/drm-intel: (260 commits) drm/i915: Update DRIVER_DATE to 20171117 drm/i915: Add a policy note for removing workarounds drm/i915/selftests: Report ENOMEM clearly for an allocation failure Revert "drm/i915: Display WA #1133 WaFbcSkipSegments:cnl, glk" drm/i915: Calculate g4x intermediate watermarks correctly drm/i915: Calculate vlv/chv intermediate watermarks correctly, v3. drm/i915: Pass crtc_state to ips toggle functions, v2 drm/i915: Pass idle crtc_state to intel_dp_sink_crc drm/i915: Enable FIFO underrun reporting after initial fastset, v4. drm/i915: Mark the userptr invalidate workqueue as WQ_MEM_RECLAIM drm/i915: Add might_sleep() check to wait_for() drm/i915/selftests: Add a GuC doorbells selftest drm/i915/cnl: Extend HDMI 2.0 support to CNL. drm/i915/cnl: Simplify dco_fraction calculation. drm/i915/cnl: Don't blindly replace qdiv. drm/i915/cnl: Fix wrpll math for higher freqs. drm/i915/cnl: Fix, simplify and unify wrpll variable sizes. drm/i915/cnl: Remove useless conversion. drm/i915/cnl: Remove spurious central_freq. drm/i915/selftests: exercise_ggtt may have nothing to do ...
2017-12-04Merge tag 'drm-misc-next-2017-11-30' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next Cross-subsystem Changes: - device tree doc for the Mitsubishi AA070MC01 and Tianma TM070RVHG71 panels (Lukasz Majewski) and for a 2nd endpoint on stm32 (Philippe Cornu) Core Changes: The most important changes are: - Add drm_driver .last_close and .output_poll_changed helpers to reduce fbdev emulation footprint in drivers (Noralf) - Fix plane clipping in core and for vmwgfx (Ville) Then we have a bunch of of improvement for print and debug such as the addition of a framebuffer debugfs file. ELD connector, HDMI and improvements. And a bunch of misc improvements, clean ups and style changes and doc updates [airlied: drop eld bits from amdgpu_dm] Driver Changes: - sii8620: filter unsupported modes and add DVI mode support (Maciej Purski) - rockchip: analogix_dp: Remove unnecessary init code (Jeffy Chen) - virtio, cirrus: add fb create_handle support to enable screenshots(Lepton Wu) - virtio: replace reference/unreference with get/put (Aastha Gupta) - vc4, gma500: Convert timers to use timer_setup() (Kees Cook) - vc4: Reject HDMI modes with too high of clocks (Eric) - vc4: Add support for more pixel formats (Dave Stevenson) - stm: dsi: Rename driver name to "stm32-display-dsi" (Philippe Cornu) - stm: ltdc: add a 2nd endpoint (Philippe Cornu) - via: use monotonic time for VIA_WAIT_IRQ (Arnd Bergmann) * tag 'drm-misc-next-2017-11-30' of git://anongit.freedesktop.org/drm/drm-misc: (96 commits) drm/bridge: tc358767: add copyright lines MAINTAINERS: change maintainer for Rockchip drm drivers drm/vblank: Fix vblank timestamp debugs drm/via: use monotonic time for VIA_WAIT_IRQ dma-buf: Fix ifnullfree.cocci warnings drm/printer: Add drm_vprintf() drm/edid: Allow HDMI infoframe without VIC or S3D video/hdmi: Allow "empty" HDMI infoframes dma-buf/fence: Fix lock inversion within dma-fence-array drm/sti: Handle return value of platform_get_irq_byname drm/vc4: Add support for NV21 and NV61. drm/vc4: Use .pixel_order instead of custom .flip_cbcr drm/vc4: Add support for DRM_FORMAT_RGB888 and DRM_FORMAT_BGR888 drm: Move drm_plane_helper_check_state() into drm_atomic_helper.c drm: Check crtc_state->enable rather than crtc->enabled in drm_plane_helper_check_state() drm/vmwgfx: Try to fix plane clipping drm/vmwgfx: Use drm_plane_helper_check_state() drm/vmwgfx: Remove bogus crtc coords vs fb size check gpu: gma500: remove unneeded DRIVER_LICENSE #define drm: don't link DP aux i2c adapter to the hardware device node ...
2017-11-24Merge tag 'drm-misc-fixes-2017-11-20' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next 4.15 merge window fixes 1 * tag 'drm-misc-fixes-2017-11-20' of git://anongit.freedesktop.org/drm/drm-misc: drm/edid: Don't send non-zero YQ in AVI infoframe for HDMI 1.x sinks drm/vc4: Account for interrupts in flight
2017-11-22drm/edid: Allow HDMI infoframe without VIC or S3DVille Syrjälä
Appedix F of HDMI 2.0 says that some HDMI sink may fail to switch from 3D to 2D mode in a timely fashion if the source simply stops sending the HDMI infoframe. The suggested workaround is to keep sending the infoframe even when strictly not necessary (ie. no VIC and no S3D). HDMI 1.4 does allow for this behaviour, stating that sending the infoframe is optional in this case. The infoframe was first specified in HDMI 1.4, so in theory sinks predating that may not appreciate us sending an uknown infoframe their way. To avoid regressions let's try to determine if the sink supports the infoframe or not. Unfortunately there's no direct way to do that, so instead we'll just check if we managed to parse any HDMI 1.4 4k or stereo modes from the EDID, and if so we assume the sink will accept the infoframe. Also if the EDID contains the HDMI 2.0 HDMI Forum VSDB we can assume the sink is prepared to receive the infoframe. v2: Fix getting has_hdmi_infoframe from display_info Always fail constructing the infoframe if the display possibly can't handle it Cc: Shashank Sharma <shashank.sharma@intel.com> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Shashank Sharma <shashank.sharma@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171113170427.4150-3-ville.syrjala@linux.intel.com
2017-11-16drm/i915/cnl: Extend HDMI 2.0 support to CNL.Rodrigo Vivi
Starting on GLK we support HDMI 2.0. So this patch only extend the work Shashank has made to GLK to CNL. v2: The version that compiles :/ v3: Invert order to newer || older platforms check. (Ville). Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Paulo Zanoni <paulo.r.zanoni@intel.com> Cc: Shashank Sharma <shashank.sharma@intel.com> Cc: Manasi Navare <manasi.d.navare@intel.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171115184205.8104-1-rodrigo.vivi@intel.com
2017-11-15drm/edid: Don't send non-zero YQ in AVI infoframe for HDMI 1.x sinksVille Syrjälä
Apparently some sinks look at the YQ bits even when receiving RGB, and they get somehow confused when they see a non-zero YQ value. So we can't just blindly follow CEA-861-F and set YQ to match the RGB range. Unfortunately there is no good way to tell whether the sink designer claims to have read CEA-861-F. The CEA extension block revision number has generally been stuck at 3 since forever, and even a very recently manufactured sink might be based on an old design so the manufacturing date doesn't seem like something we can use. In lieu of better information let's follow CEA-861-F only for HDMI 2.0 sinks, since HDMI 2.0 is based on CEA-861-F. For HDMI 1.x sinks we'll always set YQ=0. The alternative would of course be to always set YQ=0. And if we ever encounter a HDMI 2.0+ sink with this bug that's what we'll probably have to do. Cc: stable@vger.kernel.org Cc: Jani Nikula <jani.nikula@intel.com> Cc: Eric Anholt <eric@anholt.net> Cc: Neil Kownacki <njkkow@gmail.com> Reported-by: Neil Kownacki <njkkow@gmail.com> Tested-by: Neil Kownacki <njkkow@gmail.com> Fixes: fcc8a22cc905 ("drm/edid: Set YQ bits in the AVI infoframe according to CEA-861-F") Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=101639 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171108152504.12596-1-ville.syrjala@linux.intel.com Acked-by: Eric Anholt <eric@anholt.net>
2017-11-09drm/i915: Nuke intel_digital_port->portVille Syrjälä
Remove intel_digital_port->port and replace its users with intel_encoder->port. intel_encoder->port is a superset of intel_digital_port->port, and it works correctly even for MST encoders. v2: Eliminate a few dp_to_dig_port()->base.port cases too (DK) Performed with cocci: @@ @@ struct intel_digital_port { ... - enum port port; ... } @@ struct intel_digital_port *D; expression E; @@ - D->port = E; @@ struct intel_digital_port *D; @@ - D->port + D->base.port @ expression E; @@ ( - dp_to_dig_port(E)->port + dp_to_dig_port(E)->base.port | - enc_to_dig_port(E)->port + to_intel_encoder(E)->port ) @@ expression E; @@ - to_intel_encoder(&E->base) + E @@ struct intel_digital_port *D; identifier I, M; @@ I = &D->base <... ( - D->base.M + I->M | - &D->base + I ) ...> @@ identifier D; expression E; identifier M; @@ D = enc_to_dig_port(&E->base) <... ( - D->base.M + E->M | - &D->base + E ) ...> @@ identifier D, DP; expression E; identifier M; @@ DP = enc_to_intel_dp(&E->base) <... ( - dp_to_dig_port(DP)->base.M + E->M | - &dp_to_dig_port(DP)->base + E ) ...> @@ expression E; identifier M; @@ ( - enc_to_dig_port(&E->base)->base.M + E->M | - enc_to_dig_port(&E->base)->base + E | - enc_to_mst(&E->base)->primary->base.port + E->port ) @@ expression E; identifier D; @@ - struct intel_digital_port *D = E; ... when != D Cc: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com> Reviewed-by: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com> Acked-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171109152434.32074-1-ville.syrjala@linux.intel.com
2017-11-09drm/i915: Pass crtc state to DPIO PHY functionsVille Syrjälä
Rather than digging through encoder->crtc and crtc->config in the DPIO PHY functions, pass down the correct crtc state from the caller. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171031205123.13123-6-ville.syrjala@linux.intel.com Acked-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
2017-10-31drm/i915: Pass around crtc and connector states for audioVille Syrjälä
Explicitly pass the crtc and connector states into the audio code enable/disable hooks, and plumb them all the way down. This gets rid of almost all crtc->config and encoder->crtc uses. The one place where we still use them is i915_audio_component_sync_audio_rate() since that gets called from the audio driver and we don't have explicit states around then. Cc: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171030184654.17429-1-ville.syrjala@linux.intel.com Reviewed-by: Jani Nikula <jani.nikula@intel.com>
2017-10-30drm/i915: Stop frobbing with DDI encoder->typeVille Syrjälä
Currently the DDI encoder->type will change at runtime depending on what kind of hotplugs we've processed. That's quite bad since we can't really trust that that current value of encoder->type actually matches the type of signal we're trying to drive through it. Let's eliminate that problem by declaring that non-eDP DDI port will always have the encoder type as INTEL_OUTPUT_DDI. This means the code can no longer try to distinguish DP vs. HDMI based on encoder->type. We'll leave eDP as INTEL_OUTPUT_EDP, since it'll never change and there's a bunch of code that relies on that value to identify eDP encoders. We'll introduce a new encoder .compute_output_type() hook. This allows us to compute the full output_types before any encoder .compute_config() hooks get called, thus those hooks can rely on output_types being correct, which is useful for cloning on oldr platforms. For now we'll just look at the connector type and pick the correct mode based on that. In the future the new hook could be used to implement dynamic switching between LS and PCON modes for LSPCON. v2: Fix BXT/GLK PPS explosion with DSI/MST encoders v3: Avoid the PPS warn on pure HDMI/DVI DDI encoders by checking dp.output_reg v4: Rebase v5: Populate output_types in .get_config() rather than in the caller v5: Split out populating output_types in .get_config() (Maarten) Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171027193128.14483-3-ville.syrjala@linux.intel.com Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
2017-10-30drm/i915: Populate output_types from .get_config()Ville Syrjälä
Rather than having the caller of .get_config() set output_types based on encoder->type, let's just have .get_config() itself populate output_types. This way we are isolated from encoder->type, which won't be useable for this purpose anyway soon (at least for DDI encoders). Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171027193128.14483-2-ville.syrjala@linux.intel.com Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
2017-10-30drm/i915: Parse max HDMI TMDS clock from VBTVille Syrjälä
Starting from version 204 VBT can specify the max TMDS clock we are allowed to use with HDMI ports. Parse that information and take it into account when filtering modes and computing a crtc state. Also take the opportunity to sort the platform check if ladder from new to old. v2: Add defines for the values into intel_vbt_defs.h (Jani) Don't fall back to 0 silently for unknown values (Jani) Skip the debug print for the 0 case (Jani) Cc: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171030145702.23662-1-ville.syrjala@linux.intel.com
2017-10-27drm/i915: Clean up the mess around hdmi_12bpc_possible()Ville Syrjälä
Move the crtc state related 12bpc checks into hdmi_12bpc_possible() since that one already examines other parts of the crtc state. Note that we can drop the !force_dvi check since crtc_state->has_hdmi_sink already accounts for that. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171026151405.30710-1-ville.syrjala@linux.intel.com Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
2017-10-17drm/i915: Remove mostly duplicated video DIP handling from PSR codeVille Syrjälä
Now that the infoframe hooks are part of the intel_dig_port, we can use the normal .write_infoframe() hook to update the VSC SDP. We do need to deal with the size difference between the VSC DIP and the others though. Another minor snag is that the compiler will complain to use if we keep using enum hdmi_infoframe_type type and passing in the DP define instead, so et's just change to unsigned int all over for the inforframe type. v2: Rebase due to other PSR changes Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20171013194051.19286-1-ville.syrjala@linux.intel.com
2017-08-22drm/i915: Constify states passed to enable/disable/etc. encoder hooksVille Syrjälä
The enable/disable/etc. encoder hooks aren't supposed to alter the state(s), so pass them as const. Unfortunately C lacks any kind of deep const thingy, so this can't catch all abuses. But at least it acts as a hint to the reader telling them not to mess about with the state(s). v2: Update intel_tv_mode_find() and ironlake_edp_pll_on() as well v3: Deal with intel_sdvo_connector_state Acked-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20170818134958.15502-9-ville.syrjala@linux.intel.com
2017-08-22drm/i915: Init infoframe vfuncs for DP encoders as wellVille Syrjälä
DP ports may want to use the video DIP for SDP transmission, so let's initialize the vfuncs for DP encoders as well. The only exception is port A eDP prior to HSW as that one doesn't have a video DIP instance. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Shashank Sharma <shashank.sharma@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20170818134958.15502-6-ville.syrjala@linux.intel.com
2017-08-22drm/i915: Move infoframe vfuncs into intel_digital_portVille Syrjälä
DP ports will also want to utilize the video DIP for SDP transmission. So let's move the vfuncs into the dig_port. v2: Rebase due to DDI changes Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Shashank Sharma <shashank.sharma@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20170818134958.15502-5-ville.syrjala@linux.intel.com
2017-08-22drm/i915: Check has_infoframes when enabling infoframesVille Syrjälä
has_infoframe is what tells us whether infoframes should be enabled, so let's pass that instead of has_hdmi_sink to .set_infoframes(). Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com> Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20170818134958.15502-3-ville.syrjala@linux.intel.com
