We want to de-emphasize the link between the request (dependency,
execution and fence tracking) from GEM and so rename the struct from
drm_i915_gem_request to i915_request. That is we may implement the GEM
user interface on top of requests, but they are an abstraction for
tracking execution rather than an implementation detail of GEM. (Since
they are not tied to HW, we keep the i915 prefix as opposed to intel.)
In short, the spatch:
- struct drm_i915_gem_request
+ struct i915_request
A corollary to contracting the type name, we also harmonise on using
'rq' shorthand for local variables where space if of the essence and
repetition makes 'request' unwieldy. For globals and struct members,
'request' is still much preferred for its clarity.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Cc: Michał Winiarski <michal.winiarski@intel.com>
Cc: Michal Wajdeczko <michal.wajdeczko@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180221095636.6649-1-chris@chris-wilson.co.uk
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Reviewed-by: Michał Winiarski <michal.winiarski@intel.com>
Acked-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Like GEM init, GUC init, MOCS init and context creation.
Enables them to lose dev_priv locals.
Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
'ring' is an old deprecated term for a GPU engine. Chris Wilson wants to
use the name for what is currently known as an intel_ringbuffer, but it
will be dreadfully confusing if some rings are ringbuffers but other
rings are still engines. So this patch changes the names of a bunch of
parameters called 'ring' to either 'engine' or 'engine_id' according to
what they actually are.
Signed-off-by: Dave Gordon <david.s.gordon@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1469034967-15840-3-git-send-email-david.s.gordon@intel.com
Allow for the MOCS to be programmed for all engines.
Currently we program the MOCS when the first render batch
goes through. This works on most platforms but fails on
platforms that do not run a render batch early,
i.e. headless servers. The patch now programs all initialised engines
on init and the RCS is programmed again within the initial batch. This
is done for predictable consistency with regards to the hardware
context.
Hardware context loading sets the values of the MOCS for RCS
and L3CC. Programming them from within the batch makes sure that
the render context is valid, no matter what the previous state of
the saved-context was.
v2: posted correct version to the mailing list.
v3: moved programming to within engine->init_hw() (Chris Wilson)
v4: code formatting and white-space changes. (Chris Wilson)
Testcase: igt/gem_mocs_settings
Signed-off-by: Peter Antoine <peter.antoine@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1460556205-6644-1-git-send-email-chris@chris-wilson.co.uk
This change adds the programming of the MOCS registers to the gen 9+
platforms. The set of MOCS configuration entries introduced by this
patch is intended to be minimal but sufficient to cover the needs of
current userspace - i.e. a good set of defaults. It is expected to be
extended in the future to provide further default values or to allow
userspace to redefine its private MOCS tables based on its demand for
additional caching configurations. In this setup, userspace should
only utilize the first N entries, higher entries are reserved for
future use.
It creates a fixed register set that is programmed across the different
engines so that all engines have the same table. This is done as the
main RCS context only holds the registers for itself and the shared
L3 values. By trying to keep the registers consistent across the
different engines it should make the programming for the registers
consistent.
v2:
-'static const' for private data structures and style changes.(Matt Turner)
v3:
- Make the tables "slightly" more readable. (Damien Lespiau)
- Updated tables fix performance regression.
v4:
- Code formatting. (Chris Wilson)
- re-privatised mocs code. (Daniel Vetter)
v5:
- Changed the name of a function. (Chris Wilson)
v6:
- re-based
- Added Mesa table entry (skylake & broxton) (Francisco Jerez)
- Tidied up the readability defines (Francisco Jerez)
- NUMBER of entries defines wrong. (Jim Bish)
- Added comments to clear up the meaning of the tables (Jim Bish)
v7 (Francisco Jerez):
- Don't write L3-specific MOCS_ESC/SCC values into the e/LLC control
tables. Prefix L3-specific defines consistently with L3_ and
e/LLC-specific defines with LE_ to avoid this kind of confusion in
the future.
- Change L3CC WT define back to RESERVED (matches my hardware
documentation and the original patch, probably a misunderstanding
of my own previous comment).
- Drop Android tables, define new minimal tables more suitable for the
open source stack.
- Add comment that the MOCS tables are part of the kernel ABI.
- Move intel_logical_ring_begin() and _advance() calls one level down
(Chris Wilson).
- Minor formatting and style fixes.
v8 (Francisco Jerez):
- Add table size sanity check to emit_mocs_control/l3cc_table() (Chris
Wilson).
- Add comment about undefined entries being implicitly set to uncached
for forwards compatibility.
v9 (Francisco Jerez):
- Minor style fixes.
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
Acked-by: Damien Lespiau <damien.lespiau@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
