Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
possible
The indirect method has been left in-place here as a fallback path, as
it may not be possible to map the non-PAGE_SIZE aligned control areas
across some chipset+interface combinations.
This isn't a problem for the primary use-case where the core and drm
are linked together in kernel-land, but across a VM or (in the case
where it applies now) between the core in the kernel and a userspace
test tool.
The full object interfaces are about to be exposed to userspace, so we
need to check for any security-related issues and version the structs
to make it easier to handle any changes we may need in the future.
Signed-off-by: Roy Spliet <rspliet@eclipso.eu>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Reported-by: Maarten Maathuis <madman2003@gmail.com>
Reported-by: Sven Joachim <svenjoac@gmx.de>
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Fixes a PCE0 page fault noticed on NVD9 during module unload.
It fixes a bug that would have been introduced when adding more
sudevs/engines.
Signed-off-by: Martin Peres <martin.peres@labri.fr>
This value will match something that's easily available from the engine IRQ
handlers, and used to lookup the relevant context.
Since the changes in how this is done on each generation match when the
major PFIFO changes happened, fifo is responsible for calculating the
correct value to avoid duplicating the same code among many engine modules.
This is a HUGE commit, but it's not nearly as bad as it looks - any problems
can be isolated to a particular chipset and engine combination. It was
simply too difficult to port each one at a time, the compat layers are
*already* ridiculous.
Most of the changes here are simply to the glue, the process for each of the
engine modules was to start with a standard skeleton and copy+paste the old
code into the appropriate places, fixing up variable names etc as needed.
v2: Marcin Slusarz <marcin.slusarz@gmail.com>
- fix find/replace bug in license header
v3: Ben Skeggs <bskeggs@redhat.com>
- bump indirect pushbuf size to 8KiB, 4KiB barely enough for userspace and
left no space for kernel's requirements during GEM pushbuf submission.
- fix duplicate assignments noticed by clang
v4: Marcin Slusarz <marcin.slusarz@gmail.com>
- add sparse annotations to nv04_fifo_pause/nv04_fifo_start
- use ioread32_native/iowrite32_native for fifo control registers
v5: Ben Skeggs <bskeggs@redhat.com>
- rebase on v3.6-rc4, modified to keep copy engine fix intact
- nv10/fence: unmap fence bo before destroying
- fixed fermi regression when using nvidia gr fuc
- fixed typo in supported dma_mask checking
v2 (Ben Skeggs):
- some fixes for 64KiB PAGE_SIZE
- fix porting issues in (currently unused) nv41/nv44 pciegart code
Future work will be headed in the way of separating the policy supplied by
the nouveau drm module from the mechanisms provided by the driver core.
There will be a couple of major classes (subdev, engine) of driver modules
that have clearly defined tasks, and the further directory structure change
is to reflect this.
No code changes here whatsoever, aside from fixing up a couple of include
file pathnames.
