Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Pull drm updates from Dave Airlie:
"This is the main drm pull request for v4.15.
Core:
- Atomic object lifetime fixes
- Atomic iterator improvements
- Sparse/smatch fixes
- Legacy kms ioctls to be interruptible
- EDID override improvements
- fb/gem helper cleanups
- Simple outreachy patches
- Documentation improvements
- Fix dma-buf rcu races
- DRM mode object leasing for improving VR use cases.
- vgaarb improvements for non-x86 platforms.
New driver:
- tve200: Faraday Technology TVE200 block.
This "TV Encoder" encodes a ITU-T BT.656 stream and can be found in
the StorLink SL3516 (later Cortina Systems CS3516) as well as the
Grain Media GM8180.
New bridges:
- SiI9234 support
New panels:
- S6E63J0X03, OTM8009A, Seiko 43WVF1G, 7" rpi touch panel, Toshiba
LT089AC19000, Innolux AT043TN24
i915:
- Remove Coffeelake from alpha support
- Cannonlake workarounds
- Infoframe refactoring for DisplayPort
- VBT updates
- DisplayPort vswing/emph/buffer translation refactoring
- CCS fixes
- Restore GPU clock boost on missed vblanks
- Scatter list updates for userptr allocations
- Gen9+ transition watermarks
- Display IPC (Isochronous Priority Control)
- Private PAT management
- GVT: improved error handling and pci config sanitizing
- Execlist refactoring
- Transparent Huge Page support
- User defined priorities support
- HuC/GuC firmware refactoring
- DP MST fixes
- eDP power sequencing fixes
- Use RCU instead of stop_machine
- PSR state tracking support
- Eviction fixes
- BDW DP aux channel timeout fixes
- LSPCON fixes
- Cannonlake PLL fixes
amdgpu:
- Per VM BO support
- Powerplay cleanups
- CI powerplay support
- PASID mgr for kfd
- SR-IOV fixes
- initial GPU reset for vega10
- Prime mmap support
- TTM updates
- Clock query interface for Raven
- Fence to handle ioctl
- UVD encode ring support on Polaris
- Transparent huge page DMA support
- Compute LRU pipe tweaks
- BO flag to allow buffers to opt out of implicit sync
- CTX priority setting API
- VRAM lost infrastructure plumbing
qxl:
- fix flicker since atomic rework
amdkfd:
- Further improvements from internal AMD tree
- Usermode events
- Drop radeon support
nouveau:
- Pascal temperature sensor support
- Improved BAR2 handling
- MMU rework to support Pascal MMU
exynos:
- Improved HDMI/mixer support
- HDMI audio interface support
tegra:
- Prep work for tegra186
- Cleanup/fixes
msm:
- Preemption support for a5xx
- Display fixes for 8x96 (snapdragon 820)
- Async cursor plane fixes
- FW loading rework
- GPU debugging improvements
vc4:
- Prep for DSI panels
- fix T-format tiling scanout
- New madvise ioctl
Rockchip:
- LVDS support
omapdrm:
- omap4 HDMI CEC support
etnaviv:
- GPU performance counters groundwork
sun4i:
- refactor driver load + TCON backend
- HDMI improvements
- A31 support
- Misc fixes
udl:
- Probe/EDID read fixes.
tilcdc:
- Misc fixes.
pl111:
- Support more variants
adv7511:
- Improve EDID handling.
- HDMI CEC support
sii8620:
- Add remote control support"
* tag 'drm-for-v4.15' of git://people.freedesktop.org/~airlied/linux: (1480 commits)
drm/rockchip: analogix_dp: Use mutex rather than spinlock
drm/mode_object: fix documentation for object lookups.
drm/i915: Reorder context-close to avoid calling i915_vma_close() under RCU
drm/i915: Move init_clock_gating() back to where it was
drm/i915: Prune the reservation shared fence array
drm/i915: Idle the GPU before shinking everything
drm/i915: Lock llist_del_first() vs llist_del_all()
drm/i915: Calculate ironlake intermediate watermarks correctly, v2.
drm/i915: Disable lazy PPGTT page table optimization for vGPU
drm/i915/execlists: Remove the priority "optimisation"
drm/i915: Filter out spurious execlists context-switch interrupts
drm/amdgpu: use irq-safe lock for kiq->ring_lock
drm/amdgpu: bypass lru touch for KIQ ring submission
drm/amdgpu: Potential uninitialized variable in amdgpu_vm_update_directories()
drm/amdgpu: potential uninitialized variable in amdgpu_vce_ring_parse_cs()
drm/amd/powerplay: initialize a variable before using it
drm/amd/powerplay: suppress KASAN out of bounds warning in vega10_populate_all_memory_levels
drm/amd/amdgpu: fix evicted VRAM bo adjudgement condition
drm/vblank: Tune drm_crtc_accurate_vblank_count() WARN down to a debug
drm/rockchip: add CONFIG_OF dependency for lvds
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Made completely unreachable (and broken) by atomic commits.
I plan to usurp the short name of struct fence for a core kernel struct,
and so I need to rename the specialised fence/timeline for DMA
operations to make room.
A consensus was reached in
https://lists.freedesktop.org/archives/dri-devel/2016-July/113083.html
that making clear this fence applies to DMA operations was a good thing.
Since then the patch has grown a bit as usage increases, so hopefully it
remains a good thing!
(v2...: rebase, rerun spatch)
v3: Compile on msm, spotted a manual fixup that I broke.
v4: Try again for msm, sorry Daniel
coccinelle script:
- struct fence
+ struct dma_fence
- struct fence_ops
+ struct dma_fence_ops
- struct fence_cb
+ struct dma_fence_cb
- struct fence_array
+ struct dma_fence_array
- enum fence_flag_bits
+ enum dma_fence_flag_bits
- fence_init
+ dma_fence_init
- fence_release
+ dma_fence_release
- fence_free
+ dma_fence_free
- fence_get
+ dma_fence_get
- fence_get_rcu
+ dma_fence_get_rcu
- fence_put
+ dma_fence_put
- fence_signal
+ dma_fence_signal
- fence_signal_locked
+ dma_fence_signal_locked
- fence_default_wait
+ dma_fence_default_wait
- fence_add_callback
+ dma_fence_add_callback
- fence_remove_callback
+ dma_fence_remove_callback
- fence_enable_sw_signaling
+ dma_fence_enable_sw_signaling
- fence_is_signaled_locked
+ dma_fence_is_signaled_locked
- fence_is_signaled
- fence_is_later
+ dma_fence_is_later
- fence_later
+ dma_fence_later
- fence_wait_timeout
+ dma_fence_wait_timeout
- fence_wait_any_timeout
+ dma_fence_wait_any_timeout
- fence_wait
+ dma_fence_wait
- fence_context_alloc
+ dma_fence_context_alloc
- fence_array_create
+ dma_fence_array_create
- to_fence_array
+ to_dma_fence_array
- fence_is_array
+ dma_fence_is_array
- trace_fence_emit
+ trace_dma_fence_emit
- FENCE_TRACE
+ DMA_FENCE_TRACE
- FENCE_WARN
+ DMA_FENCE_WARN
- FENCE_ERR
+ DMA_FENCE_ERR
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Acked-by: Sumit Semwal <sumit.semwal@linaro.org>
Acked-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20161025120045.28839-1-chris@chris-wilson.co.uk
Fence contexts are created on the fly (for example) by the GPU scheduler used
in the amdgpu driver as a result of an userspace request. Because of this
userspace could in theory force a wrap around of the 32bit context number
if it doesn't behave well.
Avoid this by increasing the context number to 64bits. This way even when
userspace manages to allocate a billion contexts per second it takes more
than 500 years for the context number to wrap around.
v2: fix printf formats as well.
Signed-off-by: Christian König <christian.koenig@amd.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1464786612-5010-2-git-send-email-deathsimple@vodafone.de
The namespace of NVKM is being changed to nvkm_ instead of nouveau_,
which will be used for the DRM part of the driver. This is being
done in order to make it very clear as to what part of the driver a
given symbol belongs to, and as a minor step towards splitting the
DRM driver out to be able to stand on its own (for virt).
Because there's already a large amount of churn here anyway, this is
as good a time as any to also switch to NVIDIA's device and chipset
naming to ease collaboration with them.
A comparison of objdump disassemblies proves no code changes.
Tested-by: Alexandre Courbot <acourbot@nvidia.com>
Make nouveau_fence_chan refcounted, to make trace_fence_destroy
always return the correct name without a race condition.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
nouveau keeps track in userspace whether a buffer is being
written to or being read, but it doesn't use that information.
Change this to allow multiple readers on the same bo.
Acked-by: Ben Skeggs <bskeggs@redhat.com>
As opposed to an explicit wait. Allows userspace to not stall waiting
on buffer deletion.
A step towards being able to provide fences from other engines not
connected to PFIFO.
Now can be used to operate on any buffer mapped into the GPU virtual
address and not just the main inter-channel sync buffer.
Allows most of the code to be shared between nv84/nvc0 implementations,
and paves the way for doing emit/sync on non-VRAM buffers (multi-gpu,
dma-buf).
Since commit 5e120f6e4b3f35b741c5445dfc755f50128c3c44 "drm/nouveau/fence:
convert to exec engine, and improve channel sync" nouveau fence sync
implementation for nv17-50 and nvc0+ started to rely on state of fence buffer
left by previous sync operation. But as pinned bo's (where fence state is
stored) are not saved+restored across suspend/resume, we need to do it
manually.
nvc0+ was fixed by commit d6ba6d215a538a58f0f0026f0961b0b9125e8042
"drm/nvc0/fence: restore pre-suspend fence buffer context on resume".
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=50121
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: stable@vger.kernel.org
This is a HUGE commit, but it's not nearly as bad as it looks - any problems
can be isolated to a particular chipset and engine combination. It was
simply too difficult to port each one at a time, the compat layers are
*already* ridiculous.
Most of the changes here are simply to the glue, the process for each of the
engine modules was to start with a standard skeleton and copy+paste the old
code into the appropriate places, fixing up variable names etc as needed.
v2: Marcin Slusarz <marcin.slusarz@gmail.com>
- fix find/replace bug in license header
v3: Ben Skeggs <bskeggs@redhat.com>
- bump indirect pushbuf size to 8KiB, 4KiB barely enough for userspace and
left no space for kernel's requirements during GEM pushbuf submission.
- fix duplicate assignments noticed by clang
v4: Marcin Slusarz <marcin.slusarz@gmail.com>
- add sparse annotations to nv04_fifo_pause/nv04_fifo_start
- use ioread32_native/iowrite32_native for fifo control registers
v5: Ben Skeggs <bskeggs@redhat.com>
- rebase on v3.6-rc4, modified to keep copy engine fix intact
- nv10/fence: unmap fence bo before destroying
- fixed fermi regression when using nvidia gr fuc
- fixed typo in supported dma_mask checking
This is all very much a policy thing, and hence will not belong in SW
after the rework.
engsw now only handles receiving the event to say "can flip now" and makes
a callback to perform the actual work.
Still the same code, but not an "engine" anymore. The fence code is more of
a policy decision rather than exposing mechanisms, so it's not appropriate
to port it to the new engine subsystem.
Now have a somewhat simpler semaphore sync implementation for nv17:nv84,
and a switched to using semaphores as fences on nv84+ and making use of
the hardware's >= acquire operation.
