Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
A step towards being able to provide fences from other engines not
connected to PFIFO.
Now can be used to operate on any buffer mapped into the GPU virtual
address and not just the main inter-channel sync buffer.
Allows most of the code to be shared between nv84/nvc0 implementations,
and paves the way for doing emit/sync on non-VRAM buffers (multi-gpu,
dma-buf).
Since commit 5e120f6e4b3f35b741c5445dfc755f50128c3c44 "drm/nouveau/fence:
convert to exec engine, and improve channel sync" nouveau fence sync
implementation for nv17-50 and nvc0+ started to rely on state of fence buffer
left by previous sync operation. But as pinned bo's (where fence state is
stored) are not saved+restored across suspend/resume, we need to do it
manually.
nvc0+ was fixed by commit d6ba6d215a538a58f0f0026f0961b0b9125e8042
"drm/nvc0/fence: restore pre-suspend fence buffer context on resume".
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=50121
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: stable@vger.kernel.org
This is a HUGE commit, but it's not nearly as bad as it looks - any problems
can be isolated to a particular chipset and engine combination. It was
simply too difficult to port each one at a time, the compat layers are
*already* ridiculous.
Most of the changes here are simply to the glue, the process for each of the
engine modules was to start with a standard skeleton and copy+paste the old
code into the appropriate places, fixing up variable names etc as needed.
v2: Marcin Slusarz <marcin.slusarz@gmail.com>
- fix find/replace bug in license header
v3: Ben Skeggs <bskeggs@redhat.com>
- bump indirect pushbuf size to 8KiB, 4KiB barely enough for userspace and
left no space for kernel's requirements during GEM pushbuf submission.
- fix duplicate assignments noticed by clang
v4: Marcin Slusarz <marcin.slusarz@gmail.com>
- add sparse annotations to nv04_fifo_pause/nv04_fifo_start
- use ioread32_native/iowrite32_native for fifo control registers
v5: Ben Skeggs <bskeggs@redhat.com>
- rebase on v3.6-rc4, modified to keep copy engine fix intact
- nv10/fence: unmap fence bo before destroying
- fixed fermi regression when using nvidia gr fuc
- fixed typo in supported dma_mask checking
This is all very much a policy thing, and hence will not belong in SW
after the rework.
engsw now only handles receiving the event to say "can flip now" and makes
a callback to perform the actual work.
Still the same code, but not an "engine" anymore. The fence code is more of
a policy decision rather than exposing mechanisms, so it's not appropriate
to port it to the new engine subsystem.
Now have a somewhat simpler semaphore sync implementation for nv17:nv84,
and a switched to using semaphores as fences on nv84+ and making use of
the hardware's >= acquire operation.
