Reported-by: Mario Bachmann <grafgrimm77@gmx.de>
Tested-by: Greg Turner <gmturner007@ameritech.net>
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
When xorg state tracker wants to hide the cursor it calls set_cursor
with NULL buffer_handle and size=0x0, but nouveau refuses to hide it
because size is not 64x64... which is a bit odd. Both radeon and intel
check buffer_handle before validating size of cursor, so make nouveau
implementation consistent with them.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Fix 'ERROR: that open brace { should be on the previous line'
Fix 'ERROR: else should follow close brace }'
Signed-off-by: Emil Velikov <emil.l.velikov@gmail.com>
'mappable' isn't really used at all, nor is it necessary anymore as the
bo code is capable of moving buffers to mappable vram as required.
'no_vm' isn't necessary anymore either, any places that don't want to be
mapped into a GPU address space should allocate the VRAM directly instead.
nv0x-nv4x should be mostly fine, nv50 doesn't work yet.
The enter argument as implemented by commit 413d45d3627 (drm, kdb, kms:
Add an enter argument to mode_set_base_atomic() API) should be more
descriptive as to what it does vs just passing 1 and 0 around.
There is no runtime behavior change as a result of this patch.
Reported-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
CC: David Airlie <airlied@linux.ie>
CC: dri-devel@lists.freedesktop.org
* drm-kdb-next:
drm/nouveau/kms: Avoid a hang entering KDB with VT accel on.
radeon, kdb, kms: Save and restore the LUT on atomic KMS enter/exit
drm, kdb, kms: Add an enter argument to mode_set_base_atomic() API
drm/nouveau/kms: Implement KDB debug hooks for nouveau KMS.
drm/radeon/kms: Implement KDB debug hooks for radeon KMS.
Francisco Jerez advises that pre-nv20 cards would hang if we entered
kdb with accel on and IRQs disabled, so we now disable accel before
entering kdb and re-enable it on the way back out.
Reported-by: Francisco Jerez <currojerez@riseup.net>
Signed-off-by: Chris Ball <cjb@laptop.org>
Some devices such as the radeon chips receive information from user
space which needs to be saved when executing an atomic mode set
operation, else the user space would have to be queried again for the
information.
This patch extends the mode_set_base_atomic() call to pass an argument
to indicate if this is an entry or an exit from an atomic kernel mode
set change. Individual drm drivers can properly save and restore
state accordingly.
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
Tested on nv50 and nv04 HW.
This replaces all the pll_types definitions for ones that match the types
used in the tables in recent VBIOS versions.
get_pll_limits() will now accept either type or register value as input
across all limits table versions, and will store the actual register ID
that a PLL type refers to in the returned structure.
nv2x CRTC FIFOs are as large as in nv3x (4kB it seems), and the FIFO
control registers have the same layout: we can make them share the
same implementation.
Previously we were using the nv1x code, but the calculated FIFO
watermarks are usually too low for nv2x and they cause horrible
scanout artifacts. They've gone unnoticed until now because we've been
leaving one of the bandwidth regs uninitialized (CRE 47, which
contains the most significant bits of FFLWM), so everything seemed to
work fine except in some cases after a cold boot, depending on the
memory bandwidth and pixel clocks used.
Expand the crtc_gamma_set function to accept a starting offset. The
reason for this is to eventually use this function for setcolreg from
drm_fb_helper.c. The fbdev colormap function can start at any offset in
the color map.
Signed-by: James Simmons <jsimmons@infradead.org>
This is consistent with trying to access a filename that not exist
within a directory which is a good analogy here. The main reason for the
change is that it is easy to confuse the error code of EBADF as an
performing an ioctl on an invalid file descriptor (rather than an
unknown object).
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
sil164 and friends are the most common, usually they just need to be
poked once because a fixed configuration is enough for any modes and
clocks, so they worked without this patch if the BIOS had done a good
job on POST. Display couldn't survive a suspend/resume cycle though.
Unfortunately, BIOS scripts are useless here.
Load detection needs the connector wired to a CRTC, when there are no
inactive CRTCs left that means we need to cut some other head off for
a while, causing intermittent flickering.
* nouveau/for-airlied:
drm/nouveau: add module option to disable TV detection
drm/nouveau: Never evict VRAM buffers to system.
drm/nv50: fix connector table parsing for some cards
drm/nv50: add a memory barrier to pushbuf submission
drm/nouveau: print a message very early during suspend
drm/nv04-nv40: Fix up the programmed horizontal sync pulse delay.
drm/nouveau: Gigabyte NX85T connector table lies, it has DVI-I not HDMI
drm/nouveau: add option to allow override of dcb connector table types
drm/nv50: Improve PGRAPH interrupt handling.
drm/nv50: Make ctxprog wait until interrupt handler is done.
drm/nouveau: Fix fbcon corruption with font width not divisible by 8
drm/nv50: Remove redundant/incorrect ctxvals initialisation.
The calculated values were a little bit off (~16 clocks), the only
effect it could have had is a slightly offset image with respect to
the blob on analog outputs (bug 26790).
Mostly obvious simplifications.
The i915 pread/pwrite ioctls, intel_overlay_put_image and
nouveau_gem_new were incorrectly using the locked versions
without locking: this is also fixed in this patch.
Signed-off-by: Luca Barbieri <luca@luca-barbieri.com>
- Use driver level (0x2) for NV_DEBUG instead of all levels
- Create a NV_DEBUG_KMS for KMS level (0x4) and use them in modesetting code
- Remove a few odd NV_TRACE calls and replace some of them with NV_DEBUG_KMS or
NV_INFO
Signed-off-by: Maarten Maathuis <madman2003@gmail.com>
This adds a drm/kms staging non-API stable driver for GPUs from NVIDIA.
This driver is a KMS-based driver and requires a compatible nouveau
userspace libdrm and nouveau X.org driver.
This driver requires firmware files not available in this kernel tree,
interested parties can find them via the nouveau project git archive.
This driver is reverse engineered, and is in no way supported by nVidia.
Support for nearly the complete range of nvidia hw from nv04->g80 (nv50)
is available, and the kms driver should support driving nearly all
output types (displayport is under development still) along with supporting
suspend/resume.
This work is all from the upstream nouveau project found at
nouveau.freedesktop.org.
The original authors list from nouveau git tree is:
Anssi Hannula <anssi.hannula@iki.fi>
Marcin KoĆcielnicki <koriakin@0x04.net>
Matthew Garrett <mjg@redhat.com>
Matt Parnell <mparnell@gmail.com>
Patrice Mandin <patmandin@gmail.com>
Pekka Paalanen <pq@iki.fi>
Xavier Chantry <shiningxc@gmail.com>
along with project founder Stephane Marchesin <marchesin@icps.u-strasbg.fr>
