path: root/drivers/gpu/drm/nouveau/nv17_tv.h
2011-02-23drm: Mark constant arrays of drm_display_mode constChris Wilson
... and fixup some methods to accept the constant argument. Now that constant module arrays are loaded into read-only memory, using const appropriately has some benefits beyond warning the programmer about likely mistakes. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-24drm/nouveau: Break some long lines in the TV-out code.Francisco Jerez
Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2009-12-11drm/nouveau: Add DRM driver for NVIDIA GPUsBen Skeggs
This adds a drm/kms staging non-API stable driver for GPUs from NVIDIA. This driver is a KMS-based driver and requires a compatible nouveau userspace libdrm and nouveau X.org driver. This driver requires firmware files not available in this kernel tree, interested parties can find them via the nouveau project git archive. This driver is reverse engineered, and is in no way supported by nVidia. Support for nearly the complete range of nvidia hw from nv04->g80 (nv50) is available, and the kms driver should support driving nearly all output types (displayport is under development still) along with supporting suspend/resume. This work is all from the upstream nouveau project found at nouveau.freedesktop.org. The original authors list from nouveau git tree is: Anssi Hannula <anssi.hannula@iki.fi> Ben Skeggs <bskeggs@redhat.com> Francisco Jerez <currojerez@riseup.net> Maarten Maathuis <madman2003@gmail.com> Marcin Koƛcielnicki <koriakin@0x04.net> Matthew Garrett <mjg@redhat.com> Matt Parnell <mparnell@gmail.com> Patrice Mandin <patmandin@gmail.com> Pekka Paalanen <pq@iki.fi> Xavier Chantry <shiningxc@gmail.com> along with project founder Stephane Marchesin <marchesin@icps.u-strasbg.fr> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
