Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Also imports a couple of helper functions that'll be used to implement
page flipping in the following commits..
This should prevent a number of races from occuring, the most obvious of
which will be exposed when we start making use of the "display sync" evo
channel for page flipping. The DS channel will reject any command stream
that doesn't completely agree with the current "master" state.
We need to be able to have the bh run while possibly spinning waiting for
the EVO notifier to signal. This apparently happens in some circumstances
with preempt disabled, so our workqueue was never being run.
More appropriate, and we're about to be using more than just the master
EVO channel.
With cmwq, there's no reason for nouveau to use a dedicated workqueue.
Drop dev_priv->wq and use system_wq instead. Each work item is sync
flushed when the containing structure is unregistered/destroyed.
Note that this change also makes sure that nv50_gpio_handler is not
freed while the contained work item is still running.
Cc: David Airlie <airlied@linux.ie>
Cc: dri-devel@lists.freedesktop.org
Allows callers to install their own handlers for when a GPIO line
changes state (such as for hotplug detect).
This also fixes a bug where we weren't acknowledging the GPIO IRQ
until after the bottom half had run, causing a severe IRQ storm
in some cases.
Reviewed-by: Francisco Jerez <currojerez@riseup.net>
In a multihead setup vblank interrupts may end up enabled in both
heads. In that case we want to ignore the vblank interrupts coming
from the wrong CRTC to avoid tearing and unbalanced calls to
drm_vblank_get/put (fdo bug 31074).
Reported-by: Felix Leimbach <felix.leimbach@gmx.net>
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
The old code generated an interrupt storm bad enough to completely
take down my system.
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Nouveau will need this on GeForce 8 and up to account for the GPU
reordering physical VRAM for some memory types.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Acked-by: Thomas Hellström <thellstrom@vmware.com>
It seems on some chipsets that doing this from the 0x20 handler causes the
display engine to not ever signal the final 0x40 stage.
This removes the previous prepare_access() and finish_access() hooks, and
replaces it with a much simpler flush() hook.
All the chipset-specific code before nv50 has its use removed completely,
as it's not required there at all.
The previous handler basically worked correctly for a full-blown mode
change. However, it did nothing at all when a partial (encoder only)
reconfiguation was necessary, leading to the display hanging on certain
types of mode switch.
Create connectors before encoders to avoid having to do another loop across
encoder list whenever we create a new connector. This allows us to pass
the connector to the encoder creation functions, and avoid using a
create_resources() callback since we can now call it directly.
This can also potentially modify the connector ordering on nv50. On cards
where the DCB connector and encoder tables are in the same order, things
will be unchanged. However, there's some cards where the ordering between
the tables differ, and in one case, leads us to naming the connectors
"wrongly".
After thinking it over a lot it made more sense for the core to deal with
the output polling especially so it can notify X.
v2: drop plans for fake connector - per Michel's comments - fix X patch sent to xorg-devel, add intel polled/hpd setting, add initial nouveau polled/hpd settings.
v3: add config lock take inside polling, add intel/nouveau poll init/fini calls
v4: config lock was a bit agressive, only needed around connector list reading.
otherwise it could re-enter.
glisse: discard drm_helper_hpd_irq_event
v3: Reviewed-by: Michel Dänzer <michel@daenzer.net>
* drm-fbdev-cleanup:
drm/fb: remove drm_fb_helper_setcolreg
drm/kms/fb: use slow work mechanism for normal hotplug also.
drm/kms/fb: add polling support for when nothing is connected.
drm/kms/fb: provide a 1024x768 fbcon if no outputs found.
drm/kms/fb: separate fbdev connector list from core drm connectors
drm/kms/fb: move to using fb helper crtc grouping instead of core crtc list
drm/fb: fix fbdev object model + cleanup properly.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/nouveau/nouveau_drv.h
On DP outputs we'll likely end up running vbios init tables here, which
may sleep.
As opposed to repeatedly reading the amount back from the GPU every
time we need to know the VRAM size.
We should now fail to load gracefully on detecting no VRAM, rather than
something potentially messy happening.
a) slow work is always used now for any fbcon hotplug, as its not
a fast task and is more suited to being ran under slow work.
b) attempt to not do any fbdev changes when X is running as we'll
just mess it up. This hooks set_par to hopefully do the changes
once X hands control to fbdev.
This also adds the nouveau/intel hotplug support.
The connector table index in the DCB entry for each output type is an
index into the connector table, and does *not* necessarily match up
with what was previously called "index" in the connector table entries
themselves.
Not real sure what that index is exactly, renamed to "index2" as we
still use it to prevent creating multiple TV connectors.
This makes this code common to both the nv04 and nv50 paths.
For the moment, we keep the previous behaviour with HDMI/eDP connectors
and report them as DVI-D/DP instead. This will be fixed once the rest
of the code has been fixed to deal with those types.
