Not-entirely-upstream-sha1-but-equivalent: bed2dd8421
("drm/ttm: Quick-test mmap offset in ttm_bo_mmap()")
Setting CONFIG_NOUVEAU_LEGACY_CTX_SUPPORT=n (added by commit: b30a43ac7132)
causes the build to fail with:
ERROR: "drm_legacy_mmap" [drivers/gpu/drm/nouveau/nouveau.ko] undefined!
This does not happend upstream as the offending code got removed in:
bed2dd8421 ("drm/ttm: Quick-test mmap offset in ttm_bo_mmap()")
Fix that by adding check for CONFIG_NOUVEAU_LEGACY_CTX_SUPPORT around
the drm_legacy_mmap() call.
Also, as Sven Joachim pointed out, we need to make the check in
CONFIG_NOUVEAU_LEGACY_CTX_SUPPORT=n case return -EINVAL as its done
for basically all other gpu drivers, especially in upstream kernels
drivers/gpu/drm/ttm/ttm_bo_vm.c as of the upstream commit bed2dd8421.
NOTE. This is a minimal stable-only fix for trees where b30a43ac7132 is
backported as the build error affects nouveau only.
Fixes: b30a43ac7132 ("drm/nouveau: add kconfig option to turn off nouveau
legacy contexts. (v3)")
Signed-off-by: Thomas Backlund <tmb@mageia.org>
Cc: stable@vger.kernel.org
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Sven Joachim <svenjoac@gmx.de>
commit b30a43ac7132cdda833ac4b13dd1ebd35ace14b7 upstream.
There was a nouveau DDX that relied on legacy context ioctls to work,
but we fixed it years ago, give distros that have a modern DDX the
option to break the uAPI and close the mess of holes that legacy
context support is.
Full context of the story:
commit 0e975980d435d58df2d430d688b8c18778b42218
Author: Peter Antoine <peter.antoine@intel.com>
Date: Tue Jun 23 08:18:49 2015 +0100
drm: Turn off Legacy Context Functions
The context functions are not used by the i915 driver and should not
be used by modeset drivers. These driver functions contain several bugs
and security holes. This change makes these functions optional can be
turned on by a setting, they are turned off by default for modeset
driver with the exception of the nouvea driver that may require them with
an old version of libdrm.
The previous attempt was
commit 7c510133d93dd6f15ca040733ba7b2891ed61fd1
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Thu Aug 8 15:41:21 2013 +0200
drm: mark context support as a legacy subsystem
but this had to be reverted
commit c21eb21cb50d58e7cbdcb8b9e7ff68b85cfa5095
Author: Dave Airlie <airlied@redhat.com>
Date: Fri Sep 20 08:32:59 2013 +1000
Revert "drm: mark context support as a legacy subsystem"
v2: remove returns from void function, and formatting (Daniel Vetter)
v3:
- s/Nova/nouveau/ in the commit message, and add references to the
previous attempts
- drop the part touching the drm hw lock, that should be a separate
patch.
Signed-off-by: Peter Antoine <peter.antoine@intel.com> (v2)
Cc: Peter Antoine <peter.antoine@intel.com> (v2)
Reviewed-by: Peter Antoine <peter.antoine@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
v2: move DRM_VM dependency into legacy config.
v3: fix missing dep (kbuild robot)
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
(v3)"
This reverts commit 610382337557bd2057d9b47f996af0b6ff827a2b which is
Sven reports:
Commit 1e07d63749 ("drm/nouveau: add kconfig option to turn off nouveau
legacy contexts. (v3)") has caused a build failure for me when I
actually tried that option (CONFIG_NOUVEAU_LEGACY_CTX_SUPPORT=n):
| Kernel: arch/x86/boot/bzImage is ready (#1)
| Building modules, stage 2.
| MODPOST 290 modules
| scripts/Makefile.modpost:91: recipe for target '__modpost' failed
Upstream does not have that problem, as commit bed2dd8421 ("drm/ttm:
Quick-test mmap offset in ttm_bo_mmap()") has removed the use of
drm_legacy_mmap from nouveau_ttm.c. Unfortunately that commit does not
apply in 5.1.9.
The ensuing discussion proposed a number of one-off patches, but no
solid agreement was made, so just revert the commit for now to get
people's systems building again.
Reported-by: Sven Joachim <svenjoac@gmx.de>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Thomas Backlund <tmb@mageia.org>
[ Upstream commit d2434e4d942c32cadcbdbcd32c58f35098f3b604 ]
Cursor position updates were accidentally causing us to attempt to interlock
window with window immediate, and without a matching window immediate update,
NVDisplay could hang forever in some circumstances.
Fixes suspend/resume on (at least) Quadro RTX4000 (TU104).
Reported-by: Lyude Paul <lyude@redhat.com>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
encoders change
[ Upstream commit a0b694d0af21c9993d1a39a75fd814bd48bf7eb4 ]
HW has error checks in place which check that pixel depth is explicitly
provided on DP, while HDMI has a "default" setting that we use.
In multi-display configurations with identical modelines, but different
protocols (HDMI + DP, in this case), it was possible for the DP head to
get swapped to the head which previously drove the HDMI output, without
updating HeadSetControlOutputResource(), triggering the error check and
hanging the core update.
configuration
[ Upstream commit 13d03e9daf70dab032c03dc172e75bb98ad899c4 ]
Where possible, we want the failsafe link configuration (one which won't
hang the OR during modeset because of not enough bandwidth for the mode)
to also be supported by the sink.
This prevents "link rate unsupported by sink" messages when link training
fails.
context support is.
v3:
previous attempts
patch.
commit 342406e4fbba9a174125fbfe6aeac3d64ef90f76 upstream.
For a while, we've had the problem of i2c bus access not grabbing
a runtime PM ref when it's being used in userspace by i2c-dev, resulting
in nouveau spamming the kernel log with errors if anything attempts to
access the i2c bus while the GPU is in runtime suspend. An example:
[ 130.078386] nouveau 0000:01:00.0: i2c: aux 000d: begin idle timeout ffffffff
Since the GPU is in runtime suspend, the MMIO region that the i2c bus is
on isn't accessible. On x86, the standard behavior for accessing an
unavailable MMIO region is to just return ~0.
Except, that turned out to be a lie. While computers with a clean
concious will return ~0 in this scenario, some machines will actually
completely hang a CPU on certian bad MMIO accesses. This was witnessed
with someone's Lenovo ThinkPad P50, where sensors-detect attempting to
access the i2c bus while the GPU was suspended would result in a CPU
hang:
CPU: 5 PID: 12438 Comm: sensors-detect Not tainted 5.0.0-0.rc4.git3.1.fc30.x86_64 #1
Hardware name: LENOVO 20EQS64N17/20EQS64N17, BIOS N1EET74W (1.47 ) 11/21/2017
RIP: 0010:ioread32+0x2b/0x30
Code: 81 ff ff ff 03 00 77 20 48 81 ff 00 00 01 00 76 05 0f b7 d7 ed c3
48 c7 c6 e1 0c 36 96 e8 2d ff ff ff b8 ff ff ff ff c3 8b 07 <c3> 0f 1f
40 00 49 89 f0 48 81 fe ff ff 03 00 76 04 40 88 3e c3 48
RSP: 0018:ffffaac3c5007b48 EFLAGS: 00000292 ORIG_RAX: ffffffffffffff13
RAX: 0000000001111000 RBX: 0000000001111000 RCX: 0000043017a97186
RDX: 0000000000000aaa RSI: 0000000000000005 RDI: ffffaac3c400e4e4
RBP: ffff9e6443902c00 R08: ffffaac3c400e4e4 R09: ffffaac3c5007be7
R10: 0000000000000004 R11: 0000000000000001 R12: ffff9e6445dd0000
R13: 000000000000e4e4 R14: 00000000000003c4 R15: 0000000000000000
FS: 00007f253155a740(0000) GS:ffff9e644f600000(0000) knlGS:0000000000000000
CR2: 00005630d1500358 CR3: 0000000417c44006 CR4: 00000000003606e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
g94_i2c_aux_xfer+0x326/0x850 [nouveau]
nvkm_i2c_aux_i2c_xfer+0x9e/0x140 [nouveau]
__i2c_transfer+0x14b/0x620
i2c_smbus_xfer_emulated+0x159/0x680
? _raw_spin_unlock_irqrestore+0x1/0x60
? rt_mutex_slowlock.constprop.0+0x13d/0x1e0
? __lock_is_held+0x59/0xa0
__i2c_smbus_xfer+0x138/0x5a0
i2c_smbus_xfer+0x4f/0x80
i2cdev_ioctl_smbus+0x162/0x2d0 [i2c_dev]
i2cdev_ioctl+0x1db/0x2c0 [i2c_dev]
do_vfs_ioctl+0x408/0x750
ksys_ioctl+0x5e/0x90
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x60/0x1e0
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x7f25317f546b
Code: 0f 1e fa 48 8b 05 1d da 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff
ff ff c3 66 0f 1f 44 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01
f0 ff ff 73 01 c3 48 8b 0d ed d9 0c 00 f7 d8 64 89 01 48
RSP: 002b:00007ffc88caab68 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00005630d0fe7260 RCX: 00007f25317f546b
RDX: 00005630d1598e80 RSI: 0000000000000720 RDI: 0000000000000003
RBP: 00005630d155b968 R08: 0000000000000001 R09: 00005630d15a1da0
R10: 0000000000000070 R11: 0000000000000246 R12: 00005630d1598e80
R13: 00005630d12f3d28 R14: 0000000000000720 R15: 00005630d12f3ce0
watchdog: BUG: soft lockup - CPU#5 stuck for 23s! [sensors-detect:12438]
Yikes! While I wanted to try to make it so that accessing an i2c bus on
nouveau would wake up the GPU as needed, airlied pointed out that pretty
much any usecase for userspace accessing an i2c bus on a GPU (mainly for
the DDC brightness control that some displays have) is going to only be
useful while there's at least one display enabled on the GPU anyway, and
the GPU never sleeps while there's displays running.
Since teaching the i2c bus to wake up the GPU on userspace accesses is a
good deal more difficult than it might seem, mostly due to the fact that
we have to use the i2c bus during runtime resume of the GPU, we instead
opt for the easiest solution: don't let userspace access i2c busses on
the GPU at all while it's in runtime suspend.
Changes since v1:
* Also disable i2c busses that run over DP AUX
Signed-off-by: Lyude Paul <lyude@redhat.com>
[ Upstream commit f10b83de1fd49216a4c657816f48001437e4bdd5 ]
If the BAR is zero size, it indicates it was never successfully mapped.
Ensure that the BAR is valid during initialization before attempting to
use it.
Signed-off-by: Jon Derrick <jonathan.derrick@intel.com>
[ Upstream commit fc782242749fa4235592854fafe1a1297583c1fb ]
GF117 appears to use the same register as GK104 (but still with the
general Fermi readout mechanism).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=108980
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
[ Upstream commit 909e9c9c428376e2a43d178ed4b0a2d5ba9cb7d3 ]
pm_runtime_get_sync returns negative on failure.
Fixes: eaeb9010bb4b ("drm/nouveau/debugfs: Wake up GPU before doing any reclocking")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 934c5b32a5e43d8de2ab4f1566f91d7c3bf8cb64 ]
The correct way for legacy drivers to update properties that need to
do a full modeset, is to do a full modeset.
Note that we don't need to call the drm_mode_config_internal helper
because we're not changing any of the refcounted paramters.
v2: Fixup error handling (Ville). Since the old code didn't bother
I decided to just delete it instead of adding even more code for just
error handling.
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com> (v1)
Cc: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20181217194303.14397-2-daniel.vetter@ffwll.ch
[ Upstream commit a5176a4cb85bb6213daadf691097cf411da35df2 ]
[ Upstream commit 118780066e30c34de3d9349710b51780bfa0ba83 ]
When a fan is controlled via linear fallback without cstate, we
shouldn't stop polling. Otherwise it won't be adjusted again and
keeps running at an initial crazy pace.
Fixes: 800efb4c2857 ("drm/nouveau/drm/therm/fan: add a fallback if no fan control is specified in the vbios")
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1103356
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=107447
Reported-by: Thomas Blume <thomas.blume@suse.com>
Reviewed-by: Martin Peres <martin.peres@free.fr>
commit b89fdf7ae8500feae1100d8b283176a44d31d698 upstream.
We need to actually make sure we check this on resume since otherwise we
won't know whether or not the topology is still there once we've
resumed, which will cause us to still think the topology is connected
even after it's been removed if the removal happens mid-suspend.
commit 970a5ee41c72df46e3b0f307528c7d8ef7734a2e upstream.
Should hopefully fix a regression some people have been seeing since EVO
push buffers were moved to VRAM by default on Pascal GPUs.
Fixes: d00ddd9da ("drm/nouveau/kms/nv50-: allocate push buffers in vidmem on pascal")
Cc: <stable@vger.kernel.org> # 4.19+
commit 24199c5436f267399afed0c4f1f57663c0408f57 upstream.
Noticed this while working on redoing the reference counting scheme in
the DP MST helpers. Nouveau doesn't attempt to call
drm_dp_mst_topology_mgr_destroy() at all, which leaves it leaking all of
the resources for drm_dp_mst_topology_mgr and it's children mstbs+ports.
Fixes: f479c0ba4a17 ("drm/nouveau/kms/nv50: initial support for DP 1.2 multi-stream")
Cc: <stable@vger.kernel.org> # v4.10+
commit 7b0f61e91b6056c71649efa3204112a4b6cf5fc8 upstream.
As mentioned in the previous commit, we currently prevent new modesets
on recently-removed MST connectors by returning no encoder from our
->best_encoder() callback once the MST port has disappeared. This is
wrong however, because it prevents legacy modesetting users from being
able to disable CRTCs on MST connectors after the connector's respective
topology has disappeared.
So, fix this by instead by just always returning a valid encoder.
Changes since v2:
- Remove usage of atomic MST helper for now, since that got replaced
with a much simpler solution
Reviewed-by: Ben Skeggs <bskeggs@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20181008232437.5571-3-lyude@redhat.com
(cherry picked from commit e87b0bbc9f0380d403f8f2f6abba0d51c74d944f)
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
commit dc854914999d5d52ac1b31740cb0ea8d89d0372e upstream.
Remember, ida IDs start at 0, not 1!
Reviewed-by: Karol Herbst <kherbst@redhat.com>
[ Upstream commit 74a07c0a59fa372b069d879971ba4d9e341979cf ]
In case memory resources for *bl_desc* were allocated, release
them before return.
Addresses-Coverity-ID: 1472021 ("Resource leak")
Fixes: 0d466901552a ("drm/nouveau/secboot/acr: Remove VLA usage")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Reviewed-by: John Hubbard <jhubbard@nvidia.com>
While we currently grab a runtime PM ref in nouveau's normal connector
detection code, we apparently don't do this for MST. This means if we're
in a scenario where the GPU is suspended and userspace attempts to do a
connector probe on an MSTC connector, the probe will fail entirely due
to the DP aux channel and GPU not being woken up:
[ 316.633489] nouveau 0000:01:00.0: i2c: aux 000a: begin idle timeout ffffffff
[ 316.635713] nouveau 0000:01:00.0: i2c: aux 000a: begin idle timeout ffffffff
[ 316.637785] nouveau 0000:01:00.0: i2c: aux 000a: begin idle timeout ffffffff
So, grab a runtime PM ref here.
Messed up when sending pull request and sent an outdated version of
previous patch, this fixes it up to remove warnings.
panels
Fixes eDP backlight issues on more recent laptops.
If a HPD pulse signalling the need to retrain the link occurs between
the KMS driver releasing the output and the supervisor interrupt that
finishes the teardown, it was possible get a NULL-ptr deref.
Avoid this by marking the link as inactive earlier.
We need to do this earlier to prevent aux channel timeouts in resume
paths on certain systems.
This Falcon application doesn't appear to be present on some newer
systems, so let's not fail init if we can't find it.
TBD: is there a way to determine whether it *should* be there?
Fixes oopses in certain failure paths.
The NV_ERROR macro requires drm->client to be initialised, which it may not
be at this stage of the init process.
It looks like that when we moved over to using
drm_connector_for_each_possible_encoder() in nouveau, that one rather
important part of this function got dropped by accident:
/* Right v here */
for (i = 0; nv_encoder = NULL, i < DRM_CONNECTOR_MAX_ENCODER; i++) {
int id = connector->encoder_ids[i];
if (id == 0)
break;
Since it's rather difficult to notice: the conditional in this loop is
actually:
Meaning that all early breaks result in nv_encoder keeping it's value,
otherwise nv_encoder = NULL. Ugh.
Since this got dropped, nouveau_connector_ddc_detect() now returns an
encoder for every single connector, regardless of whether or not it's
detected:
[ 1780.056185] nouveau 0000:01:00.0: DRM: DDC responded, but no EDID for DP-2
So: fix this to ensure we only return an encoder if we actually found
one, and clean up the rest of the function while we're at it since it's
nearly impossible to read properly.
Changes since v1:
- Don't skip ddc probing for LVDS if we can't switch DDC through
vga-switcheroo, just do the DDC probing without calling
vga_switcheroo_lock_ddc() - skeggsb
Fixes: ddba766dd07e ("drm/nouveau: Use drm_connector_for_each_possible_encoder()")
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Currently, there's nothing in nouveau that actually cancels this work
struct. So, cancel it on suspend/unload. Otherwise, if we're unlucky
enough hpd_work might try to keep running up until the system is
suspended.
On most systems with ACPI hotplugging support, it seems that we always
receive a hotplug event once we re-enable EC interrupts even if the GPU
hasn't even been resumed yet.
This can cause problems since even though we schedule hpd_work to handle
connector reprobing for us, hpd_work synchronizes on
pm_runtime_get_sync() to wait until the device is ready to perform
reprobing. Since runtime suspend/resume callbacks are disabled before
the PM core calls ->suspend(), any calls to pm_runtime_get_sync() during
this period will grab a runtime PM ref and return immediately with
-EACCES. Because we schedule hpd_work from our ACPI HPD handler, and
hpd_work synchronizes on pm_runtime_get_sync(), this causes us to launch
a connector reprobe immediately even if the GPU isn't actually resumed
just yet. This causes various warnings in dmesg and occasionally, also
prevents some displays connected to the dedicated GPU from coming back
up after suspend. Example:
usb 1-4: USB disconnect, device number 14
usb 1-4.1: USB disconnect, device number 15
WARNING: CPU: 0 PID: 838 at drivers/gpu/drm/nouveau/include/nvkm/subdev/i2c.h:170 nouveau_dp_detect+0x17e/0x370 [nouveau]
CPU: 0 PID: 838 Comm: kworker/0:6 Not tainted 4.17.14-201.Lyude.bz1477182.V3.fc28.x86_64 #1
Hardware name: LENOVO 20EQS64N00/20EQS64N00, BIOS N1EET77W (1.50 ) 03/28/2018
Workqueue: events nouveau_display_hpd_work [nouveau]
RIP: 0010:nouveau_dp_detect+0x17e/0x370 [nouveau]
RSP: 0018:ffffa15143933cf0 EFLAGS: 00010293
RAX: 0000000000000000 RBX: ffff8cb4f656c400 RCX: 0000000000000000
RDX: ffffa1514500e4e4 RSI: ffffa1514500e4e4 RDI: 0000000001009002
RBP: ffff8cb4f4a8a800 R08: ffffa15143933cfd R09: ffffa15143933cfc
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8cb4fb57a000
R13: ffff8cb4fb57a000 R14: ffff8cb4f4a8f800 R15: ffff8cb4f656c418
FS: 0000000000000000(0000) GS:ffff8cb51f400000(0000) knlGS:0000000000000000
CR2: 00007f78ec938000 CR3: 000000073720a003 CR4: 00000000003606f0
Call Trace:
? _cond_resched+0x15/0x30
nouveau_connector_detect+0x2ce/0x520 [nouveau]
? ww_mutex_lock+0x12/0x40
drm_helper_probe_detect_ctx+0x8b/0xe0 [drm_kms_helper]
drm_helper_hpd_irq_event+0xa8/0x120 [drm_kms_helper]
nouveau_display_hpd_work+0x2a/0x60 [nouveau]
process_one_work+0x187/0x340
worker_thread+0x2e/0x380
? pwq_unbound_release_workfn+0xd0/0xd0
kthread+0x112/0x130
? kthread_create_worker_on_cpu+0x70/0x70
ret_from_fork+0x35/0x40
Code: 4c 8d 44 24 0d b9 00 05 00 00 48 89 ef ba 09 00 00 00 be 01 00 00 00 e8 e1 09 f8 ff 85 c0 0f 85 b2 01 00 00 80 7c 24 0c 03 74 02 <0f> 0b 48 89 ef e8 b8 07 f8 ff f6 05 51 1b c8 ff 02 0f 84 72 ff
---[ end trace 55d811b38fc8e71a ]---
So, to fix this we attempt to grab a runtime PM reference in the ACPI
handler itself asynchronously. If the GPU is already awake (it will have
normal hotplugging at this point) or runtime PM callbacks are currently
disabled on the device, we drop our reference without updating the
autosuspend delay. We only schedule connector reprobes when we
successfully managed to queue up a resume request with our asynchronous
PM ref.
This also has the added benefit of preventing redundant connector
reprobes from ACPI while the GPU is runtime resumed!
Cc: Karol Herbst <kherbst@redhat.com>
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1477182#c41
When probing a new MST device, it's not safe to make any assumptions
about it's current state. While most well mannered MST hubs will just
disable the branching unit on hotplug disconnects, this isn't enough to
save us from various other scenarios that might have resulted in
something writing to the MST branching unit before we got control of it.
This could happen if a previous probe we tried failed, if we're booting
in kexec context and the hub is still in the state the last kernel put
it in, etc.
Luckily; there is no reason we can't just reset the branching unit
every time we enable a new topology. So, fix this by resetting it on
enabling new topologies to ensure that we always start off with a clean,
unmodified topology state on MST sinks.
This fixes occasional hard-lockups on my P50's laptop dock (e.g. AUX
times out all DPCD trasactions) observed after multiple docks, undocks,
and module reloads.
Cc: Karol Herbst <karolherbst@gmail.com>
Currently, nouveau will re-write the DP_MSTM_CTRL register for an MST
hub every time it receives a long HPD pulse on DP. This isn't actually
necessary and additionally, has some unintended side effects.
With the P50 I've got here, rewriting DP_MSTM_CTRL constantly seems to
make it rather likely (1 out of 5 times usually) that bringing up MST
with it's ThinkPad dock will fail and result in sideband messages timing
out in the middle. Afterwards, successive probes don't manage to get the
dock to communicate properly over MST sideband properly.
Many times sideband message timeouts from MST hubs are indicative of
either the source or the sink dropping an ESI event, which can cause
DRM's perspective of the topology's current state to go out of sync with
reality. While it's tough to really know for sure what's happening to
the dock, using userspace tools to write to DP_MSTM_CTRL in the middle
of the MST link probing process does appear to make things flaky. It's
possible that when we write to DP_MSTM_CTRL, the function that gets
triggered to respond in the dock's firmware temporarily puts it in a
state where it might end up not reporting an ESI to the source, or ends
up dropping a sideband message we sent it.
So, to fix this we make it so that when probing an MST topology, we
respect it's current state. If the dock's already enabled, we simply
read DP_MSTM_CTRL and disable the topology if it's value is not what we
expected. Otherwise, we perform the normal MST probing dance. We avoid
taking any action except if the state of the MST topology actually
changes.
This fixes MST sideband message timeouts and detection failures on my
P50 with its ThinkPad dock.
Again, this doesn't do anything. drm_kms_helper_poll_enable() will have
already been called in nouveau_display_init()
Acked-by: Daniel Vetter <daniel@ffwll.ch>
Cc: Lukas Wunner <lukas@wunner.de>
This won't do anything but potentially make us miss hotplugs. We already
call drm_kms_helper_poll_disable() in
nouveau_pmops_suspend()->nouveau_display_suspend()->nouveau_display_fini()
This doesn't do anything, drm_kms_helper_poll_enable() gets called in
nouveau_pmops_resume()->nouveau_display_resume()->nouveau_display_init()
already.
When we disable hotplugging on the GPU, we need to be able to
synchronize with each connector's hotplug interrupt handler before the
interrupt is finally disabled. This can be a problem however, since
nouveau_connector_detect() currently grabs a runtime power reference
when handling connector probing. This will deadlock the runtime suspend
handler like so:
[ 861.480896] INFO: task kworker/0:2:61 blocked for more than 120 seconds.
[ 861.483290] Tainted: G O 4.18.0-rc6Lyude-Test+ #1
[ 861.485158] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 861.486332] kworker/0:2 D 0 61 2 0x80000000
[ 861.487044] Workqueue: events nouveau_display_hpd_work [nouveau]
[ 861.487737] Call Trace:
[ 861.488394] __schedule+0x322/0xaf0
[ 861.489070] schedule+0x33/0x90
[ 861.489744] rpm_resume+0x19c/0x850
[ 861.490392] ? finish_wait+0x90/0x90
[ 861.491068] __pm_runtime_resume+0x4e/0x90
[ 861.491753] nouveau_display_hpd_work+0x22/0x60 [nouveau]
[ 861.492416] process_one_work+0x231/0x620
[ 861.493068] worker_thread+0x44/0x3a0
[ 861.493722] kthread+0x12b/0x150
[ 861.494342] ? wq_pool_ids_show+0x140/0x140
[ 861.494991] ? kthread_create_worker_on_cpu+0x70/0x70
[ 861.495648] ret_from_fork+0x3a/0x50
[ 861.496304] INFO: task kworker/6:2:320 blocked for more than 120 seconds.
[ 861.496968] Tainted: G O 4.18.0-rc6Lyude-Test+ #1
[ 861.497654] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 861.498341] kworker/6:2 D 0 320 2 0x80000080
[ 861.499045] Workqueue: pm pm_runtime_work
[ 861.499739] Call Trace:
[ 861.500428] __schedule+0x322/0xaf0
[ 861.501134] ? wait_for_completion+0x104/0x190
[ 861.501851] schedule+0x33/0x90
[ 861.502564] schedule_timeout+0x3a5/0x590
[ 861.503284] ? mark_held_locks+0x58/0x80
[ 861.503988] ? _raw_spin_unlock_irq+0x2c/0x40
[ 861.504710] ? wait_for_completion+0x104/0x190
[ 861.505417] ? trace_hardirqs_on_caller+0xf4/0x190
[ 861.506136] ? wait_for_completion+0x104/0x190
[ 861.506845] wait_for_completion+0x12c/0x190
[ 861.507555] ? wake_up_q+0x80/0x80
[ 861.508268] flush_work+0x1c9/0x280
[ 861.508990] ? flush_workqueue_prep_pwqs+0x1b0/0x1b0
[ 861.509735] nvif_notify_put+0xb1/0xc0 [nouveau]
[ 861.510482] nouveau_display_fini+0xbd/0x170 [nouveau]
[ 861.511241] nouveau_display_suspend+0x67/0x120 [nouveau]
[ 861.511969] nouveau_do_suspend+0x5e/0x2d0 [nouveau]
[ 861.512715] nouveau_pmops_runtime_suspend+0x47/0xb0 [nouveau]
[ 861.513435] pci_pm_runtime_suspend+0x6b/0x180
[ 861.514165] ? pci_has_legacy_pm_support+0x70/0x70
[ 861.514897] __rpm_callback+0x7a/0x1d0
[ 861.515618] ? pci_has_legacy_pm_support+0x70/0x70
[ 861.516313] rpm_callback+0x24/0x80
[ 861.517027] ? pci_has_legacy_pm_support+0x70/0x70
[ 861.517741] rpm_suspend+0x142/0x6b0
[ 861.518449] pm_runtime_work+0x97/0xc0
[ 861.519144] process_one_work+0x231/0x620
[ 861.519831] worker_thread+0x44/0x3a0
[ 861.520522] kthread+0x12b/0x150
[ 861.521220] ? wq_pool_ids_show+0x140/0x140
[ 861.521925] ? kthread_create_worker_on_cpu+0x70/0x70
[ 861.522622] ret_from_fork+0x3a/0x50
[ 861.523299] INFO: task kworker/6:0:1329 blocked for more than 120 seconds.
[ 861.523977] Tainted: G O 4.18.0-rc6Lyude-Test+ #1
[ 861.524644] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 861.525349] kworker/6:0 D 0 1329 2 0x80000000
[ 861.526073] Workqueue: events nvif_notify_work [nouveau]
[ 861.526751] Call Trace:
[ 861.527411] __schedule+0x322/0xaf0
[ 861.528089] schedule+0x33/0x90
[ 861.528758] rpm_resume+0x19c/0x850
[ 861.529399] ? finish_wait+0x90/0x90
[ 861.530073] __pm_runtime_resume+0x4e/0x90
[ 861.530798] nouveau_connector_detect+0x7e/0x510 [nouveau]
[ 861.531459] ? ww_mutex_lock+0x47/0x80
[ 861.532097] ? ww_mutex_lock+0x47/0x80
[ 861.532819] ? drm_modeset_lock+0x88/0x130 [drm]
[ 861.533481] drm_helper_probe_detect_ctx+0xa0/0x100 [drm_kms_helper]
[ 861.534127] drm_helper_hpd_irq_event+0xa4/0x120 [drm_kms_helper]
[ 861.534940] nouveau_connector_hotplug+0x98/0x120 [nouveau]
[ 861.535556] nvif_notify_work+0x2d/0xb0 [nouveau]
[ 861.536221] process_one_work+0x231/0x620
[ 861.536994] worker_thread+0x44/0x3a0
[ 861.537757] kthread+0x12b/0x150
[ 861.538463] ? wq_pool_ids_show+0x140/0x140
[ 861.539102] ? kthread_create_worker_on_cpu+0x70/0x70
[ 861.539815] ret_from_fork+0x3a/0x50
[ 861.540521]
Showing all locks held in the system:
[ 861.541696] 2 locks held by kworker/0:2/61:
[ 861.542406] #0: 000000002dbf8af5 ((wq_completion)"events"){+.+.}, at: process_one_work+0x1b3/0x620
[ 861.543071] #1: 0000000076868126 ((work_completion)(&drm->hpd_work)){+.+.}, at: process_one_work+0x1b3/0x620
[ 861.543814] 1 lock held by khungtaskd/64:
[ 861.544535] #0: 0000000059db4b53 (rcu_read_lock){....}, at: debug_show_all_locks+0x23/0x185
[ 861.545160] 3 locks held by kworker/6:2/320:
[ 861.545896] #0: 00000000d9e1bc59 ((wq_completion)"pm"){+.+.}, at: process_one_work+0x1b3/0x620
[ 861.546702] #1: 00000000c9f92d84 ((work_completion)(&dev->power.work)){+.+.}, at: process_one_work+0x1b3/0x620
[ 861.547443] #2: 000000004afc5de1 (drm_connector_list_iter){.+.+}, at: nouveau_display_fini+0x96/0x170 [nouveau]
[ 861.548146] 1 lock held by dmesg/983:
[ 861.548889] 2 locks held by zsh/1250:
[ 861.549605] #0: 00000000348e3cf6 (&tty->ldisc_sem){++++}, at: ldsem_down_read+0x37/0x40
[ 861.550393] #1: 000000007009a7a8 (&ldata->atomic_read_lock){+.+.}, at: n_tty_read+0xc1/0x870
[ 861.551122] 6 locks held by kworker/6:0/1329:
[ 861.551957] #0: 000000002dbf8af5 ((wq_completion)"events"){+.+.}, at: process_one_work+0x1b3/0x620
[ 861.552765] #1: 00000000ddb499ad ((work_completion)(¬ify->work)#2){+.+.}, at: process_one_work+0x1b3/0x620
[ 861.553582] #2: 000000006e013cbe (&dev->mode_config.mutex){+.+.}, at: drm_helper_hpd_irq_event+0x6c/0x120 [drm_kms_helper]
[ 861.554357] #3: 000000004afc5de1 (drm_connector_list_iter){.+.+}, at: drm_helper_hpd_irq_event+0x78/0x120 [drm_kms_helper]
[ 861.555227] #4: 0000000044f294d9 (crtc_ww_class_acquire){+.+.}, at: drm_helper_probe_detect_ctx+0x3d/0x100 [drm_kms_helper]
[ 861.556133] #5: 00000000db193642 (crtc_ww_class_mutex){+.+.}, at: drm_modeset_lock+0x4b/0x130 [drm]
[ 861.557864] =============================================
[ 861.559507] NMI backtrace for cpu 2
[ 861.560363] CPU: 2 PID: 64 Comm: khungtaskd Tainted: G O 4.18.0-rc6Lyude-Test+ #1
[ 861.561197] Hardware name: LENOVO 20EQS64N0B/20EQS64N0B, BIOS N1EET78W (1.51 ) 05/18/2018
[ 861.561948] Call Trace:
[ 861.562757] dump_stack+0x8e/0xd3
[ 861.563516] nmi_cpu_backtrace.cold.3+0x14/0x5a
[ 861.564269] ? lapic_can_unplug_cpu.cold.27+0x42/0x42
[ 861.565029] nmi_trigger_cpumask_backtrace+0xa1/0xae
[ 861.565789] arch_trigger_cpumask_backtrace+0x19/0x20
[ 861.566558] watchdog+0x316/0x580
[ 861.567355] kthread+0x12b/0x150
[ 861.568114] ? reset_hung_task_detector+0x20/0x20
[ 861.568863] ? kthread_create_worker_on_cpu+0x70/0x70
[ 861.569598] ret_from_fork+0x3a/0x50
[ 861.570370] Sending NMI from CPU 2 to CPUs 0-1,3-7:
[ 861.571426] NMI backtrace for cpu 6 skipped: idling at intel_idle+0x7f/0x120
[ 861.571429] NMI backtrace for cpu 7 skipped: idling at intel_idle+0x7f/0x120
[ 861.571432] NMI backtrace for cpu 3 skipped: idling at intel_idle+0x7f/0x120
[ 861.571464] NMI backtrace for cpu 5 skipped: idling at intel_idle+0x7f/0x120
[ 861.571467] NMI backtrace for cpu 0 skipped: idling at intel_idle+0x7f/0x120
[ 861.571469] NMI backtrace for cpu 4 skipped: idling at intel_idle+0x7f/0x120
[ 861.571472] NMI backtrace for cpu 1 skipped: idling at intel_idle+0x7f/0x120
[ 861.572428] Kernel panic - not syncing: hung_task: blocked tasks
So: fix this by making it so that normal hotplug handling /only/ happens
so long as the GPU is currently awake without any pending runtime PM
requests. In the event that a hotplug occurs while the device is
suspending or resuming, we can simply defer our response until the GPU
is fully runtime resumed again.
Changes since v4:
- Use a new trick I came up with using pm_runtime_get() instead of the
hackish junk we had before
It's true we can't resume the device from poll workers in
nouveau_connector_detect(). We can however, prevent the autosuspend
timer from elapsing immediately if it hasn't already without risking any
sort of deadlock with the runtime suspend/resume operations. So do that
instead of entirely avoiding grabbing a power reference.
Currently, nouveau uses the generic drm_fb_helper_output_poll_changed()
function provided by DRM as it's output_poll_changed callback.
Unfortunately however, this function doesn't grab runtime PM references
early enough and even if it did-we can't block waiting for the device to
resume in output_poll_changed() since it's very likely that we'll need
to grab the fb_helper lock at some point during the runtime resume
process. This currently results in deadlocking like so:
[ 246.669625] INFO: task kworker/4:0:37 blocked for more than 120 seconds.
[ 246.673398] Not tainted 4.18.0-rc5Lyude-Test+ #2
[ 246.675271] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 246.676527] kworker/4:0 D 0 37 2 0x80000000
[ 246.677580] Workqueue: events output_poll_execute [drm_kms_helper]
[ 246.678704] Call Trace:
[ 246.679753] __schedule+0x322/0xaf0
[ 246.680916] schedule+0x33/0x90
[ 246.681924] schedule_preempt_disabled+0x15/0x20
[ 246.683023] __mutex_lock+0x569/0x9a0
[ 246.684035] ? kobject_uevent_env+0x117/0x7b0
[ 246.685132] ? drm_fb_helper_hotplug_event.part.28+0x20/0xb0 [drm_kms_helper]
[ 246.686179] mutex_lock_nested+0x1b/0x20
[ 246.687278] ? mutex_lock_nested+0x1b/0x20
[ 246.688307] drm_fb_helper_hotplug_event.part.28+0x20/0xb0 [drm_kms_helper]
[ 246.689420] drm_fb_helper_output_poll_changed+0x23/0x30 [drm_kms_helper]
[ 246.690462] drm_kms_helper_hotplug_event+0x2a/0x30 [drm_kms_helper]
[ 246.691570] output_poll_execute+0x198/0x1c0 [drm_kms_helper]
[ 246.692611] process_one_work+0x231/0x620
[ 246.693725] worker_thread+0x214/0x3a0
[ 246.694756] kthread+0x12b/0x150
[ 246.695856] ? wq_pool_ids_show+0x140/0x140
[ 246.696888] ? kthread_create_worker_on_cpu+0x70/0x70
[ 246.697998] ret_from_fork+0x3a/0x50
[ 246.699034] INFO: task kworker/0:1:60 blocked for more than 120 seconds.
[ 246.700153] Not tainted 4.18.0-rc5Lyude-Test+ #2
[ 246.701182] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 246.702278] kworker/0:1 D 0 60 2 0x80000000
[ 246.703293] Workqueue: pm pm_runtime_work
[ 246.704393] Call Trace:
[ 246.705403] __schedule+0x322/0xaf0
[ 246.706439] ? wait_for_completion+0x104/0x190
[ 246.707393] schedule+0x33/0x90
[ 246.708375] schedule_timeout+0x3a5/0x590
[ 246.709289] ? mark_held_locks+0x58/0x80
[ 246.710208] ? _raw_spin_unlock_irq+0x2c/0x40
[ 246.711222] ? wait_for_completion+0x104/0x190
[ 246.712134] ? trace_hardirqs_on_caller+0xf4/0x190
[ 246.713094] ? wait_for_completion+0x104/0x190
[ 246.713964] wait_for_completion+0x12c/0x190
[ 246.714895] ? wake_up_q+0x80/0x80
[ 246.715727] ? get_work_pool+0x90/0x90
[ 246.716649] flush_work+0x1c9/0x280
[ 246.717483] ? flush_workqueue_prep_pwqs+0x1b0/0x1b0
[ 246.718442] __cancel_work_timer+0x146/0x1d0
[ 246.719247] cancel_delayed_work_sync+0x13/0x20
[ 246.720043] drm_kms_helper_poll_disable+0x1f/0x30 [drm_kms_helper]
[ 246.721123] nouveau_pmops_runtime_suspend+0x3d/0xb0 [nouveau]
[ 246.721897] pci_pm_runtime_suspend+0x6b/0x190
[ 246.722825] ? pci_has_legacy_pm_support+0x70/0x70
[ 246.723737] __rpm_callback+0x7a/0x1d0
[ 246.724721] ? pci_has_legacy_pm_support+0x70/0x70
[ 246.725607] rpm_callback+0x24/0x80
[ 246.726553] ? pci_has_legacy_pm_support+0x70/0x70
[ 246.727376] rpm_suspend+0x142/0x6b0
[ 246.728185] pm_runtime_work+0x97/0xc0
[ 246.728938] process_one_work+0x231/0x620
[ 246.729796] worker_thread+0x44/0x3a0
[ 246.730614] kthread+0x12b/0x150
[ 246.731395] ? wq_pool_ids_show+0x140/0x140
[ 246.732202] ? kthread_create_worker_on_cpu+0x70/0x70
[ 246.732878] ret_from_fork+0x3a/0x50
[ 246.733768] INFO: task kworker/4:2:422 blocked for more than 120 seconds.
[ 246.734587] Not tainted 4.18.0-rc5Lyude-Test+ #2
[ 246.735393] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 246.736113] kworker/4:2 D 0 422 2 0x80000080
[ 246.736789] Workqueue: events_long drm_dp_mst_link_probe_work [drm_kms_helper]
[ 246.737665] Call Trace:
[ 246.738490] __schedule+0x322/0xaf0
[ 246.739250] schedule+0x33/0x90
[ 246.739908] rpm_resume+0x19c/0x850
[ 246.740750] ? finish_wait+0x90/0x90
[ 246.741541] __pm_runtime_resume+0x4e/0x90
[ 246.742370] nv50_disp_atomic_commit+0x31/0x210 [nouveau]
[ 246.743124] drm_atomic_commit+0x4a/0x50 [drm]
[ 246.743775] restore_fbdev_mode_atomic+0x1c8/0x240 [drm_kms_helper]
[ 246.744603] restore_fbdev_mode+0x31/0x140 [drm_kms_helper]
[ 246.745373] drm_fb_helper_restore_fbdev_mode_unlocked+0x54/0xb0 [drm_kms_helper]
[ 246.746220] drm_fb_helper_set_par+0x2d/0x50 [drm_kms_helper]
[ 246.746884] drm_fb_helper_hotplug_event.part.28+0x96/0xb0 [drm_kms_helper]
[ 246.747675] drm_fb_helper_output_poll_changed+0x23/0x30 [drm_kms_helper]
[ 246.748544] drm_kms_helper_hotplug_event+0x2a/0x30 [drm_kms_helper]
[ 246.749439] nv50_mstm_hotplug+0x15/0x20 [nouveau]
[ 246.750111] drm_dp_send_link_address+0x177/0x1c0 [drm_kms_helper]
[ 246.750764] drm_dp_check_and_send_link_address+0xa8/0xd0 [drm_kms_helper]
[ 246.751602] drm_dp_mst_link_probe_work+0x51/0x90 [drm_kms_helper]
[ 246.752314] process_one_work+0x231/0x620
[ 246.752979] worker_thread+0x44/0x3a0
[ 246.753838] kthread+0x12b/0x150
[ 246.754619] ? wq_pool_ids_show+0x140/0x140
[ 246.755386] ? kthread_create_worker_on_cpu+0x70/0x70
[ 246.756162] ret_from_fork+0x3a/0x50
[ 246.756847]
[ 246.758261] 3 locks held by kworker/4:0/37:
[ 246.759016] #0: 00000000f8df4d2d ((wq_completion)"events"){+.+.}, at: process_one_work+0x1b3/0x620
[ 246.759856] #1: 00000000e6065461 ((work_completion)(&(&dev->mode_config.output_poll_work)->work)){+.+.}, at: process_one_work+0x1b3/0x620
[ 246.760670] #2: 00000000cb66735f (&helper->lock){+.+.}, at: drm_fb_helper_hotplug_event.part.28+0x20/0xb0 [drm_kms_helper]
[ 246.761516] 2 locks held by kworker/0:1/60:
[ 246.762274] #0: 00000000fff6be0f ((wq_completion)"pm"){+.+.}, at: process_one_work+0x1b3/0x620
[ 246.762982] #1: 000000005ab44fb4 ((work_completion)(&dev->power.work)){+.+.}, at: process_one_work+0x1b3/0x620
[ 246.763890] 1 lock held by khungtaskd/64:
[ 246.764664] #0: 000000008cb8b5c3 (rcu_read_lock){....}, at: debug_show_all_locks+0x23/0x185
[ 246.765588] 5 locks held by kworker/4:2/422:
[ 246.766440] #0: 00000000232f0959 ((wq_completion)"events_long"){+.+.}, at: process_one_work+0x1b3/0x620
[ 246.767390] #1: 00000000bb59b134 ((work_completion)(&mgr->work)){+.+.}, at: process_one_work+0x1b3/0x620
[ 246.768154] #2: 00000000cb66735f (&helper->lock){+.+.}, at: drm_fb_helper_restore_fbdev_mode_unlocked+0x4c/0xb0 [drm_kms_helper]
[ 246.768966] #3: 000000004c8f0b6b (crtc_ww_class_acquire){+.+.}, at: restore_fbdev_mode_atomic+0x4b/0x240 [drm_kms_helper]
[ 246.769921] #4: 000000004c34a296 (crtc_ww_class_mutex){+.+.}, at: drm_modeset_backoff+0x8a/0x1b0 [drm]
[ 246.770839] 1 lock held by dmesg/1038:
[ 246.771739] 2 locks held by zsh/1172:
[ 246.772650] #0: 00000000836d0438 (&tty->ldisc_sem){++++}, at: ldsem_down_read+0x37/0x40
[ 246.773680] #1: 000000001f4f4d48 (&ldata->atomic_read_lock){+.+.}, at: n_tty_read+0xc1/0x870
[ 246.775522] =============================================
After trying dozens of different solutions, I found one very simple one
that should also have the benefit of preventing us from having to fight
locking for the rest of our lives. So, we work around these deadlocks by
deferring all fbcon hotplug events that happen after the runtime suspend
process starts until after the device is resumed again.
Changes since v7:
- Fixup commit message - Daniel Vetter
Changes since v6:
- Remove unused nouveau_fbcon_hotplugged_in_suspend() - Ilia
Changes since v5:
- Come up with the (hopefully final) solution for solving this dumb
problem, one that is a lot less likely to cause issues with locking in
the future. This should work around all deadlock conditions with fbcon
brought up thus far.
Changes since v4:
- Add nouveau_fbcon_hotplugged_in_suspend() to workaround deadlock
condition that Lukas described
- Just move all of this out of drm_fb_helper. It seems that other DRM
drivers have already figured out other workarounds for this. If other
drivers do end up needing this in the future, we can just move this
back into drm_fb_helper again.
Changes since v3:
- Actually check if fb_helper is NULL in both new helpers
- Actually check drm_fbdev_emulation in both new helpers
- Don't fire off a fb_helper hotplug unconditionally; only do it if
the following conditions are true (as otherwise, calling this in the
wrong spot will cause Bad Things to happen):
- fb_helper hotplug handling was actually inhibited previously
- fb_helper actually has a delayed hotplug pending
- fb_helper is actually bound
- fb_helper is actually initialized
- Add __must_check to drm_fb_helper_suspend_hotplug(). There's no
situation where a driver would actually want to use this without
checking the return value, so enforce that
- Rewrite and clarify the documentation for both helpers.
- Make sure to return true in the drm_fb_helper_suspend_hotplug() stub
that's provided in drm_fb_helper.h when CONFIG_DRM_FBDEV_EMULATION
isn't enabled
- Actually grab the toplevel fb_helper lock in
drm_fb_helper_resume_hotplug(), since it's possible other activity
(such as a hotplug) could be going on at the same time the driver
calls drm_fb_helper_resume_hotplug(). We need this to check whether or
not drm_fb_helper_hotplug_event() needs to be called anyway
Since actual hotplug notifications don't get disabled until
nouveau_display_fini() is called, all this will do is cause any hotplugs
that happen between this drm_kms_helper_poll_disable() call and the
actual hotplug disablement to potentially be dropped if ACPI isn't
around to help us.
Acked-by: Karol Herbst <kherbst@redhat.com>
Turns out this part is my fault for not noticing when reviewing
9a2eba337cace ("drm/nouveau: Fix drm poll_helper handling"). Currently
we call drm_kms_helper_poll_enable() from nouveau_display_hpd_work().
This makes basically no sense however, because that means we're calling
drm_kms_helper_poll_enable() every time we schedule the hotplug
detection work. This is also against the advice mentioned in
drm_kms_helper_poll_enable()'s documentation:
Note that calls to enable and disable polling must be strictly ordered,
which is automatically the case when they're only call from
suspend/resume callbacks.
Of course, hotplugs can't really be ordered. They could even happen
immediately after we called drm_kms_helper_poll_disable() in
nouveau_display_fini(), which can lead to all sorts of issues.
Additionally; enabling polling /after/ we call
drm_helper_hpd_irq_event() could also mean that we'd miss a hotplug
event anyway, since drm_helper_hpd_irq_event() wouldn't bother trying to
probe connectors so long as polling is disabled.
So; simply move this back into nouveau_display_init() again. The race
condition that both of these patches attempted to work around has
already been fixed properly in
d61a5c106351 ("drm/nouveau: Fix deadlock on runtime suspend")
Fixes: 9a2eba337cace ("drm/nouveau: Fix drm poll_helper handling")
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
rmk requested this for armada and I think we've had a few
conflicts build up.
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for 4.19:
Core Changes:
- add support for DisplayPort CEC-Tunneling-over-AUX (Hans Verkuil)
- more doc updates (Daniel Vetter)
- fourcc: Add is_yuv field to drm_format_info (Ayan Kumar Halder)
- dma-buf: correctly place BUG_ON (Michel Dänzer)
Driver Changes:
- more vkms support(Rodrigo Siqueira)
- many fixes and small improments to all drivers
Link: https://patchwork.freedesktop.org/patch/msgid/20180718200826.GA20165@juma
misc fixes and cleanups for next.
Link: https://patchwork.freedesktop.org/patch/msgid/CACAvsv55CfRonQ0bo2XiitkCiWTjKwhsP=+ZFhoa-BaJ72Ryew@mail.gmail.com
- fix problem with pascal and large memory systems
- fix a bunch of MST problems
- fix a runtime PM interaction with MST
Link: https://patchwork.freedesktop.org/patch/msgid/CACAvsv79O8deSts2fxJ_oS6=q8yA+OgwBSEpp5R=BQBmWa+oyg@mail.gmail.com
Workaround for issues seen on systems with large amounts of RAM, caused
by display not supporting the same physical address limits as the other
parts of the GPU.
This was causing problems on a system with a large amount of RAM, where
display push buffers were being fetched incorrectly when placed in high
system memory addresses.
While this commit will resolve the issue on that particular system, the
issue will be avoided completely with another patch to more fully solve
problems with display and large amounts of system memory on Pascal.
It's still probably a good idea to disable this to prevent weird issues
in the future.
Depending on the kernel configuration, early ARM architecture setup code
may have attached the GPU to a DMA/IOMMU mapping that transparently uses
the IOMMU to back the DMA API. Tegra requires special handling for IOMMU
backed buffers (a special bit in the GPU's MMU page tables indicates the
memory path to take: via the SMMU or directly to the memory controller).
Transparently backing DMA memory with an IOMMU prevents Nouveau from
properly handling such memory accesses and causes memory access faults.
As a side-note: buffers other than those allocated in instance memory
don't need to be physically contiguous from the GPU's perspective since
the GPU can map them into contiguous buffers using its own MMU. Mapping
these buffers through the IOMMU is unnecessary and will even lead to
performance degradation because of the additional translation. One
exception to this are compressible buffers which need large pages. In
order to enable these large pages, multiple small pages will have to be
combined into one large (I/O virtually contiguous) mapping via the
IOMMU. However, that is a topic outside the scope of this fix and isn't
currently supported. An implementation will want to explicitly create
these large pages in the Nouveau driver, so detaching from a DMA/IOMMU
mapping would still be required.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Acked-by: Christoph Hellwig <hch@lst.de>
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Tested-by: Nicolas Chauvet <kwizart@gmail.com>
In the quest to remove all stack VLA usage from the kernel[1], this
allocates the working buffers before starting the writing so it won't
abort in the middle. This needs an initial walk of the lists to figure
out how large the buffer should be.
[1] https://lkml.kernel.org/r/CA+55aFzCG-zNmZwX4A2FQpadafLfEzK6CC=qPXydAacU1RqZWA@mail.gmail.com
