path: root/drivers/gpu/drm/r128
2015-10-06drm/irq: Use unsigned int pipe in public APIThierry Reding
This continues the pattern started in commit cc1ef118fc09 ("drm/irq: Make pipe unsigned and name consistent"). This is applied to the public APIs and driver callbacks, so pretty much all drivers need to be updated to match the new prototypes. Cc: Christian König <christian.koenig@amd.com> Cc: Alex Deucher <alexander.deucher@amd.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Inki Dae <inki.dae@samsung.com> Cc: Jianwei Wang <jianwei.wang.chn@gmail.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Cc: Daniel Vetter <daniel.vetter@intel.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: David Airlie <airlied@linux.ie> Cc: Rob Clark <robdclark@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Mark Yao <mark.yao@rock-chips.com> Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org> Cc: Vincent Abriou <vincent.abriou@st.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2015-09-30drm: Remove __OS_HAS_AGPDaniel Vetter
We already express the drm/agp depencies correctly in Kconfig, so we can rip this remnant from the shared drm core days. Aside: Pretty much all the #ifdefs in radeon/nouveau could be killed if ttm would provide dummy functions. I'm not going to volunteer for that though. v2: Use IS_ENABLED(CONFIG_AGP) as suggested by Ville v3: Polish from Ville's review. Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Christian König <christian.koenig@amd.com> (v2) Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-11-20drm: remove unnecessary sizeof(u8)Fabian Frederick
sizeof(u8) is always 1. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-24drm: move drm_mmap to <drm/drm_legacy.h>Daniel Vetter
Now that we've removed the copypasted users in gem/ttm we can relegate the legacy buffer mapping support to where it belongs. Also give it the proper drm_legacy_ prefix. While at it statify drm_mmap_locked, somehow I've missed that in my previous header rework. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-12drm: Move drm_memory.c map support declarations to <drm/drm_legacy.h>Daniel Vetter
And replace the drm_core_ prefix with drm_legacy_ since really, this isn't core stuff. Also drop drm_core_dropmap since it's unused. v2: Fix up i810.ko fully which somehow slipped through. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-09-12drm: Create drm legacy driver headerDaniel Vetter
And move a few legayc functions to start things over there. It compiles ... Inspired by a patch from Dave Airlie, but with a split between drm.ko private legacy functions and stuff used by drivers. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-09-12drm: split ati_pcigart.h out of drmP.hDave Airlie
Just move this into a separate header file, and make the two users use it. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-10drm: add driver->set_busid() callbackDavid Herrmann
One step closer to dropping all the drm_bus_* code: Add a driver->set_busid() callback and make all drivers use the generic helpers. Nouveau is the only driver that uses two different bus-types with the same drm_driver. This is totally broken if both buses are available on the same machine (unlikely, but lets be safe). Therefore, we create two different drivers for each platform during module_init() and set the set_busid() callback respectively. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-10drm: mark drm_buf and drm_map as legacyDavid Herrmann
Move internal declarations to drm_legacy.h and add drm_legacy_*() prefix to all legacy functions. [airlied: add a bit of an explaination to drm_legacy.h] Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-10drm: Remove DRM_ARRAY_SIZE() for ARRAY_SIZE()Damien Lespiau
I cannot see a need to provide a DRM_ version of ARRAY_SIZE(), only used in a few places. I suspect its usage has been spread by copy & paste rather than anything else. Let's just remove it for plain ARRAY_SIZE(). Signed-off-by: Damien Lespiau <damien.lespiau@intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-04-22drm: remove drm_dev_to_irq from driversDaniel Vetter
Only used in some legacy pci drivers, and dereferencing the PCI irq is actually shorter ... Since this removes all users for drm_dev_to_irq from the tree except in drm_irq.c, move the inline helper in there. It'll disappear soon, too. v2: Polish commit message (Thierry) Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-14drivers: gpu: Include appropriate header file in r128_ioc32.cRashika
Include appropriate header file drm/r128/r128_drv.h in drm/r128/r128_ioc32.c because function r128_compat_ioctl() has its prototype declaration in the header file. This eliminates the following warning in drm/r128/r128_ioc32.c: drivers/gpu/drm/r128/r128_ioc32.c:196:6: warning: no previous prototype for ‘r128_compat_ioctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-12-18drm: use memdup_user() as a cleanupDan Carpenter
drivers/gpu/drm/r128/r128_state.c:1014:10-17: WARNING opportunity for memdup_user /c/kernel-tests/src/cocci/drivers/gpu/drm/r128/r128_state.c:1029:9-16: WARNING opportunity for memdup_user /c/kernel-tests/src/cocci/drivers/gpu/drm/r128/r128_state.c:904:10-17: WARNING opportunity for memdup_user /c/kernel-tests/src/cocci/drivers/gpu/drm/r128/r128_state.c:914:9-16: WARNING opportunity for memdup_user Use memdup_user rather than duplicating its implementation This is a little bit restricted to reduce false positives Generated by: coccinelle/api/memdup_user.cocci CC: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-12-18drm: Kill DRM_*MEMORYBARRIERDaniel Vetter
The real linux interfaces are soooo much easier on the eyes ... Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-12-18drm: Kill DRM_COPY_(TO|FROM)_USERDaniel Vetter
Less yelling ftw! Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-12-18drm: Kill DRM_IRQ_ARGSDaniel Vetter
I've killed them a long time ago in drm/i915, let's get rid of this remnant of shared drm core days for good. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-19drm: rip out drm_core_has_MTRR checksDaniel Vetter
The new arch_phys_wc_add/del functions do the right thing both with and without MTRR support in the kernel. So we can drop these additional checks. David Herrmann suggest to also kill the DRIVER_USE_MTRR flag since it's now unused, which spurred me to do a bit a better audit of the affected drivers. David helped a lot in that. Quoting our mail discussion: On Wed, Jul 10, 2013 at 5:41 PM, David Herrmann <dh.herrmann@gmail.com> wrote: > On Wed, Jul 10, 2013 at 5:22 PM, Daniel Vetter <daniel.vetter@ffwll.ch> wrote: >> On Wed, Jul 10, 2013 at 3:51 PM, David Herrmann <dh.herrmann@gmail.com> wrote: >>>> -#if __OS_HAS_MTRR >>>> -static inline int drm_core_has_MTRR(struct drm_device *dev) >>>> -{ >>>> - return drm_core_check_feature(dev, DRIVER_USE_MTRR); >>>> -} >>>> -#else >>>> -#define drm_core_has_MTRR(dev) (0) >>>> -#endif >>>> - >>> >>> That was the last user of DRIVER_USE_MTRR (apart from drivers setting >>> it in .driver_features). Any reason to keep it around? >> >> Yeah, I guess we could rip things out. Which will also force me to >> properly audit drivers for the eventual behaviour change this could >> entail (in case there's an x86 driver which did not ask for an mtrr, >> but iirc there isn't). > > david@david-mb ~/dev/kernel/linux $ for i in drivers/gpu/drm/* ; do if > test -d "$i" ; then if ! grep -q USE_MTRR -r $i ; then echo $i ; fi ; > fi ; done > drivers/gpu/drm/exynos > drivers/gpu/drm/gma500 > drivers/gpu/drm/i2c > drivers/gpu/drm/nouveau > drivers/gpu/drm/omapdrm > drivers/gpu/drm/qxl > drivers/gpu/drm/rcar-du > drivers/gpu/drm/shmobile > drivers/gpu/drm/tilcdc > drivers/gpu/drm/ttm > drivers/gpu/drm/udl > drivers/gpu/drm/vmwgfx > david@david-mb ~/dev/kernel/linux $ > > So for x86 gma500,nouveau,qxl,udl,vmwgfx don't set DRIVER_USE_MTRR. > But I cannot tell whether they break if we call arch_phys_wc_add/del, > anyway. At least nouveau seemed to work here, but it doesn't use AGP > or drm_bufs, I guess. Cool, thanks a lot for stitching together the list of drivers to look at. So for real KMS drivers it's the drives responsibility to add an mtrr if it needs one. nouvea, radeon, mgag200, i915 and vmwgfx do that already. Somehow the savage driver also ends up doing that, I have no idea why. Note that gma500 as a pure KMS driver doesn't need MTRR setup since the platforms that it supports all support PAT. So no MTRRs needed to get wc iomappings. The mtrr support in the drm core is all for legacy mappings of garts, framebuffers and registers. All legacy drivers set the USE_MTRR flag, so we're good there. All in all I think we can really just ditch this /endquote v2: Also kill DRIVER_USE_MTRR as suggested by David Herrmann v3: Rebase on top of David Herrmann's agp setup/cleanup changes. Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-19drm: remove FASYNC supportDaniel Vetter
So I've stumbled over drm_fasync and wondered what it does. Digging that up is quite a story. First I've had to read up on what this does and ended up being rather bewildered why peopled loved signals so much back in the days that they've created SIGIO just for that ... Then I wondered how this ever works, and what that strange "No-op." comment right above it should mean. After all calling the core fasync helper is pretty obviously not a noop. After reading through the kernels FASYNC implementation I've noticed that signals are only sent out to the processes attached with FASYNC by calling kill_fasync. No merged drm driver has ever done that. After more digging I've found out that the only driver that ever used this is the so called GAMMA driver. I've frankly never heard of such a gpu brand ever before. Now FASYNC seems to not have been the only bad thing with that driver, since Dave Airlie removed it from the drm driver with prejudice: commit 1430163b4bbf7b00367ea1066c1c5fe85dbeefed Author: Dave Airlie <airlied@linux.ie> Date: Sun Aug 29 12:04:35 2004 +0000 Drop GAMMA DRM from a great height ... Long story short, the drm fasync support seems to be doing absolutely nothing. And the only user of it was never merged into the upstream kernel. And we don't need any fops->fasync callback since the fcntl implementation in the kernel already implements the noop case correctly. So stop this particular cargo-cult and rip it all out. v2: Kill drm_fasync assignments in rcar (newly added) and imx drivers (somehow I've missed that one in staging). Also drop the reference in the drm DocBook. ARM compile-fail reported by Rob Clark. v3: Move the removal of dev->buf_asnyc assignment in drm_setup to this patch here. v4: Actually git add ... tsk. Cc: Dave Airlie <airlied@linux.ie> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Rob Clark <robdclark@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-07drm: const'ify ioctls table (v2)Rob Clark
Because, there is no reason for it not to be const. v1: original v2: fix compile break in vmwgfx, and couple related cleanups suggested by Ville Syrjälä Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-07-23drm/r128: s/drm_order/order_base_2/Daniel Vetter
Again just use the version provided by the linux core. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@gmail.com>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/David Howells
Convert #include "..." to #include <path/...> in drivers/gpu/. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/.David Howells
Remove redundant DRM UAPI header #inclusions from drivers/gpu/. Remove redundant #inclusions of core DRM UAPI headers (drm.h, drm_mode.h and drm_sarea.h). They are now #included via drmP.h and drm_crtc.h via a preceding patch. Without this patch and the patch to make include the UAPI headers from the core headers, after the UAPI split, the DRM C sources cannot find these UAPI headers because the DRM code relies on specific -I flags to make #include "..." work on headers in include/drm/ - but that does not work after the UAPI split without adding more -I flags. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-07-19drm: kill reclaim_buffers callbackDaniel Vetter
All leftover users either haven't set DRIVER_HAVE_DMA, in which case this will never be called, or use the drm_core implementation. Call that directly in the only callsite. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-16drm: move pci bus master enable into driver.Dave Airlie
The current enabling of bus mastering in the drm midlayer allows a large race condition under kexec. When a kexec'ed kernel re-enables bus mastering for the GPU, previously setup dma blocks may cause writes to random pieces of memory. On radeon the writeback mechanism can cause these sorts of issues. This patch doesn't fix the problem, but it moves the bus master enable under the individual drivers control so they can move enabling it until later in their load cycle and close the race. Fix for radeon kms driver will be in a follow-up patch. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-11-11drm: Make the per-driver file_operations struct constArjan van de Ven
From fdf1fdebaa00f81de18c227f32f8074c8b352d50 Mon Sep 17 00:00:00 2001 From: Arjan van de Ven <arjan@linux.intel.com> Date: Sun, 30 Oct 2011 19:06:07 -0700 Subject: [PATCH] drm: Make the per-driver file_operations struct const The DRM layer keeps a copy of struct file_operations inside its big driver struct... which prevents it from being consistent and static. For consistency (and the general security objective of having such things static), it's desirable to get this fixed. This patch splits out the file_operations field to its own struct, which is then "static const", and just stick a pointer to this into the driver struct, making it more consistent with how the rest of the kernel does this. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-31gpu: add module.h to drivers/gpu files as required.Paul Gortmaker
So that we don't get build failures once the implicit module.h presence is removed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-07drm: rework PCI/platform driver interface.Dave Airlie
This abstracts the pci/platform interface out a step further, we can go further but this is far enough for now to allow USB to be plugged in. The drivers now just call the init code directly for their device type. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits) vmwgfx: Implement a proper GMR eviction mechanism drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2 drm/radeon/kms: properly compute group_size on 6xx/7xx drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker drm/radeon/kms/evergreen: set the clear state to the blit state drm/radeon/kms: don't poll dac load detect. gpu: Add Intel GMA500(Poulsbo) Stub Driver drm/radeon/kms: MC vram map needs to be >= pci aperture size drm/radeon/kms: implement display watermark support for evergreen drm/radeon/kms/evergreen: add some additional safe regs v2 drm/radeon/r600: fix tiling issues in CS checker. drm/i915: Move gpu_write_list to per-ring drm/i915: Invalidate the to-ring, flush the old-ring when updating domains drm/i915/ringbuffer: Write the value passed in to the tail register agp/intel: Restore valid PTE bit for Sandybridge after bdd3072 drm/i915: Fix flushing regression from 9af90d19f drm/i915/sdvo: Remove unused encoding member i915: enable AVI infoframe for intel_hdmi.c [v4] drm/i915: Fix current fb blocking for page flip drm/i915: IS_IRONLAKE is synonymous with gen == 5 ... Fix up conflicts in - drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the new simplified stack-based kmap_atomic() interface - drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL removal cleanups.
2010-09-16drm: use noop_llseekArnd Bergmann
The drm device drivers currently allow seeking on the character device but never care about the actual file position. When we change the default llseek operation to be no_llseek, calling llseek on a drm device would return an error condition, which is an API change. Explicitly setting noop_llseek lets us keep the current API. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.freedesktop.org
2010-08-30drm: kill get_reg_ofs callbackDaniel Vetter
Every driver used the default implementation. Fold that one into the only callsite and drop the callback. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-30drm: kill drm_map_ofs callbacksDaniel Vetter
All drivers happily copy&pasted the default implementation without checking whether this callback is used at all. It's not. Sigh. Kill it. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-17drm: block userspace under allocating buffer and having drivers overwrite it ↵Dave Airlie
(v2) With the current screwed but its ABI, ioctls for the drm, Linus pointed out that we could allow userspace to specify the allocation size, but we pass it to the driver which then uses it blindly to store a struct. Now if userspace specifies the allocation size as smaller than the driver needs, the driver can possibly overwrite memory. This patch restructures the driver ioctls so we store the structure size we are expecting, and make sure we allocate at least that size. The copy from/to userspace are still restricted to the size the user specifies, this allows ioctl structs to grow on both sides of the equation. Up until now we didn't really use the DRM_IOCTL defines in the kernel, so this cleans them up and adds them for nouveau. v2: fix nouveau pushbuf arg (thanks to Ben for pointing it out) Reported-by: Linus Torvalds <torvalds@linuxfoundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-02drm/r128: fixed brace and spacing coding style issuesNicolas Kaiser
Fixed brace and spacing coding style issues. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-18drm: convert drm_ioctl to unlocked_ioctlArnd Bergmann
drm_ioctl is called with the Big Kernel Lock held, which shows up very high in statistics on vfs_ioctl. Moving the lock into the drm_ioctl function itself makes sure we blame the right subsystem and it gets us one step closer to eliminating the locked version of fops->ioctl. Since drm_ioctl does not require the lock itself, we only need to hold it while calling the specific handler. The 32 bit conversion handlers do not interact with any other code, so they don't need the BKL here either and can just call drm_ioctl. As a bonus, this cleans up all the other users of drm_ioctl which now no longer have to find the inode or call lock_kernel. [airlied: squashed the non-driver bits of the second patch in here, this provides the flag for drivers to use to select unlocked ioctls - but doesn't modify any drivers]. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.sourceforge.net Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-31drm/r128: Add test for initialisation to all ioctls that require itBen Hutchings
Almost all r128's private ioctls require that the CCE state has already been initialised. However, most do not test that this has been done, and will proceed to dereference a null pointer. This may result in a security vulnerability, since some ioctls are unprivileged. This adds a macro for the common initialisation test and changes all ioctl implementations that require prior initialisation to use that macro. Also, r128_do_init_cce() does not test that the CCE state has not been initialised already. Repeated initialisation may lead to a crash or resource leak. This adds that test. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-27drm/r128: Use request_firmware() to load CCE microcodeBen Hutchings
Firmware blob looks like this: __be32 datah __be32 datal Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-18drm: Remove memory debugging infrastructure.Eric Anholt
It hasn't been used in ages, and having the user tell your how much memory is being freed at free time is a recipe for disaster even if it was ever used. Signed-off-by: Eric Anholt <eric@anholt.net>
2009-05-06drm/r128: fix r128 ioremaps to use ioremap_wc.Dave Airlie
This should allow r128 to start working again since PAT changes. taken from F-11 kernel. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-03-13drm: Make drm_local_map use a resource_size_t offsetBenjamin Herrenschmidt
This changes drm_local_map to use a resource_size for its "offset" member instead of an unsigned long, thus allowing 32-bit machines with a >32-bit physical address space to be able to store there their register or framebuffer addresses when those are above 4G, such as when using a PCI video card on a recent AMCC 440 SoC. This patch isn't as "trivial" as it sounds: A few functions needed to have some unsigned long/int changed to resource_size_t and a few printk's had to be adjusted. But also, because userspace isn't capable of passing such offsets, I had to modify drm_find_matching_map() to ignore the offset passed in for maps of type _DRM_FRAMEBUFFER or _DRM_REGISTERS. If we ever support multiple _DRM_FRAMEBUFFER or _DRM_REGISTERS maps for a given device, we might have to change that trick, but I don't think that happens on any current driver. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-11-25drm: move drm vblank initialization/cleanup to driver load/unloadKeith Packard
drm vblank initialization keeps track of the changes in driver-supplied frame counts across vt switch and mode setting, but only if you let it by not tearing down the drm vblank structure. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18drm: kill drm_device->irqJesse Barnes
Like the last patch but adds a macro to get at the irq value instead of dereferencing pdev directly. Should make things easier for the BSD guys and if we ever support non-PCI devices. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-18drm: Rework vblank-wait handling to allow interrupt reduction.Jesse Barnes
Previously, drivers supporting vblank interrupt waits would run the interrupt all the time, or all the time that any 3d client was running, preventing the CPU from sleeping for long when the system was otherwise idle. Now, interrupts are disabled any time that no client is waiting on a vblank event. The new method uses vblank counters on the chipsets when the interrupts are turned off, rather than counting interrupts, so that we can continue to present accurate vblank numbers. Co-author: Michel Dänzer <michel@tungstengraphics.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
