include radeon_asic.h header file in the various xxx_dpm.c files
to reduce sparse false positive warnings. Not so great patch
in itself, but reducing warning count from 391 to 258 may help
to see real problems..
Signed-off-by: Michele Curti <michele.curti@gmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
No longer needed now that the underlying bug was fixed in
b0880e87c1fd038b84498944f52e52c3e86ebe59
(drm/radeon/dpm: fix vddci setup typo on cayman).
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=69721
Reviewed-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Tested-by: Alexandre Demers <alexandre.f.demers@gmail.com>
We were using the vddc mask rather than the vddci mask.
Bug:
https://bugzilla.kernel.org/show_bug.cgi?id=79071
May also fix:
https://bugs.freedesktop.org/show_bug.cgi?id=69723
Noticed by: Dieter Nützel <Dieter@nuetzel-hh.de>
Cc: stable@vger.kernel.org
git://people.freedesktop.org/~deathsimple/linux into drm-next
So this is the initial pull request for radeon drm-next 3.15. Highlights:
- VCE bringup including DPM support
- Few cleanups for the ring handling code
* 'drm-next-3.15' of git://people.freedesktop.org/~deathsimple/linux:
drm/radeon: cleanup false positive lockup handling
drm/radeon: drop radeon_ring_force_activity
drm/radeon: drop drivers copy of the rptr
drm/radeon/cik: enable/disable vce cg when encoding v2
drm/radeon: add support for vce 2.0 clock gating
drm/radeon/dpm: properly enable/disable vce when vce pg is enabled
drm/radeon/dpm: enable dynamic vce state switching v2
drm/radeon: add vce dpm support for KV/KB
drm/radeon: enable vce dpm on CI
drm/radeon: add vce dpm support for CI
drm/radeon: fill in set_vce_clocks for CIK asics
drm/radeon/dpm: fetch vce states from the vbios
drm/radeon/dpm: fill in some initial vce infrastructure
drm/radeon/dpm: move platform caps fetching to a separate function
drm/radeon: add callback for setting vce clocks
drm/radeon: add VCE version parsing and checking
drm/radeon: add VCE ring query
drm/radeon: initial VCE support v4
drm/radeon: fix CP semaphores on CIK
inverted logic.
It's needed by by both the asic specific functions and the
extended table parser.
When we parse the power tables use the stored mac_vddc value
rather than lookig it up manually each time.
For btc and newer, we may modify the power state depending
on the circumstances. Use the modified state rather than
the base state.
We need more control over the ordering of dpm init with
respect to the rest of the asic. Specifically, the SMC
has to be initialized before the rlc and cg/pg. The pm
code currently initializes late in the driver, but we need
it to happen much earlier so move pm handling into the asic
specific callbacks.
This makes dpm more reliable and makes clockgating work
properly on CIK parts and should help on SI parts as well.
Right now it's called right after enable, but after
reworking the dpm init order, it will get called later
to accomodate loading the smc early, but enabling
thermal interrupts and block powergating later after
the ring tests are complete.
This is based on a similar patch from Alexandre Demers.
While fixing up some warnings with that patch I saw some
additional cleanups that could be applied. This patch
simplifies the logic for patching the power state.
Cc: Alexandre Demers <alexandre.f.demers@gmail.com>
With CONFIG_ACPI=n the following build warning is seen:
drivers/gpu/drm/radeon/ni_dpm.c:3448:31: warning: unused variable 'eg_pi' [-Wunused-variable]
Move the definition of eg_pi inside the CONFIG_ACPI 'if' block.
filter out mclk and sclk levels higher than listed in the clk
voltage dependency tables. Supporting these clocks will require
additional driver tweaking that isn't supported yet.
See bug:
https://bugs.freedesktop.org/show_bug.cgi?id=68235
Calling force_performance_level() from set_power_state()
doesn't work on some asics because the current power
state pointer has not been properly updated at that point.
Move the calls to force_performance_level() out of the
asic specific set_power_state() functions and into
the main power state sequence.
Fixes dpm resume on SI.
Check to make sure the dc limits are valid before using them.
Some systems may not have a dc limits table. In that case just
use the ac limits. This fixes hangs on systems when the power
state is changed when on battery (dc) due to invalid performance
state parameters.
Should fix:
https://bugs.freedesktop.org/show_bug.cgi?id=68708
v2: fix up limits in dpm_init()
Newer versions of gcc seem to wander off into the
weeds when dealing with variable sizes arrays in
structs. Rather than indexing the arrays, use
pointer arithmetic.
See bugs:
https://bugs.freedesktop.org/show_bug.cgi?id=66932
https://bugs.freedesktop.org/show_bug.cgi?id=66972
https://bugs.freedesktop.org/show_bug.cgi?id=66945
According to the internal teams, we never hit the limit for
mclk switching on these asics, so we can disable the check.
Need to check for engine and memory clock ss separately
and only enable dynamic ss if either of them are found.
This should fix systems which have a ss table, but do
not have entries for engine or memory. On those systems
we may enable dynamic spread spectrum without enabling
it on the engine or memory clocks which can lead to a
hang in some cases.
fixes some systems reported here:
https://bugs.freedesktop.org/show_bug.cgi?id=66963
v2: fix typo
On rv770 and newer, clock gating is not required
for thermal protection. The only requirement is that
the design utilizes a thermal sensor.
Need to program EnabledLevels to 1 to force the low state.
Check if we can switch the mclk during the vblank time otherwise
we may get artifacts on the screen when the mclk changes.
Allows you to force a performance level via sysfs.
Add #include <linux/seq_file.h> to *_dpm.c files
This allows you to look at the current DPM state via
debugfs.
Was disabled due to stability issues on certain boards
caused by the a bug in the parsing of the atom mc reg tables.
That's fixed now so re-enable.
Fixes hangs with DPM in some cases.
The rv770 version was using the wrong power state type.
This adds dpm support for SI asics. This includes:
- dynamic engine clock scaling
- dynamic memory clock scaling
- dynamic voltage scaling
- dynamic pcie gen1/gen2/gen3 switching
- power containment
- shader power scaling
Set radeon.dpm=1 to enable.
v2: enable hainan support, rebase
v3: guard acpi stuff
v4: fix 64 bit math
v5: fix 64 bit div harder
v6: fix thermal interrupt check noticed by Jerome
v7: attempt fix state enable
We weren't properly catching errors in dpm_enable()
and dpm_set_power_state().
Add a way to look up the bootup mvdd. Required for DPM on SI.
Validate the voltages against the voltage requirements of the
dispclk. We currently don't adjust the disp clock so it never
changes, but we need to filter out voltage levels that are too
low none the less.
Use the new fixed point functions for leakage
calculations on cayman.
v2: fix up 64 bit math
SI uses a new atom table. Required for DPM on SI.
This properly implemented dynamic state adjustment by
using a working copy of the requested and current
power states.
Needed to properly handle dynamic state adjustment.
This adds dpm support for cayman asics. This includes:
- clockgating
- dynamic pcie gen1/gen2 switching (requires additional acpi support)
- power containment
v2: fold in tdp fix
v3: fix indentation
v4: fix 64 bit div
v5: attempt to fix state enable
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
