Allow interval trees to quickly check for overlaps to avoid unnecesary
tree lookups in interval_tree_iter_first().
As of this patch, all interval tree flavors will require using a
'rb_root_cached' such that we can have the leftmost node easily
available. While most users will make use of this feature, those with
special functions (in addition to the generic insert, delete, search
calls) will avoid using the cached option as they can do funky things
with insertions -- for example, vma_interval_tree_insert_after().
[jglisse@redhat.com: fix deadlock from typo vm_lock_anon_vma()]
Link: http://lkml.kernel.org/r/20170808225719.20723-1-jglisse@redhat.com
Link: http://lkml.kernel.org/r/20170719014603.19029-12-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Acked-by: Christian König <christian.koenig@amd.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Doug Ledford <dledford@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Christian Benvenuti <benve@cisco.com>
Change "prefered" to "preferred"
Signed-off-by: Kent Russell <kent.russell@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Change "stollen" to "stolen"
Pull drm updates from Dave Airlie:
"This is the main pull request for the drm, I think I've got one later
driver pull for mediatek SoC driver, I'm undecided on if it needs to
go to you yet.
Otherwise summary below:
Core drm:
- Atomic add driver private objects
- Deprecate preclose hook in modern drivers
- MST bandwidth tracking
- Use kvmalloc in more places
- Add mode_valid hook for crtc/encoder/bridge
- Reduce sync_file construction time
- Documentation updates
- New DRM synchronisation object support
New drivers:
- pl111 - pl111 CLCD display controller
Panel:
- Innolux P079ZCA panel driver
- Add NL12880B20-05, NL192108AC18-02D, P320HVN03 panels
- panel-samsung-s6e3ha2: Add s6e3hf2 panel support
i915:
- SKL+ watermark fixes
- G4x/G33 reset improvements
- DP AUX backlight improvements
- Buffer based GuC/host communication
- New getparam for (sub)slice infomation
- Cannonlake and Coffeelake initial patches
- Execbuf optimisations
radeon/amdgpu:
- Lots of Vega10 bug fixes
- Preliminary raven support
- KIQ support for compute rings
- MEC queue management rework
- DCE6 Audio support
- SR-IOV improvements
- Better radeon/amdgpu selection support
nouveau:
- HDMI stereoscopic support
- Display code rework for >= GM20x GPUs
msm:
- GEM rework for fine-grained locking
- Per-process pagetable work
- HDMI fixes for Snapdragon 820.
vc4:
- Remove 256MB CMA limit from vc4
- Add out-fence support
- Add support for cygnus
- Get/set tiling ioctls support
- Add T-format tiling support for scanout
zte:
- add VGA support.
etnaviv:
- Thermal throttle support for newer GPUs
- Restore userspace buffer cache performance
- dma-buf sync fix
stm:
- add stm32f429 display support
exynos:
- Rework vblank handling
- Fixup sw-trigger code
sun4i:
- V3s display engine support
- HDMI support for older SoCs
- Preliminary work on dual-pipeline SoCs.
rcar-du:
- VSP work
imx-drm:
- Remove counter load enable from PRE
- Double read/write reduction flag support
tegra:
- Documentation for the host1x and drm driver.
- Lots of staging ioctl fixes due to grate project work.
omapdrm:
- dma-buf fence support
- TILER rotation fixes"
* tag 'drm-for-v4.13' of git://people.freedesktop.org/~airlied/linux: (1270 commits)
drm: Remove unused drm_file parameter to drm_syncobj_replace_fence()
drm/amd/powerplay: fix bug fail to remove sysfs when rmmod amdgpu.
amdgpu: Set cik/si_support to 1 by default if radeon isn't built
drm/amdgpu/gfx9: fix driver reload with KIQ
drm/amdgpu/gfx8: fix driver reload with KIQ
drm/amdgpu: Don't call amd_powerplay_destroy() if we don't have powerplay
drm/ttm: Fix use-after-free in ttm_bo_clean_mm
drm/amd/amdgpu: move get memory type function from early init to sw init
drm/amdgpu/cgs: always set reference clock in mode_info
drm/amdgpu: fix vblank_time when displays are off
drm/amd/powerplay: power value format change for Vega10
drm/amdgpu/gfx9: support the amdgpu.disable_cu option
drm/amd/powerplay: change PPSMC_MSG_GetCurrPkgPwr for Vega10
drm/amdgpu: Make amdgpu_cs_parser_init static (v2)
drm/amdgpu/cs: fix a typo in a comment
drm/amdgpu: Fix the exported always on CU bitmap
drm/amdgpu/gfx9: gfx_v9_0_enable_gfx_static_mg_power_gating() can be static
drm/amdgpu/psp: upper_32_bits/lower_32_bits for address setup
drm/amd/powerplay/cz: print message if smc message fails
drm/amdgpu: fix typo in amdgpu_debugfs_test_ib_init
Rename:
wait_queue_t => wait_queue_entry_t
'wait_queue_t' was always a slight misnomer: its name implies that it's a "queue",
but in reality it's a queue *entry*. The 'real' queue is the wait queue head,
which had to carry the name.
Start sorting this out by renaming it to 'wait_queue_entry_t'.
This also allows the real structure name 'struct __wait_queue' to
lose its double underscore and become 'struct wait_queue_entry',
which is the more canonical nomenclature for such data types.
into drm-next
New radeon and amdgpu features for 4.13:
- Preliminary Raven support
- MEC queue management rework from Andres
- Audio support for DCE6
- Improved module parameters for controlling radeon vs amdgpu support
for SI and CIK
- Bug fixes
- General code cleanups
[airlied: dropped drmP.h header from one file was needed and build broke]
* 'drm-next-4.13' of git://people.freedesktop.org/~agd5f/linux: (362 commits)
drm/amdgpu: Fix compiler warnings
drm/amdgpu: vm_update_ptes remove code duplication
drm/amd/amdgpu: Port VCN over to new SOC15 macros
drm/amd/amdgpu: Port PSP v10.0 over to new SOC15 macros
drm/amd/amdgpu: Port PSP v3.1 over to new SOC15 macros
drm/amd/amdgpu: Port NBIO v7.0 driver over to new SOC15 macros
drm/amd/amdgpu: Port NBIO v6.1 driver over to new SOC15 macros
drm/amd/amdgpu: Port UVD 7.0 over to new SOC15 macros
drm/amd/amdgpu: Port MMHUB over to new SOC15 macros
drm/amd/amdgpu: Cleanup gfxhub read-modify-write patterns
drm/amd/amdgpu: Port GFXHUB over to new SOC15 macros
drm/amd/amdgpu: Add offset variant to SOC15 macros
drm/amd/powerplay: add avfs control for Vega10
drm/amdgpu: add virtual display support for raven
drm/amdgpu/gfx9: fix compute ring doorbell index
drm/amd/amdgpu: Rename KIQ ring to avoid spaces
drm/amd/amdgpu: gfx9 tidy ups (v2)
drm/amdgpu: add contiguous flag in ucode bo create
drm/amdgpu: fix missed gpu info firmware when cache firmware during S3
drm/amdgpu: export test ib debugfs interface
This will allow amdgpu-pro / other out-of-tree amdgpu builds to make use
of these options for using the out-of-tree amdgpu driver instead of the
in-tree radeon driver in a clean way.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
If AMDGPU supports SI, add a module parameter to control SI
support in radeon. It's on by default in radeon, while it will be
off by default in AMDGPU as long as SI support is experimental.
Signed-off-by: Felix Kuehling <Felix.Kuehling@amd.com>
Acked-by: Michel Dänzer <michel.daenzer@amd.com>
Same as the previous patch, but for pageflipping now. This also lets us
clear up the copy paste for vblank/vline IRQs.
Changes since v1:
- Preserve the order all registers are written back
Signed-off-by: Lyude <lyude@redhat.com>
Same as the previous patch, but now for handling HDMI audio interrupts.
Changes since v1:
- Preserve the order we write back all registers
The current code here is really, really bad. A huge amount of it looks
to be copy pasted, it has some weird hatred of arrays and code sharing,
switch cases everywhere for things that really don't need them, and it
makes the file seem immensely more complex then it actually is. This is
a pain for maintanence, and is vulnerable to more weird irq handling
bugs.
So, let's start cleaning this up a bit. Modify all of the IRQ handlers
for evergreen/si so that they just use for loops. As well, we add a
helper function radeon_irq_kms_set_irq_n_enabled(), whose purpose is
just to update the state of registers that enable/disable interrupts
while printing any changes to the set of enabled interrupts to the
kernel log.
Note in this commit, since vblank/vline irq acking is intertwined with
page flip irq acking, we can't cut out all of the copy paste in
evergreen/si_irq_ack() just yet.
Changes since v1:
- Preserve order we write back all registers
If AMDGPU supports CIK, add a module parameter to control CIK
support in radeon. It's off by default in radeon, while it will be
on by default in AMDGPU.
Include <drm/*.h> instead of relative path from include/drm, then
remove the -Iinclude/drm compiler flag.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1493009447-31524-14-git-send-email-yamada.masahiro@socionext.com
Signed-off-by: Christopher James Halse Rogers <christopher.halse.rogers@canonical.com>
Use a more common logging style.
Miscellanea:
o Coalesce formats and realign arguments
o Neaten a few macros now using pr_<level>
I plan to usurp the short name of struct fence for a core kernel struct,
and so I need to rename the specialised fence/timeline for DMA
operations to make room.
A consensus was reached in
https://lists.freedesktop.org/archives/dri-devel/2016-July/113083.html
that making clear this fence applies to DMA operations was a good thing.
Since then the patch has grown a bit as usage increases, so hopefully it
remains a good thing!
(v2...: rebase, rerun spatch)
v3: Compile on msm, spotted a manual fixup that I broke.
v4: Try again for msm, sorry Daniel
coccinelle script:
- struct fence
+ struct dma_fence
- struct fence_ops
+ struct dma_fence_ops
- struct fence_cb
+ struct dma_fence_cb
- struct fence_array
+ struct dma_fence_array
- enum fence_flag_bits
+ enum dma_fence_flag_bits
- fence_init
+ dma_fence_init
- fence_release
+ dma_fence_release
- fence_free
+ dma_fence_free
- fence_get
+ dma_fence_get
- fence_get_rcu
+ dma_fence_get_rcu
- fence_put
+ dma_fence_put
- fence_signal
+ dma_fence_signal
- fence_signal_locked
+ dma_fence_signal_locked
- fence_default_wait
+ dma_fence_default_wait
- fence_add_callback
+ dma_fence_add_callback
- fence_remove_callback
+ dma_fence_remove_callback
- fence_enable_sw_signaling
+ dma_fence_enable_sw_signaling
- fence_is_signaled_locked
+ dma_fence_is_signaled_locked
- fence_is_signaled
- fence_is_later
+ dma_fence_is_later
- fence_later
+ dma_fence_later
- fence_wait_timeout
+ dma_fence_wait_timeout
- fence_wait_any_timeout
+ dma_fence_wait_any_timeout
- fence_wait
+ dma_fence_wait
- fence_context_alloc
+ dma_fence_context_alloc
- fence_array_create
+ dma_fence_array_create
- to_fence_array
+ to_dma_fence_array
- fence_is_array
+ dma_fence_is_array
- trace_fence_emit
+ trace_dma_fence_emit
- FENCE_TRACE
+ DMA_FENCE_TRACE
- FENCE_WARN
+ DMA_FENCE_WARN
- FENCE_ERR
+ DMA_FENCE_ERR
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Acked-by: Sumit Semwal <sumit.semwal@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/20161025120045.28839-1-chris@chris-wilson.co.uk
Now we can program a flip during a vertical blank period, if it's the
one targeted by the flip (or a later one). This allows simplifying
radeon_flip_work_func considerably.
Fence contexts are created on the fly (for example) by the GPU scheduler used
in the amdgpu driver as a result of an userspace request. Because of this
userspace could in theory force a wrap around of the 32bit context number
if it doesn't behave well.
Avoid this by increasing the context number to 64bits. This way even when
userspace manages to allocate a billion contexts per second it takes more
than 500 years for the context number to wrap around.
v2: fix printf formats as well.
Signed-off-by: Christian König <christian.koenig@amd.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1464786612-5010-2-git-send-email-deathsimple@vodafone.de
Signed-off-by: Arindam Nath <arindam.nath@amd.com>
Reviewed-by: Leo Liu <leo.liu@amd.com>
When this flag is set, we program the hardware to execute the flip
during horizontal blank (i.e. for the next scanline) instead of during
vertical blank (i.e. for the next frame).
Currently this is only supported on ASICs which have a page flip
completion interrupt (>= R600), and only if the use_pflipirq parameter
has value 2 (the default).
Signed-off-by: Nils Wallménius <nils.wallmenius@gmail.com>
Some GPU block like UVD and VCE require hard reset to be properly
resume if there is no real powerdown of the asic like during various
hibernation step. This patch perform such hard reset.
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: Christian König <christian.koenig@amd.com>
In some cases, like when freezing for hibernation, we need to be
able to force hard reset even if no engine are stuck. This patch
add a bool option to current asic reset callback to allow to force
hard reset on asic that supports it.
Quite few suspend/hibernation bugs are related to this block. Add
an option to disable those as a work around.
This will later on serve for module option to disable vce.
When the radeon driver resets a gpu, it attempts to test whether all the
rings can successfully handle an IB. If these rings fail to respond, the
process will wait forever. Another gpu reset can't happen at this point,
as the current reset holds a lock required to do so. Instead, make all
the IB tests run with a timeout, so the system can attempt to recover
in this case.
While this doesn't fix the underlying issue with card resets failing, it
gives the system a higher chance of recovering. These timeouts have been
confirmed to help both a Tathi and Hawaii card recover after a gpu reset.
This also adds a new function, radeon_fence_wait_timeout, that behaves like
fence_wait_timeout. It is used instead of fence_wait_timeout as it continues
to work during a reset. radeon_fence_wait is changed to be implemented
using this function.
V2:
- Changed the timeout to 1s, as the default 10s from radeon_wait_timeout was
too long. A timeout of 100ms was tested and found to be too short.
- Changed radeon_fence_wait_timeout to behave more like fence_wait_timeout.
Signed-off-by: Matthew Dawson <matthew@mjdsystems.ca>
This is preparation for the fixes in the following patches.
Signed-off-by: Slava Grigorev <slava.grigorev@amd.com>
Cc: stable@vger.kernel.org
into drm-next
[airlied: fixup build problems on arm - added errno.h include]
* 'drm-next-4.5' of git://people.freedesktop.org/~agd5f/linux: (152 commits)
amd/powerplay: fix copy paste typo in hardwaremanager.c
amd/powerplay: disable powerplay by default initially
amd/powerplay: don't enable ucode fan control if vbios has no fan table
drm/amd/powerplay: show gpu load when print gpu performance for Cz. (v2)
drm/amd/powerplay: check whether need to enable thermal control. (v2)
drm/amd/powerplay: add point check to avoid NULL point hang.
drm/amdgpu/powerplay: Program a calculated value as Deep Sleep clock.
drm/amd/powerplay: Don't return an error if fan table is missing
drm/powerplay/hwmgr: log errors in tonga_hwmgr_backend_init
drm/powerplay: add debugging output to processpptables.c
drm/powerplay: add debugging output to tonga_processpptables.c
amd/powerplay: Add structures required to report configuration change
amd/powerplay: Fix get dal power level
amd\powerplay Implement get dal power level
drm/amd/powerplay: display gpu load when print performance for tonga.
drm/amdgpu/powerplay: enable sysfs and debugfs interfaces late
drm/amd/powerplay: move shared function of vi to hwmgr. (v2)
drm/amd/powerplay: check whether enable dpm in powerplay.
drm/amd/powerplay: fix bug that dpm funcs in debugfs/sysfs missing.
drm/amd/powerplay: fix boolreturn.cocci warnings
DP audio is derived from the dfs clock.
HPD signals on DVI ports can be fired off before the pins required for
DDC probing actually make contact, due to the pins for HPD making
contact first. This results in a HPD signal being asserted but DDC
probing failing, resulting in hotplugging occasionally failing.
This is somewhat rare on most cards (depending on what angle you plug
the DVI connector in), but on some cards it happens constantly. The
Radeon R5 on the machine used for testing this patch for instance, runs
into this issue just about every time I try to hotplug a DVI monitor and
as a result hotplugging almost never works.
Rescheduling the hotplug work for a second when we run into an HPD
signal with a failing DDC probe usually gives enough time for the rest
of the connector's pins to make contact, and fixes this issue.
Signed-off-by: Lyude <cpaul@redhat.com>
The radeon_asic_ring structures are never modified, so declare them as
const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Fixes a harmless error message caused by:
51a4726b04e880fdd9b4e0e58b13f70b0a68a7f5
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
This patch deinlines indirect register accessor functions.
These functions perform two mmio accesses, framed by spin lock/unlock.
Spin lock/unlock by itself takes more than 50 cycles in ideal case
(if lock is exclusively cached on current CPU).
With this .config: http://busybox.net/~vda/kernel_config,
after uninlining these functions have sizes and callsite counts
as follows:
r600_uvd_ctx_rreg: 111 bytes, 4 callsites
r600_uvd_ctx_wreg: 113 bytes, 5 callsites
eg_pif_phy0_rreg: 106 bytes, 13 callsites
eg_pif_phy0_wreg: 108 bytes, 13 callsites
eg_pif_phy1_rreg: 107 bytes, 13 callsites
eg_pif_phy1_wreg: 108 bytes, 13 callsites
rv370_pcie_rreg: 111 bytes, 21 callsites
rv370_pcie_wreg: 113 bytes, 24 callsites
r600_rcu_rreg: 111 bytes, 16 callsites
r600_rcu_wreg: 113 bytes, 25 callsites
cik_didt_rreg: 106 bytes, 10 callsites
cik_didt_wreg: 107 bytes, 10 callsites
tn_smc_rreg: 106 bytes, 126 callsites
tn_smc_wreg: 107 bytes, 116 callsites
eg_cg_rreg: 107 bytes, 20 callsites
eg_cg_wreg: 108 bytes, 52 callsites
Functions r100_mm_rreg() and r100_mm_rreg() have a fast path and
a locked (slow) path. This patch deinlines only slow path.
r100_mm_rreg_slow: 78 bytes, 2083 callsites
r100_mm_wreg_slow: 81 bytes, 3570 callsites
Reduction in code size is more than 65,000 bytes:
85740176 22294680 20627456 128662312 7ab3b28 vmlinux.before
85674192 22294776 20627456 128598664 7aa4288 vmlinux
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
It is theoretically possible that a swapped out BO gets the
same GTT address, but different backing pages while being swapped in.
Instead just use another VA state to note updated areas.
Use the generic mechanism to declare a bitmap instead of unsigned long.
Initial support for VCE 1.0 using newest firmware.
v2: rebased
v3: fix for TN
v4: fix FW size calculation
For setting clocks with VCE v1.0
v2: (chk) rebased on current tree
Previously we were completely over allocating, fix this
by actually implementing the size calculation.
Userspace will be able to tell whether a GPU reset occured by comparing
an old referece value of the counter with a new value.
Signed-off-by: Marek Olšák <marek.olsak@amd.com>
Saving the current UVD state on suspend and restoring it on resume
just doesn't work reliable. Just close cleanup all sessions on suspend.
Similar to the Intel implementation, but instead of just falling back to a
global linear list when we have an overlapping userptr request we accumulate
all overlapping userptrs in a local list.
git://git.pengutronix.de/git/pza/linux into drm-next
imx-drm limit fixes
Fix IPU IC downscaler to its hardware limitation of 4:1 and the
IPU DI pixel clock divider integer part to 8-bit.
* tag 'imx-drm-fixes-2015-03-31' of git://git.pengutronix.de/git/pza/linux:
gpu: ipu-v3: turns out the IPU can only downsize 4:1
gpu: ipu-v3: limit pixel clock divider to 8-bits
drm/radeon: programm the VCE fw BAR as well
drm/radeon: always dump the ring content if it's available
radeon: Do not directly dereference pointers to BIOS area.
drm/radeon/dpm: fix 120hz handling harder
Need to expand the check to handle short circuiting
if the selected state is the same as current state.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=87796
This adds initial DP 1.2 MST support to radeon, on CAYMAN
and up in theory.
This is off by default.
v2: agd5f:
- add UNIPHY3 offsets
- move atom cmd table code into atombios_encoders.c
- whitespace cleanup
- replace some magic numbers with proper defines
This is to be called on short HPD irqs, just introduce
the basic infrastructure for it.
The atombios tables have an unfortunate restriction on only
being able to write 12 bytes, MST really wants 16-bytes here,
and since the hw can do it, we should just write directly to it.
This uses a module option to allow for it now, and maybe
we should provide the old code as a fallback for a while.
v2: (agd5f)
- move registers to a proper register header
- only enable on DCE5+
- enable by default on DCE5+
- Switch pad to aux mode before using it
- reformat instance handling to better match the
rest of the driver
This adds a callback for each asic family to determine what
registers are allowed to be read back via the info ioctl.
The idea here is to allow usermode to query things like GPU status
registers or GPU harvest registers for profiling and determining
the gfx config.
Tested-by: Marek Olšák <marek.olsak@amd.com>
