path: root/drivers/gpu/drm/radeon/radeon_bios.c
2011-07-12drm/radeon/kms: fix typo in read_disabled vbios codeAlex Deucher
BUS_CNTL reg and bits moved between pre-PCIE and PCIE asics. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-30drm/radeon/kms: increase rom size for atrm methodAlex Deucher
The vbios rom is >64k on a lot of modern asics. Increase the fetch size for atrm to make sure we don't miss part of a larger rom. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-01-07drm/radeon/kms: add disabled vbios accessor for NI asicsAlex Deucher
Some systems disable the vbios on secondary cards or cards that have been posted. This code re-enabled the vbios so the driver can load it. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-12-01drm/radeon/kms: fix typos in disabled vbios codeAlex Deucher
6xx/7xx was hitting the wrong BUS_CNTL reg and bits. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-07Merge branch 'drm-platform' into drm-testingDave Airlie
* drm-platform: drm: Make sure the DRM offset matches the CPU drm: Add __arm defines to DRM drm: Add support for platform devices to register as DRM devices drm: Remove drm_resource wrappers
2010-07-01drm/radeon/kms: don't read attempt to read bios from VRAM on unposted GPU.Dave Airlie
Since the VGA switcheroo, we'd attempt to read the BIOS from VRAM on startup but on some unposted cards this can cause hangs/crashes. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=28592 (further problem pointed out by agd5f on IGP systems) Reported-by: Reilithion on #radeon Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-01drm: Remove drm_resource wrappersJordan Crouse
Remove the drm_resource wrappers and directly use the actual PCI and/or platform functions in their place. [airlied: fixup nouveau properly to build] Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org> Reviewed-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drivers/gpu/drm: Use kmemdupJulia Lawall
Use kmemdup when some other buffer is immediately copied into the allocated region. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; statement S; @@ - to = \(kmalloc\|kzalloc\)(size,flag); + to = kmemdup(from,size,flag); if (to==NULL || ...) S - memcpy(to, from, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dave Airlie <airlied@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01Merge branch 'gpu-switcher' of /ssd/git//linux-2.6 into drm-next-stageDave Airlie
* 'gpu-switcher' of /ssd/git//linux-2.6: vga_switcheroo: initial implementation (v15) fb: for framebuffer handover don't exit the loop early. Conflicts: drivers/gpu/drm/i915/i915_dma.c drivers/gpu/drm/radeon/Makefile drivers/gpu/drm/radeon/radeon.h
2010-03-01vga_switcheroo: initial implementation (v15)Dave Airlie
Many new laptops now come with 2 gpus, one to be used for low power modes and one for gaming/on-ac applications. These GPUs are typically wired to the laptop panel and VGA ports via a multiplexer unit which is controlled via ACPI methods. 4 combinations of systems typically exist - with 2 ACPI methods. Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method ATI/ATI - some ASUS - use ATPX ACPI Method Intel/Nvidia - - use _DSM ACPI method Nvidia/Nvidia - - use _DSM ACPI method. TODO: This patch adds support for the ATPX method and initial bits for the _DSM methods that need to written by someone with access to the hardware. Add a proper non-debugfs interface - need to get some proper testing first. v2: add power up/down support for both devices on W500 puts i915/radeon into D3 and cuts power to radeon. v3: redo probing methods, no DMI list, drm devices call to register with switcheroo, it tries to find an ATPX method on any device and once there is two devices + ATPX it inits the switcher. v4: ATPX msg handling using buffers - should work on more machines v5: rearchitect after more mjg59 discussion - move ATPX handling to radeon driver. v6: add file headers + initial nouveau bits (to be filled out). v7: merge delayed switcher code. v8: avoid suspend/resume of gpu that is off v9: rearchitect - mjg59 is always right. - move all ATPX code to radeon, should allow simpler DSM also proper ATRM handling v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv v11: fix bug in resuming Intel for 2nd time. v12: start fixing up nvidia code blindly. v13: blindly guess at finishing nvidia code v14: remove radeon audio hacks - fix up intel resume more like upstream v15: clean up printks + remove unnecessary igd/dis pointers mount debugfs /sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected + 2 cards. DIS - immediate change to discrete IGD - immediate change to IGD DDIS - delayed change to discrete DIGD - delayed change to IGD ON - turn on not in use OFF - turn off not in use Tested on W500 (Intel/ATI) and T500 (Intel/ATI) Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11drm/radeon/kms: check for valid PCI bios and not OF romDave Airlie
stops us trying to treat a OF rom as a PCI rom. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-11-04drm/radeon/kms: remove some misleading debugging outputAlex Deucher
2009-10-05drm/radeon/kms: add support for "Surround View"Alex Deucher
"Surround View" is an option in the system bios that enables the AMD IGP chip in conjunction with a discrete AMD card. However, since the IGP vbios is part of the system bios it is not accessible via the rom bar or the legacy vga location. When "Surround View" is enabled in the system bios, the system bios puts a copy of the IGP vbios image at the start of vram. This patch adds support for reading the vbios image out of vram on IGP cards. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-15drm/radeon: introduce kernel modesetting for radeon hardwareJerome Glisse
Add kernel modesetting support to radeon driver, use the ttm memory manager to manage memory and DRM/GEM to provide userspace API. In order to avoid backward compatibility issue and to allow clean design and code the radeon kernel modesetting use different code path than old radeon/drm driver. When kernel modesetting is enabled the IOCTL of radeon/drm driver are considered as invalid and an error message is printed in the log and they return failure. KMS enabled userspace will use new API to talk with the radeon/drm driver. The new API provide functions to create/destroy/share/mmap buffer object which are then managed by the kernel memory manager (here TTM). In order to submit command to the GPU the userspace provide a buffer holding the command stream, along this buffer userspace have to provide a list of buffer object used by the command stream. The kernel radeon driver will then place buffer in GPU accessible memory and will update command stream to reflect the position of the different buffers. The kernel will also perform security check on command stream provided by the user, we want to catch and forbid any illegal use of the GPU such as DMA into random system memory or into memory not owned by the process supplying the command stream. This part of the code is still incomplete and this why we propose that patch as a staging driver addition, future security might forbid current experimental userspace to run. This code support the following hardware : R1XX,R2XX,R3XX,R4XX,R5XX (radeon up to X1950). Works is underway to provide support for R6XX, R7XX and newer hardware (radeon from HD2XXX to HD4XXX). Authors: Jerome Glisse <jglisse@redhat.com> Dave Airlie <airlied@redhat.com> Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
