path: root/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
2013-12-04radeon: workaround pinning failure on low ram gpuJerome Glisse
commit 97b6ff6be9da7675aab339334fda996d6c5077d9 upstream. GPU with low amount of ram can fails at pinning new framebuffer before unpinning old one. On such failure, retry with unpinning old one before pinning new one allowing to work around the issue. This is somewhat ugly but only affect those old GPU we care about. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-20drm/radeon: Remove superfluous variableNiels Ole Salscheider
bool in_mode_set from struct radeon_crtc is not used anymore. Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01DRM/radeon: For single CRTC GPUs move handling of CRTC_CRT_ON to crtc_dpms().Egbert Eich
On all dual CRTC GPUs the CRTC_CRT_ON in the RADEON_CRTC_EXT_CNTL register controls the CRTC of the primary DAC. Therefore it is set in the DAC DMPS function. This is different for GPU's with a single CRTC but a primary and a TV DAC: here it controls the single CRTC no matter where it is routed. Therefore we set it here. This avoids an elaborate on/off state tracking since both primary_dac_dpms() and tv_dac_dpms() functions would have to touch this bit. On single CRTC GPUs with just one DAC it's irrelevant where this bit is handled. agd5f: fix warning Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-09-20drm/radeon: Remove unused functionsLauri Kasanen
This applies on top of drm/radeon: Mark all possible functions / structs as static. Signed-off-by: Lauri Kasanen <cand@gmx.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-09-20drm/radeon: Mark all possible functions / structs as staticLauri Kasanen
Let's allow GCC to optimize better. This exposed some five unused functions, but this patch doesn't remove them. Signed-off-by: Lauri Kasanen <cand@gmx.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-08-13drm/radeon: properly handle crtc powergatingAlex Deucher
Need to make sure the crtc is gated on before modesetting. Explicitly gate the crtc on in prepare() and set a flag so that the dpms functions don't gate it off during mode set. Noticed by sylware on IRC. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2012-07-19drm: Make the .mode_fixup() operations mode argument a const pointerLaurent Pinchart
The passed mode must not be modified by the operation, make it const. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon: Restrict offset for legacy display engine.Michel Dänzer
The hardware only takes 27 bits for the offset, so larger offsets are truncated, and the display shows random bits other than the intended ones. Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20Merge tag 'v3.2-rc6' of /home/airlied/devel/kernel/linux-2.6 into drm-core-nextDave Airlie
Merge in the upstream tree to bring in the mainline fixes. Conflicts: drivers/gpu/drm/exynos/exynos_drm_fbdev.c drivers/gpu/drm/nouveau/nouveau_sgdma.c
2011-12-20drm: Replace pitch with pitches[] in drm_framebufferVille Syrjälä
Otherwise each driver would need to keep the information inside their own framebuffer object structure. Also add offsets[]. BOs on the other hand are driver specific, so those can be kept in driver specific structures. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-11-11drm/radeon/kms: remove extraneous calls to radeon_pm_compute_clocks()Alex Deucher
It's already called via the DPMS functions. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-22drivers:video:aty:radeon_base Fix typo occationally to occasionallyJustin P. Mattock
The below patch fixes a typo occationally to occasionally. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-16Merge commit '5359533801e3dd3abca5b7d3d985b0b33fd9fe8b' into drm-core-nextDave Airlie
This commit changed an internal radeon structure, that meant a new driver in -next had to be fixed up, merge in the commit and fix up the driver. Also fixes a trivial nouveau merge. Conflicts: drivers/gpu/drm/nouveau/nouveau_mem.c
2011-03-13drm/radeon: fix page flipping hangs on r300/r400Dave Airlie
We've been getting reports of complete system lockups with rv3xx hw on AGP and PCIE when running gnome-shell or kwin with compositing. It appears the hw really doesn't like setting these registers while stuff is running, this moves the setting of the registers into the modeset since they aren't required to be changed anywhere else. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=35183 Reported-and-tested-by: Álmos <aaalmosss@gmail.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-23drm/radeon: introduce gem_to_radeon_bo helperDaniel Vetter
... and switch it to container_of upcasting. v2: converted new pageflip code-paths. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-02drm/radeon/kms: add new pll algo for avivo asicsAlex Deucher
Based on the vbios code. This should hopefully fix the pll problems on a number of avivo asics once it's enabled. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-19drm, kdb, kms: Change mode_set_base_atomic() enter argument to be an enumJason Wessel
The enter argument as implemented by commit 413d45d3627 (drm, kdb, kms: Add an enter argument to mode_set_base_atomic() API) should be more descriptive as to what it does vs just passing 1 and 0 around. There is no runtime behavior change as a result of this patch. Reported-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> CC: David Airlie <airlied@linux.ie> CC: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-19Revert "radeon, kdb, kms: Save and restore the LUT on atomic KMS enter/exit"Jason Wessel
This reverts commit ff773714dd30b802c336064109c535d8b2774e2f. A generic solution is needed to save and retore the LUT information. CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: dri-devel@lists.freedesktop.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-19Revert "drm/radeon/kms: remove some pll algo flags"Dave Airlie
This reverts commit f28488c282d8916b9b6190cc41714815bbaf97d5. On my rv610 test machine the monitor failed to light up after this. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06Merge branch 'drm-radeon-next' of ../drm-radeon-next into drm-core-nextDave Airlie
* 'drm-radeon-next' of ../drm-radeon-next: drm/radeon/kms: add drm blit support for evergreen drm/radeon: Modify radeon_pm_in_vbl to use radeon_get_crtc_scanoutpos() drm/radeon: Add function for display scanout position query. drm/radeon/kms: rework spread spectrum handling drm/radeon/kms: remove new pll algo drm/radeon/kms: remove some pll algo flags drm/radeon/kms: prefer high post dividers in legacy pll algo drm/radeon/kms: properly handle 40 bit MC addresses in the cursor code drm/radeon: add properties to configure the width of the underscan borders drm/radeon/kms/r6xx+: use new style fencing (v3) drm/radeon/kms: enable writeback (v2) drm/radeon/kms: clean up r6xx/r7xx blit init (v2)
2010-10-06radeon, kdb, kms: Save and restore the LUT on atomic KMS enter/exitJason Wessel
When changing VTs non-atomically the kernel works in conjunction with the Xserver in user space and receives the LUT information from the Xserver via a system call. When changing modes atomically for kdb, this information must be saved and restored without disturbing user space as if nothing ever happened. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: David Airlie <airlied@linux.ie> CC: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06drm, kdb, kms: Add an enter argument to mode_set_base_atomic() APIJason Wessel
Some devices such as the radeon chips receive information from user space which needs to be saved when executing an atomic mode set operation, else the user space would have to be queried again for the information. This patch extends the mode_set_base_atomic() call to pass an argument to indicate if this is an entry or an exit from an atomic kernel mode set change. Individual drm drivers can properly save and restore state accordingly. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: David Airlie <airlied@linux.ie> CC: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06drm/radeon/kms: Implement KDB debug hooks for radeon KMS.Chris Ball
Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06drm/radeon/kms: remove new pll algoAlex Deucher
The recent changes to the old algo (prefer high post div) coupled with the range and precision limitations of using fixed point with the new algo make the new algo less useful. So drop the new algo. This should work as well or better than the old new/old combinations and simplifies the code a lot. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=30218 among others. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06drm/radeon/kms: remove some pll algo flagsAlex Deucher
These shouldn't be needed with the post div changes in the last patch. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-23drm/radeon/kms: fix typo in radeon_compute_pll_gainAlex Deucher
Looks like this got copied from the ddx wrong. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-02drm/radeon/kms: move a bunch of modesetting debug to correct debug usage.Dave Airlie
This migrates a bunch of DRM_DEBUG->DRM_DEBUG_KMS so we can get more modesetting related info without all the other ioctl handling easily. Also the PM code moves to DRM_DEBUG_DRIVER mostly. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drm/radeon/kms/pm: add support for no display power statesAlex Deucher
The lowest power states often cause display problems, so only enable them when all displays are off. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drm: move radeon_fixed.h to shared drm_fixed.h headerBen Skeggs
Will be used by nouveau driver also in the near future. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drm/radeon/kms/pm: add asic specific callbacks for getting power state (v2)Alex Deucher
This also simplifies the code and enables reclocking with multiple heads active by tracking whether the power states are single or multi-head capable. Eventually, we will want to select a power state based on external factors (AC/DC state, user selection, etc.). (v2) Update for evergreen Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drm/radeon/kms/pm: move pm state update to crtc functionsAlex Deucher
crtcs are what we ultimately care about wrt to pm. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-15drm/radeon/kms/rs4xx: make sure crtcs are enabled when setting timingAlex Deucher
based on ddx patch from Matthias Hopf. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-25drm/radeon/kms: update new pll algoAlex Deucher
- add support for pre-avivo chips - add support for fixed post/ref dividers - add support for non-fractional fb dividers By default avivo chips use the new algo and pre-avivo chips use the old algo. Use the "new_pll" module option to toggle between them. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-18drm/radeon/kms: simplify memory controller setup V2Jerome Glisse
Get rid of _location and use _start/_end also simplify the computation of vram_start|end & gtt_start|end. For R1XX-R2XX we place VRAM at the same address of PCI aperture, those GPU shouldn't have much memory and seems to behave better when setup that way. For R3XX and newer we place VRAM at 0. For R6XX-R7XX AGP we place VRAM before or after AGP aperture this might limit to limit the VRAM size but it's very unlikely. For IGP we don't change the VRAM placement. Tested on (compiz,quake3,suspend/resume): PCI/PCIE:RV280,R420,RV515,RV570,RV610,RV710 AGP:RV100,RV280,R420,RV350,RV620(RPB*),RV730 IGP:RS480(RPB*),RS690,RS780(RPB*),RS880 RPB: resume previously broken V2 correct commit message to reflect more accurately the bug and move VRAM placement to 0 for most of the GPU to avoid limiting VRAM. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-09drm/radeon/kms: rework pll algo selectionAlex Deucher
Rework the pll algo selection so that the pll algo in use can be selected more easily. This allows us to select different pll divider selection algos for specific monitors that work better with one algo or the other. This is needed for the next patch which adds an LVDS pll quirk for a specific notebook. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-09drm/radeon/kms: add workaround for rn50/rv100 serversAlex Deucher
Some servers have two VGA ports but only report one in the bios connector tables. On these systems always set up the TV DAC so that it displays properly even if the bios is wrong. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-01-24drm/radeon/kms: clean up pll structAlex Deucher
- add a new flag for fixed post div - pull the pll flags into the struct Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-01-21drm/radeon/kms/r4xx: cleanup atom pathAlex Deucher
most of radeon_legacy_atom_set_surface() is taken care of in atombios_set_base(), so remove the duplicate setup and move the remaining bits (DISP_MERGE setup and FP2 sync) to atombios_crtc.c where they are used. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-12-23drm/radeon/kms: fix legacy rmxAlex Deucher
This makes 640x480 on my R100 work again, both in aspect and centered mode. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Tested-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/radeon/kms: more r4xx lvds fixesAlex Deucher
Grab pll ref div from regs at driver init. r4xx seems very picky about the dividers for the pll driving lvds. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/radeon/kms/legacy: set overscan regs on modesetAlex Deucher
These can end up with garbage otherwise. fixes rh bug 537140 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm/radeon/kms: fix legacy crtc2 dpmsAlex Deucher
noticed by Matthijs Kooijman on fdo bug 22140 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm/radeon/kms: don't use bios dividers for lvds on r4xxAlex Deucher
R4xx cards don't have lvds pll dividers since they use atom. should fix rh bug 541562 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-02drm/radeon/kms: Rework radeon object handlingJerome Glisse
The locking & protection of radeon object was somewhat messy. This patch completely rework it to now use ttm reserve as a protection for the radeon object structure member. It also shrink down the various radeon object structure by removing field which were redondant with the ttm information. Last it converts few simple functions to inline which should with performances. airlied: rebase on top of r600 and other changes. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-02drm/radeon/kms: Don't overwrite crtc_gen_cntl or crtc_gen_cntl2Jerome Glisse
Don't overwritte crtc_gen_cntl or crtc_gen_cntl2 or we may loose the cursor. This especialy happen when changing video mode. Fix bugs: https://bugzilla.redhat.com/show_bug.cgi?id=529146 Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-02drm/radeon/kms: Disable both CRTCs during mode switchPierre Ossman
Reconfiguring one CRTC whilst another is running can cause a hang under some circumstances. Unfortunately we haven't pinpointed exactly what those circumstances are, so disable all CRTCs for every mode switch. Signed-off-by: Pierre Ossman <pierre@ossman.eu> Acked-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-02drm/radeon/kms: fix oops when set_base is call with no FBJerome Glisse
Just do nothing if crct_set_base() is called with no FB. The oops happens when the user switches between X & vt or in some case when changing mode. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-10-15drm/radeon/kms: fix internal tmds setup on legacy display engineAlex Deucher
- crtc 0 routing was wrong - need to clear various timing bits in FP_GEN_CNTL - need to set FP_H/V2_SYNC_STRT_WID regs for crtc 1 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-10-12drm/radeon/kms: use drm_mode directly for panel modesAlex Deucher
This reduces the number of mode format conversions needed and makes native panel mode support cleaner. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-10-12drm/radeon/kms: Update memory bandwidth requirements in mode_set_base hook.Michel Dänzer
The hook may change the number of bytes per pixel being scanned out, which affects the CRTC memory bandwidth requirements. E.g. booting in 8bpp and then running X in 32bpp would result in the bandwidth requirements being underestimated for the latter and consequently in CRTC FIFO underruns causing visible artifacts with 3D intensive workloads. ATOM changes only compile-tested. Signed-off-by: Michel Dänzer <daenzer@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
