Fast-forwarded to current state of Linus' tree as there are patches to be
applied for files that didn't exist on the old branch.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This is necessary even with PCI(e) GART, and it makes writeback work even with
AGP on my PowerBook. Might still be unreliable with older revisions of UniNorth
and other AGP bridges though.
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
Reviewed-by: Alex Deucher <alex.deucher@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
Unconditionally initialize the drm gem object - it's not
worth the trouble not to for the few kernel objects.
This patch only changes the place of the drm gem object,
access is still done via pointers.
v2: Uncoditionally align the size in radeon_bo_create. At
least the r600/evergreen blit code didn't to this, angering
the paranoid gem code.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
We were previously dropping alignment requests on the floor
when allocating buffers so we always ended up page aligned.
Certain tiling modes on 6xx+ require larger alignment which
wasn't happening before.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Jerome Glisse <j.glisse@gmail.com>
When writeback is enabled, the GPU shadows writes to certain
registers into a buffer in memory. The driver can then read
the values from the shadow rather than reading back from the
register across the bus. Writeback can be disabled by setting
the no_wb module param to 1.
On r6xx/r7xx/evergreen, the following registers are shadowed:
- CP scratch registers
- CP read pointer
- IH write pointer
On r1xx-rr5xx, the following registers are shadowed:
- CP read pointer
v2:
- Combine wb patches for r6xx-evergreen and r1xx-r5xx
- Writeback is disabled on AGP boards since it tends to be
unreliable on AGP using the gart.
- Check radeon_wb_init return values properly.
We need to handle the ring while we've already locked it, so split out
the allocation and commit functions in order to allow them to be used.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* korg/drm-radeon-testing: (62 commits)
drm/radeon/kms: update new pll algo
drm/radeon/kms: add support for square microtiles on r3xx-r5xx
drm/radeon/kms: force pinning buffer into visible VRAM
drm/radeon/kms/evergreen: fix typo in cursor code
drm/radeon/kms: implement reading active PCIE lanes on R600+
drm/radeon/kms: for downclocking non-mobility check PERFORMANCE state
drm/radeon/kms: simplify storing current and requested PM mode
drm/radeon: fixes for r6xx/r7xx gfx init
drm/radeon/rv740: fix backend setup
drm/radeon/kms: fix R3XX/R4XX memory controller initialization
[rfc] drm/radeon/kms: pm debugging check for vbl.
drm/radeon: Fix memory allocation failures in the preKMS command stream checking.
drm: Add generic multipart buffer.
drm/radeon/kms: simplify memory controller setup V2
drm/radeon: Add asic hook for dma copy to r200 cards.
drm/radeon/kms: Create asic structure for r300 pcie cards.
drm/radeon/kms: remove unused r600_gart_clear_page
drm/radeon/kms: remove HDP flushes from fence emit (v2)
drm/radeon/kms: add LVDS pll quirk for Dell Studio 15
drm/radeon/kms: simplify picking power state
drivers/gpu/drm/radeon/atom.c
drivers/gpu/drm/radeon/atombios.h
drivers/gpu/drm/radeon/atombios_dp.c
drivers/gpu/drm/radeon/r600.c
drivers/gpu/drm/radeon/r600_audio.c
drivers/gpu/drm/radeon/r600_cp.c
drivers/gpu/drm/radeon/radeon.h
drivers/gpu/drm/radeon/radeon_connectors.c
drivers/gpu/drm/radeon/radeon_ring.c
drivers/gpu/drm/radeon/rv770.c
If at IB free time fence wasn't emited that means the IB wasn't
scheduled because an error occured somewhere, thus we can free
then fence and mark the IB as free.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
There is 3 different distinct states for an indirect buffer (IB) :
1- free with no fence
2- free with a fence
3- non free (fence doesn't matter)
Previous code mixed case 2 & 3 in a single one leading to possible
catastrophique failure. This patch rework the handling and properly
separate each case. So when you get ib we set the ib as non free and
fence status doesn't matter. Fence become active (ie has a meaning
for the ib code) once the ib is scheduled or free. This patch also
get rid of the alloc bitmap as it was overkill, we know go through
IB pool list like in a ring buffer as the oldest IB is the first
one the will be free.
Fix :
https://bugs.freedesktop.org/show_bug.cgi?id=26438
and likely other bugs.
V2 remove the scheduled list, it's useless now, fix free ib scanning
Fix :
This add an utilities function radeon_ib_bogus_add which will
save an ib into a list of ib which can then be dumped using
debugfs. Once dumped the ib is removed from the list. This
should allow to save & capute ib for further debugging.
The locking & protection of radeon object was somewhat messy.
This patch completely rework it to now use ttm reserve as a
protection for the radeon object structure member. It also
shrink down the various radeon object structure by removing
field which were redondant with the ttm information. Last it
converts few simple functions to inline which should with
performances.
airlied: rebase on top of r600 and other changes.
We sometimes lock IB then the ring and sometimes the ring then
the IB. This is mostly due to the IB locking not being well defined
about what data in the structs it actually locks. Define what I
believe is the correct behaviour and gets rid of the lock dep ordering
warning.
This convert r4xx to new init path it also fix few bugs.
This adds the r600 KMS + CS support to the Linux kernel.
The r600 TTM support is quite basic and still needs more
work esp around using interrupts, but the polled fencing
should work okay for now.
Also currently TTM is using memcpy to do VRAM moves,
the code is here to use a 3D blit to do this, but
isn't fully debugged yet.
Authors:
If there is a problem then this is hiding it, we shouldn't
ever need to flush the IB. Either the buffers are:
WB - caching just works.
WC - no need to do explicit flush, the MB + readback will do it
Add kernel modesetting support to radeon driver, use the ttm memory
manager to manage memory and DRM/GEM to provide userspace API.
In order to avoid backward compatibility issue and to allow clean
design and code the radeon kernel modesetting use different code path
than old radeon/drm driver.
When kernel modesetting is enabled the IOCTL of radeon/drm
driver are considered as invalid and an error message is printed
in the log and they return failure.
KMS enabled userspace will use new API to talk with the radeon/drm
driver. The new API provide functions to create/destroy/share/mmap
buffer object which are then managed by the kernel memory manager
(here TTM). In order to submit command to the GPU the userspace
provide a buffer holding the command stream, along this buffer
userspace have to provide a list of buffer object used by the
command stream. The kernel radeon driver will then place buffer
in GPU accessible memory and will update command stream to reflect
the position of the different buffers.
The kernel will also perform security check on command stream
provided by the user, we want to catch and forbid any illegal use
of the GPU such as DMA into random system memory or into memory
not owned by the process supplying the command stream. This part
of the code is still incomplete and this why we propose that patch
as a staging driver addition, future security might forbid current
experimental userspace to run.
This code support the following hardware : R1XX,R2XX,R3XX,R4XX,R5XX
(radeon up to X1950). Works is underway to provide support for R6XX,
R7XX and newer hardware (radeon from HD2XXX to HD4XXX).
Authors:
