path: root/drivers/gpu/drm/radeon/radeon_semaphore.c
2012-06-21drm/radeon: rework ring syncing codeChristian König
Move inter ring syncing with semaphores into the existing ring allocations, with that we need to lock the ring mutex only once. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com>
2012-05-09drm/radeon: rip out the ib poolJerome Glisse
It isn't necessary any more and the suballocator seems to perform even better. Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-09drm/radeon: simplify semaphore handling v2Jerome Glisse
Directly use the suballocator to get small chunks of memory. It's equally fast and doesn't crash when we encounter a GPU reset. v2: rebased on new SA interface. Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-09drm/radeon: define new SA interface v3Christian König
Define the interface without modifying the allocation algorithm in any way. v2: rebase on top of fence new uint64 patch v3: add ring to debugfs output Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-09drm/radeon: make sa bo a stand alone objectChristian König
Allocating and freeing it seperately. Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-09drm/radeon: use inline functions to calc sa_bo addrChristian König
Instead of hacking the calculation multiple times. Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-09drm/radeon: replace the per ring mutex with a global oneChristian König
A single global mutex for ring submissions seems sufficient. Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-03drm/radeon: fix a bug with the ring syncing codeChristian König
Rings need to lock in order, otherwise the ring subsystem can deadlock. v2: fix error handling and number of locked doublewords. v3: stop creating unneeded semaphores. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-05drm/radeon: allocate semaphore from the ib poolJerome Glisse
This allow to share the ib pool with semaphore and avoid having more bo around. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20drm/radeon: rename struct radeon_cp to radeon_ringChristian König
That naming seems to make more sense, since we not only want to run PM4 rings with it. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20drm/radeon: make some asic pointers per ringChristian König
Emitting fences, semaphores and ib works differently on different ring, so its is easier to maintain separate functions for each ring. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20drm/radeon: make cp variable an arrayChristian König
Replace cp, cp1 and cp2 members with just an array of radeon_cp structs. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20drm/radeon: make all functions work with multiple rings.Christian König
Give all asic and radeon_ring_* functions a radeon_cp parameter, so they know the ring to work with. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20drm/radeon/kms: add support for semaphores v3Christian König
They are used to sync between rings, while fences sync between a ring and the cpu. v2 Fix radeon_semaphore_driver_fini when no semaphore were allocated. v3 Initialize list early on to avoid issue in case or early error Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
