Linux 3.14-rc7
Backmerge to help out Intel guys.
Just move all fields into radeon_cs_reloc, removing unused/duplicated fields.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Now that Christian fixed the performance problems with
the feedback buffer in mesa, we can enable variable UVD
clocks. There are multiple UVD power states associated
with different types and numbers of streams. This uses
the appropriate state based on that information rather
than always using the fastest UVD clocks which saves some
power. One possible downside is that this may adversely
affect decode benchmarks since these power states target
specific playback requirements rather than maximum
performance. If that becomes an issue, we can add a
sysfs attribute to force the max UVD state.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Need to free the uvd ring. Also reshuffle gart tear down to
happen after uvd tear down.
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Cc: stable@vger.kernel.org
It seems this got dropped when we merged UVD support
last year. Add this back now.
Otherwise the kernel might reject our decoding requests.
Has same version of UVD as other CIK parts.
git://people.freedesktop.org/~danvet/drm-intel into drm-next
Bit a bit -fixes pull request in the merge window than usual dua to two
feauture-y things:
- Display CRCs are now enabled on all platforms, including the odd DP case
on gm45/vlv. Since this is a testing-only feature it should ever hurt,
but I figured it'll help with regression-testing -fixes. So I left it
in and didn't postpone it to 3.14.
- Display power well refactoring from Imre. Would have caused major pain
conflict with the bdw stage 1 patches if I'd postpone this to -next.
It's only an relatively small interface rework, so shouldn't cause pain.
It's also been in my tree since almost 3 weeks already.
That accounts for about two thirds of the pull, otherwise just bugfixes:
- vlv backlight fix from Jesse/Jani
- vlv vblank timestamp fix from Jesse
- improved edp detection through vbt from Ville (fixes a vlv issue)
- eDP vdd fix from Paulo
- fixes for dvo lvds on i830M
- a few smaller things all over
Note: This contains a backmerge of v3.12. Since the -internal branch
always applied on top of -nightly I need that unified base to merge bdw
patches. So you'll get a conflict with radeon connector props when pulling
this (and nouveau/master will also conflict a bit when Ben doesn't
rebase). The backmerge itself only had conflicts in drm/i915.
There's also a tiny conflict between Jani's backlight fix and your sysfs
lifetime fix in drm-next.
* tag 'drm-intel-fixes-2013-11-07' of git://people.freedesktop.org/~danvet/drm-intel: (940 commits)
drm/i915/vlv: use per-pipe backlight controls v2
drm/i915: make backlight functions take a connector
drm/i915: move opregion asle request handling to a work queue
drm/i915/vlv: use PIPE_START_VBLANK interrupts on VLV
drm/i915: Make intel_dp_is_edp() less specific
drm/i915: Give names to the VBT child device type bits
drm/i915/vlv: enable HDA display audio for Valleyview2
drm/i915/dvo: call ->mode_set callback only when the port is running
drm/i915: avoid unclaimed registers when capturing the error state
drm/i915: Enable DP port CRC for the "auto" source on g4x/vlv
drm/i915: scramble reset support for DP port CRC on vlv
drm/i915: scramble reset support for DP port CRC on g4x
drm/i916: add "auto" pipe CRC source
MAINTAINERS
drivers/gpu/drm/i915/intel_panel.c
drivers/gpu/drm/nouveau/core/subdev/mc/base.c
drivers/gpu/drm/radeon/atombios_encoders.c
drivers/gpu/drm/radeon/radeon_connectors.c
The parameter is in bytes not dwords.
Make sure the UVD clocks are still active before sending
the destroy message, otherwise the hw might hang.
This only seem to work for H.264 but not for VC-1 streams.
Need to investigate further why exactly.
This reverts commit 4b40e5921230beb1951f04d2b1b92c4c88fbad43.
Always use the regular UVD state for now. This fixes
a performance regression with UVD playback on certain APUs.
Starting with UVD3 message and feedback buffers have their
own 256MB segment, so no need to force them into VRAM any more.
Use the UVD handle information to determine which
which power states to select when using UVD. For
example, decoding a single SD stream requires much
lower clocks than multiple HD streams.
v2: switch to a cleaner dpm/uvd interface
v3: change the uvd power state while streams
are active if need be
Add a helper function for counting the number of open stream handles.
v2: fix copy-pasta in comments and whitespace error
v3: make function static since it's only used in radeon_uvd.c
at the moment
v4: make non-static again for future changes
v5: make static again for new rework of dpm uvd changes
When the message buffer is currently moving block until it is idle again.
Improve error handling in case userspace sends us
an invalid command buffer.
We also need to check the handle.
Otherwise just reinitialize from scratch on resume,
and so make it more likely to succeed.
Changing the UVD BOs offset on suspend/resume doesn't work because the VCPU
internally keeps pointers to it. Just keep it always pinned and save the
content manually.
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=66425
v2: fix compiler warning
v3: fix CIK support
Note: a version of this patch needs to go to stable.
Avoid creating temporary platform device that will lead to issue
when several radeon gpu are in same computer. Instead directly use
the radeon device for requesting firmware.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
This commit converts the source of the val_seq counter to
the ww_mutex api. The reservation objects are converted later,
because there is still a lockdep splat in nouveau that has to
resolved first.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
When using UVD, the driver must switch to a special UVD power
state. In the CS ioctl, switch to the power state and schedule
work to change the power state back, when the work comes up,
check if uvd is still busy and if not, switch back to the user
state, otherwise, reschedule the work.
Note: We really need some better way to decide when to
switch out of the uvd power state. Switching power states
while playback is active make uvd angry.
V2: fix locking.
V3: switch from timer to delayed work
V4: check fence driver for UVD jobs, reduce timeout to
1 second and rearm timeout on activity
v5: rebase on new dpm tree
v6: rebase on interim uvd on demand changes
v7: fix UVD when DPM is disabled
v8: unify non-DPM and DPM UVD handling
v9: remove leftover idle work struct
Signed-off-by: Christian König <deathsimple@vodafone.de>
v2: agd5f: fix clock dividers setup for bonaire
v3: agd5f: rebase
This fixes the kernel side so that the ring should come
up and ring and IB tests should work. The userspace
UVD drivers will also need big endian fixes.
UVD ring can't use scratch thus it does need writeback buffer to keep
a valid address or radeon_ring_backup will trigger a kernel fault.
It's ok to not unpin the write back buffer on suspend as it leave in
gtt and thus does not need eviction.
v2: Fix the uvd case.
Reported and tracked by Wojtek <wojtask9@wp.pl>
Instead of duplicating the code over and over again, just use a single
function to handle the clock calculations.
That not only saves some power, but also solves problems with
older chips where an idle UVD block on higher clocks can
cause problems.
Message and feedback buffers must be at start of
VRAM, not at start of address space.
Just until we get proper DPM for that.
Just everything needed to decode videos using UVD.
v6: just all the bugfixes and support for R7xx-SI merged in one patch
v7: UVD_CGC_GATE is a write only register, lockup detection fix
v8: split out VRAM fallback changes, remove support for RV770,
add support for HEMLOCK, add buffer sizes checks
