path: root/drivers/gpu/drm/savage
2014-09-24drm: move drm_mmap to <drm/drm_legacy.h>Daniel Vetter
Now that we've removed the copypasted users in gem/ttm we can relegate the legacy buffer mapping support to where it belongs. Also give it the proper drm_legacy_ prefix. While at it statify drm_mmap_locked, somehow I've missed that in my previous header rework. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-12drm: Move drm_memory.c map support declarations to <drm/drm_legacy.h>Daniel Vetter
And replace the drm_core_ prefix with drm_legacy_ since really, this isn't core stuff. Also drop drm_core_dropmap since it's unused. v2: Fix up i810.ko fully which somehow slipped through. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-09-12drm: Create drm legacy driver headerDaniel Vetter
And move a few legayc functions to start things over there. It compiles ... Inspired by a patch from Dave Airlie, but with a split between drm.ko private legacy functions and stuff used by drivers. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-09-10drm: move drm-lock API to drm_legacy.hDavid Herrmann
Same as the other legacy APIs, most of this is internal, so prefix it with drm_legacy_* and move into drm_legacy.h. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-10drm: add driver->set_busid() callbackDavid Herrmann
One step closer to dropping all the drm_bus_* code: Add a driver->set_busid() callback and make all drivers use the generic helpers. Nouveau is the only driver that uses two different bus-types with the same drm_driver. This is totally broken if both buses are available on the same machine (unlikely, but lets be safe). Therefore, we create two different drivers for each platform during module_init() and set the set_busid() callback respectively. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-09-10drm: mark drm_buf and drm_map as legacyDavid Herrmann
Move internal declarations to drm_legacy.h and add drm_legacy_*() prefix to all legacy functions. [airlied: add a bit of an explaination to drm_legacy.h] Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-10drm: Remove DRM_ARRAY_SIZE() for ARRAY_SIZE()Damien Lespiau
I cannot see a need to provide a DRM_ version of ARRAY_SIZE(), only used in a few places. I suspect its usage has been spread by copy & paste rather than anything else. Let's just remove it for plain ARRAY_SIZE(). Signed-off-by: Damien Lespiau <damien.lespiau@intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-12-18drm: Kill DRM_*MEMORYBARRIERDaniel Vetter
The real linux interfaces are soooo much easier on the eyes ... Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-12-18drm: Kill DRM_COPY_(TO|FROM)_USERDaniel Vetter
Less yelling ftw! Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-19drm: rip out drm_core_has_MTRR checksDaniel Vetter
The new arch_phys_wc_add/del functions do the right thing both with and without MTRR support in the kernel. So we can drop these additional checks. David Herrmann suggest to also kill the DRIVER_USE_MTRR flag since it's now unused, which spurred me to do a bit a better audit of the affected drivers. David helped a lot in that. Quoting our mail discussion: On Wed, Jul 10, 2013 at 5:41 PM, David Herrmann <dh.herrmann@gmail.com> wrote: > On Wed, Jul 10, 2013 at 5:22 PM, Daniel Vetter <daniel.vetter@ffwll.ch> wrote: >> On Wed, Jul 10, 2013 at 3:51 PM, David Herrmann <dh.herrmann@gmail.com> wrote: >>>> -#if __OS_HAS_MTRR >>>> -static inline int drm_core_has_MTRR(struct drm_device *dev) >>>> -{ >>>> - return drm_core_check_feature(dev, DRIVER_USE_MTRR); >>>> -} >>>> -#else >>>> -#define drm_core_has_MTRR(dev) (0) >>>> -#endif >>>> - >>> >>> That was the last user of DRIVER_USE_MTRR (apart from drivers setting >>> it in .driver_features). Any reason to keep it around? >> >> Yeah, I guess we could rip things out. Which will also force me to >> properly audit drivers for the eventual behaviour change this could >> entail (in case there's an x86 driver which did not ask for an mtrr, >> but iirc there isn't). > > david@david-mb ~/dev/kernel/linux $ for i in drivers/gpu/drm/* ; do if > test -d "$i" ; then if ! grep -q USE_MTRR -r $i ; then echo $i ; fi ; > fi ; done > drivers/gpu/drm/exynos > drivers/gpu/drm/gma500 > drivers/gpu/drm/i2c > drivers/gpu/drm/nouveau > drivers/gpu/drm/omapdrm > drivers/gpu/drm/qxl > drivers/gpu/drm/rcar-du > drivers/gpu/drm/shmobile > drivers/gpu/drm/tilcdc > drivers/gpu/drm/ttm > drivers/gpu/drm/udl > drivers/gpu/drm/vmwgfx > david@david-mb ~/dev/kernel/linux $ > > So for x86 gma500,nouveau,qxl,udl,vmwgfx don't set DRIVER_USE_MTRR. > But I cannot tell whether they break if we call arch_phys_wc_add/del, > anyway. At least nouveau seemed to work here, but it doesn't use AGP > or drm_bufs, I guess. Cool, thanks a lot for stitching together the list of drivers to look at. So for real KMS drivers it's the drives responsibility to add an mtrr if it needs one. nouvea, radeon, mgag200, i915 and vmwgfx do that already. Somehow the savage driver also ends up doing that, I have no idea why. Note that gma500 as a pure KMS driver doesn't need MTRR setup since the platforms that it supports all support PAT. So no MTRRs needed to get wc iomappings. The mtrr support in the drm core is all for legacy mappings of garts, framebuffers and registers. All legacy drivers set the USE_MTRR flag, so we're good there. All in all I think we can really just ditch this /endquote v2: Also kill DRIVER_USE_MTRR as suggested by David Herrmann v3: Rebase on top of David Herrmann's agp setup/cleanup changes. Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-19drm: remove FASYNC supportDaniel Vetter
So I've stumbled over drm_fasync and wondered what it does. Digging that up is quite a story. First I've had to read up on what this does and ended up being rather bewildered why peopled loved signals so much back in the days that they've created SIGIO just for that ... Then I wondered how this ever works, and what that strange "No-op." comment right above it should mean. After all calling the core fasync helper is pretty obviously not a noop. After reading through the kernels FASYNC implementation I've noticed that signals are only sent out to the processes attached with FASYNC by calling kill_fasync. No merged drm driver has ever done that. After more digging I've found out that the only driver that ever used this is the so called GAMMA driver. I've frankly never heard of such a gpu brand ever before. Now FASYNC seems to not have been the only bad thing with that driver, since Dave Airlie removed it from the drm driver with prejudice: commit 1430163b4bbf7b00367ea1066c1c5fe85dbeefed Author: Dave Airlie <airlied@linux.ie> Date: Sun Aug 29 12:04:35 2004 +0000 Drop GAMMA DRM from a great height ... Long story short, the drm fasync support seems to be doing absolutely nothing. And the only user of it was never merged into the upstream kernel. And we don't need any fops->fasync callback since the fcntl implementation in the kernel already implements the noop case correctly. So stop this particular cargo-cult and rip it all out. v2: Kill drm_fasync assignments in rcar (newly added) and imx drivers (somehow I've missed that one in staging). Also drop the reference in the drm DocBook. ARM compile-fail reported by Rob Clark. v3: Move the removal of dev->buf_asnyc assignment in drm_setup to this patch here. v4: Actually git add ... tsk. Cc: Dave Airlie <airlied@linux.ie> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Rob Clark <robdclark@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-07drm: const'ify ioctls table (v2)Rob Clark
Because, there is no reason for it not to be const. v1: original v2: fix compile break in vmwgfx, and couple related cleanups suggested by Ville Syrjälä Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-05-31drm (ast, cirrus, mgag200, nouveau, savage, vmwgfx): Remove drm_mtrr_{add, del}Andy Lutomirski
This replaces drm_mtrr_{add,del} with arch_phys_wc_{add,del}. The interface is simplified (because the base and size parameters to drm_mtrr_del never did anything), and it no longer adds MTRRs on systems that don't need them. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-10-03Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm merge (part 1) from Dave Airlie: "So first of all my tree and uapi stuff has a conflict mess, its my fault as the nouveau stuff didn't hit -next as were trying to rebase regressions out of it before we merged. Highlights: - SH mobile modesetting driver and associated helpers - some DRM core documentation - i915 modesetting rework, haswell hdmi, haswell and vlv fixes, write combined pte writing, ilk rc6 support, - nouveau: major driver rework into a hw core driver, makes features like SLI a lot saner to implement, - psb: add eDP/DP support for Cedarview - radeon: 2 layer page tables, async VM pte updates, better PLL selection for > 2 screens, better ACPI interactions The rest is general grab bag of fixes. So why part 1? well I have the exynos pull req which came in a bit late but was waiting for me to do something they shouldn't have and it looks fairly safe, and David Howells has some more header cleanups he'd like me to pull, that seem like a good idea, but I'd like to get this merge out of the way so -next dosen't get blocked." Tons of conflicts mostly due to silly include line changes, but mostly mindless. A few other small semantic conflicts too, noted from Dave's pre-merged branch. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (447 commits) drm/nv98/crypt: fix fuc build with latest envyas drm/nouveau/devinit: fixup various issues with subdev ctor/init ordering drm/nv41/vm: fix and enable use of "real" pciegart drm/nv44/vm: fix and enable use of "real" pciegart drm/nv04/dmaobj: fixup vm target handling in preparation for nv4x pcie drm/nouveau: store supported dma mask in vmmgr drm/nvc0/ibus: initial implementation of subdev drm/nouveau/therm: add support for fan-control modes drm/nouveau/hwmon: rename pwm0* to pmw1* to follow hwmon's rules drm/nouveau/therm: calculate the pwm divisor on nv50+ drm/nouveau/fan: rewrite the fan tachometer driver to get more precision, faster drm/nouveau/therm: move thermal-related functions to the therm subdev drm/nouveau/bios: parse the pwm divisor from the perf table drm/nouveau/therm: use the EXTDEV table to detect i2c monitoring devices drm/nouveau/therm: rework thermal table parsing drm/nouveau/gpio: expose the PWM/TOGGLE parameter found in the gpio vbios table drm/nouveau: fix pm initialization order drm/nouveau/bios: check that fixed tvdac gpio data is valid before using it drm/nouveau: log channel debug/error messages from client object rather than drm client drm/nouveau: have drm debugging macros build on top of core macros ...
2012-10-03drm/savage: re-add busmaster enable, regression fixFlorian Zumbiehl
466e69b8b03b8c1987367912782bc12988ad8794 dropped busmaster enable from the global drm code and moved it to the individual drivers, but missed the savage driver. So, this re-adds busmaster enable to the savage driver, fixing the regression. Signed-off-by: Florian Zumbiehl <florz@florz.de> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/David Howells
Convert #include "..." to #include <path/...> in drivers/gpu/. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-09-06drm: use drm_compat_ioctl for 32-bit appsKeith Packard
Most of the DRM drivers appear to be missing the .compat_ioctl file operation entry necessary for 32-bit application compatibility. This patch uses drm_compat_ioctl for all drivers which don't have their own, and which are using drm_ioctl for .unlocked_ioctl. This leaves drivers/gpu/drm/psb/psb_drv.c unchanged; it has a custom .unlocked_ioctl and will presumably need a custom .compat_ioctl as well. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Dave Airlie <airlied@gmail.com>
2012-07-19drm/savage: clean up reclaim_buffersDaniel Vetter
The reclaim_buffers function of the savage driver actually wants to run with the hw_lock held - at least there are printks in the call-chain to that effect. But the drm core only calls reclaim_buffers as used by savage _after_ forcefully dropping the hwlock (in case it's still hold by the closing fd). So do the same idlelock dance as for the other dma drivers and hope that papers over any issues. v2: Don't let the idlelock linger around. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Tested-by: Tormod Volden <debian.tormod@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-17drm: checking the wrong variable in savage_do_init_bci()Dan Carpenter
drm_core_ioremap() initializes ->handle. We already know "dev->agp_buffer_map" is a valid pointer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-04-10drm/savage: fix integer overflows in savage_bci_cmdbuf()Xi Wang
Since cmdbuf->size and cmdbuf->nbox are from userspace, a large value would overflow the allocation size, leading to out-of-bounds access. Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drivers/gpu/drm/savage/savage_state.c: add missing kfreeJulia Lawall
Most of the error handling code in this function frees the buffers kcmd_addr, kvb_addr, and kbox_addr allocated at the beginning of this function. These two branches are changed to do the same. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-11-11drm: Make the per-driver file_operations struct constArjan van de Ven
From fdf1fdebaa00f81de18c227f32f8074c8b352d50 Mon Sep 17 00:00:00 2001 From: Arjan van de Ven <arjan@linux.intel.com> Date: Sun, 30 Oct 2011 19:06:07 -0700 Subject: [PATCH] drm: Make the per-driver file_operations struct const The DRM layer keeps a copy of struct file_operations inside its big driver struct... which prevents it from being consistent and static. For consistency (and the general security objective of having such things static), it's desirable to get this fixed. This patch splits out the file_operations field to its own struct, which is then "static const", and just stick a pointer to this into the driver struct, making it more consistent with how the rest of the kernel does this. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-31gpu: add module.h to drivers/gpu files as required.Paul Gortmaker
So that we don't get build failures once the implicit module.h presence is removed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-14savage: remove unnecessary if statementGreg Dietsche
the code always returns ret regardless, so if(ret) check is unnecessary. v2: fixed up the spelling. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Reviewed-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-07drm: rework PCI/platform driver interface.Dave Airlie
This abstracts the pci/platform interface out a step further, we can go further but this is far enough for now to allow USB to be plugged in. The drivers now just call the init code directly for their device type. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits) vmwgfx: Implement a proper GMR eviction mechanism drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2 drm/radeon/kms: properly compute group_size on 6xx/7xx drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker drm/radeon/kms/evergreen: set the clear state to the blit state drm/radeon/kms: don't poll dac load detect. gpu: Add Intel GMA500(Poulsbo) Stub Driver drm/radeon/kms: MC vram map needs to be >= pci aperture size drm/radeon/kms: implement display watermark support for evergreen drm/radeon/kms/evergreen: add some additional safe regs v2 drm/radeon/r600: fix tiling issues in CS checker. drm/i915: Move gpu_write_list to per-ring drm/i915: Invalidate the to-ring, flush the old-ring when updating domains drm/i915/ringbuffer: Write the value passed in to the tail register agp/intel: Restore valid PTE bit for Sandybridge after bdd3072 drm/i915: Fix flushing regression from 9af90d19f drm/i915/sdvo: Remove unused encoding member i915: enable AVI infoframe for intel_hdmi.c [v4] drm/i915: Fix current fb blocking for page flip drm/i915: IS_IRONLAKE is synonymous with gen == 5 ... Fix up conflicts in - drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the new simplified stack-based kmap_atomic() interface - drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL removal cleanups.
2010-09-16drm: use noop_llseekArnd Bergmann
The drm device drivers currently allow seeking on the character device but never care about the actual file position. When we change the default llseek operation to be no_llseek, calling llseek on a drm device would return an error condition, which is an API change. Explicitly setting noop_llseek lets us keep the current API. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.freedesktop.org
2010-08-30drm: kill get_reg_ofs callbackDaniel Vetter
Every driver used the default implementation. Fold that one into the only callsite and drop the callback. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-30drm: kill drm_map_ofs callbacksDaniel Vetter
All drivers happily copy&pasted the default implementation without checking whether this callback is used at all. It's not. Sigh. Kill it. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-23Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (33 commits) drm/radeon/kms: fix typo in radeon_compute_pll_gain drm/radeon/kms: try to detect tv vs monitor for underscan drm/radeon/kms: fix sideport detection on newer rs880 boards drm/radeon: fix passing wrong type to gem object create. drm/radeon/kms: set encoder type to DVI for HDMI on evergreen drm/radeon/kms: add back missing break in info ioctl drm/radeon/kms: don't enable MSIs on AGP boards drm/radeon/kms: fix agp mode setup on cards that use pcie bridges drm: move dereference below check drm: fix end of loop test drm/radeon/kms: rework radeon_dp_detect() logic drm/radeon/kms: add missing asic callback assignment for evergreen drm/radeon/kms/DCE3+: switch pads to ddc mode when going i2c drm/radeon/kms/pm: bail early if nothing's changing drm/radeon/kms/atom: clean up dig atom handling drm/radeon/kms: DCE3/4 transmitter fixes drm/radeon/kms: rework encoder handling drm/radeon/kms: DCE3/4 AdjustPixelPll updates drm/radeon: Fix stack data leak drm/radeon/kms: fix GTT/VRAM overlapping test ...
2010-08-17drm: block userspace under allocating buffer and having drivers overwrite it ↵Dave Airlie
(v2) With the current screwed but its ABI, ioctls for the drm, Linus pointed out that we could allow userspace to specify the allocation size, but we pass it to the driver which then uses it blindly to store a struct. Now if userspace specifies the allocation size as smaller than the driver needs, the driver can possibly overwrite memory. This patch restructures the driver ioctls so we store the structure size we are expecting, and make sure we allocate at least that size. The copy from/to userspace are still restricted to the size the user specifies, this allows ioctl structs to grow on both sides of the equation. Up until now we didn't really use the DRM_IOCTL defines in the kernel, so this cleans them up and adds them for nouveau. v2: fix nouveau pushbuf arg (thanks to Ben for pointing it out) Reported-by: Linus Torvalds <torvalds@linuxfoundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-05Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (204 commits) agp: intel-agp: do not use PCI resources before pci_enable_device() agp: efficeon-agp: do not use PCI resources before pci_enable_device() drm: kill BKL from common code drm/kms: Simplify setup of the initial I2C encoder config. drm,io-mapping: Specify slot to use for atomic mappings drm/radeon/kms: only expose underscan on avivo chips drm/radeon: add new pci ids drm: Cleanup after failing to create master->unique and dev->name drm/radeon: tone down overchatty acpi debug messages. drm/radeon/kms: enable underscan option for digital connectors drm/radeon/kms: fix calculation of h/v scaling factors drm/radeon/kms/igp: sideport is AMD only drm/radeon/kms: handle the case of no active displays properly in the bandwidth code drm: move ttm global code to core drm drm/i915: Clear the Ironlake dithering flags when the pipe doesn't want it. drm/radeon/kms: make sure HPD is set to NONE on analog-only connectors drm/radeon/kms: make sure rio_mem is valid before unmapping it drm/agp/i915: trim stolen space to 32M drm/i915: Unset cursor if out-of-bounds upon mode change (v4) drm/i915: Unreference object not handle on creation ...
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-01drm: Remove drm_resource wrappersJordan Crouse
Remove the drm_resource wrappers and directly use the actual PCI and/or platform functions in their place. [airlied: fixup nouveau properly to build] Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org> Reviewed-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drivers/gpu/drm: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Reviewed-by: Corbin Simpson <MostAwesomeDude@gmail.com> Reviewed-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-18drm: convert drm_ioctl to unlocked_ioctlArnd Bergmann
drm_ioctl is called with the Big Kernel Lock held, which shows up very high in statistics on vfs_ioctl. Moving the lock into the drm_ioctl function itself makes sure we blame the right subsystem and it gets us one step closer to eliminating the locked version of fops->ioctl. Since drm_ioctl does not require the lock itself, we only need to hold it while calling the specific handler. The 32 bit conversion handlers do not interact with any other code, so they don't need the BKL here either and can just call drm_ioctl. As a bonus, this cleans up all the other users of drm_ioctl which now no longer have to find the inode or call lock_kernel. [airlied: squashed the non-driver bits of the second patch in here, this provides the flag for drivers to use to select unlocked ioctls - but doesn't modify any drivers]. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.sourceforge.net Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-18drm: Remove memory debugging infrastructure.Eric Anholt
It hasn't been used in ages, and having the user tell your how much memory is being freed at free time is a recipe for disaster even if it was ever used. Signed-off-by: Eric Anholt <eric@anholt.net>
2009-03-13drm: Use resource_size_t for drm_get_resource_{start, len}Benjamin Herrenschmidt
The DRM uses its own wrappers to obtain resources from PCI devices, which currently convert the resource_size_t into an unsigned long. This is broken on 32-bit platforms with >32-bit physical address space. This fixes them, along with a few occurences of unsigned long used to store such a resource in drivers. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
