[ Upstream commit 35681862808472a0a4b9a8817ae2789c0b5b3edc ]
Once channel's job is hung, it dumps the channel's state into KMSG before
tearing down the offending job. If multiple channels hang at once, then
they dump messages simultaneously, making the debug info unreadable, and
thus, useless. This patch adds mutex which allows only one channel to emit
debug messages at a time.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit d9a0a05bf8c76e6dc79230669a8b5d685b168c30 ]
Currently when a host1x device driver is unregistered, it is not
detached from the host1x controller, which means that the device
will stay around and when the driver is registered again, it may
bind to the old, stale device rather than the new one that was
created from scratch upon driver registration. This in turn can
cause various weird crashes within the driver core because it is
confronted with a device that was already deleted.
Fix this by detaching the driver from the host1x controller when
it is unregistered. This ensures that the deleted device also is
no longer present in the device list that drivers will bind to.
Reported-by: Sowjanya Komatineni <skomatineni@nvidia.com>
Tested-by: Sowjanya Komatineni <skomatineni@nvidia.com>
[ Upstream commit b78e70c04c149299bd210759d7c7af7c86b89ca8 ]
Currently when the gather buffers are copied, they are copied to a
buffer that is allocated for the host1x client that wants to execute the
command streams in the buffers. However, the gather buffers will be read
by the host1x device, which causes SMMU faults if the DMA API is backed
by an IOMMU.
Fix this by allocating the gather buffer copy for the host1x device,
which makes sure that it will be mapped into the host1x's IOVA space if
the DMA API is backed by an IOMMU.
git://anongit.freedesktop.org/tegra/linux into drm-next
drm/tegra: Changes for v5.3-rc1
This contains a couple of small improvements and cleanups for the Tegra
DRM driver.
Link: https://patchwork.freedesktop.org/patch/msgid/20190621150753.19550-1-thierry.reding@gmail.com
So there is no need to check for a value that can never happen. No need
to check the return value all anyway, as any debugfs call can take the
result of this function as an option just fine.
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: dri-devel@lists.freedesktop.org
Cc: linux-tegra@vger.kernel.org
Based on 1 normalized pattern(s):
this software is licensed under the terms of the gnu general public
license version 2 as published by the free software foundation and
may be copied distributed and modified under those terms this
program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
merchantability or fitness for a particular purpose see the gnu
general public license for more details
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 285 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190529141900.642774971@linutronix.de
Logical devices created by the host1x bus infrastructure don't need to
be associated with a device tree node. Doing so will cause the driver
core to attempt to hook up IOMMU operations and fail because it is not
a real device.
However, for backwards-compatibility, we need to provide various OF_*
uevent variables that were previously provided by of_device_uevent() and
which are parsed by libdrm in userspace when querying the available
devices. Do this by implementing a uevent callback for the host1x bus.
Recent versions of the DMA API debug code have started to warn about
violations of the maximum DMA segment size. This is because the segment
size defaults to 64 KiB, which can easily be exceeded in large buffer
allocations such as used in DRM/KMS for framebuffers.
Technically the Tegra SMMU and ARM SMMU don't have a maximum segment
size (they map individual pages irrespective of whether they are
contiguous or not), so the choice of 4 MiB is a bit arbitrary here. The
maximum segment size is a 32-bit unsigned integer, though, so we can't
set it to the correct maximum size, which would be the size of the
aperture.
When deferring probe, avoid logging a confusing error message. While at
it, make the error message more informational.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
this program is free software you can redistribute it and or modify
it under the terms and conditions of the gnu general public license
version 2 as published by the free software foundation this program
is distributed in the hope it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not see http www gnu org
licenses
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 228 file(s).
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Link: https://lkml.kernel.org/r/20190528171438.107155473@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
If SMMU support is not available, fall back to programming the bypass
stream ID (0x7f).
Fixes: de5469c21ff9 ("gpu: host1x: Program the channel stream ID")
Suggested-by: Mikko Perttunen <mperttunen@nvidia.com>
Reviewed-by: Mikko Perttunen <mperttunen@nvidia.com>
[treding@nvidia.com: rebase this on top of a later build fix]
In case the IOMMU API is not available compiling host1x fails with
the following error:
In file included from drivers/gpu/host1x/hw/host1x06.c:27:
drivers/gpu/host1x/hw/channel_hw.c: In function ‘host1x_channel_set_streamid’:
drivers/gpu/host1x/hw/channel_hw.c:118:30: error: implicit declaration of function
‘dev_iommu_fwspec_get’; did you mean ‘iommu_fwspec_free’? [-Werror=implicit-function-declaration]
struct iommu_fwspec *spec = dev_iommu_fwspec_get(channel->dev->parent);
iommu_fwspec_free
Signed-off-by: Stefan Agner <stefan@agner.ch>
Currently gathers of a hung job are getting NOP'ed and a restarted CDMA
executes the NOP'ed gathers. There shouldn't be a reason to not restart
CDMA execution starting with a next job, avoiding the unnecessary churning
with gathers NOP'ing.
There is a chance that the last job has been completed at the time of
CDMA timeout handler invocation. In this case there is no need to complete
the completed job.
Host1x doesn't have information about jobs inter-dependency, that is
something that will become available once host1x will get a proper
jobs scheduler implementation. Currently a hang job causes other unrelated
jobs to be canceled, that is a relic from downstream driver which is
irrelevant to upstream. Let's cancel only the hanging job and not to touch
other jobs in queue.
The host1x CDMA push buffer is terminated by a special opcode (RESTART)
that tells the CDMA to wrap around to the beginning of the push buffer.
To accomodate the RESTART opcode, an extra 4 bytes are allocated on top
of the 512 * 8 = 4096 bytes needed for the 512 slots (1 slot = 2 words)
that are used for other commands passed to CDMA. This requires that two
memory pages are allocated, but most of the second page (4092 bytes) is
never used.
Decrease the number of slots to 511 so that the RESTART opcode fits
within the page. Adjust the push buffer wraparound code to take into
account push buffer sizes that are not a power of two.
The HOST1X_CHANNEL_DMAEND is an offset relative to the value written to
the HOST1X_CHANNEL_DMASTART register, but it is currently treated as an
absolute address. This can cause SMMU faults if the CDMA fetches past a
pushbuffer's IOMMU mapping.
Properly setting the DMAEND prevents the CDMA from fetching beyond that
address and avoid such issues. This is currently not observed because a
whole (almost) page of essentially scratch space absorbs any excessive
prefetching by CDMA. However, changing the number of slots in the push
buffer can trigger these SMMU faults.
The host1x and clients instantiated on Tegra186 support addressing 40
bits of memory.
On Tegra186 and later, the ARM SMMU provides an input address space that
is 48 bits wide. However, memory clients can only address up to 40 bits.
If the geometry is used as-is, allocations of IOVA space can end up in a
region that is not addressable by the memory clients.
To fix this, restrict the IOVA space to the DMA mask of the host1x
device.
Tegra186 and later support 40 bits of address space. Additional
registers need to be programmed to store the full 40 bits of push
buffer addresses.
Since command stream gathers can also reside in buffers in a 40-bit
address space, a new variant of the GATHER opcode is also introduced.
It takes two parameters: the first parameter contains the lower 32
bits of the address and the second parameter contains bits 32 to 39.
The CDMA push buffer can currently only handle opcodes that take a
single word parameter. However, the host1x implementation on Tegra186
and later supports opcodes that require multiple words as parameters.
Unfortunately the way the push buffer is structured, these wide opcodes
cannot simply be composed of two regular opcodes because that could
result in the wide opcode being split across the end of the push buffer
and the final RESTART opcode required to wrap the push buffer around
would break the wide opcode.
One way to fix this would be to remove the concept of slots to simplify
push buffer operations. However, that's not entirely trivial and should
be done in a separate patch. For now, simply use a different function
to push four-word opcodes into the push buffer. Technically only three
words are pushed, with the fourth word used as padding to preserve the
2-word alignment required by the slots abstraction. The fourth word is
always a NOP opcode.
Additional care must be taken when the end of the push buffer is
reached. If a four-word opcode doesn't fit into the push buffer without
being split by the boundary, NOP opcodes will be introduced and the new
wide opcode placed at the beginning of the push buffer.
When processing command streams, make sure the host1x's stream ID is
programmed for the channel so that addresses are properly translated
through the SMMU.
In order to enable the MMIO path stream ID protection provided by the
incarnation of host1x found in Tegra186 and later, the host1x must be
provided with the list of stream ID register offsets for each of its
clients. Some clients (such as VIC) have multiple stream ID registers
that are assumed to be contiguous. The host1x is programmed with the
base offset and a limit which provide the range of registers that the
host1x needs to monitor for writes.
This new debugfs file represents the state of host1x bus devices,
specifying the list of subdevices and marking which ones have
successfully registered.
In this usage, the two are completely equivalent, but the completion
documents better what is going on, and we generally try to avoid
semaphores these days.
The host1x hardware found on Tegra194 is mostly backwards compatible
with the version found on Tegra186, with the notable exceptions of the
increased number of syncpoints and mlocks. In addition, some rarely
used features such as syncpoint wait bases were dropped and some
registers had to move around to accomodate the increased number of
syncpoints.
The number of syncpoints on Tegra186 is 576 and therefore no longer fits
into 8 bits. Increase the size of the syncpoint ID field to 10 in order
to accomodate all syncpoints.
The register region allocated per channel was decreased from 16384 bytes
to 256 bytes on Tegra186 and later. Resize the region to make sure every
channel (instead of only the first) is properly programmed.
Host1x is getting attached to an implicit IOMMU DMA domain if
CONFIG_ARM_DMA_USE_IOMMU=y. Since Host1x driver manages IOMMU by
itself, Host1x device must be detached from the implicit domain using
arch-specific IOMMU-API.
All other assignments have a single space around the = sign, so remove
the spurious tab for consistency.
Only gather pins are mapped by the Host1x driver, regular BO relocations
are not. Check whether size of unpin isn't 0, otherwise IOVA allocation at
0x0 could be erroneously released.
Host1x's CDMA can't access the command buffers if IOMMU and Host1x
firewall are enabled in the kernels config because firewall doesn't map
the copied buffer into IOVA space. Fix this by skipping IOMMU
initialization if firewall is enabled as firewall merges sparse cmdbufs
into a single contiguous buffer and hence IOMMU isn't needed in this case.
Pull drm updates from Dave Airlie:
"This starts to support NVIDIA volta hardware with nouveau, and adds
amdgpu support for the GPU in the Kabylake-G (the intel + radeon
single package chip), along with some initial Intel icelake enabling.
Summary:
New Drivers:
- v3d - driver for broadcom V3D V3.x+ hardware
- xen-front - XEN PV display frontend
core:
- handle zpos normalization in the core
- stop looking at legacy pointers in atomic paths
- improved scheduler documentation
- improved aspect ratio validation
- aspect ratio support for 64:27 and 256:135
- drop unused control node code.
i915:
- Icelake (ICL) enabling
- GuC/HuC refactoring
- PSR/PSR2 enabling and fixes
- DPLL management refactoring
- DP MST fixes
- NV12 enabling
- HDCP improvements
- GEM/Execlist/reset improvements
- GVT improvements
- stolen memory first 4k fix
amdgpu:
- Vega 20 support
- VEGAM support (Kabylake-G)
- preOS scanout buffer reservation
- power management gfxoff support for raven
- SR-IOV fixes
- Vega10 power profiles and clock voltage control
- scatter/gather display support on CZ/ST
amdkfd:
- GFX9 dGPU support
- userptr memory mapping
nouveau:
- major refactoring for Volta GV100 support
tda998x:
- HDMI i2c CEC support
etnaviv:
- removed unused logging code
- license text cleanups
- MMU handling improvements
- timeout fence fix for 50 days uptime
tegra:
- IOMMU support in gr2d/gr3d drivers
- zpos support
vc4:
- syncobj support
- CTM, plane alpha and async cursor support
analogix_dp:
- HPD and aux chan fixes
sun4i:
- MIPI DSI support
tilcdc:
- clock divider fixes for OMAP-l138 LCDK board
rcar-du:
- R8A77965 support
- dma-buf fences fixes
- hardware indexed crtc/du group handling
- generic zplane property support
atmel-hclcdc:
mediatek:
- use generic video mode function
exynos:
- S5PV210 FIMD variant support
- IPP v2 framework
- more HW overlays support"
* tag 'drm-next-2018-06-06-1' of git://anongit.freedesktop.org/drm/drm: (1286 commits)
drm/amdgpu: fix 32-bit build warning
drm/exynos: fimc: signedness bug in fimc_setup_clocks()
drm/exynos: scaler: fix static checker warning
drm/amdgpu: Use dev_info() to report amdkfd is not supported for this ASIC
drm/amd/display: Remove use of division operator for long longs
drm/amdgpu: Update GFX info structure to match what vega20 used
drm/amdgpu/pp: remove duplicate assignment
drm/sched: add rcu_barrier after entity fini
drm/amdgpu: move VM BOs on LRU again
drm/amdgpu: consistenly use VM moved flag
drm/amdgpu: kmap PDs/PTs in amdgpu_vm_update_directories
drm/amdgpu: further optimize amdgpu_vm_handle_moved
drm/amdgpu: cleanup amdgpu_vm_validate_pt_bos v2
drm/amdgpu: rework VM state machine lock handling v2
drm/amdgpu: Add runtime VCN PG support
drm/amdgpu: Enable VCN static PG by default on RV
drm/amdgpu: Add VCN static PG support on RV
drm/amdgpu: Enable VCN CG by default on RV
drm/amdgpu: Add static CG control for VCN on RV
drm/exynos: Fix default value for zpos plane property
The number of words and the offset in a gather don't need to be
explicitly sized, so make them unsigned int instead.
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Tested-by: Dmitry Osipenko <digetx@gmail.com>
All other array variables use a plural, and this is the only one using
the *array suffix. This is confusing, so rename it for consistency.
Functions taking a pointer to a host1x syncpoint as an argument don't
need to specify a pointer to a host1x instance because it can be
obtained from the syncpoint.
Use unsigned int where possible and don't unnecessarily initialize the
loop variable.
Rather than storing some identifier derived from the application
context that can't be used concretely anywhere, store a pointer to the
client directly so that accesses can be made directly through that
client object.
The job submission userspace ABI doesn't support this and there are no
plans to implement it, so all of this code is dead and can be removed.
The compiler is complaining with the following errors:
drivers/gpu/host1x/cdma.c:94:48: error:
passing argument 3 of ‘dma_alloc_wc’ from incompatible pointer type
[-Werror=incompatible-pointer-types]
drivers/gpu/host1x/cdma.c:113:48: error:
The expected pointer type of the third argument to dma_alloc_wc() is
dma_addr_t but phys_addr_t is passed.
Change the phys member of struct push_buffer to be dma_addr_t so that we
pass the correct type to dma_alloc_wc().
Also check pb->mapped for non-NULL in the destroy function as that is the
right way of checking if dma_alloc_wc() was successful.
Signed-off-by: Emil Goode <emil.fsw@goode.io>
The IOVA API uses a memory cache to allocate IOVA nodes from. To make
sure that this cache is available, obtain a reference to it and release
the reference when the cache is no longer needed.
On 64-bit ARM this is hidden by the fact that the DMA mapping API gets
that reference and never releases it. On 32-bit ARM, this is papered
over by the Tegra DRM driver (the sole user of the host1x API requiring
the cache) acquiring a reference to the IOVA cache for its own purposes.
However, there may be additional users of this API in the future, so fix
this upfront to avoid surprises.
Fixes: 404bfb78daf3 ("gpu: host1x: Add IOMMU support")
If IOVA allocation or IOMMU mapping fails, dma_free_wc() is invoked with
size=0 because of a typo, that triggers "kernel BUG at mm/vmalloc.c:124!".
With each bus implementing its own DMA configuration callback, there is no
need for bus to explicitly set the force_dma flag. Modify the
of_dma_configure function to accept an input parameter which specifies if
implicit DMA configuration is required when it is not described by the
firmware.
Signed-off-by: Nipun Gupta <nipun.gupta@nxp.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> # PCI parts
Reviewed-by: Rob Herring <robh@kernel.org>
[hch: tweaked the changelog a bit]
ACPI/OF support for configuration of DMA is a bus specific aspect, and
thus should be configured by the bus. Introduces a 'dma_configure' bus
method so that busses can control their DMA capabilities.
Also update the PCI, Platform, ACPI and host1x buses to use the new
method.
Suggested-by: Christoph Hellwig <hch@lst.de>
Acked-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[hch: simplified host1x_dma_configure based on a comment from Thierry,
rewrote changelog]
Use IOMMU groups to attach the host1x device to its IOMMU domain. This
is not strictly necessary because the domain isn't shared with any other
device, but it makes the code consistent with how IOMMU is handled in
other drivers and provides an easy way to detect when no IOMMU has been
attached via device tree.
When an error happens during the initialization of one of the sub-
devices, make sure to properly cleanup all sub-devices that have been
initialized up to that point.
The current check is slightly difficult to read, rewrite it to improve
that a little.
"This is the main drm pull request for v4.15.
Core:
- Atomic object lifetime fixes
- Atomic iterator improvements
- Sparse/smatch fixes
- Legacy kms ioctls to be interruptible
- EDID override improvements
- fb/gem helper cleanups
- Simple outreachy patches
- Documentation improvements
- Fix dma-buf rcu races
- DRM mode object leasing for improving VR use cases.
- vgaarb improvements for non-x86 platforms.
New driver:
- tve200: Faraday Technology TVE200 block.
This "TV Encoder" encodes a ITU-T BT.656 stream and can be found in
the StorLink SL3516 (later Cortina Systems CS3516) as well as the
Grain Media GM8180.
New bridges:
- SiI9234 support
New panels:
- S6E63J0X03, OTM8009A, Seiko 43WVF1G, 7" rpi touch panel, Toshiba
LT089AC19000, Innolux AT043TN24
i915:
- Remove Coffeelake from alpha support
- Cannonlake workarounds
- Infoframe refactoring for DisplayPort
- VBT updates
- DisplayPort vswing/emph/buffer translation refactoring
- CCS fixes
- Restore GPU clock boost on missed vblanks
- Scatter list updates for userptr allocations
- Gen9+ transition watermarks
- Display IPC (Isochronous Priority Control)
- Private PAT management
- GVT: improved error handling and pci config sanitizing
- Execlist refactoring
- Transparent Huge Page support
- User defined priorities support
- HuC/GuC firmware refactoring
- DP MST fixes
- eDP power sequencing fixes
- Use RCU instead of stop_machine
- PSR state tracking support
- Eviction fixes
- BDW DP aux channel timeout fixes
- LSPCON fixes
- Cannonlake PLL fixes
amdgpu:
- Per VM BO support
- Powerplay cleanups
- CI powerplay support
- PASID mgr for kfd
- SR-IOV fixes
- initial GPU reset for vega10
- Prime mmap support
- TTM updates
- Clock query interface for Raven
- Fence to handle ioctl
- UVD encode ring support on Polaris
- Transparent huge page DMA support
- Compute LRU pipe tweaks
- BO flag to allow buffers to opt out of implicit sync
- CTX priority setting API
- VRAM lost infrastructure plumbing
qxl:
- fix flicker since atomic rework
amdkfd:
- Further improvements from internal AMD tree
- Usermode events
- Drop radeon support
nouveau:
- Pascal temperature sensor support
- Improved BAR2 handling
- MMU rework to support Pascal MMU
exynos:
- Improved HDMI/mixer support
- HDMI audio interface support
tegra:
- Prep work for tegra186
- Cleanup/fixes
msm:
- Preemption support for a5xx
- Display fixes for 8x96 (snapdragon 820)
- Async cursor plane fixes
- FW loading rework
- GPU debugging improvements
vc4:
- Prep for DSI panels
- fix T-format tiling scanout
- New madvise ioctl
Rockchip:
- LVDS support
omapdrm:
- omap4 HDMI CEC support
etnaviv:
- GPU performance counters groundwork
sun4i:
- refactor driver load + TCON backend
- HDMI improvements
- A31 support
- Misc fixes
udl:
- Probe/EDID read fixes.
tilcdc:
- Misc fixes.
pl111:
- Support more variants
adv7511:
- Improve EDID handling.
- HDMI CEC support
sii8620:
- Add remote control support"
* tag 'drm-for-v4.15' of git://people.freedesktop.org/~airlied/linux: (1480 commits)
drm/rockchip: analogix_dp: Use mutex rather than spinlock
drm/mode_object: fix documentation for object lookups.
drm/i915: Reorder context-close to avoid calling i915_vma_close() under RCU
drm/i915: Move init_clock_gating() back to where it was
drm/i915: Prune the reservation shared fence array
drm/i915: Idle the GPU before shinking everything
drm/i915: Lock llist_del_first() vs llist_del_all()
drm/i915: Calculate ironlake intermediate watermarks correctly, v2.
drm/i915: Disable lazy PPGTT page table optimization for vGPU
drm/i915/execlists: Remove the priority "optimisation"
drm/i915: Filter out spurious execlists context-switch interrupts
drm/amdgpu: use irq-safe lock for kiq->ring_lock
drm/amdgpu: bypass lru touch for KIQ ring submission
drm/amdgpu: Potential uninitialized variable in amdgpu_vm_update_directories()
drm/amdgpu: potential uninitialized variable in amdgpu_vce_ring_parse_cs()
drm/amd/powerplay: initialize a variable before using it
drm/amd/powerplay: suppress KASAN out of bounds warning in vega10_populate_all_memory_levels
drm/amd/amdgpu: fix evicted VRAM bo adjudgement condition
drm/vblank: Tune drm_crtc_accurate_vblank_count() WARN down to a debug
drm/rockchip: add CONFIG_OF dependency for lvds
Pull dma-mapping updates from Christoph Hellwig:
- turn dma_cache_sync into a dma_map_ops instance and remove
implementation that purely are dead because the architecture doesn't
support noncoherent allocations
- add a flag for busses that need DMA configuration (Robin Murphy)
* tag 'dma-mapping-4.15' of git://git.infradead.org/users/hch/dma-mapping:
dma-mapping: turn dma_cache_sync into a dma_map_ops method
sh: make dma_cache_sync a no-op
xtensa: make dma_cache_sync a no-op
unicore32: make dma_cache_sync a no-op
powerpc: make dma_cache_sync a no-op
mn10300: make dma_cache_sync a no-op
microblaze: make dma_cache_sync a no-op
ia64: make dma_cache_sync a no-op
frv: make dma_cache_sync a no-op
x86: make dma_cache_sync a no-op
floppy: consolidate the dummy fd_cacheflush definition
drivers: flag buses which demand DMA configuration
